Diomede's Notepad, Sketchpad, and Chilling Pad
1101113151619
  • DiomedeDiomede Posts: 15,454
    14 - Create Separate Fabric for Waistband and Skirt
    Select the four waistband panels on the right side and set a new fabric which you can rename in the upper right side of the screen.
    cc37 right click to assign to new fabric and give belt separate fabric name.jpg
    1526 x 808 - 105K
    edited September 2022
    15 - Export the Skirt OBJ
    - select all of the panels on the right side.
    - use the file menu to export obj
    - the export options are attached.  amke sure weld is selected, and make sure Daz scale is selected.
    1479 x 892 - 144K
    1421 x 1029 - 186K
    Post edited by Diomede on
    16 - Start a new Daz Studio Scene with Genesis 1 in Basic Female morph set to 1.  Import the Skirt OBJ
    Will be using the transfer utility.
    In the import options, make sure to use Daz Studio scale to match the MD export setting.
    The skirt should load fitting the Basic Female shape of Genesis 1.
    1886 x 970 - 254K
    cc41 imports and fits genesis 1 basic female shape and it has two surfaces one for the belt and one for the skirt.jpg
    1235 x 906 - 157K
    17 - Edit Skirt Object Using Transfer Utility
    Select the skirt
    Use edit object to bring up the transfer utility.
    NOTE - cannot use defaults because have fitted the skirt to the Basic Female morph.  So see settings in screengrab.
    1725 x 906 - 231K
    1479 x 879 - 172K
    18 - Basic Test for Conforming and Morphing
    Can test to see if the transfer utility worked.
    Does the skirt morph if the Basic Female is dialed to 0?  Yes.
    Does the skirt morph if an unrelated morph is used like Victoria 5?  Yes.
    Does the skirt conform if the legs are posed?  Yes.
    19 - Basic test for DForce
    Recall that I created a separate material zone for the waistband.  That will help the DForce test.
    - Select the skirt and use the simulation pane to create a DForce object.
    - Use the surfaces tab to set the dynamic strength of the waistband to 0.
    - Pose a leg in a way that would affect the skirt.
    - Run a DForce simulation.
    Skirt drapes on raised thigh.
    20 - Preliminary Thoughts for Adapting Genesis 1 Workflow to Genesis 9
    General There is good reason to believe that the same basic steps will work for genesis 9.  I intend to create three Avatars for my version of MD.  The Base G9, the G9F, and the G9M.  For gendered clothing I will model the garment using MD or a more general modeling program to G9F or G9M as appropriate.  I will then use reverse deformation in the rigging stage of Daz Studio transfer utility.  For items that are unigender, I can create morphs for the clothing item that fit each avatar and then import those as substitutions for the default morph created by the transfer utility.
    UVMapping - I have not discussed that above.  MD can have decent UVMaps derived from the 2D panels, but that may depend on whether the mesh needs to have retopology.
    Retopology - the default of my old version of MD uses triangles.  It can change to quads but the results around edges and seams are not good.  May be better off brushing up on retopology in other programs - and if so, then also brushing up on UVMapping in other programs.
    1773 x 969 - 238K
    1402 x 924 - 185K
    1445 x 932 - 183K
    1036 x 907 - 132K
    edited October 2022
    My first render with Genesis 9 assets, including Victoria 9.
    NNVIATWAS - nearly naked Vicki in a temple with a sword.  The stone cube is an elevated altar.
    1280 x 1600 - 2M
    edited October 2022
    My second render is the same scene but with the darker color opton for the armor.
    1280 x 1600 - 2M
    edited December 2022
    Jay video on creating G9 morphs for earlier generation characters
    and for genesis 2 and 3 T-Pose figures
    Jay video on saving and sharing morphs.
    Mada has a thread on answering Genesis 9 clothing questions.
    Thank you, Mada!
    https://www.daz3d.com/forums/discussion/597726/genesis-9-clothing-questions/p1
    Canary3D has a video on fixing the G9 eyes figure when you create a morph that affects the G9 figure eye sockets
    edited November 2022
    Bohemian3 has a great thread and also youtube tutorials on using Marvelous Designer to create custom clothes for Daz figures.  Thank you, Bohemian3.
