Wear Them All
1235712
    did you do the 'fit to' option? some things load without automatically fitting the figure and you have to conform/fit to first. I have the cool coils hair so I'll install and check it.
    HI don't know, could be.How do you tell if it's a prop?  One of the hairs is Cool Coils Hair, the other is Petite Fleur Hair,
  • TooncesToonces Posts: 919
    The pdf that came with this latest release of wear them all had some guidance for hair.
    Shows how to determine if it's a prop or not. Also shows how to convert it if it is a prop.
  • valzheimervalzheimer Posts: 519
    ^ This, thank you :) Yes if it loads as a static prop/object (happens with hr2 files, it will be just an object under scene tab, no bones under it), you can convert it temporarily from prop to figure and then use autofit using a clone :) It's explained in the Read Me, I'm here if anyone needs assistence or send me a message here in the forum.
    mtl1 said:
    Quick question @valzheimer : I tried fitting "Emo Girl : A3" (https://www.daz3d.com/emo-girl-a3) last night and got massive deformities around the breast region -- very similar to autofitting some Genesis items to G2F/G3F. Oddly enough, I didn't encounter this issue when I autofitted other shirts and dresses. Do you know what causes this issue?
    I would post some images, but I'm away from my rendering computer at the moment. The deformities look... crumpled in?
    I just tried this dress on my Genesis 3 girl, if breast area looks a little rough after conversion, try tips included in the PDF, convert to SubD (so it goes form Base to High resolution) and add smoothing modifier. You can also use breast morphs included in the dress (they work) to readjust shaping directly on the dress, I attached the screenshot of how I achieved this result in my scene :) Hope it helps.
    1656 x 966 - 635K
    Another one from Threed Recluse (3DRecluse). This one is the Men of Action for David 3.
    1500 x 1200 - 195K
  • mtl1mtl1 Posts: 1,508
    edited April 2017
    Okay, so I'm back home now... this is what I get with the Emo Girl dress compared to the Ravyn dress. I wonder if the initial fit changes the way the dress will fit? Or perhaps it's a bone or weight-map issue?
    I'm curious because, like I mentioned earlier, I've occasionally experienced this autofitting Genesis 1 products... or autofitting V4 to Genesis 1 products too.
    edit: Smoothing doesn't fix the issue either...
    784 x 683 - 421K
    683 x 613 - 524K
    Post edited by mtl1 on
    A gorgeous pic from the lovely artist Sandra Bauser - Esbee Art using the Scorpio Rising for V3 outfit by Aeon Soul
    738 x 960 - 61K
    edited April 2017
    Did you see my settings in the screenshot, where I highlighted smoothing/collision and mesh resoultion? Try adding smoothing and change smoothing type to generic, than up the value, also SubD the dress. Yes some older items are a bit rough to refit due to the difference between, in this case, Aiko 3 and Gendesis 3 female, that's where those distortions may appear.
    The dress has breast morphs, try using them as well to pull the breast area a little "out".
    Post edited by valzheimer on
    Yeah, I juuuuust saw it :) I think my thread didn't refresh properly or something. Let me try another render and see what's up... I'm trying another method at the moment from one of my previous work flows.
    Haha, ok, you had me for a moment there wondering if we're using the same dress. I would like to hear of the progress you make with it, good luck! :)
    V.
    I retried it with subD and increasing smoothing and there's a slight difference... Hm.
    Coincidentally enough, the wrinkles correspond almost 1 to 1 with the Chest Lower weight map, but changing out the weight doesn't do anything at all.
    After some more poking, I believe it has to do with the original fit of the item as I see a pretty large gap between G3F (or Aiko 3) and the dress itself when I inspect it under Lt Wireframe. There's a portion of the dress that doesn't follow the undercurve of the breast, as compared to other dresses and other pieces of clothing. I'd post a screenshot, but I'm not sure if showing a figure's nude wireframe is considered NSFW laugh
    Hmmm. Now I wonder if the dress V-tearing fix posted earlier could help with this.
    1403 x 861 - 670K
    My girl had bigger breast so it didn't show as much probably... You can also try dFormers for these stubborn areas, here's a usefull link to how to use them on clothes:
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    The Dress for V3. This was a hard one. I went through so many poses to find one that had the least distortion of the dress. The sleeves were impossible, they must be dynamic. The bottom train was a hot mess but was able to use the bones to straighten it out some but I hid it from the render anyway. I forgot to put the slippers on before the dress and couldn't stop the poke through so I took them off because I didn't want to start all over with the dress.  But still, a lovely little number. Just got this today and all the textures each for $1.99, not bad.
    717 x 881 - 873K
    Oh, OK will have to re read the .pdf. I do remember reading something like that , thanks
    I ended up exporting it to Blender and doing a manual smooth on the dress :) Relatively straightforward, as I can directly paint use the smooth/flatten tool and re-import as a morph.
