• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • G8.1 and Zeddicuss expressions
    PerttiA said:
    blaz said:
    Damn it, I knew they were older products but I thought they got updated to work with 8.1.
    I know about the folder workaround but I was hoping to avoid it since my expression library is not that big.
    The textures aren't really a problem since DAZ did a great job. And we have Map Transfer...
    Thanks for all the answers.
    I don't understand why the size of your expression library makes you want to avoid the workaround/fix...
    Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
    The dummy/placeholder files are located in;
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files)
    Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
    @PerttiA That's the most concise explanation I've seen yet. I will resist saying something snarky about Daz' failing to provide this information. Now, would you happen to know why Daz might have felt it was useful or necessary to prevent the loading of these files?
    @certaintree38 Thanks for your explanation. I waded through several pages of the Victoria 8.1 thread looking for this info.
    By
    xyer0 xyer0 March 2021 in The Commons
  • Torment is with which Genesis 8/8.1 Female
    @jonsebask04 I'm thinking she's Tara 2 HD.
    By
  • Another character I'm returning 8.1 it's not.
    nicstt said:
    outrider42 said:
    Guys...the "special shaders" can be applied to literally anything. They are not exclusive to Genesis 8.1. The only changes are the UV map, which is of debatable importance, and the new face rig. Every other "feature" marketed for 8.1 is available very easily for 8.0.
    The new PBR shader can use tiles for the details, which means the UV map does not matter. You could apply the PBR shader to Genesis 1,2,3 as well, or even Victoria 3 if you wanted to. Or a banana.
    I just want you guys to understand that most of what you are buying here is marketing. Even the face rig that 8.1 uses has roots in 8.0 as a purchased product. So why be bothered by a character actually being for 8.0? You can simply load that character on 8.1 and get all of the advertised benefits of 8.1.
    After all, just because a character is 8.1 does not mean that character uses PBR Skin Shader. That is the PA's choice to use it or not.
    Thus the advertising on the character is not technically wrong, because this character CAN be used for 8.1, just like all 8.0 characters can be. It may be a bit misleading, but I believe this PA is not a native English speaker and is perhaps as confused as many customers are about 8.1. IMO Daz has failed to create a clear guideline for them.
    It's not about the shader but the new UVs; the extra map (the head) is there to give better detail around the neck.
    Shader & UV improvements
    • Genesis 8.1 adds a new PBR (Physically Based Rendering) skin shader.
    • The Genesis 8.1 skin shader introduces improvements for Subsurface Scattering (less waxy skin), resulting in incredibly lifelike skin.
    • Added support to leverage MicroSkin tiling micro normal maps from our partners at Texturing.xyz
    • New processes and resources in our pipeline have been added to ensure details between sculpts and textures better match, resulting in greater realism.
    • Updated UVs for better pixel density and better seams.
    • All these combined create a better looking skin in Genesis 8.1.
    • Update your Daz Studio Default Resources package (DIM or DazCentral) to 4.15+ to access our new skin shader for Genesis 8.1 characters.
    taken from: https://www.daz3d.com/genesis-8-1 ;
    ...so now instead of having a seam that is hidden almost entirely by hair, you now have a seam that runs and smacks you upside the face by going right across the collarbone. I still don't see how that's a good change.
    If the pixel density were such a huge issue as to be noticeable on a super close-up (I've never even noticed it as an issue when composing any of my pieces), one could have simply upscaled the body to 8k to off-set the 4k head map. It's not the best solution in the world, but with the improved upscale algorithms out there, it's a better option than putting a seam across the collarbone, imo.
    By
    MelissaGT MelissaGT March 2021 in The Commons
  • [RESOLVED] Needs a little explanation on "Genesis 8.1"
    Atanacius said:
    @nemesis10 :
    so, "The enhanced capabilities of 8.1 are not backward compatible, however, so you won't be able to apply the new skins and capabilities on a Genesis 8 character."
    That's mean if I purchase that:
    https://www.daz3d.com/leon-hd-for-genesis-81-male
    Where I can purchase Genesis 8.1 Male ?
    I mean, in the page here: https://www.daz3d.com/genesis-8-1
    We're talking about a Victoria 8.1 / Michael 8.1... But not anything on a Genesis 8.1 Male/Female base?
    The base figures, Genesis 8.1 Female and Male are included in "Genesis 8 Starter Essentials" which is free (included in DS), just download the updated version and install.