    The Daz Art Studio Forum thread on MD - https://www.daz3d.com/forums/discussion/comment/7825796/#Comment_7825796
    Example of youtube video
    Video on Useful settings in Marvelous Designer
    ShelLuser has a thread with tips on Daz Studio to Substance Painter workflow.  Thank you.
    https://www.daz3d.com/forums/discussion/601656/guide-using-daz-studio-substance-painter-easier-than-you-may-think#latest
    Thanks for the links to the tutorials...
    You are most welcome.  Thank you for stopping by my thread.  Hope you find the links helpful.  The first page of the thread has many more links in a variety of categories.  I was not notified I had a visitor.  Cheers.
    I will check out the first page links also. I'm always looking for ways to help do things. Sorry you didn't get the notification.
    Clothing Thickness Workflow: DForce Dynamic Surface Add-On.
    Recall that the amazingly generous Mada has a thread on creating clothes for Genesis 9.
    I will post a series of screenshots adapting information from a video in that thread.  In this project, I modeled a simple low res TShirt for the Genesis 9 base mesh, and then used a DForce dynamic surface add-on to create thickness at the hem, sleeves, and collar, yet still be able to use DForce for the garment.  I will be using Daz Studio to do the rigging, and using Carrara to do the modeling.  You can use any modeler, even modelers that do not like edges that intersect with more than two planes.
    Here is a link to a video tutorial by Mada on the same subject.  https://www.youtube.com/watch?v=lOWdOSQVRco#t=
    In this first post, see a look at the mesh of the shirt and the add-ons, and a look at how the DForce drapes at the back of the waistbut the add-on helps hold the thickness of the hem.
    1870 x 1234 - 223K
    1422 x 1275 - 99K
    1975 x 1336 - 275K
    Modeling a simple shirt with thickness at the collar, sleeves,and hem.
    Load the base genesis 9 shape in the modeler of your choice preserving scale.  I am using Carrara, but you can use Hexagon,Blender, Silo, ZBrush, or anything else you want.  The important thing is to be able to preserve scale when exporting for use in Studio.
    To get the modeling dummy for use in Carrara, follow the suggestions in the Carrara frum by Wendy, Proprose, and Bunyip.  Open Daz Studio and load the Genesis 9 base figure (neither male nor female).  Save as a character preset to location of your choice.  You can then load that character preset in Carrara and use it as a modeling dummy.  This is not a modeling tutorial so I am just going to skip ahead some.
    Here is a relatively close fitting lo-res T-Shirt mesh.  Create one in any program you want.
    Note that I modeled the waist hem to have a curl toward the inside and then extruded up inside.  I did the same for the sleeves and the collar.
    And here is a rough UVMap. I have highlighted the UVs of that inner curl at the hem.The UVmap is rough, but should be OK for this rigging for DForce example.
    I created shader domains for the shirt trim (at waist, neck, and arms).  These are for texturing the shirt; they do not match either the inner curls or the future add-ons.
    Save This Mesh As a Separate File
    ee01 model simple shirt with thickness to fit g9 base shape not gendered.jpg
    2055 x 1324 - 294K
    ee02 have thickness model as curl at bottomhem and collar and sleeves see inner edge near an outer edge.jpg
    2104 x 1219 - 231K
    2245 x 1210 - 392K
    1810 x 1303 - 276K
    Creating the Add-On Meshes - Delete and Bridge
    Use a renamed working mesh that you can throw away.  The add-on meshes are strips of polygons that bridge the curled inward edge back to the main fabric.  To do this in Carrara, I selected the loop of main fabric polygons bordering below where I wanted to bridge to the inner curl.
    I then deleted that loop.
    I then selected the edge loop of the inner curl and the edge loop of the main fabric that I want to bridge.
    I then used the bridge tool.
    2272 x 1180 - 273K
    2323 x 1123 - 255K
    2218 x 1168 - 258K
    2218 x 1168 - 258K
    333 x 246 - 11K
    1992 x 1150 - 205K
    Repeat for all Add On Meshes
    Following the steps for the waist hem, select and delete a loop of polygons around the main fabric of the collar.  Select loops of edges of the main mesh and the inner curl around the collar and use the bridge tool.
