[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]
1679111220
  • RiverSoft ArtRiverSoft Art Posts: 6,962
    kerry said:
    RiverSoftArt said:
    kerry said:
    Firstly the problem is my fault, I didn't read the instructions, just jumped right in.
    I created a custom conversion, but didn't do it properly,
    1) I never used it from the scripts menu just straight from smart content. Instructions say that's important.
    2) I instructed it to start converting without correctly setting the output directory (I think that was the mistake i made)
    The result was a perfectly great converted custom character but G9 in general stopped working as expected.
    Now any new file with a new G9 loaded gives me an error, as does any store-bought G9 character or newly converted G9 character.
    The error is Duplicate formulas found in files. make sure the content is properly installed. See log for more
    log and other Details are attached.
    I then have to press a dialogue box to get the character to load which it then works fine. However, I can't just let the script do its thing and convert a bunch at a time and that is where this niggle becomes a real annoyance.
    I tried uninstalling and reinstalling.
    Any help fixing would be greatly appreciated.
    I'm open to the idea it might be an unrelated coincidence. It's just G9 was working ok before and not after so naturally linked them.
    I paid penance for my mistake when I finally read the instructions before converting 30 male characters and had to press ok dialogue twice in the process for each. so had to supervise the script for 2 hours
    BTW, Overall I'm really very happy with the product.
    Where did you specify the output directory?  I think you probably used the "My Daz 3D Library" and something got overwritten?  The output directory should never be into the main library.  It should be the "My Library".  I think you need to reinstall Genesis 9 and possibly G9 Starter Essentials.
    Thanks, fixed it, I somehow selected a folder that wasn't in any of my Daz Folders but it's now in My Library and all is working as it should be.
    Awesome!  I am glad you fixed it.
  • necroscensionnecroscension Posts: 128
    edited June 2023
    Material Suits updates are out! It appears that the suits with anatomical elements are working with shape dials/presets! Thanks sickleyield!
    Post edited by necroscension on
  • N-RArtsN-RArts Posts: 1,609
    RiverSoftArt said:
    N-RArts said:
    I'm trying to convert an 8.1 character, but the conversion hangs on ERC Freezing: Neck Size. Which means the program becomes unresponsive, and I have to force close Daz Studio.
    Where are converted morph files saved to in the data folder? I have to delete them and start again.
    What does the Daz Log say?  If you bring up the Daz Log (Help->Troubleshooting->View Log File...) in Notepad++, Notepad++ will detect when the log file changes so you can get all the messages DS sent out before it hung?  It might be that it hung in a different place.
    As far what happens after ERC freeze, the next major steps are creating the character property, saving the morphs, copying the materials, and then finally saving the character.
    I've uploaded two logs (just in case you want more info). One for the Character Converter using G8.1F. The other is the Custom Character Converter using G8F.
    With the Custom Character Converter I had an infamous "random restart", when Daz Studio became unresponsive. It crashed when the converter came across one of the philthrum morphs.
    This is the last information when the Character Converter Log crashed:
    2023-05-31 04:20:09.638 [DEBUG] ::      Adjust Rigging to Shape = true
    2023-05-31 04:20:09.638 [DEBUG] :: DoERCFreeze Genesis9 Value null  false
    2023-05-31 04:20:09.675 [INFO] :: ERC Freezing: Neck Size
    2023-05-31 04:20:10.339 [DEBUG] :: Setting PBMNeckSize modifier value to 0
    2023-05-31 04:20:10.353 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
    2023-05-31 04:20:10.353 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
    2023-05-31 04:20:10.364 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
    2023-05-31 04:20:10.374 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
    2023-05-31 04:20:10.384 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
    2023-05-31 04:20:10.410 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
    2023-05-31 04:20:10.421 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
    2023-05-31 04:20:10.432 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476
    2023-05-31 04:20:10.443 [DEBUG] :: Setting RSSYG8_1FPBMNeckSize modifier value to -0.1809999942779541
    2023-05-31 04:20:10.455 [DEBUG] :: CreateCharacterControllerProperty Genesis9 Nite 8 1 v2 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541 /Actor/People
    2023-05-31 04:20:10.531 [INFO] :: Creating Character Controller Property: Nite 8 1 v2
    2023-05-31 04:20:10.531 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
    2023-05-31 04:20:10.532 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
    2023-05-31 04:20:10.539 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
    2023-05-31 04:20:10.545 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
    2023-05-31 04:20:10.550 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
    2023-05-31 04:20:10.562 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
    2023-05-31 04:20:10.566 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
    2023-05-31 04:20:10.571 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476
    2023-06-02 02:49:25.621 +++++++++++++++ DAZ Studio 4.21.0.5 starting +++++++++++++++++
    And this is the last of the log info for the Custom Character Converter:
    2023-06-02 03:16:21.460 [DEBUG] ::      Adjust Rigging to Shape = true
    2023-06-02 03:16:21.461 [DEBUG] :: DoERCFreeze Genesis9 Value null  false
    2023-06-02 03:16:21.461 [INFO] :: ERC Freezing: Philtrum Angle
    2023-06-02 03:16:22.262 [DEBUG] :: Setting PHMPhiltrumAngle modifier value to 0
    2023-06-02 03:16:22.270 [DEBUG] :: Setting PBMNeckSize modifier (safename = RSSYG8_1FPBMNeckSize) value to -0.1809999942779541
    2023-06-02 03:16:22.274 [DEBUG] :: AdjustRiggingToShape Genesis9 true true false  false
    2023-06-02 03:16:22.275 [DEBUG] ::      Doing Adjustments...