    662 x 645 - 613K
    Sorry for the spam: I tried smoothing the underbreast of the clone with great success! Less artifacts than before, but the dress is still quite form-fitting as opposed to loose. Oh well :) This smoothing obviously is specific for this dress and would not be applicable to other pieces of clothing...
    637 x 726 - 611K
    Looks great @mtl1 ! Yes I didn't see this problem on other Aiko 3 clothes, might be that dress specific, but I'm glad you found the solution :)
  • KnittingmommyKnittingmommy Posts: 8,191
    edited April 2017
    I picked up some M3 clothes during the sale.  Here is the first thing I've tried. Forgot to say what the outfit is: 3 Piece Suit for M3. The materials needed some work on the settings after converting to Iray, but overall they didn't too badly.  This is on Saiyaness' new guy, Dale for Genesis 3.  There are more pictures on my Lab thread with the material issues and the fixes I made.  I have a distortion issue with the crotch area and a problem with the tie that I need to see if I can find a fix for, but I haven't read the pdf, yet, so I might find an answer in there.  :)  Overall, I didn't have to think too much to get things working.
    Post edited by Knittingmommy on
  • LlynaraLlynara Posts: 4,772
    Boopsie is a doll!.
    Llynara said:
    That's what friends are for! LOL If it makes you feel any better, I just dropped $30 over there. Couldn't resist $3 and $6 outfits. Here's Xurge's Necromancer for M4 using the original Wear Them All on Darwin's newest character, Evan for G3M. He's got his elf ears and Creature Creator settings on too. He looks badass! I just need to tweak the outfit's materials a bit more, but having fun with it.
    This is amazing Llynara
    Thanks! I tied up my computer all day trying to get the version with TD3 Atmos fog and snow rendered. Wow, is that ever slow. Will post that version soon.
    I heart The Dress! The Blue Moods texture for it is that one that caught my eye and made me fall in love with V3 and her amazing wardrobe. It's fitted "the old way", to Genesis with Gen 3 Iconic Shapes for Genesis and then to G3F with the original Wear Them All. I'll try again with the new expansion and see how that works.
    edited April 2017
    This looks great on Dale! I picked up that outfit too, along with the 60s men's suit. That one should be fun too.
    Post edited by Llynara on
  • RCTSpankyRCTSpanky Posts: 850
    edited April 2017
    Thanks for the latest addition. I have tested teen Josie 7 together with the Aiko 3 Idol Outfit from Digitalbabes. Apart from the stockings everything was converted nearly perfect.
    528 x 747 - 103K
    Post edited by RCTSpanky on
    did you try adding smoothing to the stockings? that often fixes the poke thru.
    Llynara said:
    Boopsie is a doll!.
    iI know, I picked up the whole collection yesterday for $21.  Have you figured out a way to make the sleeves work?
  • scorpioscorpio Posts: 8,533
    Llynara said:
    Boopsie is a doll!.
    The sleeves aren't dynamic, but anything that hangs down like that is very awkward to autofit. Dangling sleeves tend to have extra bones these don't usually transfer when autofitting.
    Pitty, I really love the sleeves
    edited April 2017
    I had the same problem with the arm ribbons when I tried fitting Aiko 3's Nymph dress. They just crunched up in ugly bunches.
    Laurie
    Post edited by AllenArt on
  • greymouser69greymouser69 Posts: 501
    edited April 2017
    Had to give the old ISOP Casablanca suit set for m3 a try on Dale.  Also trying one of DT's new light probe expansion & tone mapping.
    Dale
    1920 x 1080 - 772K
    Post edited by greymouser69 on
    edited April 2017
    @greymouse69 Nice! The Casablanca Suit looks pretty snazzy!
    scorpio said:
    Llynara said:
    Boopsie is a doll!.
    It might be better to put the figure into a T pose, then parent the sleeves to the arms instead of autofitting. Sometimes that works, sometimes it doesn't. That trick works GREAT with older hair that won't autofit.
    I've also fit new hair to old figures that way- parenting to the head instead of fitting. Here's an example with two Gen 3s wearing newer hairs (V3 has Fantasy Warrior Hair for G3F and M3 is wearing SAV's Alpha Moikana hair)
    It would be fun to redo this pic with G3F and G3M and see how they look.
    On The Dress, I will try the sleeves a few different ways and see if I can get any to work. I love The Dress and want to have those sleeves working too. Gotta go out to family stuff at the moment. More later!
  • RainRain Posts: 354
    edited April 2017
    Llynara said:
    Boopsie is a doll!.
    Wow!  That is a lovely picture!
    Post edited by Rain on
    Personally I never autofit hair, its always seemed simpler to me to scale etc it to fit, but then I've been doing it before autofit came along.
    Yes parenting the sleeves might work - it might be easier to use 2 sets one for the right arm and one for the left hiding what you don't need.
