* CLOSED * RRRR - It was a great idea, but... Render Contest
Totte
A new years and a new round of RRRR.
The theme for this round is It was a great idea, but...
Just image all those great ideas with a less then great outcome, all those Hold by beer moments, or anything imaginable that someone imagines, does that clearly shows why everyone else dropped the idea before.
Check the entries only thread, first post, for an example on how to post an entry.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Name | LBs |
| Totte | 2 |
| acb | 2 |
| Luci45 | 1 |
| aprilshowers2065 | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread.
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Wednesday January 14 - 2026, and will go on until Sunday March 15, 2026 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Luci45 sponsors with a $40 Daz GC,
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
Dartanbeck is sponsoring with items from his store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/ ;
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
RRRR Good Intentions / Mixed up Mythology
https://www.daz3d.com/forums/discussion/727991/closed-rrrr-good-intentions-mixed-up-mythology-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/727986/rrrr-good-intentions-mixed-up-mythology-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/736086/rrrr-good-intentions-mixed-up-mythology-winners
RRRR - Unusual Laws / Refused Sports
https://www.daz3d.com/forums/discussion/737821/closed-rrrr-unusual-laws-refused-sports-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/737816/rrrr-unusual-laws-refused-sports-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/745691/rrrr-unusual-laws-refused-sports-winners-announced
RRRR - The Lyrics
https://www.daz3d.com/forums/discussion/745966/rrrr-the-lyrics-render-contest-closed/
Entries Only: https://www.daz3d.com/forums/discussion/745961/rrrr-the-lyrics-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/753416/winners-rrrr-the-lyrics-render-contest
Gosh, my whole thread about Richard and Jack is full of their great ideas that went south (like when Jack took Richard punting on the river). I look forward to what people post here. I'm sure there will be some good laughs. I've gotten so busy with other stuff that I have had to opt out of some things, including RRRR.
Good to see @barbult here again. Good inspitation for people in your Jack and Richard thread then. (I should have added a Richard to my sample post in the entries only thread, it only have a Jack in it,
Pull #1
#1930 Parkside Freight 2017 (#47443)
#6254 XI Street of Lisbon (#109235)
#1850 Containment Hallway (#46165)
#411 Genesis 3 Female Body Morphs (#22050)
LB1 #1243 Lotus Maiden Outfit Textures (#24478)
LB2 #5796 ManWolverine for Genesis 9 (#103879)
That's a weird environment and prop combo...
Pull #1
4285 Rune Outfit for Genesis 3 Female(s)
5730 Vintage Boxing Accessories
1050 Creepy Poses for Creature Creator Genesis 2
1049 Creepy Old Attic
2545 Jupiter 5 Rocket (LB)
Weird pull, and two consecutive numbers?!
Pull#1
And I thought we did everything there is to do with the little Ball of Calm last april.
@luci45, @acb: Even the pulls in this RRRR seems to go south :-)
And yet it seemed like such a good idea at the time...
Running another RRRR seemed like such a great idea
Until the first bad pull, and then the second one, and the third one..
You know you miss it, barbult. How about one render, featuring Richard?
tag:luci45 #1
Attic Convergence
Because they hated the times they lived in, Space Corps recruits Carl and Pete volunteered for the Infinite Space Flight. It seemed like a great idea. (What have we got to lose?, mused Pete.) Years later, out of boredom, they pressed the emergency time travel button. It also seemed like a great idea.
Wizardess Milia found a spell to get herself out of the wretched seventeenth century. It seemed like a great idea.
All were dismayed to find themselves in a cluttered attic somewhere in the mid-twentieth century.
Also Used
Satine
Space Corps Suit
PTF Portals
Tag: Totte#01
Also used:
XI Tram of Lisbon
LowPi Crowd Generation Bundle
LP Medieval Life Expansion
LP A Dinner and a Show Expansion
Mei Lin 7 + Lotus Maiden Outfit For genesis 3 females + Electro Hair
Traffic Patterns ( Sedan car )
Ty for genesis 9 + Gentlemen Style Outfit for Genesis 9 + Louie Beard + M3D Viking Hair
Italian scooter
Scripts, Shaders and Lights used:
Skies of Economy
Code 66 Merry Xmas 2025
Invisi Lights
Emission Profile Master
The Happy Train
In Lisbon, entertainment entrepreneur Remigio Fernandes created the Happy Train. He added an engine and pulled trams around the tram tracks that now worked as moving bars. The result caused traffic problems as the trains had to share the streets with cars and people, and tourists just dropped their rented scooters on the streets everywhere to jump on the train.
Totte#01 LOL, a happy train! Awesome! I love the lighting and the tram cars crowded with LowPi s. The car lights are hitting the building and train just right - is that because of your
Emission Profile Master or Invisi Lights?
Pull#2
2232 Hospital Wear for Genesis 3 Male(s) and Female(s)
4294 Rog Fantasy Home - Large Room
2607 Key Chain (old and broken)
2034 Grassy Grove
3597 Ogrec for Genesis 8 Male (LB)
4813 Spirit of Punk Airship Iray (re-pull)
Thanks, actually, the car is using traffic patterns default shaders.
invisi Lights in the trams, and EMP lights from camera view like a car coming seeing all that.
@luci45: I feel almost sorry for the Space Corps, in the same attic as Milia, nice one!
