It's My Party and I'll Complain If I Want To Complaint Thread
1…5657596162…100
  • LeatherGryphonLeatherGryphon Posts: 12,508
    edited August 2018
    CO2 ( carbon dioxide) isn't toxic, that is CO (carbon monoxide). That's why it safe to use for stage effects and so on.
    Carbon dioxide may not be literally toxic but it's killed a lot of people by displacing the oxygen in the area.  Which is why use of large amounts of carbon dioxide needs adequate ventilation.
    And yeah, we sat in the front, near the stage of Her Majesty's Theater in London for "Phantom of the Opera" back in the early '90s and we were neck deep in fog rolling off the stage during the boat scene. Cool! yes
  • TaozTaoz Posts: 10,368
    Not as such, according to the normal definition of "toxic", but toxicity is usually a matter of amount, which is also the case here. CO2 may actually kill you if the concentration in the air is high enough, even if there is enough oxygen present.
    "Concentrations of 7% to 10% (70,000 to 100,000 ppm) may cause suffocation, even in the presence of sufficient oxygen, manifesting as dizziness, headache, visual and hearing dysfunction, and unconsciousness within a few minutes to an hour."
    https://en.wikipedia.org/wiki/Carbon_dioxide#Toxicity
    So in the context discussed here it might become dangerous, in a small, poorly ventilated room. They also use it to stunn or kill pigs in the meat industry, though in that context they use pure CO2 with no oxygen. It's also heavier than air so even if you just faint because of it you may end up on the floor where there's only CO2 and no oxygen, and then you're almost sure to die.
  • I did nearly add that it isn't beneficial either, so shouldn't be allowed to displace the oxygenated air. I wasn't aware of the issue when oxygen is present, though.
  • TJohnTJohn Posts: 11,448
    But if you're  a plant, you're cool.
    meh  tried to make appt with my primary doctor.  they gave me appt with the nurse practitioner.
    i told them i had no confidence in the nurse p.
    told them i stopped taking all the medications, except the needles in my eyes x.x
    they seem to think the metfornin,etc side effects are acceptable.
    they gave me appt with a different n.p. >.<
    dunno if i throw a noisy enough fit, i'll get to see the dr.
    i need to ask him if i should be on disability.
    was reading about statin myopathy.  they prolly think thats acceptable too.
    thinkin bout getting a cupcake tattoo on my inner forearm.
    these look cute?
    without the candle-
  • XyetztXyetzt Posts: 27,561
    I am upset.  I got a stupid movie at the mall thinking it had a digital copy but the code turned out to be bad meaning no good.  I got a bluray disc but not a digital copy.
    you have no hatchlings??
    edited August 2018
    Not in my signature but I do have hatchlings.
    Things not working tonight so, like tv box
    edit Adopt one today!
    Post edited by Xyetzt on
  • kyoto kidkyoto kid Posts: 42,451
    edited August 2018
    ...for any who have waaaaaaaaaaaaaaay too much content than your system can handle. this might be the perfect solution.
    https://www.zdnet.com/article/intel-this-ruler-ssd-is-worlds-densest-so-you-can-cram-1pb-in-single-1u-rack/?ftag=TRE-03-10aaa6b&bhid=25597626630961060680701967597670
    Post edited by kyoto kid on
  • DanaTADanaTA Posts: 13,413
    Wow.  I thought it was 1PB, but 32TB on a single module is still very impressive!  Probably costs more than my car did, though.
    Dana
    ...agh, 22:00 and still in the mid 80s. That should be the normal high here for this date, not the late night temperature.
    ...Ugh nearly quarter to Midnight and still 80°
    weather saying scattered thunderstorms thru Monday.
    cant make any plans, is basically might be a thunderstorm, might not
    tattoo artist sent me the pics he took.
    wearing my string tie bikini bottom.  eat your heart out vicki  tee hee
    smiley
    5312 x 2988 - 4M
    5312 x 2988 - 4M
    eeek
    Common telemarketing scams
    Just say no to suspicious calls
    Beware of callers from unknown numbers who immediately ask, “Can you hear me?” If you say ‘yes’ to any unknown caller you could fall victim to fraud.
    • The caller could record your affirmative response and use it to sign you up for an expensive service or to ‘prove’ that you agree to charges on a credit card.
    • If you think the call may be legit, you could answer, “I can hear you.”
    • Unless you contact us first, we'll never call you to verify a one-time PIN sent through text or ask you for your personal information. Like your account passcode or Social Security Number.
    That 'local' number may not be so local
    • Scammers can use a fake number from an area code close to or familiar to you, to make you more likely to assume that the call is from a local business and get you to answer the call.
    • For more information on common telemarketing scams, head here.
    Check that refurbished phone
    Check the factory settings
    Make sure the phone has been cleared of any evidence of prior ownership. If it’s been restored to factory settings, the memory should be clear. If you find any information stored in the phone, it may not be entirely safe.
    Look for the phone's serial number (IMEI/MEID/ESN)
    • The phone’s unique serial number can typically be found underneath the battery.
    • Call the manufacturer to check on the history of the phone using that number, it’s unique to every phone, so you should be able to get details on previous ownership.
    • If it was reported stolen, the manufacturer should be able to tell you.