    By
    PerttiA PerttiA March 2021 in Technical Help (nuts n bolts)
    By
    nicstt nicstt March 2021 in The Commons
    @nemesis10 :
    By
    Atanacius Atanacius March 2021 in Technical Help (nuts n bolts)
    I have way, way too many morphs in my library and I'm mostly interested in buying 8.1 characters for skins and maps that match the new UVs. I'm also interested in seeing how more experienced folks manage the shader settings for different types of characters.
    On a broader level, introducing the new layout and features meant vendors having to update their products and provide extended support on short notice. Older expressions and some cosmetic products and tools require workarounds to use on 8.1. From the atmosphere at the time of release, it felt like a lot of people were thinking, "Okay, this is a pain for now, but we might see some really cool new stuff and once support ramps up it'll probably be worth it." That hasn't happened yet, and while in the long run it probably will I think right now there's just legitimate interest in seeing more benefits to it.
    That said, I know there were other people who were really nervous about the whole store potentially shifting over to 8.1 wholesale and leaving those who didn't want to adopt it behind, so there are also benefits to a longer introductory period and options for hybrid characters. The language could just be clearer.
    By
    plasma_ring plasma_ring March 2021 in The Commons
  • Genesis 8.1 / Victoria 8.1
    alienarea said:
    Not sure if this has been discussed here before, or should be in a new thread.
    It seems that Victoria 8.1 is quite disjunct from Genesis 8.1 Female.
    Genesis 8 Female and Genesis 8.1 Female seem to be identical in shape.
    In Genesis 3 and 8, when you loaded Victoria (7 for 3 and 8 for 8) and dialed out the Victoria morphs, you had the base genesis female.
    With Victoria 8.1, this is not the case.
    As a result, I can apply a shape preset saved from G8 to G8.1 and it looks like my G8 character, nut when I apply it to V8.1 with   Victoria dialed-out, I get a freak.
    V8.1 is just a character morph for G8.1F, in that respect nothing has changed.
    After dialing out V8.1, what does your "Currently used" list look like (choose 'Show hidden properties' first)?
    By
    PerttiA PerttiA March 2021 in The Commons
    By
    alienarea alienarea March 2021 in The Commons
  • Hair I.D Please
    Taoz said:
    Looks like this one:
    https://www.daz3d.com/sammy-hair-for-genesis-2-female-s-and-victoria-4
    Yes it does Taoz thank you very much :)
    By
    beachlegs beachlegs March 2021 in The Commons
    I still have to question the choice to move a seam from below the chin/behind the ear to across the collarbone. Just...yeah...I'll continue on preferring the base Genesis 8 UV thankyouverymuch.
    And in regards to the new shader...the benefits above the Uber Shader are again, quite debatable. There are the new tiled normals...which meh...if a character has well-made normals and bump and specular to begin with, the microdetails aren't really needed anyways? And don't get me started on the new shader taking away features from the Uber Shader that a lot of people used and relied on for really nice skin. If I were to purchase a character that uses the new shader, I'd just convert them over to Uber anyways, lol.
    It's really all personal preference. I can see how it would be good if a vendor stated what UV map and what shader the character uses, but I don't think it should stop anybody from purchase. As you said, any G8 character can be shifted to 8.1 and get all the benefits of the 8.1 facial rig. That's really the only selling factor of 8.1...the facial rigging.
    By
    You're missing the point entirely.  Daz markets to hobbyists and is all about ease of use: click and it works as advertised.  Daz isn't Blender, and certainly doesn't advertise its products as kits, but as ready-to-use assets.  This product was not advertised as a banana, but a Genesis 8.1 character, and that brings with it certain expectations.  If Daz and/or the PA can't meet those expectations, they should expect returns.
    Daz hasn't even put a video about 8.1 on their YouTube channel, while there are four (4) on Octane.  This is not how you launch an update to your base figure.
    By
    Sevrin Sevrin March 2021 in The Commons
    By
    outrider42 outrider42 March 2021 in The Commons
  • New! Novica & Forum Members Tips & Product Reviews Pt 14
    *****  Tutorials T  through W ******
    Tutorial: Tears by SereneNight
    Tutorial: Teeth, Getting Realistic Shapes      Getting realistic teeth shapes was here and slight tweaks here.
    Tutorial: Texturing      Texturing With DestinysGarden  is a good thread- let a pro show you how!
    Tutorial: UltraScatter Advanced Instancing       UltraScatter Advanced Instancing:   RGcincy's handy notes, how-to.
    Tutorial: UltraScenery Experiments (barbult)
    Victoria 4 for Genesis 2 Female:  How to use the product.