Pull #2
#4373 Forest Spirits Tree and Mushroom for Genesis 9 (#89204)
#3237 dForce CB Knights Order for Genesis 8 Male(s) (#70619)
#4737 CORD 812 SC (Rendo)
#3956 Elena Dark Queen Outfit Armor for Genesis 8 and 8.1 Females (#85261)
LB1 #6472 Medieval Castle Gatehouse (#112945)
LB2 #1431 FWSA Max for Tween Ryan 7 (#32505)
Tag: Totte#02
Also Used:
Freja 8.1 HD + (Rest of Elena Dark Queen Outfit) + Braided Band Hair + Fantasy Weapons 5
Tristan 8 + Commander Hair + Fantasy Weapons 5
Slacker Outfit + Gothic Mohawk Hair
Me3dival Village Walls construction Kit
Modular Medieval Village
Blacksmith Forge ( Battle axe )
KOO Alphonso for Genesis 9 + Ned Hair + KUJ Outlaw Suit
Blue Mamba
LowPi Low Polygon Figure
XI Classic Cruiser Motorcycle
Genesis 8 Male + Western Knights Series 01
PBS Shaders Vol 2
PBS Shaders Vol 3
Paint! for DAZ Studio Iray
The Drive-Thru Medieval experience
After the failure with the Happy Train, entertainment entrepreneur Remigio Fernandes bought an old medieval castle and created his drive-thru medieval experience. The problem was that the live action actors dropped their weapons, and sometime fell themselves, damaging cars and visitors, so the insurance company close down the establishment.
So, Remigio is 0 for 2. What will he try next? Maybe he should try politics.
That sounds like an excellent career switch for someone like Remigo ;-) What can possibly go wrong?
tag:luci45#2
Dr Showpot's Retreat
The Third Woodland War ended with the destruction of most wild places and wild sentient creatures were sent to asylums/reservations. Dr Showpot convinced the government that he could teach them meditation to deal with their "anger issues." It was a great idea, but whenever there was a tourist flyover, all hell broke loose. (Dr Showpot didn't know where the weapons came from.)
2034 Grassy Grove
Also Used
Pd Batik Iray Shaders
Suffolk Wagon with Wagon Trades texture
Mr Rubble HD for Brute 8
Woody for Genesis 3 Male
dForce Miellyn Outfit for Genesis 3 and 8 Female(s) wings
Mad Weapons
dForce Vintage Doctor For Genesis 8 Male(s) Coat
Hugo Pompadour Hair for Genesis 8 Males and Genesis 9
Santa Slayer Defensive Laser Cannon
Orestes Iray HDRI Skydomes - Summer Day
Rog Fantasy Home - Entrance
@Luci45: Poor Dr Showpot, it was really such a great idea!
Thanks, Totte.
Pull #3
691 Capsces Poses Brodie 6
4859 Star View
5346 The Waiting Room
1871 Garden Variety Jack
1411 Eclectic Hair for Genesis 3 Female(s)
Tag: acb#1
Balls
"I know you've got huge balls. But do you really think, it's a good idea to go to the pool, today?"
"YES!"
The pull:
Also used:
@acb: What can possible go wrong?
tag: luci45 #3
Pumpkinhead Security
The Reilly Brothers Security and Surveillance Solutions Systems contracted the AI Pumpkinheads to create the ultimate home protection system. They were amazed but skeptical when the Pumpkinheads revealed their reducing machine, the best solution for neutralizing potential threats.
4859 StarView
also used:
FSL Rigged and Morphing Deep Magics Iray
Ethereal VDB FX
New York Essence for G3F
Victoria 7
Fraser Hair
Timothy HD for Michael 6
Jarek for M6
SRB 800 + SRB 800: Honor
Doctor's Coat and Suit for Genesis 2 Male(s)
Eldritch Seeker G2M
Jack Pumpkin Poses
@luci45: Wonderfully weird! Never trust an AI!
acb#1 - Well the big balls are balls of calm, so maybe they will work on Ms (or Mr) spider. A laudible use of your strange pull.
Thanks, Totte.
Pull #4
5358 The Streets Of Old London
5035 Super Bodysuit Superhero Textures
2155 Hd Trumpet And Poses For Genesis 8
5995 Wonderful Weaves - Eclectic Woven Fabric Shaders
1853 FWSA Blanche HD for Mabel 8
Pull #3
#2667 Bernedette Hair for Genesis 8 Female(s) (#59119)
#192 FW Savannah HD for Victoria 6 (#21487)
#4788 Susie's Rags V4, A4 & G4 (Rendo)
#932 Classic Trenchcoat for Genesis 3 Male(s) (#23381)
LB1: #4486 POWERTOWN (Rendo)
LB2: #2265 Speed Jet (#52051)
Tag: Totte#03
Also Used:
Liquid Halo Remix
LY Emily + WorkBoots + Esidor Hair
Gwenbeiz with Hair for Genesis 3 males + Everyday Drinks
LY Keiran HD 8.1 + Skate Queen + Dance Poses
City Bus
LowPi Bundle
Scripts, Lights and Shaders used:
RSSY 3Delight2Iray
Platinum Pack 1
UHT2 Ultra Salon
Anti gravity flight
Tech investor Senan O'Dugan convinced the city council to allow his self flying personal airspeeder based on his revolutionary anti gravity system, to be allowed in the city traffic. The problem was that the anti gravity field wreaked havoc on peoples hair.
Pull #4
#167 Pistol and Poses for M6 and V6 (#21420)
#5494 FH Sci-Fi Window Vignette (#91819)
#6117 Julian 9 (#108889)
#3859 dForce The Young Wizard Outfit for Genesis 8 and 8.1 Males Bundle (#83998)
LB1 #4418 FN Edith HD for Genesis 9 (#89445)
LB2 #515 Shadow Outfit Textures (#22290)
Looks like @luci45 guessed right, looks like Remigio will go into politics ....
