Adding to Cart…
Update / 04.03.2024
Update: III
Update ________ 08.03.2024
Can I ask what you render with? These environments look fantastic.
Hexagon can help make log cabins too.
@ Hexagon can help make log cabins too.
Nice to see someone who builds a good job their log cabin. I currently use Lumion, Twinmotion and Unreal and switch between the programmes.
INFO:
http://www.bruder-aural.com/00_-09.08.2024_-001-00_-architektur_-gebaeude_-022-01.html
The work above shows Twinmotion
Update of a model, it is checked for errors, here these minimalist views help us a lot.
Own designs and models / Low-poly style / system-friendly
16 residential units, 2 building complexes, independent texture nodes.
INFO_ http://www.bruder-aural.com/01_-16.03.2024_-004-00_-001...
Current project
Great models nova
I also like to make lowpoly models, notice render times are low too,but if you put on several channels hires photorealistic textures to make clothes model look realistic maybe has less impact on render speed
Thanks, yes that's right, I prefer 2k textures. For detail rendering, I go up to 4k, so you can balance it nicely.
I'm lucky enough to have access to a second fast computer for large projects, although I have to put my name on a small waiting list, but that's no problem. The aim is for models to run on small systems, too. You should never look at my models individually, they are always put together in modules so that they can walk in and around the buildings without any problems, as is appropriate for VR. Many people build chocolate facades and then there's nothing behind the backdrop - we don't want to go there and that's the wrong way.
A model should always have 360° ends !
Once I had lan with many single computers, original purpose was for animation: 4 computers = cut rendering in 1/4 time
But my workflow changed to start with one project, start slow rendering on one machine,while switch to work on something else on another computer, modelling yet another 3d object or make textures
Now I have fewer multicores laptops more powerful instead so I can work with hexagon while some cores render
I can also work on textures for my 3dmodels on my tablet anywhere
Villa concept / DAZ 3D-Hexagon
http://www.bruder-aural.com/02_-30.03.2024_-005-00_-001-00_-architektur_-gebaeude_-034-00.html
Presence station area gets an update
New base foundation for 1000x1000 buildings.
INFO_ http://www.bruder-aural.com/03_-28.04.2024_-000-00_-005-01_-1000x1000_-art.html
Boolean execution can be saved, but when exporting, the system still crashes.
Is this known? The chances are 80% for a crash, tested on 3 systems.
Interesting, The newer version of Hexagon appears to be more stable. Check for update.
Hi, it is more stable, but again we have the bug that it often crashes when we use boolean method.
OK, we'll now try the newer beta version
Hexagon as an installation version as a file on the hard disk
We would like to have this as a download file on the hard disk, is there a possibility? Currently it is only available in DAZ Install Manager (64-bit), where I can only move it back and forth, but not download it separately? We bought Hexagon a long time ago and have a product key
Feedback, the latest version is much more stable. We have tested things that always crashed, but not this one. Thanks for the tip, we didn't realize that there was a newer version.
OK, unfortunately I see: It is a pity that Hexagon cannot be installed independently without the Install Manager.
This BETA version is not available as a standalone installer. It must be downloaded and installed using Install Manager.
Gate for new O-foundation 1000x1000 m
great work
Thank you very much Fettbemme, I finally have a little more time this week and am already looking forward to the next project.
Hexagon / recovery room.
INFO_ https://www.bruder-aural.com/05_-008-00_-raeume_-000-00_-raum-00_-000-00.html?fbclid=IwY2xjawElzEBleHRuA2FlbQIxMAABHdapcyxVB_meVQH4Hd72ScB2iXgmWPJyPIg6AYpTVZLBrgazAFROFhjfbQ_aem_hB8X1zj3vrl-ei1F3xvkMg
Once to Daz and again to Hexagon
Scene_ The model is not yet finished, it shows a two-storey fashion boutique, the interior work has begun. The whole thing is designed for VR tours. Everything behind the building has also been worked out and is accessible. I will create a small brick pond in front of the entrance to the building.
INFO ____ http://www.bruder-aural.com/000-00_-005-02_-1000x1000...
Wow
Projekt_ Personen in Twinmotion mit KI und PS bearbeiten.
Gebäude: Eigenes / Hexagon
Person: Artstation (Photogrammetrie) https://www.artstation.com
Twinmotion: 2023.2.3
KI (Spalte): Mindjorny + Krea
Zyklen: 4 (Anzahl der Durchläufe der KI)
PS+NIK ( https://nikcollection.dxo.com/de/ )
INFO_ https://www.fotocommunity.de/.../nova17-wg-2.../2215844
This is awesome work and great promos for Hexagon.
Thank you, that's exactly the goal, I'm currently on Facebook and many people there don't know Hexagon. I hope to make it better known.
Presentation surface with turntable for objects
Twinmotion 2023.2.3
Own model and 3D Scan
1 image was processed with KI+PS+NIK