    Tutorial: Weight Mapping:  How To Smooth All Face Groups At Once  (By SickleYield)
    Tutorial: Weight Mapping: Creating One  by Chris-2599934
    Tutorial: Windows, Making Them From Planes And Cubes Realistically       Making Windows using planes and cubes, with glass panes and images!
    By
    Novica Novica March 2021 in Art Studio
     ********** TUTORIALS**********
    Tutorial:  Bus, Noggins- Converting from Bryce to Daz Studio   (RGcincy)   Here
    Tutorial:  Breast Gone-  In Hexagon  (Smoothing Zev0s Grow Up product even more)
    Tutorial: Clothing, Making in Blender SickleYield's tutorial on Deviant Art.
    Tutorial:  Content Package Assist
    Tutorial: Converting G3 and G8 Clothing by SickleYield on Deviant Art
    Tutorial: Create Categories     Using Gen2F, I showed how to Create Categories and Export to save your custom categories. (Here's WHY you may want to do that with your characters.)
    Tutorial: Custom Actions In Toolbar     How to Create Custom Actions In Toolbar
    Tutorial: Customizing Morphs Using Morph Loader Pro
    Tutorial: D Former     D Former Tutorial           D Former tutorial and links
    Tutorial: Depth of Field         Flipmode provides a good depth of field tutorial for you.
    Tutorial: Expressions:  How To Make Them As A Dial
    Tutorial:  Face Control  (Knittingmommy)  Use on cartoon characters
    Tutorial: Fisty's Shaders & Getting Rid of Gooey Lips     This one shows you Fisty's shaders. Get rid of the overly gooey lips.
    Tutorial: Fur Brushes Download and Video (Kathryn Loch)
    Tutorial: Garibaldi Hair     Doing a cat with Garibaldi Hair- Tutorial
    Tutorial:  GenX links on "how to use."
    Tutorial: Generation 4 Materials on Genesis 2     This one put Generation 4 materials on Genesis 2 using Victoria 4 for Genesis 2 Female.
    Tutorial: Geometry Shells     How to do Geometry Shells  (video tutorial the3dwizard) and doing makeup for different characters
    Tutorial: Hair Shaders (Slosh, his product)   explaining how to use them.
    Tutorial: Hay Bales   Take a freebie and make the hay straws thicker. Here's what you get.
    Tutorial: Iclone   Iclone videos
    Tutorial: Images- How To Put Them In Forum Posts     Here's  Putting Images in Posts
    Tutorial:  Instances: Using Ultrascatter
    By
  • Hair I.D Please
    By
    Taoz Taoz March 2021 in The Commons
  • Novica & Forum Members Tips & Product Reviews Pt 13
    This is post 14 and we're allowed 30 per thread, so we've got a few more to go. I just got online and will start on Thread 14 and get it set up. Wow, thread 14, I started with Thread 1  March, 2013. Eight years ago I started documenting my trials and learning experience, with Victoria and Michael 4, and Genesis. (That was weird, having one figure for male and female.) And of course, 3DL. There are many of you with much, much more experience and longevity with Daz (Zygote!) and I really love your contributions to the thread. Thanks for being along for the ride, we've got years more to come!
    I'll go start on setting up the other thread, there's 16 more posts on this thread, so feel free. Just keep the last one for me please, for a link to the next thread. :)  I'm doing a second render of the challenge combination, would love to start the next thread featuring your renders. Perhaps showcase MM items, I'm picking up some nice stuff in that PC+ for a day.
    By
  • Hair I.D Please
    Looking for the short blonde hair in the main promo image please MRL Brienne for Victoria 8 | 3D Models and 3D Software by Daz 3D
    By
  • Historical Wheelchairs
    This is probably a bit niche, but I'd love to see some historical wheelchairs, like the ones in this Science Museum article about early self propelled wheelchairs, and mechanical chain driven chairs (I'd love to see the Queen Victoria pony powered wheelchair too, but let's face it, there's niche and there's 'only one person will buy this.')
    The article is below. I think it could be awesome fun to see some historical/steampunk wheelchair content.
    The Science Museum's History of the Wheelchair Article
    By
    Jon_KJ Jon_KJ March 2021 in Product Suggestions
  • Deleted the empty expression files from G8.1 but expressions are still not working.
    fred9803 said:
    This thread here discusses the expressions issue. See if you are following the right procedure.
    Thanks! I think I might have figured it out with the help of that thread.
    By
    Sera Sera March 2021 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
