* CLOSED* RRRR - Unusual Laws / Refused Sports - Render Contest
Totte
Welcome to yet another round of RRRR. This time we're having a theme, and the theme is Unusual Laws / Refused Sports. This time too we have two parallell themes, you can render one3, the other or both in your entry,
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Name | LBs |
luci45 |
1 |
acb |
2 |
Totte |
3 |
katywhite |
1 |
Rafael |
1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Friday July 25 - 2025, and will go on until Sunday September 28, 2025 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
Dartanbeck is sponsoring with items from his store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/ ;
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
RRRR Good Intentions / Mixed up Mythology
https://www.daz3d.com/forums/discussion/727991/closed-rrrr-good-intentions-mixed-up-mythology-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/727986/rrrr-good-intentions-mixed-up-mythology-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/736086/rrrr-good-intentions-mixed-up-mythology-winners
OK!!!!
Pull#1
457 Basix - Poses for Genesis 3 Male(s)
1841 Genesis 2 Legacies for G3F: Stylish
657 Caleb for m4 & Genesis
63 A Curious Bus
1344 East Park Lobby
Pull #1
#539 Cista Sanctorium DS (22335)
#4037 Long Haul Freighter (86155)
#5903 i13 Sci-Fi Splendor Expressions for the Genesis 3 Female(s) (31509)
#4764 CORD 812 SC (Rendo)
LB1: #1414 FWSA Lexi HD for Rune 7 (32219)
LB2: #903 Rough Rider for Genesis 3 Female(s) (23285)
LB3: #5287 Spaceship Jumpsuit Outfit Textures (82856)
tag:luci45 #1
Interpretive Mixed Martial Arts - How It Began
Caleb and Ninive had worked hard developing their new sport and a variety of awesome routines. They were sure they would impress the judges after getting a public following on their nationwide tour. When they damaged the old building (owned by Ninive's dad) getting out their newly tricked-out bus, a police officer arrived almost immediately threatening to arrest them. They had damaged a Classic DAZ Historical Building and were in deep trouble. Fortunately Nine's father paid the large fine and restorative repairs and they continued on their mission.
63 A Curious Bus
Also Used
Dale GM3
Law Enforcement G3M
Asian Persuasion
Zior Hair
Water Spirit Warrior
Rose Hair
Ceridwen Texture
Nice pull.
@Luci45: You're of to a great start here, nice use of that pull!
Tag: Totte#01
Also Used:
Textures for Rough Rider for Genesis 3 Female(s) + Z Utility Walking and Crawling
Jinx Jones 8.1B + Spaceship Jumpsuit Outfit for Genesis 8 and 8.1 Females + Afro Styles Hair C
Callum 9 + Chet Hair + Mime Artist
Alpha Base
Mesa Desert
Orestas Iray HDRI Skies
SH Star Hauler
Cargo Ship
Desert of Desolation
ROG Fantasy Home (painting frame)
Scripts, Plugins and shaders used:
PBS Shaders Vol 3
RSSY 3DL to Iray
Skies of Economy
FilterForge
The art law
At the spaceport of Yethi-Groon, law states that all pieces of art has to be transported openly to prevent fraud and other criminal activities. Lexi and miss Jinx had bought a painting of Pippi Longstocking's Father at an auction. It was said that it actually was painted at the island where he lived as a chief over the whole island.
Pull #2
#2925 The Colosseum (64727)
#74 Muelsfell Victorian Street Display Base DS (21197)
#2652 Warg HD for Daz Dog 8 (58507)
#4369 Runic Tattoos for Genesis 9 (88657)
LB1: #5210 Unicycle Bob Iray Addon (79975)
LB2: #4664 Return To Driza: Small Homes (Rendo)
LB3: #5919 The Sinful Witch for Genesis 2 Female(s) (20426)
Ohh Crap!
tag:luci45#2
Maybe A Landscaper Would Help
Because there wasn't much work available on Planet Earth, Stephanie immigrated to Beta-Trapunia, where female human workers were welcome to do things the Trapunias found distasteful - all form of physical labor. Because the Trapunians found them "unmanageable", male humans were not allowed on the planet. When asked by Zik to beautify the plant life, Stephanie explained that landscaping was men's work.
