Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1…4849505153
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,959
    I am just confused
    I actually have gotten VWD to work in the Carrara beta version with the python script installed on my C drive which is a SSD
    3X in a row now on my Win10 machine
    so which if not all of those factors is important, I have no idea
    Beta has different extensions to the release build, a trial and error mix of which ones clash with each other
    also it uses my CPU heavily which might be why it worked on my far superior Win7 CPU before that stopped putting out a signal
    so the script being on the C drive may help with that as my externals can go to sleep if not in constant use
    I have not been successful with fiddling around with power management settings to stop that, it seems to be a Seagate feature
    edited June 7
    updated my Nvidia driver, now Octane render 4 Carrara doesn't work
    wonderful /s
    will try rolling back
    Otoy recommends 431.86
    if my AI stuff won't work with that, so be it
    in the end, Carrara is more important
    ...and it won't let me install itcrying
    OK back in business 581.42 works
    my Zynk Zydian character in AK totem suit is overjoyed
    1920 x 1080 - 527K
  • StezzaStezza Posts: 9,329
    BE AWARE: if you get or have got these free props
    Destroy! - A pack of props and crowd generator tools submitted by @FrankTheTank
    then you'll not need DS6 as it won't do the weight transfers needed to use the models in Carrara
    You will need DS V4.x to do the transfers. yes
    There are a lot of usefull models in the package but most will need the usual tweaking of textures etc in Carrara.. wink
  • Bunyip02Bunyip02 Posts: 9,345
    Uh-oh, was looking at getting a high-end graphics computer with a 5060Ti card, might need to reconsider .....
    edited June 11
    you can still have DS|4 installed too, in fact you need it for all the plugins,
    Also,
    Filament will use your onboard graphics and actually the 5060Ti card OpenGL component, I think too.
    wow.. I bought mine just before the price hike and now it's $5,000au more that what I paid in August last year!  surprise
    edited June 16
    the game ready figures import rigged and can rotate the bone, could add IK
    no Blendshapes
    1920 x 1040 - 312K
    no weight blending conversions needed?
    its an FBX so you import it, not load from the browser
    edited June 17
    ok.. I thought that was a duf
    is there an easy way to apply poses in Carrara with fBX?
    I got this one as the freebie. .... just needs materials adjusted and had to shrink the hair cap down
    800 x 600 - 361K
    Post edited by Stezza on
    if you make it an animation group, you can at least re-use poses
    and they should work on any of the other ones if inclined to get
    otherwise Unreal Engine is probably the only free pipeline for animation
    and possibly Mixamo
    I found it fairly easy to retarget in UE4.27
    you could grab a free duf character (just a shaping morph) too so hope you did
    not sure if need to be in the same cart, is same code
  • DartanbeckDartanbeck Posts: 22,162
    Very cool. I haven't tried mine yet. Thanks for the info!
    edited June 18
    OK
    import the FBX into the Carrara plugin called DAZ Studio
    set rotation on the base and garment to 0
    choose the Genesis9(2) that loads with it
    apply G9 poses, animations or Aniblocks (you then bake to timeline)
    as far as I have gotten
    not figured out how to apply to the Carrara figure
    good for extras in D|S scenes though
    edited June 24
    https://www.daz3d.com/space-road-stop
    I am trying to work  with this monstrosity
    in Twinmotion admittedly because sets this big usually don't play well in Carrara
    well, this is impossible to use even in Twinmotion
    so...
    I followed the DAZ-DEALS links to the gallery and see this https://www.daz3d.com/gallery#image=1228861
    our own Ted
    (gallery image link expired in less than an hour)
    so Diomede, did you render this in Carrara?
    If so, was it a challenge?
    and no, I cannot test it myself yet because it's frozen up my Twinmotion UI and is using all my VRAM and RAM surprise
  • DiomedeDiomede Posts: 15,474
    The quick answer is 'No. I did not arrange or render the scene in Carrara.'
    To be honest, I did not remember doing that. Then I noticed that I had put in the description 'Daz+ PC Club Anniversary Sale.'  By itself, that didn't mean I did it in Daz Studio, but it gave me a hint of where I would find my old drafts. My project files are in Daz Studio DUF format.
    thanks
    I also since discovered there is an exterior prop version of it which you likely used
    the creator does have a warning about loading the full figures after all
    So I tried. And my test to load it in Carrara did not go well. Load hung up at 56.8%.
    edited June 24
    It is now up to 61.6% load. I mention it because for today, you can look at my time stamps and get an idea how long it is taking to load. In the future, I think the forum just lists date. But for now, you can see minutes. It took 17 minutes to advance another 4.8% of the load.
    Post edited by Diomede on
    thanks
    No problem. And now you got me curious so I am trying to load it in Carrara while I do other stuff around the house, and occasionally checking in.
    Failure.
    The full Space Road Stop, https://www.daz3d.com/space-road-stop  ,never completed its loading in Carrara. The program eventually crashed, although it did not freeze my computer. I don't know exactly how long it took to crash, or how much progress it ultimately made in loading. I had been doing other chores around the house.
    yeah, what I expected TBH
    why was so intrigued seeing your render
    how the hell does one unhide body part in Carrara after accidentally fitting geograft clothing angry
    have you tried turning the pc off and back on again? devil  cool
    might as well
    ended up reloading the character and picking different clothes
    edited July 29
    I bought a set off FAB marketplace
    and of couse in DAZ Studio it loads untextured and I have find the maps manually
    well
    Carrara just to taunt me, gives a rendering failed in the ass room and the UI goes wonky
    unusable
    but
    IT LOADS ALL THE TEXTURES!
    OK, feel a tad better, it actually only loaded one texture cheeky
    just showing how the UI screws up
    1920 x 1040 - 229K
    In your best Beavis and Butthead voice,
    ...gives a rendering failed in the ass...
    heh, heh, heh
    edited September 29
    Chyll, instead of a geoshell, use surface replicated sprinkles (tiny spheres)
    1920 x 1080 - 331K
    I bought
    Harry Chuchupeiker (for Poser)
    and he works nearly ok in Carrara apart from one problem
    when posing some of the seams are splitting
    I remember something about this from about 15 years ago and I can't remember the fix
    any hints to fix the splits in the mesh..
    btw - the imported obj file doesn't have the splits only when loading the poser cr2 file.
    edited October 19
    probably turn off limits loading it or zero it with limits off
    or like the 3DU goat losing it's horn turn off IK
    or Songbird Remix Poser version needeing limits or IK off for the hip
    I cannot find the threads on it even with Google site search
