RRRR "Behind the scenes" Render Contest *CLOSED *
Totte
Yes, you saw it, it's for real!
We're back for another mind shaking, troublemaking, record breaking, reality faking, history making, GPU breaking and breathtaking RRRR Render Contest!
This time the theme is "Behind the scenes", which can be behind a book, a photo, a painting, a movie, someone life or a song or a poem. Just use your imagination and the items you pull.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over seven years until it needed a well deserved break. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list. (I personally will see much joy in dropping Camel, I don't know how many times it has been pulled over the years)
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Randomizer that works well:
Update!
This seems to have issues (being hacked)?
Randomizer where you get all numbers in one draw scroll down last all the gibbersh and ads and set it to unique values (Remind me to write a randomizer for DS for the next round): random
So I recommend this instead: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
Current Lucky Bastards Standings:
| Player | LB count |
| Rafael | 2 |
| Totte | 2 |
| Luci45 | 1 |
| Zethara | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at WednesDay September 14 2023, and will go on until Sunday October 29 2023 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Daventaki is sponsoring with a $10 DAZ GC.
Luci45 is sponsoring with a $15 DAZ GC.
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 10 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) https://www.daz3d.com/forums/discussion/374101/rrrr-but-you-promised-entries-only-thread
RRRRR - Coming Late Excuses (anotherone where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time): https://www.daz3d.com/forums/discussion/482906/rrrrr-coming-late-excuses-entries-only-thread/
RRRR - Back From the dead: https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
I will throw in a $10 gift card.
Thank you! Now when the forum notifications and file upload are working again, I though it was time to run it! Good luck everybody!
Pull #01
Mystic Thrones.
SciFi PinUp Outfit for Genesis 8 Female(s).
Lief Viking Outfit for Genesis 8 Male(s).
Fight and Fiction.
Fight and Fiction is a bundle of animations. My first thought was to do a re-pull because a still image can t show an animation. But then I thought that animations are just a series of poses. So I can treat them as if I had drawn poses. So that s my plan.
What do you think Totte?
Good thinking Batman!!
Seems like a fun contest, but is there an easy way to get a list of all the products I have ?
Is it easy to select one frame as a pose ? I'm new to Daz and I don't think I have any animation packs to check myself.
If you look at the previous contest - there is a description on how to dump that out of DIM.
Here: https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Oh, we're back at it already! At least we're having a cooler spell where I live so my GPU can handle it.
I'll chip in $15. It's the best I can do right now.
Woohoo, it's back! My first pull:
1454 SKU90764 Lelandii Hedges - Conifer Clipped Hedges
128 SKU88255 Biped Droid
625 SKU55383 Harrison HD for Michael 8
1365 SKU89884 Heliconia longiflora - Exotic Flowers and Foliage
Random numbers generated Sep 15 2023 at 15:4:37 by psychicscience.org
Free educational resources for parapsychology and psychical research.
Pull #1
4689 Repair Module
432 Axel International
1094 Contemporary Garden Furniture Set 01
2777 Holiday Cactus
242 Amazon Kingfisher (LB)
Totte, can we also use inspiration behind a poem or a song?
Yes, I add that too, my bad!
Pull #1
616 Scott 6 (#22513)
438 Decorative Easel Set (#22101)
1171 Mei Lin 7 (#24039)
2829 Vintage Jukebox DS (#60871)
LB1: 4589 BMW 502 (for Poser) (Rendo) <- Will see if this one even loads....
LB2: 2193 dForce Casual Suit Outfit for Genesis 8 Male(s) (#50573)
Random numbers generated Sep 17 2023 at 16:59:58 by psychicscience.org
Pull #1
4702 2193 28554 2608
Random numbers generated Sep 13 2023 at 22:34:6 by psychicscience.org
Flex Sportswear for Genesis 8 Females
Geometric Deco Iray Glass Shaders
Traveler's Naturals - Mushroom Singles Vol 1
Underbelly for Genesis 8 Male
tag: luci45 #1
Redon Finds Color
Odilon Redon was encouraged by his muse, Mr Eye, to move on to colors, flowers and other grander things
4689 Repair Module
2777 Holiday Cactus
Also used:
G9 Eye and lahes
Haberdashery Hats for Genesis 8 and 8.1
Effortless Cool for Genesis Male
Unshaven Beard for Genesis
Art Studio
Various flowers and butterflys
Gopherus #01
Mystic Thrones.