    You can also use the Cellular Telecommunications and Internet Association free stolen phone checker tool,
    Purchase from a reputable retailer or manufacturer
    Any reputable business will be able to provide details of the refurbishment, including prior ownership.
    whatcha doin to keep cool?
    i'se all alone at work today. no one to talk to
    reminiscing starbucks.  they do make sugarfree frappacinos. the vanilla isn't half bad. is sugar free vanilla syrup.
    poland springs sipps bottles changed their cap again.
    edited August 2018
    Complaint:  I just re-examined the schedule for Chautauqua and found a concert I'd missed.  This coming Tuesday (8/14) is a performance of Mendelssohn's Hebrides Overture (aka: "Fingal's Cave").  Cool!  yes
    One of my favorites probably because of the connection to that old Loony Tunes cartoon with the Mynah bird.  Unfortunately, I've spent all my adventure money for this summer on a long desired thing at the last on-line auction I participated in. sad
    Words of Wisdom:  Beware of on-line auctions, you're liable to find things you can't do without! enlightened
    Mendelssohn: "Hebrides Overture" https://www.youtube.com/watch?v=2DURLkSebck
    Inside the real Fingal's Cave in Scotland: https://www.youtube.com/watch?v=W6NwRgW7xN4
    An Exerpt from one of the Mynah bird cartoons: https://www.youtube.com/watch?v=vKsjYdEAmNI
    ...usually going to the corner pub that has AC.  Cinemas in town are too expense and that only lasts about 2 hours then it's just deal with the heat or go to another and spend another 12 - 18$. Don't drink that much coffee anymore (acid issues) so staying all day at a coffee shop doesn't work anymore.
    ...is it unsweetened or artificially sweetened?
    ...yeah another day in the 90s again (92°), even though it was supposed to cool down into the low- mid 80s today. That 60% chance of water from the sky for tomorrow has pretty much been taken out of the forecast now however still calling for a high in the upper 70s, low 80s Sunday so two days of relief.
    Based on the ten day forecast, we will have one month (31 days) worth of 90+ temperatures by mid month (as recorded at the airport, 34 days as recorded in the city). Feels like I'm back in New Orleans again save for the extreme humidity and great Cajun/Creole food (though there is a streetcar that goes by my building like I had when I lived there).
    Adopt one today!
    trying for a sleeping hatchling to be tattoo
    is a thinly disguised laxative basically
    edited August 2018
    Non-complaint:  While going through these boxes of photos I found a few of my office/lab at the Kennedy Space Center in the Launch Control Center.  Two Raytheon mini-computers.  These four pictures show one of the computers arranged in a "U" shape around my pilot's chair.  A KSR-33 teletype & Tektronics 4012 graphic storage display, a card reader & line printer on one side, two 9-track tape drives behind me, and on my left a 7-track tape drive, three 5 foot racks of equipment containing the Raytheon RDS-500 computer, its 64 Kilobytes of memory, and a large sized, teeny-tiny capacity, hard drive as well as some specialized interface equipment for video conversion and analog data tape control.
    This is only one end of the long computer lab.  The other end of the lab contained my desk/office in one corner,  two 7 foot cabinets for storage of computer manuals, a keypunch machine,  and the other "U" shaped computer bay containing a Raytheon 706 mini-computer, a Gould electrostatic graphic printer, a KSR-35 teletype, another Tektronics 4012 graphic storage display, and another line printer.  (computers didn't talk to each other back then).
    Also in the lab was a long row of 7 foot equipment racks for interfacing remote measurement data input lines from around the space center to the large bank of analog data recorders in the next room.  And way in the back of the room was a work bench where we would tear into new or misbehaving equipment trying to make them behave.
    This is how I did 2D & 3D graphics & animation in the mid to late '70s surprise  And "yes", it was mine, all mine, <bua-ha-ha>. devil None of the other 5 people who worked in the room knew anything about computers.  They were either technicians or analog data people or NASA managers.
    Our two rooms were dedicated to "Special Measurements" not active launch control.  We handled experimental data collection and data processing like electric field measurement, lightning detection and prediction, analysis of radar dispersion patterns for the shuttle runway landing radar, stress analysis during construction of the giant electronic plug in the shuttle's "Tail Service Mast (TSM)" that would get pulled out just a second before the shuttle took off.  The big launch computers  were on the same floor in the center of the building but I don't even think I was in there more than a couple times in 5 years.  That's OK, their job was handled by a big team of programmers and it was all "by the book" scripted to the last detail stuff.  I got to play and be creative and do the interesting work.  It was a fun time in my life. smiley To this day, everytime I see a film of a shuttle launch I watch carefully to see if I can spot the plug being pulled.  cool
     I sometimes wonder where I would have ended up had I stayed.  (Probably promoted beyond my level of competence.  The "Peter Principle" at work. )
    1153 x 800 - 85K
    495 x 320 - 27K
    And all that computing power fits on a smart phone now, right?   wink
    Dana
    edited August 2018
    ...ahh finally, a break in the heat.  Now 69° in the hood when at this time last night it was 85°.  Actually was able to cook dinner tonight.  Two days of relief ahead before it becomes sweltering again.  Might actually get some 3D work done.
    Dana
    A cheap smart phone.  frown
    been like 3 weeks since kicked out of pc club
    edited August 2018
    i was only able to find this thread thru searh
    https://www.daz3d.com/forums/discussion/111966/ot-is-there-caffeine-in-starbucks-ice-coffee/p6
    it doesnt update to 'recent' , not even in my discussions
    i posted important question bout dairy queen
    Post edited by Mistara on
    edited August 2018
    downpour outside  eek  thundahs
    pulled tomato plant under awning
    good mornin
    whos not awake yet?
