RRRR "As the story goes" Render Contest *CLOSED*
Totte
It's time for another round of the RRRR Render Contest.
This time the theme is As the story goes, and the rules are a bit different this time, to I tell you, read through and also look at the example in the Entries only thread.
How does it work?
This played in blocks, where each block consists of at least two renders. You start a block by randomly pull four items as you always do. For newcomers there is an explaination of pulling random items further down. Now make a scene and render an image, still very similar to how RRRR always works. You do not put this into the entries only thread yet. Now, you repull two or three items, keeping one or two of the items you used in the first render. Now, make a prequel or sequel to the first image with the new set of items you have. Now you can call it done, or challenge your luck and make a third psrt of the story, repulling two or three of the items of this last image, and keep going until you think your' done.
When your done, you create an entry in the Entries only thread with all the images in the order they go in your story, and add some text for each of them. Now, you can start another block, witha fresh 4 item pull. OK, that wasn't very hard was it?
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list. (I personally will see much joy in dropping Camel, I don't know how many times it has been pulled over the years)
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Important!
You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!). Then when you have a story block of at least two entries, you post that in the entries only thread.
Then the entry should also be posted in the Entries only thread
More rules clarifications...
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every entry block will compete in both categories.
Contest duration!
It starts now at Saturday February 3, 2024 and will go on all over the holidays until Sunday March 31 2024 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 7 entry blocks of at least 2 renders per player.
So, good luck and start your render engines!
ist of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
Nice twist!
Tag: Fixmypcmike #1
Pulls: 2908 2943 1737 3414
Darius 6 20522 https://www.daz3d.com/darius-6
Extravagance for Baroque Grandeur DS 20813 https://www.daz3d.com/extravagance-for-baroque-grandeur
Holiday Accessories 13708 https://www.daz3d.com/holiday-accessories
Props Pack - Grapes 28431 https://www.daz3d.com/props-pack-grapes
Pull #1
328 Arctic Fox by AM
2180 Fantasy Horns For Genesis 8 Female Volume 1
5353 Skin Builder 3 for Genesis 3 Female(s)
3387 Lillian Hair for Genesis 8 Females(s)
Pull #01
Village Road.
LoREZ 14MU Worker Bundle.
Laid Back Outfit for Genesis 3 Male(s).
DAZ Studio Iray HDR Outdoor Environments.
Tag: Fixmypcmike #1a
Title: "The Game Is Afoot!"
Darius Finn pondered the strange display set before him: a plate of red grapes, and a fake gift box. The box was wrapped in a ribbon like a gift, but had no lid and could not be opened without cutting it apart. Judging from its weight and the lack of any change when moved, there was nothing inside. The grapes were real, the plate on which they rested nondescript. No one had seen the person who had left the objects. Clearly someone was sending him a message, but the meaning eluded him. The game was afoot!
Also used:
TOA Legend for Genesis 2 Male(s) and Michael 6 17376 https://www.daz3d.com/toa-legend-for-genesis-2-male-s-and-michael-6
Basic Hair 17545 https://www.daz3d.com/basic-hair
BWC Skies 16940 https://www.daz3d.com/bwc-skies
Tag: Fixmypcmike #1b
Retained from pull #1a:
Pulls: 2384 1383 3086
Casual Sexy Poses for Genesis 2 Female(s) 16494 https://www.daz3d.com/casual-sexy-poses-for-genesis-2-female-s
Spooky Plots 11460 http://docs.daz3d.com/doku.php/public/read_me/index/11460/start
Sienna Hair for Genesis 2 Female(s) 22298 https://www.daz3d.com/sienna-hair-for-genesis-3-female-s-and-genesis-2-female-s
Title: "A Grave Affront"
In search of answers, Darius headed into town. However, his journey was interrupted when he was struck from behind. When he awakened, he found himself in an unfamiliar forest in a small cemetery, beside an open grave. Across the grave, a women reclined atop a coffin.
"Good to have you awake, Mr. Finn. May I call you Mr. Finn?"
"As we have not been formally introduced, it would seem to be the most suitable option. Might I have the pleasure of knowing your name?"
"I am Janna, Mr. Finn."
"And might I know the name of the person due to take residence in this plot? I should add that using his or her coffin as a divan seems rather disrespectful."
"Oh, this box is unoccupied, Mr. Finn, and I'm rather hoping it will stay that way."
Darius would have asked what role he was to play in keeping that coffin empty, but he suddenly found himself uable to speak as he drifted into unconsciousness.
Also Used:
FWF Janna 19939 https://www.daz3d.com/fwf-janna
The Lost Place 22031 https://www.daz3d.com/the-lost-place
Tag: Fixmypcmike #1c
Retained from pull #1b:
Pulls: 1837 884 3477
Fantasy Warrior Poses 14085 https://www.daz3d.com/fantasy-warrior-poses
Jai Hair 7966 https://www.daz3d.com/jai-hair
ULTRAGENESIS: Faces of G 30713 https://www.daz3d.com/ultragenesis-faces-of-g
Well this is an interesting twist.