    2023-06-02 03:16:23.857 [INFO] :: Vert 0
    2023-06-02 03:16:23.873 [INFO] :: Vert 1
    2023-06-02 03:16:23.889 [INFO] :: Vert 2
    2023-06-02 03:16:23.905 [INFO] :: Vert 3
    2023-06-02 03:16:23.922 [INFO] :: Vert 4
    2023-06-02 03:16:23.939 [INFO] :: Vert 5
    2023-06-02 03:16:23.955 [INFO] :: Vert 6
    2023-06-02 03:16:23.971 [INFO] :: Vert 7
    2023-06-02 03:16:23.987 [INFO] :: Vert 8
    2023-06-02 03:16:24.003 [INFO] :: Vert 9
    2023-06-02 03:16:24.019 [INFO] :: Vert 10
    2023-06-02 03:16:24.035 [INFO] :: Vert 11
    2023-06-02 03:16:24.051 [INFO] :: Vert 12
    2023-06-02 03:16:24.067 [INFO] :: Vert 13
    2023-06-02 03:16:24.083 [INFO] :: Vert 14
    2023-06-02 03:16:24.099 [INFO] :: Vert 15
    2023-06-02 03:16:24.115 [INFO] :: Vert 16
    2023-06-02 03:16:24.132 [INFO] :: Vert 17
    2023-06-02 03:16:24.148 [INFO] :: Vert 18
    2023-06-02 03:16:24.164 [INFO] :: Vert 19
    2023-06-02 03:16:24.180 [INFO] :: Vert 20
    2023-06-02 03:16:24.196 [INFO] :: Vert 21
    2023-06-02 03:16:24.212 [INFO] :: Vert 22
    2023-06-02 03:16:24.228 [INFO] :: Vert 23
    2023-06-02 03:16:24.244 [INFO] :: Vert 24
    2023-06-02 03:16:24.260 [INFO] :: Vert 25
    2023-06-02 03:16:24.276 [INFO] :: Vert 26
    2023-06-02 03:16:24.292 [INFO] :: Vert 27
    2023-06-02 03:16:24.308 [INFO] :: Vert 28
    2023-06-02 03:16:24.324 [INFO] :: Vert 29
    2023-06-02 03:16:24.341 [INFO] :: Vert 30
    2023-06-02 03:16:24.357 [INFO] :: Vert 31
    2023-06-02 03:16:24.373 [INFO] :: Vert 32
    2023-06-02 03:16:24.389 [INFO] :: Vert 33
    2023-06-02 03:16:24.405 [INFO] :: Vert 34
    2023-06-02 03:16:24.421 [INFO] :: Vert 35
    2023-06-02 03:16:24.437 [INFO] :: Vert 36
    2023-06-02 03:16:24.453 [INFO] :: Vert 37
    2023-06-02 03:16:24.469 [INFO] :: Vert 38
    2023-06-02 03:16:24.486 [INFO] :: Vert 39
    2023-06-02 03:16:24.502 [INFO] :: Vert 40
    2023-06-02 03:16:24.518 [INFO] :: Vert 41
    2023-06-02 03:16:24.534 [INFO] :: Vert 42
    2023-06-02 03:16:24.551 [INFO] :: Vert 43
    2023-06-02 03:16:24.567 [INFO] :: Vert 44
    2023-06-02 03:16:24.583 [INFO] :: Vert 45
    2023-06-02 03:16:24.599 [INFO] :: Vert 46
    2023-06-02 03:16:24.615 [INFO] :: Vert 47
    2023-06-02 03:16:24.631 [INFO] :: Vert 48
    2023-06-02 03:16:24.647 [INFO] :: Vert 49
    2023-06-02 03:16:24.663 [INFO] :: Vert 50
    2023-06-02 03:16:24.680 [INFO] :: Vert 51
    2023-06-02 03:16:24.696 [INFO] :: Vert 52
    2023-06-02 03:16:24.712 [INFO] :: Vert 53
    2023-06-02 03:16:24.728 [INFO] :: Vert 54
    2023-06-02 03:16:24.744 [INFO] :: Vert 55
    2023-06-02 03:16:24.761 [INFO] :: Vert 56
    2023-06-02 03:16:24.777 [INFO] :: Vert 57
    2023-06-02 03:16:24.793 [INFO] :: Vert 58
    2023-06-02 03:16:24.809 [INFO] :: Vert 59
    2023-06-02 03:16:24.825 [INFO] :: Vert 60
    2023-06-02 03:16:24.841 [INFO] :: Vert 61
    2023-06-02 03:16:24.857 [INFO] :: Vert 62
    2023-06-02 03:16:24.873 [INFO] :: Vert 63
    2023-06-02 03:16:24.889 [INFO] :: Vert 64
    2023-06-02 03:16:24.905 [INFO] :: Vert 65
    2023-06-02 03:16:24.921 [INFO] :: Vert 66
    2023-06-02 03:16:24.937 [INFO] :: Vert 67
    2023-06-02 03:16:24.953 [INFO] :: Vert 68
    2023-06-02 03:16:24.970 [INFO] :: Vert 69
    2023-06-02 03:16:24.986 [INFO] :: Vert 70
    2023-06-02 03:16:25.003 [INFO] :: Vert 71