    Repeat again for the sleeves. And repeat for any other holes for which you will want thickness.
    Create a shading domain for the bridged meshes.  These will be the add on.
    Isolate and Save the Add On Meshes
    Use the shading domain to select all of the bridged meshes at the waist, sleeves, and collar (and any others) - and only those.
    Invert the selection.
    Delete all non-bridged polygons leaving only the add on mesh.
    Save the add on mesh as a file with its own name.
    You can see how the addon mesh without the garment relates to the base figure.
    1975 x 1255 - 233K
    1297 x 1279 - 158K
    1870 x 1234 - 223K
    1648 x 1255 - 186K
    2055 x 1213 - 277K
    1422 x 1275 - 99K
    1963 x 1282 - 203K
    Confirm Garment Mesh and Add On Mesh
    Load the saved garment mesh that had the curled thick edges but no add-ons.
    Load the saved add-on mesh that bridges between the edge of the internal curls to the main fabric of the garment.
    If look closely, can see the rows of gray vertexes overlapping the main garment.
    1927 x 1156 - 155K
    2317 x 1297 - 248K
    Export the OBJs for the Main Garment and for the Add-On.
    Using Carrara, there is a preset for OBJ export for Daz Studio 'full scene.'  Just be consistent in whichever modeling program OBJ export you use.
    The garment should be saved seprately from the add on.  I did not use smoothing for either. Just be consistent.
    1879 x 1194 - 223K
    1558 x 1153 - 179K
    In Daz Studio - Import and Rig the Main Garment Mesh, Not the Add-On
    Load the Genesis 9 Development Figure.  In this example, I modeled to the base shape, so that is what I load.
    Import the main garment mesh.  I saved out of Carrara in Daz Studiofull scene, so in the import dialogue of Daz Studio I choose the Carrara preset.  Just be consistent.
    Confirm the main garment appears to fit and is at base resolution (in my example).
    2301 x 1336 - 340K
    1507 x 1189 - 203K
    1908 x 1192 - 243K
    Use the Transfer Utility - Genesis 9 is the Source - the Shirt is the Target
    In this example, I am not doing any smoothing. I modeled to the base mesh so there is no need to reverse to source.
    In this example, I also avoid the transfer utility default of parenting the mesh just to make extra sure that the mesh stays in its default location.  In this simplest example, I am avoiding smoothing and reverse deformations and parenting to make extra sure that when the mesh for the add-on is imported that none of the vertexes for the main garment have been moved.
    The result should be that the shirt is now a conforming garment that fits Genesis 9 base.
    2047 x 1216 - 270K
    1854 x 1207 - 223K
    Save the Shirt Garment as a Figure/Prop Asset
    Now that the shirt is rigged, save it as a figure/prop asset for future use.  This step will save necessary information to the data folder.  If you have not done so already, choose a name for yourself for your custom products.  Studio will create a subfolder with your name in the data folder.  Also choose a name for this product which will be used for the add-on as well.
    ee26 save as figure propasset not parented follower set compatible G9 Base.jpg
    2038 x 1012 - 222K
    In a New Scene, Load Your New Shirt and Assign DForce
    Clear the current scene or start a new Daz Studio scene.
    Load the shirt garment just saved as a figure prop asset.  In the simulation tab, assign a new DForce dynamic surface.
    In the surfaces tab, confirm that DForce channels exist.
    2157 x 1177 - 215K
    2034 x 1264 - 267K
    1893 x 1188 - 236K
    Save the DForce Shirt as a Wearable Preset
    I loaded the Genesis 9 base from the standard folder, not the development rig.
    I fit the shirt to the Genesis 9.
    The result is that the new shirt conforms to and is parented to the standard Genesis 9 in its base form.
    Select the genesis 9 figure and Save As Wearable Preset.
    I created a subfolder for the wearable preset in the same general area as the custom figure prop asset.
    2316 x 1231 - 273K
    2326 x 1236 - 307K
    2151 x 1230 - 242K
    ee33 with G9 base selected file save as wearable preset and save the dforce enabled shirt.jpg
    2470 x 1273 - 350K
    1537 x 1032 - 141K
