Lucas 8
123457»
  • 3Diva3Diva Posts: 12,058
    edited October 2017
    j cade said:
    Theoretically its possible to have a skin setup with a Translucency strength of .9 and still have the skin look light, but a) that doesn't solve the render time issue b) in my experimenting I have a recurring issue of the characters breaking out in green fireflies if I push the settings too much trying to make things lighter
    below is as light as I've gotten the skin with translucency at .9 so far same lights and rendered the same time as the others. If I actually let it render enough it would probably look pretty decent, but man is it super fiddly tiny value chances can make everything go screwy, If you look close you can see some of the green fireflies starting to creep in.
    Yeh, I'm not sure I understand the point of super high translucency - but your settings look pretty good! :) It's unfortunate that it makes green fireflies. That's weird. I don't think I've ever gotten green fireflies, but occasionally if I'm not careful tweaking the settings I'll get like odd "empty"/transparent pixels speckled across the skin. I'm not sure what causes that.
    Post edited by 3Diva on
  • zombietaggerungzombietaggerung Posts: 3,969
    edited October 2017
    I've found that giving the SSS Direction setting a number, I've only tried it between .55-.65, gets rid of those green speckles and seems to stop that weird no-background transparency. At least that seems to work for me when trying to duplicate the G8 skin settings for G3.
    Edit: If translucency is set to .9 the figure still renders see through with no BG. hmmmmmm....
    Post edited by zombietaggerung on
    He looks great indeed.
    Would you like to share your tweek/setting changes?
    Here they are: https://www.dropbox.com/s/6qo3z2pqb2ip0uf/Lucas 8 New Settings.zip?dl=0
    No one's tested it yet, so please let me know if I messed up with packaging it or if there are any other issues. :)
    Sure, let me see if I can package it up and send you the link. :) Send me a PM as a nudge if you don't hear back from me in a day or so (I can get forgetful).
    I'd like the link, too, please? Your results are the only thing that will keep Lucas from being returned for me.
    Here you go: https://www.dropbox.com/s/6qo3z2pqb2ip0uf/Lucas 8 New Settings.zip?dl=0
    Let me know if you have any trouble with them or if I've packaged them up incorrectly.
    edited October 2017
    Here are the alternate settings for Lucas 8: https://www.dropbox.com/s/6qo3z2pqb2ip0uf/Lucas 8 New Settings.zip?dl=0
    I've included four different settings to accommodate different lighting and different tastes. Feel free to make farther changes to the skin if it's not to your liking, of course. :)
    Download the zip file, then open the folder and drop the "Presets" folder into your My Library. You should then be able to find the new settings under Presets >> Materials.
    Let me know if you guys have any trouble with them or if I messed up with the packaging of the files.
    I'll also upload them to ShareCG or Rendo when I get some time. :)
    Also, if you guys want to know my render settings and lighting (which makes a difference in helping to enhance the details), let me know and I'll see about sharing those as well. :)
    edited October 2017
    hahah Yeah, that glitch is so weird. Next time I get that issue I'll try your fix, hopefully it works with lower translucency settings. :) Thank you!
  • RCDescheneRCDeschene Posts: 2,817
    edited October 2017
    JOdel said:
    I'll admit I was surprised to see Elijah bundled in with Lucas. Lucien, I'd have expected. But not Elijah.
    Elijah I actually get. What I don't get is Brodie. He was a tween boy, not a slim adult male. If they really had to include a Gen 6 male, Jayden would have made much more sense.
    Though, if someone like Elijah is comparable enough to David & Lucian, why didn't they include characters like Eva or Genevieve in Stephanie's promotion?
    Post edited by RCDeschene on
  • Carola OCarola O Posts: 3,862
    Had some fun with Lucas 8, a dash of M8 and some morph packages. Than continued the fun with postwork in Topaz Studio (the free version). This be the result, posting two of the pictures I ended up doing.
    Male model -1 Topaz 1 and 2
    That looks really good! I particularly like the bottom one! :)
  • Kev914Kev914 Posts: 1,153
    edited October 2017
    I created this image with Lucas. I think I like him!
    Your alternations made him look more mature, @Carola 0. He looks good.
    Post edited by Chohole on
  • xyer0xyer0 Posts: 6,524
    Will do! :) I'll send you the link as well.
    Thanks to you! Now, what if you did fix-up shader settings for the G8F/M's and sold them as Divamakeup New Looks for Genesis 8 Core?
    That would be cool! :)  I'm not sure Daz would go for it though. lol
    Of course they would. I remember a product for Victoria 7 (that I cannot presently locate) that offered new settings for her. Judging from this forum alone, people really need options for Genesis 8 that make them compatible with Genesis 3 in the same render. Right now, I can either light for Genesis 8 Core skins or for Genesis 3, but the same lights rarely work for both.
    Thank you Diva and Kevin :) playing around more with him to see what comes out of it.. The differences between the two pics are two different choices in topaz studio, they both worked from the same base render
  • EJWorksEJWorks Posts: 483
    I was having some rendering issues, but here is Lucas "lurking" in the shadows.
    1393 x 878 - 848K