    2023-06-02 03:16:25.020 [INFO] :: Vert 72
    2023-06-02 03:16:25.036 [INFO] :: Vert 73
    2023-06-02 03:16:25.052 [INFO] :: Vert 74
    2023-06-02 03:16:25.068 [INFO] :: Vert 75
    2023-06-02 03:16:25.084 [INFO] :: Vert 76
    2023-06-02 03:16:25.101 [INFO] :: Vert 77
    2023-06-02 03:16:25.120 [INFO] :: Vert 78
    2023-06-02 03:16:25.136 [INFO] :: Vert 79
    2023-06-02 03:16:25.152 [INFO] :: Vert 80
    2023-06-02 03:16:25.168 [INFO] :: Vert 81
    2023-06-02 03:16:25.186 [INFO] :: Vert 82
    2023-06-02 03:16:25.203 [INFO] :: Vert 83
    2023-06-02 03:16:25.219 [INFO] :: Vert 84
    2023-06-02 03:16:25.235 [INFO] :: Vert 85
    2023-06-02 03:16:25.252 [INFO] :: Vert 86
    2023-06-02 03:16:25.269 [INFO] :: Vert 87
    2023-06-02 03:16:25.285 [INFO] :: Vert 88
    2023-06-02 03:16:25.302 [INFO] :: Vert 89
    2023-06-02 03:16:25.317 [INFO] :: Vert 90
    2023-06-02 03:16:25.334 [INFO] :: Vert 91
    2023-06-02 03:16:25.351 [INFO] :: Vert 92
    2023-06-02 03:16:25.367 [INFO] :: Vert 93
    2023-06-02 03:16:25.383 [INFO] :: Vert 94
    2023-06-02 03:16:25.401 [INFO] :: Vert 95
    2023-06-02 03:16:25.416 [INFO] :: Vert 96
    2023-06-02 03:16:25.432 [INFO] :: Vert 97
    2023-06-02 03:16:25.449 [INFO] :: Vert 98
    2023-06-02 03:16:25.465 [INFO] :: Vert 99
    2023-06-02 03:16:25.481 [INFO] :: Vert 100
    2023-06-02 03:16:25.497 [INFO] :: Vert 101
    2023-06-02 03:16:25.513 [INFO] :: Vert 102
    2023-06-02 03:16:25.529 [INFO] :: Vert 103
    2023-06-02 03:16:25.545 [INFO] :: Vert 104
    2023-06-02 03:16:25.561 [INFO] :: Vert 105
    2023-06-02 03:16:25.576 [INFO] :: Vert 106
    2023-06-02 03:16:25.593 [INFO] :: Vert 107
    2023-06-02 03:16:25.610 [INFO] :: Vert 108
    2023-06-02 03:16:25.626 [INFO] :: Vert 109
    2023-06-02 03:16:25.642 [INFO] :: Vert 110
    2023-06-02 03:16:25.658 [INFO] :: Vert 111
    2023-06-02 03:16:25.675 [INFO] :: Vert 112
    2023-06-02 03:16:25.691 [INFO] :: Vert 113
    2023-06-02 03:16:25.708 [INFO] :: Vert 114
    2023-06-02 03:16:25.724 [INFO] :: Vert 115
    2023-06-02 03:16:25.740 [INFO] :: Vert 116
    2023-06-02 03:16:25.756 [INFO] :: Vert 117
    2023-06-02 03:16:25.772 [INFO] :: Vert 118
    2023-06-02 03:16:25.789 [INFO] :: Vert 119
    2023-06-02 03:16:25.807 [INFO] :: Vert 120
    2023-06-02 03:16:25.823 [INFO] :: Vert 121
    2023-06-02 03:16:25.839 [INFO] :: Vert 122
    2023-06-02 03:16:25.855 [INFO] :: Vert 123
    2023-06-02 03:16:25.871 [INFO] :: Vert 124
    2023-06-02 03:16:25.887 [INFO] :: Vert 125
    2023-06-02 03:16:25.903 [INFO] :: Vert 126
    2023-06-02 03:16:25.920 [INFO] :: Vert 127
    2023-06-02 03:16:25.936 [INFO] :: Vert 128
    2023-06-02 03:16:25.952 [INFO] :: Vert 129
    2023-06-02 03:16:25.968 [INFO] :: Vert 130
    2023-06-02 03:16:25.984 [INFO] :: Vert 131
    2023-06-02 03:16:26.001 [INFO] :: Vert 132
    2023-06-02 03:16:26.018 [INFO] :: Vert 133
    2023-06-02 03:16:26.034 [INFO] :: Vert 134
    2023-06-02 03:16:26.050 [INFO] :: Vert 135
    2023-06-02 03:16:26.066 [INFO] :: Vert 136
    2023-06-02 03:16:26.082 [INFO] :: Vert 137
    2023-06-02 03:16:26.098 [INFO] :: Vert 138
    2023-06-02 03:16:26.114 [INFO] :: Vert 139
    2023-06-02 03:16:26.130 [INFO] :: Vert 140
    2023-06-02 03:16:26.146 [INFO] :: Vert 141
    2023-06-02 03:16:26.162 [INFO] :: Vert 142
