RRRR "Behind the scenes" Render Contest *CLOSED *
TotteTotte Posts: 15,248
edited October 2023 in Art Studio
Yes, you saw it, it's for real!
We're back for another mind shaking, troublemaking, record breaking,  reality faking,  history making, GPU breaking and breathtaking RRRR Render Contest!
This time the theme is "Behind the scenes", which can be behind a book, a photo, a painting, a movie, someone life or a song or a poem. Just use your imagination and the items you pull.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over seven years until it needed a well deserved break. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
 For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list. (I personally will see much joy in dropping Camel, I don't know how many times it has been pulled over the years)
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Randomizer that works well:
Update!
This seems to have issues (being hacked)?
Randomizer where you get all numbers in one draw scroll down last all the gibbersh and ads and set it to unique values (Remind me to write a randomizer for DS for the next round): random
So I recommend this instead: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
Current Lucky Bastards Standings:
Player LB count
Rafael 2
Totte 2
Luci45 1
Zethara 1
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then
the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at  WednesDay September 14 2023, and will go on until Sunday October 29 2023 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Daventaki is sponsoring with a $10 DAZ GC.
Luci45 is sponsoring with a $15 DAZ GC.
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 10 entries per player.
So, good luck and start your render engines!
Post edited by Totte on
«134
