I had one and used to join tape in loops, disable the erase head (forgotten how) and overdub loops singing rounds, harmonies, playing my recorder (the plastic flute type not the tape)
I can't remember which episode it was, but I've seen it twice now. The best I remember is he says the name "Wendy", follows it up with a bunch of flashing love-heart emoticons on the screen, and followes that by putting a bunch of cats on the screen. Pretty sure it was meant to represent Wendy > Loves > Cats ;-)
I'll let you know if I ever come across it again, cause I'm pretty sure it was you he was referring to. Maybe he knows you from your quirky YouTube stuff, since he often mentions others as part of the style of his videos.
Regards the turntable, yeah that's quite a bit older than the one I had, I think the Fidelity HF42 was a late 70s design that also enjoyed popularity in the 80s. Anyway, I suspect we're about to get a lecture on signal-to-noise ratio pretty soon unless we get back on topic, so I suppose we better had before the next page hits :-P
I don't even use that name on Youtube though
I imagine there are many Wendys out there and most decent people love cats
as for thread topic, some threads are more enforced than others as long as we stay away from so called controversial matters
remixing your art with AI however definitely applies to music too, so music nostalgia and innovation are a part of that subject
I use Nano Banana to tweak my renders and give them a more cinematic look, especially when I want quick results or don't have hours to spend on rendering. This is a great workflow, especially for those who create visual novels or comics.
With the right prompts, it makes fine adjustments without distorting the original image at all. Here is just a quick example of what I mean.
Some might call it laziness, but when you lack a high-end GPU with massive VRAM, tools like this are a lifesaver."
Perhaps he saw you comment on a piece of gear on a forum somewhere where you use that name. I dunno, but if you have a synth or some other piece of audio gear, that might even give a clue as to what episode I saw it in, since it might be related to a piece of gear you own, and that he did a video about.
Sure, it might not be you. But who else do you know who goes by the 'Wendy Loves Cats' phrase?
You're the only one I know!
never watched his videos until now and don't go on other forums
just seems unlikely as I don't mention synths really in my videos though I do have a Roland Gaia plus several ordinary electronic keyboards and have sometimes played them along with VSTs with my Midi controller as background music
not made a thing about it though, doubt anyone knows other than the unrelated Melody Assistant Virtual Singer videos I got a bit of notoriety over how ear torturing they were
those are pure midi file driven, yes I compose many bad midi tunes with it
it uses a musical score, as a pianist, I cannot work with piano roll format at all
just seems unlikely as I don't mention synths really in my videos ...
I think he meant Wendy from the Prince band The Revolution. That's my guess.
"Wendy Ann Melvoin (born January 26, 1964) is an American guitarist and singer-songwriter, best known for her work with Prince as part of his backing band the Revolution, and for her collaboration with Lisa Coleman as one half of the duo Wendy & Lisa."
Again, that's a corrective measure and it's never the same as shooing (or in this case rendering) a scene at the correct shutter speed to start with.
Bear in mind that in order to do what they do, A.I. models must have an internal grasp of Frame Rate, Shutter Speed, ISO. F-stop etc, so the question is how do you get at those parameters in order to render out something professional enough to either composite or match real footage?
Since I never see these options, I'm hoping that it would undertand such instructions. I've seen a video where an A.I. model understood lens type (which is promising), but that's not nearly enough for producing output suited to professional video work, or for producing something you can throw into DaVinci to use in an optimal, specifically intended way.
Have you looked at some of the ComfyUI workflows available within ComfyUI interface?
Some of the workflows actually have camera controls.
There is also a workflow from Avalon on YouTube (I bought his AI package, great set with seeds, workflow, prompt engineering, starter images, audio tracks for folley, music , speech, action etc).
Some interesting tricks is stating the camera model and type being used, depending on the AI model you use and it's awareness of real world cameras, you can prompt in or out motion blur. Set camera back information and more, not just lens.
There are a few real world camera assets here in the Daz store that can make a difference in your quest. Lots of experimenting with different camera settings and you might be able to get what you're looking for.
@BarefootUptoMySoul
On the plus side, it means that Evil Onion is safe around Richard!
@Tugpsx
Thanks for the heads-up on that, and I have to say that's the most promising thing I've heard so far in that respect. The moment you mentioned being able to set "Camera Back" as well as lens properties, a huge smile crept across my face!
Absolutely, I'm planning to use ComfyUI. In fact I'm learning A.I. faster than I otherwise would be by watching videos about ComfyUI. I've never seen the sort of tool you describe, but man, I'm damn glad to hear that one exists since I think the whole system would be very crude and unprofessional without it.
Do you know the name of the ComfyUI tool that allows you to set that sort of stuff?
Also, is there a term that should be used to search for that specific type of node?
Check out Comfyui-prompt-camera-assistant, it should get you going.
I still have my mother's reel to reel tape player somewhere - now that's '60's nostalgia for you.
Had one like that only it was light green with dark green specks
Had one until apartment fire destroyed it in December of 2012
Ha! Ours had the green bottom and the white top.
I figured it had to be pretty common when I image searched it
flecks better describe it than houndstooth though, my memories are sometimes very inaccurate
I know we wore clothing with that pattern too
so right on topic IMO
And they are so durn adorable.
so weird how the AI added text to every single shot in this video
in spite oof having start and finish frames without
this set, Elven Village for DS Iray by powerage
has had the same issue using AI animation before, it must remind the AI database of a game
You have so much fun. Looks great.
and my username isn't unique
just luvs instead of loves and the z on catz
full circle
AI imitation of miniatures being used in movie production
Has anyone already tried the new AI based render engine on R'hub?
I don't interact with other YouTubers much
just a few Reddit Reading channels
others, I find people get angsty easily
and don't have comments enabled on my main channel for the same reason
so its pretty much less than zero, never watched a single one of his videos until you linked him
Just send him a message and ask. Lol
I need to knooooowwwwwww......argghhhh
And don't hate me. I got the Wendys confused. It's Wendy Carlos the synthesizer pioneer.
Even a google search shows her with her cat. lol
Correction: EVERY picture shows her with her cat.
Mystery solved.
as I said repeatedly
lots of Wendys love cats
thats why my username is luvs and catz
wendylovescats is pretty common
Or even more common would be how many cats love Wendy >•<
that, is heavily edited and that strobe effect is layers
I have done it myself using animated gifs
there are AI models that specifically remove motion blur
Topaz Video AI being the top one
I have never rendered motion blur in DAZ Studio either...
I doubt many modern cinematographers do either, nowadays everything is added in production
easier to edit in aberrations than remove them
only homemovies have motion blur and photographers using film and a longer exposure
postwork is a thing
Chinatown by Stonemason, oldie but a goodie
PromptCameraAssistant
Inputs
Thanks, I did not know about that.