pull:
3084 Mei Lin 8
1191 DD PBR Camo Fabric Shaders for Iray Vol 3
3910 Princess of China 2
2764 Lisas Botanicals Tall Grass
2476 Josie Tails Hair for Genesis 2 Female(s)
Also used:
Blue Collar Basics Coveralls for G2Ms and G2Fs
Atmospheric Skies 16k HDRIs with Optimized VDB Haze
Various morphs
Fantasy Skins for Genesis 8
Subsurface Workshop - SSS Shaders for Iray
Utopia Cityscape Blocks
Greeble City Blocks 3 and 4
Ah, you've already started...
Pull#1
Odd: two Sahira 8 themed products in the same pull. And it seems it insists on pirates wearing tops.
Thanks, Totte. #1 was hopeless for me, and that's what came out.
Totte#01 Haha, that's funny. I love the pose of the lady in the back. And quite a work of art!
acb - A pirate should be well dressed for the futuristic lab. LOL.
pull #3
4161 Reynard For Genesis 8 Male
3820 Platea Pergo Iray Addon
1609 Feeling Fruity OmniHair Shaders
1382 Edwardian Hair for Genesis 3 Female(s)
1009 Cowboy Outfit for Genesis 3 Male(s) (LB)
@Luci45: #2: That's a nice one, and here the women call it "Karlgöra" "Men's work". (We often, like the Germans, have words for things.
Tag: Totte#02
Also Used:
Unicycle Bob
Genesis + Lora for Genesis + Flak Vest + Essence Pants
IG Iray Lilith 6 + Urban Assault Rifle+ Muzzle Flashes
Julius 9 + Combat Uniform + Modern Weapons Collection 2 + Modern Weapons Collection 2 Poses for Genesis 9
Van Helsing 9 + Combat Ready Outfit + Modern Weapons Collection 2 + Modern Weapons Collection 2 Poses for Genesis 9
Saddle for Daz Dog 8
Platea (Flag)
Foxhole Props
Shaders, Scripts and other resources used:
RSSY 3DLToIray
Iray Converter for Genesis
MMX Smoke
VDB Explosions
Gladiator Ultra
Media mogul Richard Deepwater tried to convince the Olympic Committee that his new idea for a Olympic sport, Gladiator Ultra, would sell a lot of commercial spots at very high prices and would make the Olympic Committee very rich, but they declined his idea.
Totte#02 Great render. Looks like Idiocracy! It would do well in the USA.
Puff #3
#5310 Country Ford for Daz Studio and Carrara (42901)
#4237 Victoria 9 HD Makeup (87804)
#616 Elisse HD for Victoria 7 (22540)
#4612 Movie Sets, City Block 12 (Rendo)
LB1: #2047 Darius 8 (48907)
LB2: #2295 Wise Wizard Beard for Genesis 8 Male(s) (52575)
LB3: #1566 Deco 12th Floor DS (34923)
3 environments, two of them very large exterior and one interior, this will be tricky ...
tag:luci45#3
Cosplay Convention Games
The Annual Platean Cosplay Convention committee pondered including a new sporting competition for their upcoming event.
Freestyle Watersports, suggested by new member Johnny Jawsome, seemed like a great idea until they saw Johnny in action.
Distraught committee members discussed a requirement that attendees pass a human DNA test or at least show themselves out of costume. Reynard, Knowing he wouldn't do well with either option, said those seemed a bit harsh and they should just refuse the sport and continue playing badminton and croquet.
Pull
Also used"
SY Splashstravaganza Iray
SY Rigged Waves Iray
Jawsome Quickstrike HD Shark for Genesis 9
Victoria Iven for Genesis 3 Female(s)
Mina for Iven
Ophelia 7
Leo 7
Capsces Creature Creator Shapes for Genesis 2 Male(s)
Creature Creator for Genesis 2 Male(s)
I'm glad I don't have three environments!
Pull #4
6006 Wild Plants - Wild Ferns Volume 1
1409 EleBeast for Genesis 3 Male
1008 Courtly Manners - the Ladies
4302 Rough Concrete Shaders For Iray
5505 Tribal Village Huts (LB)
@Luci45: #3 - That's a great one, clever Cosplay guy that Johhny!