Fight and Fiction.
On a planet not so far away, 70 years ago…
Zsa Zsa, the Queen of Outer Space returns to Venus only to find Valiant Thor sitting on her throne. Before she can speak, he announces, “Zsa Zsa, I am your brother.” “Brother!” she gasps! “Sister!” he replies. “Now get your butt off my throne!”
Could this be the inspiration for George Lucas, who years later wrote about the dysfunctional Skywalker family.
It also explains why Valiant Thor chose to leave Venus and become the first Venusian ambassador to Earth to try to promote nuclear disarmament with President Eisenhower. And why he never appeared on Hollywood Squares… he was afraid of accidentally sitting in Zsa Zsa’s square.
@luci45 Excellent! And is this also the origin of the old spanish song, De Colores?
@elor I thought that you could copy the pose from the animation. But when I did it copied the entire animation to the new figure. So I just rendered out the frames of the animation that I wanted then combined them in photoshop like Luci might do when she makes a graphic manga.
Totte: #1
Also used:
PBS Shaders Vol 3
Wolfgang 8.1 HD + Bubba Hair + Standing Conversation 2 (Pose set)
RSSY 3Delight to Iray
M601 + Refracted Glass (shader) + iReal Shaders + EcVh0 Daily Cloth Shader
Giddy Up + Kimberly Hair + Mei Lin 7 Varity Pose Pack
Shopping Street
Skies of Economy
Traffic Patterns
Michael 8 + Pack Leader + Zenty Cool Hairstyle + All Action (Pose)
Jäger Maestro - Retired Hockey Player
After a long career in the world's best Hockey leagues, the Jäger decided to spend time doing what he loves the most, selling art and listen to and enjoy Country&Western music at his impromptu popup galleries.
I've just realised this is a difficult theme :-)
@Luci45: Odilon Redon must be happy to leave his grey period, very well done and a great pull usage as always.
@Gopherus: Zsa Zsa seems to be quite a strongminded sister, great use of that pull.
Pull #2
751 Shenandoah: Greatcoat for Genesis 2 Male(s) (#22855)
3981 Pencil Mustache and Goatee for Genesis 8.1 Males (#84498)
2383 Stylish Hair and Beard for Genesis 3 and 8 Male(s) (#53025)
2461 Bounty Huntsman Outfit for Genesis 8 Male(s) (#54319)
LB1: 3484 MMX Fantasy Eyes Mini for Genesis 3 and 8 (#74047)
LB2: 535 40s Vogue for Frivolous 40s (#22321)
Random numbers generated Sep 21 2023 at 11:44:2 by psychicscience.org
Ehh? Not one single prop, just clothes, hair, beards and eyes.... weird!
Thanks, Gopherus and Totte. Yes, I have heard that many muses like to spread color around, en la primavera and other seasons.
So, Gopherus, I was not expecting to see Valient Thor on the RRRR (or Zsa Zsa for that matter.) He definitley cleaned up well for his ambassadorship but still couldn't inspire the Earthlings to quit wanting to blow s*** up. Wonderful render - I love the way you used the animation frames
I agree, Totte, that this is a difficult theme. Sorry. Actually it was mostly the new guy Rafa's idea. He needs to do a render. LOL. Pretty cool use of a hard pull. Looks like your next pull could be a character-driven theme.
Pull #2
682 Buried Treasure for Piratess
677 Bug Hunt
2744 Holiday Nook Iray Addon
5261 Small Fishing Boat
600 Blue Steel Poses for Michael 7
That was a weird pull with so many props, will take some time to chew that one, but I see a theme......
Thanks Luci and Totte for your comments
I wasn t expecting anyone to remember Valiant who i think looked more like a 7 foot tall Rod Serling but someone had to wear thor s duds.
