Star Trek Builders Unite 7: The Continuing Mission
1…1920222425…101
  • mdbruffymdbruffy Posts: 2,345
    I sent you a PM.
    scatha said:
    One chair, divided in elements that are easily switched off / made invisible.
    I assume you have shaders for these, since DS ones will not work for you?
    Send me a mail addie I can send the package to for you?
  • Realized I hadn't posted any progress here on my little project. So we have a 'cast' photo, my security chief and ship's counselr on their way to greet the new first officer, said first officer getting into an argument in engineering with the alien chief engineer, our security chief testing the 'new' transporter unit, our flight navigator in his quarters before they get renovated so he's not sharing anymore, and finally our Captain leaving the holodeck with the ship's Andorian Operation officer and getting some unexpected Vulcan sass from the ship's doctor in the process.
    These are all in the order I rendered them up. The holodeck one was post my Windows 10 upgrade this weekend. It took 4 hours to render but it's using the time much better than it was previously.  Almost no grain in the pic now. I did manage to do up the Republic in her right numbering and lettering but I don't have a proper render of it to share quite yet.
    I rendered all but the bridge from my 'stage' set. I built up the corridors like I'd shown before and I'll share that, sans any of the rooms, once I get it cleaned up a bit. I'm saving the rooms as loadable objects later to cut the scene sizes down. The bridge and the observation lounge are all going to be on their own 'set'. I will end up having to not load engineering to load up my cargo bay, although I'm toying with letting it latch on to where I dropped the holodeck. The goal is to set it up to render multple shots while I'm at work since it takes so long to render in iray.
    And yes, I am swapping out thos chairs in our Ensigns quarters for the other model. I compeletely blitzed on that when I was dropping them in before.
    I am going to have to do up a Constitution hallway set up though to attach to the same quarters. I probably won't attach engineering though. I'll only need the quarters and hallways and maybe the torpedo bay, but I've been thinking about the big open crew lounge from TMP though as well. I'm thinking I might move that elsewhere though just so I don't have to do a massive edit.
    3200 x 1800 - 573K
    3200 x 1800 - 917K
    3200 x 1800 - 729K
    3200 x 1800 - 905K
    3840 x 2160 - 1004K
    3840 x 2160 - 660K
    All of these are looking great so far! I'm really excited to see where the story goes! laugh
    edited August 2015
    ashe5k, it's all looking like it's going to be intresting.
    Post edited by mdbruffy on
    Tonight's Update. Now for the other work stations.
    1269 x 787 - 273K
  • scathascatha Posts: 756
    mdbruffy said:
    I sent you a PM.
    You have mail.  :)
    Let me know if it arrived and works in good order.
    Got it. Going to try it out now. :-)
    scatha,check your e-mails, please.
    scatha said:
    mdbruffy said:
    I sent you a PM.
    You have mail.  :)
    Whoops, corrected file in the mail
    Just got it. will check it right now.
    Should be the right one, even included the mtl file for your use in poser and double checked I had the right one.
    edited August 2015
    I think they'll do okay. Thank you!
    1269 x 787 - 101K
    You're welcome, Mads.  :)
    Hey, scatha, it's now UV mapped and textured- except for the arm command panels- I'll get those tomorrow.
    1516 x 1592 - 469K
    I do really like that raised level for the commander's chair. It looks great.
    And thank you mdbruffy and Night-Forager. I imagine this is going to take me a few months to get it all rendered and assembled.
    Great, looks good, mate. That'll finish up that bridge of yours.  :)
    Yes, it will. :-)
  • Night-ForagerNight-Forager Posts: 130
    edited August 2015
    And here it is, the U.S.S. Tobias, NCC-101593.
    I did my best to match the color scheme of the Venture-class update from Star Trek: Online.
    1280 x 720 - 375K
    1280 x 720 - 223K
    1280 x 720 - 132K
    1280 x 720 - 268K
    Post edited by Night-Forager on
    Your registry numbers on the underside of the saucer look  a little faint, but otherwise, it's looking good.
    scatha, the chairs are in place and they raise the whole set to a new level. Thanks again!
    1880 x 1920 - 1M
    Awesome, looks great, Mads!  :)
    wink
    Just give me a holler if you need anything else on future projects, I enjoyed this. :)
    Okay.
  • So, does anyone have any advice on destroying that wonderful Torpedo set mdbruffy made up and for the most part re-creating the aftermath of the phaser hits in Wrath of Khan?
    I'm thinking a bulk of the left wall will be gone with torn metal top and bottom and a view in between out the side of the nebula. The fire supression system should have kicked in and doused it but obviously there will be smoke.  All we ever see of it in the film is the damage to the exterior and the explosion inside.
    Textures. cracks, scorch marksm etc can add alot. You can do it with Photoshop brushes:
    http://naldzgraphics.net/freebies/crack-brushes-for-photoshop/
  • Robert FreiseRobert Freise Posts: 4,701
    Grrrr forum gremins strike again no updates
    Have you bookmarked the thread and then set up your notifications setting in your profile?
    Another update. The back console's in place. Just have one more model to make and this one'll be done.
    1269 x 787 - 285K
    edited August 2015
    Yes I have
    I'll get updates regualry for a while then it'll start to skip one or two posts or more then it stops until I come back and unsubscribe and resubscribe then the process starts again
    Post edited by Robert Freise on