Tag: Totte#03
Also used:
Husdon Outfit
Victoria 9 + dForce Retro Radiance Outfit + BW Lucas Everyday Glasses + Small Earrings+HS City Braids Hair
Hit Jumpsuit + Audry Hair
Dirty Dishes + Dirty Dishes Expansion
Scripts, Lights and Shaders used:
Skies of Economy
RSSY 3DLToIray
Invisi Lights
Prime ribs
At the posh restaurant The Overlook, health inspector John Auber was very displeased to find that he got six pieces prime ribs on his plate. They were not served according to section 47:11 in the Health and Safety Regulations, which clearly states that prime ribs have to be served in prime numbers only.
Soooo... what exactly do you mean by 'refused sports' ?
"Sports" that never hit it, like "car tabletennis" or "downhill curling" or whatever you can come up with...
Got it - so failed sports like elephant juggling and monkey boxing would fit the bill
Is a random selection by my Product Library page (I have 51) and item on page (there seem to be 40 per page) acceptable ?
If so here's my Pull #1
page50 item8 - FREE ebook - Choosing a product that works in the market ...unusable, redraw
page15 item22 - Capsces Cute And Casual Keiko 6 ...Gen 2 poses, OK
page45 item 29 - Safari Starter Bundle ...a bundle with a backdrop and some wild animals, OK
page12 item20 - Mixies Thigh Stockings ...for Cookie, OK
page 12 item 32 - Strappy Suspender Textures ...for an item I don't have, redraw
page 23 item 13 - Warrior maiden Okami ...V4 morph and texture, OK
If not, no problem
Replicator Roulette
After discovering that the equipment they had stolen from the recently looted lab could also materialize clothing, a new pastime quickly took hold: Replicator Roulette.
The main rule of Replicator Roulette is: What the replicator gives, you must wear.
Given the tendency toward underwear and especially tops, it's to be feared that interest will wane over time.
Also used:
Pull 2
Total Destruction... now near you
Apparently, it's against the law to hold arena fights with mythical and/or undead creatures that control massive robots and/or vihicles in the middle of a city. The resulting widespread devastation seems to be problematic for some. Who would have guessed?
Also used:
@acb #1: That sounds like a fun game, almost like the RRRR itself, kind of recursive render ;-)
@acb #2: Poeple are so negative these days, fightclub on the streets, what can possibly go wrong?
Pull#3:
The last few pulls sum up my collection quite well: creatures, tops, and the boy's bedroom... apparently.
Pull #04
#2680 Doomsday Textures for Cyborg Generation 8 Female (58889)
#5416 Chesterhaven (66451)
#4611 Razor Rider_Hotel Reception (Rendo)
#2865 Yuzuru 8 (63183)
LB1: #3003 dForce Bellowtalons Knight Outfit Textures (66359)
LB2: #2528 Liquid 3 Iray Shaders - Mixed Cocktails (56731)
LB3: #3940 The Young Wizard Outfit dForce Tunic for Genesis 8 and 8.1 Males (84721)
tag:luci45#4
Interspecies Meet and Greet
In the tiny country of Polypodia every creature was required by law to attend the Basic Civility Class. With this measure President Elebeast intended "to promote some degree of peace and understanding among the country's wide variety of species."
Pull
1008 Courtly Manners - the Ladies (G1 and G2F)
Also Used
Elebeast for Genesis
Twiglet Wood Spirit
TyRex
Mr. Turtle and the Conspicuous Interloper
Mouse for Genesis
Death Cap HD
Drakon
LowPoly Crowd Creator Expansion: Outer Rim
Day Bed
Plant Pots Vol 2 - Square and Unusual
TreeScapes Backdrops
Woodland Floor Iray Shaders
Daydream Dress
Fairy Dell Outfit for Genesis 2 Female(s)
Mall Girl for Genesis top
Everyday 1950 for Genesis Female skirt
Batik Shaders
Hand-Dyed Shaders
DG Iray Tropical Fabrics Shaders