    2023-06-02 03:16:26.178 [INFO] :: Vert 143
    2023-06-02 03:16:26.196 [INFO] :: Vert 144
    2023-06-02 03:16:26.212 [INFO] :: Vert 145
    2023-06-02 03:16:26.228 [INFO] :: Vert 146
    2023-06-02 03:16:26.244 [INFO] :: Vert 147
    2023-06-02 03:16:26.260 [INFO] :: Vert 148
    2023-06-02 03:16:26.276 [INFO] :: Vert 149
    2023-06-02 03:16:26.292 [INFO] :: Vert 150
    2023-06-02 03:16:26.309 [INFO] :: Vert 151
    2023-06-02 03:16:26.325 [INFO] :: Vert 152
    2023-06-02 03:16:26.341 [INFO] :: Vert 153
    2023-06-02 03:16:26.356 [INFO] :: Vert 154
    2023-06-02 03:16:26.373 [INFO] :: Vert 155
    2023-06-02 03:16:26.390 [INFO] :: Vert 156
    2023-06-02 03:16:26.406 [INFO] :: Vert 157
    2023-06-02 03:16:26.422 [INFO] :: Vert 158
    2023-06-02 03:16:26.438 [INFO] :: Vert 159
    2023-06-02 03:16:26.454 [INFO] :: Vert 160
    2023-06-02 03:16:26.471 [INFO] :: Vert 161
    2023-06-02 03:16:26.487 [INFO] :: Vert 162
    2023-06-02 03:16:26.503 [INFO] :: Vert 163
    2023-06-02 03:16:26.519 [INFO] :: Vert 164
    2023-06-02 03:16:26.535 [INFO] :: Vert 165
    2023-06-02 03:16:26.551 [INFO] :: Vert 166
    2023-06-02 03:16:26.567 [INFO] :: Vert 167
    2023-06-02 03:16:26.585 [INFO] :: Vert 168
    2023-06-02 03:16:26.601 [INFO] :: Vert 169
    2023-06-02 03:16:26.617 [INFO] :: Vert 170
    2023-06-02 03:16:26.634 [INFO] :: Vert 171
    2023-06-02 03:16:26.649 [INFO] :: Vert 172
    2023-06-02 03:16:26.666 [INFO] :: Vert 173
    2023-06-02 03:16:26.682 [INFO] :: Vert 174
    2023-06-02 03:16:26.699 [INFO] :: Vert 175
    2023-06-02 03:16:26.715 [INFO] :: Vert 176
    2023-06-02 03:16:26.731 [INFO] :: Vert 177
    2023-06-02 03:16:26.747 [INFO] :: Vert 178
    2023-06-02 03:16:26.763 [INFO] :: Vert 179
    2023-06-02 03:16:26.780 [INFO] :: Vert 180
    2023-06-02 03:16:26.797 [INFO] :: Vert 181
    2023-06-02 03:16:26.813 [INFO] :: Vert 182
    2023-06-02 03:16:26.829 [INFO] :: Vert 183
    2023-06-02 03:16:26.845 [INFO] :: Vert 184
    2023-06-02 03:16:26.862 [INFO] :: Vert 185
    2023-06-02 03:16:26.878 [INFO] :: Vert 186
    2023-06-02 03:16:26.894 [INFO] :: Vert 187
    2023-06-02 03:16:26.910 [INFO] :: Vert 188
    2023-06-02 03:16:26.926 [INFO] :: Vert 189
    2023-06-02 03:16:26.942 [INFO] :: Vert 190
    2023-06-02 03:16:26.958 [INFO] :: Vert 191
    2023-06-02 03:16:26.976 [INFO] :: Vert 192
    2023-06-02 03:16:26.992 [INFO] :: Vert 193
    2023-06-02 03:16:27.008 [INFO] :: Vert 194
    2023-06-02 03:16:27.024 [INFO] :: Vert 195
    2023-06-02 03:16:27.040 [INFO] :: Vert 196
    2023-06-02 03:16:27.056 [INFO] :: Vert 197
    2023-06-02 03:16:27.072 [INFO] :: Vert 198
    2023-06-02 03:16:27.088 [INFO] :: Vert 199
    2023-06-02 03:16:27.104 [INFO] :: Vert 200
    2023-06-02 03:16:27.121 [INFO] :: Vert 201
    2023-06-02 03:16:27.136 [INFO] :: Vert 202
    2023-06-02 03:16:27.153 [INFO] :: Vert 203
    2023-06-02 03:16:27.170 [INFO] :: Vert 204
    2023-06-02 03:16:27.186 [INFO] :: Vert 205
    2023-06-02 03:16:27.202 [INFO] :: Vert 206
    2023-06-02 03:16:27.219 [INFO] :: Vert 207
    2023-06-02 03:16:27.235 [INFO] :: Vert 208
    2023-06-02 03:16:27.251 [INFO] :: Vert 209
    2023-06-02 03:16:27.267 [INFO] :: Vert 210
    2023-06-02 03:16:27.283 [INFO] :: Vert 211
    2023-06-02 03:16:27.299 [INFO] :: Vert 212