Want to make sure I understand since it’s late here. Pull 4 items & render as always. Can keep up to two randoms as part of a story. Pull #2 would then have two or three randoms & so on.
Example:
Pull #1: 4 randoms, render and story. Catch. Players have to commit-- no changing. I decide to keep “Vampire Ventriloquist” or something. Post scene here and begin story. Pull#2 -- three randoms not 4. Decide to keep another random for a maximum of 2. Pull#3 would then be 2 randoms and finish story. When done, put renders in any order to complete the storyline. Only then put the renders in the entries part?
Hope that makes sense. Off to bed. : )
Title: "The Final Chapter -- Red Sky At Morning"
When Darius next awoke, he found himself surrounded by figures with swords. After the initial shock, he realized that they were statues, six women carved out of red marble. He was seated in the armchair in his study, and it was morning.
He studied the six statues. They all had the same build, and the same short hair, but the faces were all different, old, young, of different nationalities. The swords, however, were real -- naval sabres, in fact. He began to piece together the clues. The gift-wrapped box, a box not meant to be opened, with nothing inside -- like the empty coffin in the graveyard. A red box, red grapes, and now red statues.
And naval sabres. There's that old naval adage, "red sky at morning, sailors take warning." But the statues were all women, even old women, not likely to be found on a naval vessel.
He snapped his fingers. There is a place where such an array of women could be found amongst naval weaponry -- a munitions factory. Perhaps the red grapes represented grapeshot. He was being warned about an explosion at a nearby factory.
Time to save some lives!
THE END
Also Used:
Holiday Nook 11599 https://www.daz3d.com/holiday-nook
Fantasy Weapons Collection 15720 https://www.daz3d.com/fantasy-weapons-collection
ACTIVE - Escape Poses 24194 https://www.daz3d.com/active-escape-poses
West Park Horror Movie Poses 2 17373 https://www.daz3d.com/West-Park-Horror-movie-poses-2
Daz3D Pose Converter by MCphylyss https://www.sharecg.com/v/89846/browse/8/Script/Daz3d-Pose-Converter-Standalone
Magical Granite 16420 https://www.daz3d.com/magical-granite-shader
Gemologica 14789 https://www.daz3d.com/gemologica
Tag: Fixmypcmike #2a
Pulls: 3634 1256 1195 4040
MynX for Victoria 7 33831
Helen 10611
Vintage Boy 10251
Khan's Tiger Den Rumble In The Jungle Texture Set DS 68921
A question: are we supposed to decide what the first pull is about before we do the next pull?
tag:luci45 #1
Fox Tails
Used:
Also Used:
UltraHD IRAY HDRI With DOF - Outdoor Pack 2
Nida and Daisy and Friends morphs
dForce Furry Tail (AprilYSH Christmas freebie 2019)
dForce Evergreens Outfit for Genesis 8 Females
Rock Collection - Real World Stones
I'm going to keep these from pull #1:
Pull #2:
3374 Light the Way
5999 The Rider
(DAZ double-posted and then I moved the big picture to the one above, but it's linked to the upload below. I don't want to spend another half hour trying to fix it.)
Pull #1:
Formations For Rock Collection #36255
She Orc For Genesis 8 Female #45717
Iv Squish Morphs For Genesis 8 Female(s) #62683
Secret Time Machine #84469
Pull #1
779 - overall dress outfit G8F sku 46239
984 - take a seat poses for G8 - sku 67645
835 - Quick Check Lane - sku 13317
500 - i13 Clothing Interior - sku 36989
[Take a seat pose applied to dress then dForce to floor]
(random actor was #38 - Theo (again)
This assumes players *must* to pick from the first pull? Luck of the draw, going to be difficult. Keeping "Check Lane" & "Clothing shop"
Theo was working at his sister’s clothing store when he came across something really weird. He called her up and she called the police which might’ve been a mistake.
@fixmypcmike: A great opening story for the content - well done
@luci45 : Fluffy tails - I look forward to were this will take us
@Tynkere: I see a plot building up here
Block#1 Pull #1
#937 Henryk for Michael 7 (#23375)
#5124 WWII Weapons -Pack 2_Axis Forces (Rendo)
#2035 European Daggers DS (#48619)
#2401 Zelara 8 HD Add-On (#53505)
Question: I think I may end up with a backwards story: that is, the questions posed by the "first" entry are sort of answered by going into the past, so the story is meant to go in reverse chronological order. I assume it's okay to arrange them that way.
Yes, you can place the second image after or before the first (prequel or sequel), and the same for the next, first, between the two or last, and so on...
