Prop Painter quick question
This looks like a great and easy to use scattering tool like the one in Unreal Engine, and I'm glad to see Stonemason making such useful plugins now. Does anyone happen to know if it's designed for DAZ Studio 6 though, or will it work with older versions like 4.24?  Thanks very much.
  • PaulaDeggPaulaDegg Posts: 44
    It works fine with 4.24, as you can see with this image. Over one thousand instances, I might have gone a bit mad, hahaha
    1600 x 2000 - 3M
  • SnowSultanSnowSultan Posts: 3,848
    Thank you, I had not checked that thread.  Haha, that looks great though Paula, and I can't imagine placing all of those by hand.   ;)
  • it work yes on 4.x and 6 and it very funny to use!  Thanks Stonemason you did a great toy with that
  • RandWulfRandWulf Posts: 243
    Why does it not show up in tools when I try to install in in DS 6?  Installs perfectly in DS 4.
  • jmucchiellojmucchiello Posts: 2,698
    edited October 29
    I ran the installer twice. Once for DS4 and once for DS6. DS6 can see the plugin. DS4 can't. Nothing in Tools. Nothing in About Plugins.
    Setup.exe did not report any errors. Both times it said everything was fine.
    Post edited by jmucchiello on
  • StonemasonStonemason Posts: 1,309
    Thanks for letting me know, and sorry for the hassle. Can you both tell me the exact Studio versions you’re using, whether they’re general release or beta, and which folders you selected when installing Prop Painter? RandWulf, is it listed in About Installed Plugins under the Help menu in DS6, or missing there too?
  • ArtiniArtini Posts: 11,032
    Prop Painter works on terrains created with UltraScenery 2
    Finally one can easily place objects visually on such terrains.
    UltraScenery2 + Prop Painter + MatineeFX = Awesomeness
    https://www.daz3d.com/ultrascenery2-realistic-landscape-system
    https://www.daz3d.com/prop-painter
    https://www.daz3d.com/matineefx
  • I hope this doesn't sound churlish, as it's not meant to be, but ... I'm saddened it took DS4 to end and the appearance of DS6 for it to be realised that this could be done in DS4. It would have been wonderful to be able to do this years ago in DS4.. BUT it's fantastic that we can do it now. Regards, Richard.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,835
    edited October 29
    I admit I am waiting for the other 2 by Totte and Umblefugly as in no hurry
    want to see the advantages and disadvantages of all
    for example, I have UltraScenery2 and not used it yet in spite of owning it for months!!
    I had to uninstall the DS4 version and install it again (after trying repair a couple times) and it finally installed. Now to actually find the time to use it.
    I'm sure there's a good reason. And I'd like to learn it. Why isn't the panel a docked panel?
    Hi, it is version 6.25.2026.14722 (64 Bit) and it does not show in About Installed Plugins,    It tries ti install to C:\Program Files\DAZ 3D\DAZStudio6.
    I just tried a different folder in my 2nd content folder, and that did the trick == I can see it now in both Tools and About Installed Plugins
    edited October 31
     honestly there's no good reason at all, I just didn't consider it, I tend to work with floating panels more often than not, will keep it in mind for future projects and possible updates for PP
    Good to see you and RandWulf got it working!
    Post edited by Stonemason on
    I wish I could do floating panels, but I only have one monitor and that isn't conducive to floating dialogs.