    2023-06-02 03:16:27.315 [INFO] :: Vert 213
    2023-06-02 03:16:27.331 [INFO] :: Vert 214
    2023-06-02 03:16:27.347 [INFO] :: Vert 215
    2023-06-02 03:16:27.364 [INFO] :: Vert 216
    2023-06-02 03:16:27.381 [INFO] :: Vert 217
    2023-06-02 03:16:27.397 [INFO] :: Vert 218
    2023-06-02 03:16:27.413 [INFO] :: Vert 219
    2023-06-02 03:16:27.429 [INFO] :: Vert 220
    2023-06-02 03:16:27.445 [INFO] :: Vert 221
    2023-06-02 03:16:27.461 [INFO] :: Vert 222
    2023-06-02 03:16:27.477 [INFO] :: Vert 223
    2023-06-02 03:16:27.493 [INFO] :: Vert 224
    2023-06-02 03:16:27.509 [INFO] :: Vert 225
    2023-06-02 03:16:27.525 [INFO] :: Vert 226
    2023-06-02 03:16:27.542 [INFO] :: Vert 227
    2023-06-02 03:16:27.559 [INFO] :: Vert 228
    2023-06-02 03:16:27.575 [INFO] :: Vert 229
    2023-06-02 03:16:27.591 [INFO] :: Vert 230
    2023-06-02 03:16:27.607 [INFO] :: Vert 231
    2023-06-02 03:16:27.623 [INFO] :: Vert 232
    2023-06-02 03:16:27.639 [INFO] :: Vert 233
    2023-06-02 03:16:27.655 [INFO] :: Vert 234
    2023-06-02 03:16:27.671 [INFO] :: Vert 235
    2023-06-02 03:16:27.689 [INFO] :: Vert 236
    2023-06-02 03:16:27.706 [INFO] :: Vert 237
    2023-06-02 03:16:27.722 [INFO] :: Vert 238
    2023-06-02 03:16:27.739 [INFO] :: Vert 239
    2023-06-02 03:16:27.756 [INFO] :: Vert 240
    2023-06-02 03:16:27.772 [INFO] :: Vert 241
    2023-06-02 03:16:27.788 [INFO] :: Vert 242
    2023-06-02 03:16:27.805 [INFO] :: Vert 243
    2023-06-02 03:16:27.820 [INFO] :: Vert 244
    2023-06-02 03:16:27.837 [INFO] :: Vert 245
    2023-06-02 03:16:27.853 [INFO] :: Vert 246
    2023-06-02 03:16:27.869 [INFO] :: Vert 247
    2023-06-02 03:16:27.885 [INFO] :: Vert 248
    2023-06-02 03:16:27.901 [INFO] :: Vert 249
    2023-06-02 03:16:27.917 [INFO] :: Vert 250
    2023-06-02 03:16:27.933 [INFO] :: Vert 251
    2023-06-02 03:16:27.950 [INFO] :: Vert 252
    2023-06-02 03:16:27.967 [INFO] :: Vert 253
    2023-06-02 03:16:27.983 [INFO] :: Vert 254
    2023-06-02 03:16:27.999 [INFO] :: Vert 255
    2023-06-02 03:16:28.015 [INFO] :: Vert 256
    2023-06-02 03:16:28.031 [INFO] :: Vert 257
    2023-06-02 03:16:28.047 [INFO] :: Vert 258
    2023-06-02 03:16:28.063 [INFO] :: Vert 259
    2023-06-02 03:16:28.079 [INFO] :: Vert 260
    2023-06-02 03:16:28.095 [INFO] :: Vert 261
    2023-06-02 03:16:28.111 [INFO] :: Vert 262
    2023-06-02 03:16:28.127 [INFO] :: Vert 263
    2023-06-02 03:16:28.145 [INFO] :: Vert 264
    2023-06-02 03:16:28.161 [INFO] :: Vert 265
    2023-06-02 03:16:28.177 [INFO] :: Vert 266
    2023-06-02 03:16:28.193 [INFO] :: Vert 267
    2023-06-02 03:16:28.209 [INFO] :: Vert 268
    2023-06-02 03:16:28.226 [INFO] :: Vert 269
    2023-06-02 03:16:28.241 [INFO] :: Vert 270
    2023-06-02 03:16:28.258 [INFO] :: Vert 271
    2023-06-02 03:16:28.274 [INFO] :: Vert 272
    2023-06-02 03:16:28.290 [INFO] :: Vert 273
    2023-06-02 03:16:28.306 [INFO] :: Vert 274
    2023-06-02 03:16:28.322 [INFO] :: Vert 275
    2023-06-02 03:16:28.339 [INFO] :: Vert 276
    2023-06-02 03:16:28.355 [INFO] :: Vert 277
    2023-06-02 03:16:28.372 [INFO] :: Vert 278
    2023-06-02 03:16:28.388 [INFO] :: Vert 279
    2023-06-02 03:16:28.403 [INFO] :: Vert 280
    2023-06-02 03:16:28.419 [INFO] :: Vert 281
    2023-06-02 03:16:28.435 [INFO] :: Vert 282
    2023-06-02 03:16:28.452 [INFO] :: Vert 283