Fixmypcmike #2a
MynX for Victoria 7 33831 https://www.daz3d.com/mynx-for-victoria-7
Helen 10611 https://www.daz3d.com/helen
Vintage Boy 10251 http://docs.daz3d.com/doku.php/public/read_me/index/10251/start
Khan's Tiger Den Rumble In The Jungle Texture Set DS 68921 https://www.daz3d.com/khans-tiger-den-rumble-in-the-jungle-texture-set
Also Used:
Genesis 1, on Bed:
Brijitte for Genesis 16398 https://www.daz3d.com/brijitte
Regina Malorum Hair 17225 https://www.daz3d.com/regina-malorum-hair
MynX, kneeling:
Water Spirit Warrior Outfit for G3F 33415 https://www.daz3d.com/water-spirit-warrior-outfit-for-genesis-3-female-s
Kimberly Hair 22853 https://www.daz3d.com/kimberly-hair-for-genesis-2-female-s-and-genesis-3-female-s
Genesis 1, Child:
Emelie and Edward Odd 15577 https://www.daz3d.com/emelie-and-edward-odd
Little Melody Hair 15930 https://www.daz3d.com/little-melody-hair
Ready to Play - Backgammon Set 21497 https://www.daz3d.com/ready-to-play-backgammon-set
Part 1: The Present Day (2024)
"He's doing it again," Brijitte whispered.
"They're just playing pieces," MynX replied.
"He's. Doing. It. Again!" Brijitte enunciated through clenched teeth.
MynX sighed. "I know. What the hell do we do about it?"
Fixmypcmike #2b
Retained from #2a:
Pulls: 3833 2554 4078
Monster Skulls HD 44297 https://www.daz3d.com/monster-skulls-hd
Nadia 17758 https://www.daz3d.com/nadia
Easy Environments Winter Fields 79889 https://www.daz3d.com/easy-environments-winter-fields
Fixmypcmike #2b
Retained from #2a:
Also Used:
Pure Hair: Bubblegum for Genesis 13325 https://www.daz3d.com/pure-hair-bubblegum
Demon Armor for Genesis Brute X 14491 https://www.daz3d.com/demon-armor-for-genesis-brute-x
Doomed Poet Clothing 16154 https://www.daz3d.com/doomed-poet-clothing
Soulless Outfit for G3F 23095 https://www.daz3d.com/soulless-outfit-for-genesis-3-female-s
Apprentice Mage in the Tower 16105 https://www.daz3d.com/apprentice-mage-in-the-tower
Five Years Ago (2019)
The giant monster MynX had run through with her sword had shrunk to the form of a human woman. "I sure hope that means it's dead," she muttered. "One down, two to go."
Or, not. The other monsters were gone, nothing left but two giant skulls. And a kid. Where the hell did he come from? And how the hell did he do -- whatever he did?"
Fixmypcmike #2c
Retained from #2b:
Pulls: 120 3525 3405
Treasures of Egypt 2 1487 https://www.daz3d.com/treasures-of-egypt-2
Backyard Pergola 31649 https://www.daz3d.com/backyard-pergola
Dashing & Daring Poses 28220 https://www.daz3d.com/dashing-daring-poses-for-lee-7
tag:luci45 #1
Fox Tails Part 2
Pull#2
3374 Light the Way
5999 The Rider
From Pull #1:
Also Used
dForce H&C Coverall jumpsuit outfits for Genesis 8 Female(s)
SF Crash Site
Block#2 Pull #1
720 BWC Fashion Poses for V6, V5 and V4
2937 i13 Sandwiches
5418 Space Explorer Suit For Genesis 8 And 8.1 Females
2144 Fairytale Collection -- Fairytale Story
This will be really stupid.
Fixmypcmike #2c
Retained from #2b:
Also Used:
Dragon Rage 15025 https://www.daz3d.com/dragon-rage
Jepe's SteamZ 3884 https://www.daz3d.com/jepes-steamz
Six Years Ago (2018)
Brijitte was ready to scream with frustration, but she knew that wouldn't get her anywhere. She forced herself to remain calm and focused. All she knew so far was that she needed to find a person, a boy. Why? She had no clue. What was she supposed to do when she found him? No idea. What was special about him? Unknown. What he looked like, how old he was, the smoke revealed nothing.
Time to try a different tack. She cast another divination.
"Who can lead me to the boy?"
Finally the smoke began to reveal something. A woman holding a sword. Battered and bruised, her clothing torn, but her stance suggested she had been victorious.
FIND HER, AND YOU WILL FIND THE BOY
Well, that was something. At least she knew what this woman looked like. Much better odds than finding one boy out of a billion.
It looks like I need another pull to finish this story.
Fixmypcmike #2d
Retained from #2c:
Pulls: 4157 3886 890
English Village Pub Props 2 90537 https://www.daz3d.com/english-village-pub-props-2
Old Country Farmhouse 48419 https://www.daz3d.com/old-country-farmhouse
M4 Tuxedo 7992 https://www.daz3d.com/m4-tuxedo
Fixmypcmike #2d
Retained from #2c:
Also Used:
Dark Storm Outfit from Genesis 3 Starter Essentials 21630 https://www.daz3d.com/genesis-3-starter-essentials
M4 Tuxedo textures by Chohole
Five years from now (2029)
This was probably the first time in the past ten years that Brijitte and MynX were thinking the exact same thing.
"Is this the end of the world? Well, if it is, I probably won't be alive long enough to see it."
I need to redraw an item: I don't own the required product for Formations For Rock Collection.
Newly pulled: My Camel Camelia HD #21424