@Totte #01 Jager made a good choice retiring to the land of the palms and working on his tan... Changes in latitudes, changes in attitudes... i like the perspective of palms leading into the distance...
Pull #02
RW Classic Chess.
V4 Elite Texture: Amy.
Secrets of Danaides Poses for Genesis 8.
Dain 8 HD Add-On.
Oh, Hell yeah, I'm in!
And hopefully, I can stay in for the duration. (I got sidetracked by a couple of other render projects during the last one. Pro Tip, people: DO NOT, under ANY circumstances, attempt to create an animation sequence in Iray! You will not live that long! Seriously people, I am 60-something years old; I'm going to be dead in thirty years! I literally do not have time for that crap!)
Here's Pull #1:
4568 - Holly Hair For V4
4631 - Drinking Horns
2864 - Textures For Reptilian 6 Hd
3348 - Steamworks Interior
And I have absolutely no clue what any of this stuff is!
Luci45:#2
A Steven Spielberg Anecdote on the Making of Jaws
"With all the difficulties we were having with the huge mechanical shark, I often had this thought that we could maybe tame a real shark. When a professional shark hunter told me about the Sea Witch/Piratess Bellatrix, who had tamed some enormous sharks, I had to go and talk to her. She tried to sell me some expensive equipment for 'luring, trapping and taming.' I almost said yes, but then I saw that one of her crew was a shark, in pants! I decided that was too tame for my puposes. I needed a killer shark."
Pull:
677 Bug Hunt
Also used:
At Sea Vignette
Bellatrix for Genesis 2 Female(s)
Charm Hair
Shark
Killer Shark for Genesis
Pirate for Genesis and Genesis 2 Male(s)
Swashbucklers
Landis Hair for Genesis 8 and Genesis 3 Male(s)
Unshaven 3 (Mec4D)
Nomad for Genesis 3 Male(s) and Female(s)
Steel Frame Specs
Real Feel Cozy Turtleneck Genesis
SG Baseball Cap for Genesis
Skies of iRadiance - Sunny Sky HDRIs for Iray
@Luci45: Luci #2 - Wow! Such a superb use of a quite weird pull! Just love it!
Totte:#2
Also used:
UHT2 Ultra Saloon
IG Gianni HD + Oliver Hair + Road Cruiser
KOO Matthieu + Luxury Watches + Biker Outfit (headware) + XI Classic Cruiser
Darsel for G8M + Biker Outfit + Viking Raider (bracers)
IG Iray Lilith 6 HD + Frivolous 40s + harlow Hair + C1 More (expressions)
Ly Clover HD + Retro Aviator Outfit
Kitchen Counter Stuff
SubSurface Workshop
Vemon for Genesis 8 Male + Hollywood + Rudolf Beard + Vintage Motorcycle
LY Keiran 8.1 + Old School Bike + Boho Chick + High Seas Hair
1920 City Street
Pred Busstop (billboard)
Born To Run
This was what Bruce Springsteen saw in the evening before he went home and wrote the epic song Born To Run.
Thanks, Totte. That was one of the few that came together easily, more or less.
Totte #2 Wow, Born to Run. That's great. I love the the guy looking at the camera. What a motley bunch!
Pull #3:
1288 Dark Waters for Piratess
3921 Mystery Cave
5972 Toon Generations 2 Essentials for Genesis 3
2170 Ferae Fae Poses For Giselle 6
2801 Horizons
So the Piratess again! With a different texture.
Pull #1
17710 "His EarStuff"
60197 "Agate Noir for Genesis 8 Female(s)"
16280 "Genesis 2 Starter Essentials Male"
65781 "Santa Slayer Defensive Laser Cannon"
A former child actress once explained how when she was pretty young, she was standing in her spot atop the set's stairs ready for her entrance. The director looks around the set and sees a baby spotlight near the actress that he didn't want. He points at the spotlight (and close to the actress) and shouts, "Kill that baby!" The actress burst into tears.
"Kill That Baby!"
Only way I could think of showing those MMX eyes....