    2023-06-02 03:16:28.468 [INFO] :: Vert 284
    2023-06-02 03:16:28.484 [INFO] :: Vert 285
    2023-06-02 03:16:28.500 [INFO] :: Vert 286
    2023-06-02 03:16:28.516 [INFO] :: Vert 287
    2023-06-02 03:16:28.533 [INFO] :: Vert 288
    2023-06-02 03:16:28.549 [INFO] :: Vert 289
    2023-06-02 03:16:28.566 [INFO] :: Vert 290
    2023-06-02 03:16:28.582 [INFO] :: Vert 291
    2023-06-02 03:16:28.598 [INFO] :: Vert 292
    2023-06-02 03:16:28.614 [INFO] :: Vert 293
    2023-06-02 03:16:28.630 [INFO] :: Vert 294
    2023-06-02 03:16:28.646 [INFO] :: Vert 295
    2023-06-02 03:16:28.662 [INFO] :: Vert 296
    2023-06-02 03:16:28.679 [INFO] :: Vert 297
    2023-06-02 03:16:28.695 [INFO] :: Vert 298
    2023-06-02 03:16:28.711 [INFO] :: Vert 299
    2023-06-02 03:16:28.729 [INFO] :: Vert 300
    2023-06-02 03:16:28.745 [INFO] :: Vert 301
    2023-06-02 03:16:28.761 [INFO] :: Vert 302
    2023-06-02 03:16:28.778 [INFO] :: Vert 303
    2023-06-02 03:16:28.794 [INFO] :: Vert 304
    2023-06-02 03:16:28.810 [INFO] :: Vert 305
    2023-06-02 03:16:28.826 [INFO] :: Vert 306
    2023-06-02 03:16:28.842 [INFO] :: Vert 307
    2023-06-02 03:16:28.859 [INFO] :: Vert 308
    2023-06-02 03:16:28.876 [INFO] :: Vert 309
    2023-06-02 03:16:28.893 [INFO] :: Vert 310
    2023-06-02 03:16:28.911 [INFO] :: Vert 311
    2023-06-02 03:16:28.930 [INFO] :: Vert 312
    2023-06-02 03:16:28.948 [INFO] :: Vert 313
    2023-06-02 03:16:28.968 [INFO] :: Vert 314
    2023-06-02 03:16:28.987 [INFO] :: Vert 315
    2023-06-02 03:16:29.005 [INFO] :: Vert 316
    2023-06-02 03:16:29.023 [INFO] :: Vert 317
    2023-06-02 03:16:29.040 [INFO] :: Vert 318
    2023-06-02 03:16:29.059 [INFO] :: Vert 319
    2023-06-02 03:16:29.078 [INFO] :: Vert 320
    2023-06-02 03:16:29.096 [INFO] :: Vert 321
    2023-06-02 03:16:29.115 [INFO] :: Vert 322
    2023-06-02 03:16:29.134 [INFO] :: Vert 323
    2023-06-02 03:16:29.157 [INFO] :: Vert 324
    2023-06-02 03:16:29.176 [INFO] :: Vert 325
    2023-06-02 03:16:29.193 [INFO] :: Vert 326
    2023-06-02 03:16:29.211 [INFO] :: Vert 327
    2023-06-02 03:16:29.229 [INFO] :: Vert 328
    2023-06-02 03:16:29.250 [INFO] :: Vert 329
    2023-06-02 03:16:29.269 [INFO] :: Vert 330
    2023-06-02 03:16:29.286 [INFO] :: Vert 331
    2023-06-02 03:16:29.302 [INFO] :: Vert 332
    2023-06-02 03:16:29.318 [INFO] :: Vert 333
    2023-06-02 03:16:29.334 [INFO] :: Vert 334
    2023-06-02 03:16:29.350 [INFO] :: Vert 335
    2023-06-02 03:16:29.368 [INFO] :: Vert 336
    2023-06-02 03:16:29.384 [INFO] :: Vert 337
    2023-06-02 03:16:29.400 [INFO] :: Vert 338
    2023-06-02 03:16:29.417 [INFO] :: Vert 339
    2023-06-02 03:16:29.432 [INFO] :: Vert 340
    2023-06-02 03:16:29.449 [INFO] :: Vert 341
    2023-06-02 03:16:29.465 [INFO] :: Vert 342
    2023-06-02 03:16:29.481 [INFO] :: Vert 343
    2023-06-02 03:16:29.497 [INFO] :: Vert 344
    2023-06-02 03:16:29.513 [INFO] :: Vert 345
    2023-06-02 03:16:29.529 [INFO] :: Vert 346
    2023-06-02 03:16:29.545 [INFO] :: Vert 347
    2023-06-02 03:16:29.564 [INFO] :: Vert 348
    2023-06-02 03:16:29.580 [INFO] :: Vert 349
    2023-06-02 03:16:29.596 [INFO] :: Vert 350
    2023-06-02 03:16:29.612 [INFO] :: Vert 351
    2023-06-02 03:16:29.628 [INFO] :: Vert 352
    2023-06-02 03:16:29.644 [INFO] :: Vert 353
