Hex Gallery
1262728293032»
  • NovaNova Posts: 220
    edited March 4
    Update / 04.03.2024
    1904 x 881 - 188K
    Post edited by Nova on
    edited March 8
    Update: III
    Update ________ 08.03.2024
    2800 x 1080 - 299K
    2800 x 1080 - 375K
    2800 x 1080 - 269K
    2800 x 1080 - 340K
    2800 x 1080 - 270K
    2800 x 1080 - 396K
  • FirstBastionFirstBastion Posts: 7,544
    Can I ask what you render with? These environments look fantastic.
    Hexagon can help make log cabins too.
    edited March 10
    @ Hexagon can help make log cabins too.
    Nice to see someone who builds a good job their log cabin. I currently use Lumion, Twinmotion and Unreal and switch between the programmes.
    INFO:
    http://www.bruder-aural.com/00_-09.08.2024_-001-00_-architektur_-gebaeude_-022-01.html
    The work above shows Twinmotion
    edited March 16
    Update of a model, it is checked for errors, here these minimalist views help us a lot.
    Own designs and models / Low-poly style / system-friendly
    16 residential units, 2 building complexes, independent texture nodes.
    INFO_ http://www.bruder-aural.com/01_-16.03.2024_-004-00_-001...
    3000 x 1200 - 410K
    3000 x 1200 - 364K
    edited March 20
    Current project
    1920 x 1080 - 226K
    3000 x 1200 - 834K
    3000 x 1200 - 658K
    3000 x 1200 - 1M
  • mach25mach25 Posts: 256
    Great models nova yes
    I also like to make lowpoly models, notice render times are low too,but if you put on several channels hires photorealistic textures to make clothes model look realistic maybe has less impact on render speed
    edited March 23
    Thanks, yes that's right, I prefer 2k textures. For detail rendering, I go up to 4k, so you can balance it nicely. smiley
    I'm lucky enough to have access to a second fast computer for large projects, although I have to put my name on a small waiting list, but that's no problem. The aim is for models to run on small systems, too. You should never look at my models individually, they are always put together in modules so that they can walk in and around the buildings without any problems, as is appropriate for VR. Many people build chocolate facades and then there's nothing behind the backdrop - we don't want to go there and that's the wrong way.
    A model should always have 360° ends !
    edited March 24
    Once I had lan with many single computers, original purpose was for animation: 4 computers = cut rendering in 1/4 time
    But my workflow changed to start with one project, start slow rendering on one machine,while switch to work on something else on another computer, modelling yet another 3d object or make textures
    Now I have fewer multicores laptops more powerful instead so I can work with hexagon while some cores render
    I can also work on textures for my 3dmodels on my tablet anywhere
    Post edited by mach25 on
    edited April 2
    3500 x 1200 - 809K
    3500 x 1200 - 639K
    3500 x 1200 - 810K
    3500 x 1200 - 870K
    3500 x 1200 - 660K
    edited April 26
    Presence station area gets an update
    3200 x 1200 - 303K
    edited April 28
    New base foundation for 1000x1000 buildings.
    INFO_ http://www.bruder-aural.com/03_-28.04.2024_-000-00_-005-01_-1000x1000_-art.html
    1902 x 863 - 215K
    edited April 28
    Boolean execution can be saved, but when exporting, the system still crashes.
    Is this known? The chances are 80% for a crash, tested on 3 systems.
    1607 x 853 - 105K
    1245 x 864 - 78K
    284 x 122 - 8K
  • TugpsxTugpsx Posts: 734
    Interesting, The newer version of Hexagon appears to be more stable. Check for update.
    edited April 29
    Hi, it is more stable, but again we have the bug that it often crashes when we use boolean method.
    OK, we'll now try the newer beta version
    524 x 153 - 14K
    edited April 29
    Hexagon as an installation version as a file on the hard disk
    We would like to have this as a download file on the hard disk, is there a possibility? Currently it is only available in DAZ Install Manager (64-bit), where I can only move it back and forth, but not download it separately? We bought Hexagon a long time ago and have a product key
    edited April 29
    Feedback, the latest version is much more stable. We have tested things that always crashed, but not this one.  Thanks for the tip, we didn't realize that there was a newer version.
    OK, unfortunately I see: It is a pity that Hexagon cannot be installed independently without the Install Manager.
    This BETA version is not available as a standalone installer. It must be downloaded and installed using Install Manager.
    985 x 720 - 58K
    edited May 16
    Gate for new O-foundation 1000x1000 m
    3200 x 1200 - 376K
    3200 x 1200 - 729K
    3200 x 1200 - 605K
