Daz Studio 6.25[.0.x], General Release!
24567…25
  • Interesting. I'll look at it in the morning or later tonight. Need to remember Scripts I have in Menu option.
  • LeanaLeana Posts: 13,641
    Batman_Sid said:
    Where's the SDK that is announced in the video?
    I see files related to "Daz Studio 6+ BETA SDK" in my DIM.
    Elor said:
    musicm391_efa02a68ea said:
    Daz 6 isnt showing up in my DIm. i even tried reinstalling it? What am i doing wrong?
    It didn't either the first time I launched DIM half an hour ago, but Daz 6 does appear now (I don't rememebr if I re-launched DIM or refreshed the install tab).
    It did the same for me, when I first opened DIM I didn't see the general release itself (some plugins like Measure Metrics did appear though) but after relaunching DIM I see it now.
  • SquishySquishy Posts: 727
    The first thing that jumps out at me as for whatever reason, the UI font is different and does not display very well in 1080p, it's uncomfortably hard to read compared to 4.x. There does not seem to be any setting I can find that changes this.
  • figured it out. the problem was with the download filers. thanks for your guys help.
  • BanyanBanyan Posts: 42
    edited June 4
    Does Daz Studio 6 support my 3d mouse like DS 4 did?
    Post edited by Banyan on
    There's a plugin available for that, see this thread: https://www.daz3d.com/forums/discussion/759601/bj-3dconnexion-3d-mouse-plugin-for-daz-studio-2026
  • Venger1979Venger1979 Posts: 14
    For some reason DAZ6 is (alot) slower in the preview render then DAZ4.23. I have a 3090RTX Nvidea card. I would assume that it would at least be the same speed of the application.
  • hapciupalithapciupalit Posts: 132
    I have noticed a problem with the focus on scenes prepared in Daz 4.24 and Daz 6.
    I usually prepare my scenes in Daz 4.24 due to the viewport lag and render them in Daz 6. So I place the focal point on the eye of the character or whatever and then when I load the same scene in Daz 6, I notice that the white sphere stays in the same place as it was in Daz 4, but the actual focus point is a bit back. I'm not sure if I not understanding the focus point right, or is it something to do with Daz 6? I have attached a screenshot.
    I have placed a plane in the exact same spot as where my character was so it's a bit more obvious, so in Daz 6 the focus is not in the right place.
    1710 x 1942 - 865K
  • jmucchiellojmucchiello Posts: 2,616
    bronyswvg said:
    Does this release means end of life of DAZ 4.24.X? Is DAZ 6 officially released or is it still beta version? Should I back up my 4.24.X zip to avoid being forced to update to DAZ 6?
    Since all PA plugins and many scripts are still not ported to Daz 6, it would be shooting themselves in the foot to end 4.24 support any time soon. This is the official release, apparently.
    That said, you should still back up the 4.24 zip, and associated plugins and starter resources, just in case support ends in the future. You don't want to be surprised in the future, either.
  • alofaroalofaro Posts: 43
       Given the feedback above, I am not going to try installing DAZ Studio 6 for now, even if in theory can go in parallel (I have too many bought plugins, plus a well structured personalised Scripts menu, thank you Daz), but I have nonetheless a question, what is the older model of GPU supported by DAZ Studio 6 (well, the NVIDIA libraries it uses) ? Or said in a different ways, what is the older version of CUDA it is compatible with ? Or in a different way again, what is the lowest "computer capability" the card must have to be usable with DAZ Studio 6 ?
      Any of the above answers would be enough for me, actually, the anwer to the second or third question are even better than to the first, because with that I can more precisely kind of backtrack to the family of cards, and see if I could still use at least the more recent ones I have.
      Thanks !
  • lopassntrs1lopassntrs1 Posts: 9
    Spent some time talking to AI bot on how could i make the viewport work better. It suggested me using the Simplify plugin, which is for Blender.
    I hope this shows how much this AI bot will be usefull to us!
  • DoctorJellybeanDoctorJellybean Posts: 10,228
    DS 4.x won't disappear.
    They have been notified.
    When they announced DS6 Daz specifically said that the latest DS4 would remain available for download. Having a backup can't hurt though.
    edited June 4
      Thanks !
    You can use any GPU as long as it supports the 576.57 driver or higher. 576.80 Is the first Studio Driver (SD) after the minimum. NVIDIA recommends installing Studio Drivers (SD).
    Post edited by DoctorJellybean on
  • ElorElor Posts: 4,249
    The name implies it should work with Daz Studio 4.24, but just to be sure: if I'm updating Default Ressources for Daz Studio 4.23+, it won't cause any problem with Daz Studio 4.24 ?
    No.
      Thanks !
    The viewport works well enough with a 40xx series GPU. I've been running the beta for a month side-by-side with 4.24 and my productivity is up. Probably because I had no idea how helpful have two copies of Daz running could be. Moreso than the beta. But the beta loads scenes and unloads screens 10 times faster than 4.24. That alone is worth the lack of some scripts and plugins for most of my workflows.
    Search for Daz Studio 6 in the DIM filter bar. That's what I had to do.
    edited June 4
      Thanks !
    As a complement, from what I've read in the "Iray highlights" thread, all pre-Turing GPU support has been declared deprecated, which means it will likely be removed at some point. So while 10xx cards still work for now, we don't know how long that will last.
    Post edited by Leana on
  • jjb24jjb24 Posts: 75
    No.
    Is there any place that describes what 'Default Resources for Daz Studio 4.23+' is? What does it add? What does it remove? Why should I install it?
    No.
    "Default resources" contains basic things you need to use DS like the default shaders and lights.
    4.24 and its plugins is unaffected by installing 6
  • Found that the Premier Functions aren't working, as Render Queue isn't popping up for me.
  • battfieldbattfield Posts: 81
    As ever, it’s a right pain to use with a graphics tablet.
    Did you install the DS6 version of the plugins?
    Did you login via Connect? The plugins need to be authorized.
  • ImagoImago Posts: 5,813
    Any improvement for the animation tools? Or it still got the "double click scrub" timeline?
  • mjmeyermjmeyer Posts: 5
    edited June 4
    yesThank you  very much
    Leana said:
    mjmeyer said:
    b) Is DAZ Studio 6 only a temporary trial version and will I have to subscribe to an expensive plan to really use it?
    No, it's not. It works like DS4 did, there's a free version and if you're a Premier member you have access to more features.