    2023-06-02 03:16:29.660 [INFO] :: Vert 354
    2023-06-02 03:16:29.676 [INFO] :: Vert 355
    2023-06-02 03:16:29.692 [INFO] :: Vert 356
    2023-06-02 03:16:29.708 [INFO] :: Vert 357
    2023-06-02 03:16:29.725 [INFO] :: Vert 358
    2023-06-02 03:16:29.741 [INFO] :: Vert 359
    2023-06-02 03:16:29.759 [INFO] :: Vert 360
    2023-06-02 03:16:29.775 [INFO] :: Vert 361
    2023-06-02 03:16:29.791 [INFO] :: Vert 362
    2023-06-02 03:16:29.808 [INFO] :: Vert 363
    2023-06-02 03:16:29.824 [INFO] :: Vert 364
    2023-06-02 03:16:29.840 [INFO] :: Vert 365
    2023-06-02 03:16:29.857 [INFO] :: Vert 366
    2023-06-02 03:16:29.873 [INFO] :: Vert 367
    2023-06-02 03:16:29.889 [INFO] :: Vert 368
    2023-06-02 03:16:29.905 [INFO] :: Vert 369
    2023-06-02 03:16:29.921 [INFO] :: Vert 370
    2023-06-02 03:16:29.937 [INFO] :: Vert 371
    2023-06-02 03:16:29.954 [INFO] :: Vert 372
    2023-06-02 03:16:29.971 [INFO] :: Vert 373
    2023-06-02 03:16:29.987 [INFO] :: Vert 374
    2023-06-02 03:16:30.003 [INFO] :: Vert 375
    2023-06-02 03:16:30.019 [INFO] :: Vert 376
    2023-06-02 03:16:30.040 [INFO] :: Vert 377
    2023-06-02 03:16:30.056 [INFO] :: Vert 378
    2023-06-02 03:16:30.072 [INFO] :: Vert 379
    2023-06-02 03:16:30.088 [INFO] :: Vert 380
    2023-06-02 03:16:30.104 [INFO] :: Vert 381
    2023-06-02 03:16:30.120 [INFO] :: Vert 382
    2023-06-02 03:16:30.137 [INFO] :: Vert 383
    2023-06-02 03:16:30.155 [INFO] :: Vert 384
    2023-06-02 03:16:30.171 [INFO] :: Vert 385
    2023-06-02 03:16:30.187 [INFO] :: Vert 386
    2023-06-02 03:16:30.204 [INFO] :: Vert 387
    2023-06-02 03:16:30.223 [INFO] :: Vert 388
    2023-06-02 03:16:30.240 [INFO] :: Vert 389
    2023-06-02 03:16:30.257 [INFO] :: Vert 390
    2023-06-02 03:16:30.274 [INFO] :: Vert 391
    2023-06-02 03:16:30.411 [DEBUG] ::      Adjust Rigging to Shape = true
    2023-06-02 03:16:30.411 [DEBUG] :: DoERCFreeze Genesis9 Value null  false
    2023-06-02 03:16:30.411 [INFO] :: ERC Freezing: Neck Size
    2023-06-02 03:16:31.216 [DEBUG] :: Setting PBMNeckSize modifier value to 0
    2023-06-02 03:16:31.224 [DEBUG] :: CreateCharacterControllerProperty Genesis9 N-Ra G9 Nite RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541 /Actor/People
    2023-06-02 03:16:31.225 [INFO] :: Creating Character Controller Property: N-Ra G9 Nite
    2023-06-02 03:16:31.226 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
    2023-06-02 03:16:31.226 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
    2023-06-02 03:16:31.237 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
    2023-06-02 03:16:31.247 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
    2023-06-02 03:16:31.256 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
    2023-06-02 03:16:31.277 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
    2023-06-02 03:16:31.285 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
    2023-06-02 03:16:31.293 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476
    INSERT "RANDOM" RESTART HERE
    2023-06-02 03:48:15.898 +++++++++++++++ DAZ Studio 4.21.0.5 starting +++++++++++++++++
    txt
    txt
    CharacterCoverter.txt
    162K
    txt
    txt
    CustomCharacter Converter.txt
    964K
  • EboshijaanaEboshijaana Posts: 576
    Naturally, I had to experiment on the update.
    It is not AS broken as pre-update, but not quite the transfer utility level.
    623 x 626 - 77K
    651 x 597 - 62K
  • KeironKeiron Posts: 419
    edited June 2023
    Hi RiversoftArt
    I've just downloaded a recent update
    I have just converted Albany
    I found the nails morphs caused an issue with a thin body, so I dialed out the one that caused the issue may be all these dials could be zeroed by default
    It looks like all the morphs load with gen 9 including the lower versions, it's dificult to see what is what, in my case i see 9, 8 and 8.1 as I have removed all the others
    Adding the original into the scene  showed it was very close in shaping and textures
    The eyelashes were a problem here, the RSSY Genesis Eyelash's were in the wrong place I've attached a render for you to see
    I replaced the RSSY 8 eyelashes with the G9 ones and all is OK I couldnt see a RSSY 8 eyelash
    I couldn't change the eye colour, however, if I replaced the RSSY eyes with the Gen 9 ones or with the RSSY 8 and 8.1  eyes all was then well
    I noticed the converted Actor shows RSSY Genesis 8
    I tried to change the makeup using g9 and g8 but this didn't work, the original 8 has lots of options but I couldn't see these
    Keep up the good work
    801 x 887 - 343K
    Post edited by Keiron on
    I also exposed a few TU settings in the data/RiverSoft Art/Common/RSG8G9CharacterConversionConstants.dsa file.  You could try setting some of those.
    Keiron said:
    Hi RiversoftArt
    If you want to have them removed by default, edit the data/RiverSoft Art/Common/RSG8G9CharacterConversionConstants.dsa file (in a text editor), the variable
    var MORPH_FILTERS           = [
      'mouthrealism',
      'eyelash',
      'height',
      'navel'
    specifies the names of morphs to not convert.
    edited June 2023
    Since Daz log usually lags 1-3 messages behind when it crashes, it makes it a little difficult to figure exactly when it crashed.  However, it either crashed during all the steps to create the controller property or just after.  Thankfully, we can figure that out.
    Go to data/RiverSoft Art/Common/RSG8G9CharacterConversionConstants.dsa and load it in a text editor.  Change:
    var BREAK_POINT             = "";
    to
    var BREAK_POINT             = "CHARACTER PROPERTY";
    Run again.  If it crashes, please post the log.  If it DOESN'T crash, the script will stop after creating the character controller.  If that step was successful, it tells me more.  Please post the log. (BTW, make sure to change the BREAK_POINT variable back or every conversion will always stop at this point)
    Post edited by RiverSoft Art on
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    Unfortunately, the update does not fix the mac issue. The leading / is still missing in the path.
    edited June 2023
    With the converter, I've notice most of the models I have do not use FBM/FHM in their morph naming but use Head or Body instead. I have attempted to resave the name of the morphs to start with FHM/FBM, but still have issues because sometimes I wind up having doubled morphs. Was it ever considered to see if the morph name includes Head or Body as an OR statement?
    edited June 2023
    RiverSoftArt said:
    Keiron said:
    Hi RiversoftArt
      'mouthrealism',
      'eyelash',
      'height',
      'navel'
    Ah, so we can use this to skip converting HD morphs on characters where HD is part of the preset. (Or save the character without the HD morphs as another character preset...)
    Okay, I've spent a few hours testing the converter with the file edited. I tried using the EXACT same settings between the converter and TU.
    Thoughts;
    1. Regardless of settings, the Converter changes the body of g9 while TU leaves it alone.
    2. Could the 'reverse source shape from target' setting affect the above?
    I will try to use my self-made clone for the converter, just to see if it would affect things.
    613 x 618 - 79K
    617 x 616 - 81K
  • jepegraphicsjepegraphics Posts: 901
    At least DAZ Studio doesn't crash anymore whe loading the Material Suit, that's a big step forward!
    Now only someone who can explain how to get the shaping morphs of the MASC Gens to show up - any suggestions? The basic shape morphs in the genitals are there, but not the various expansions from other merchants.
  • kirbawirbakirbawirba Posts: 191
    Don't know if this has been addressed yet but when executing the command to install custom actions the popup says "Fa&vorites" instead of just favorites.  Is that intended?
    And the distorted character thing can be slightly mitigated with dialing down some character morphs, but every one I've tried to convert has been misshapen and twisted.  Even in the absence of HD morphs, they need to be adjusted to the point where they resemble the G9 dev model more than anything else.  The material copy is flawless, though.
    carlosgimpera said:
    Laurita said:
    Not exactly a great success. Neither on a stock Aurore 8 (left) nor on a custom character.
    Conversions
    I saw this post and wanted to try Aurore. The only thing I had to do was to turn down the main Aurore Character dial once converted. That makes the character a plain G9 shape with Aurore Mats suit, no wrinkles. Then I just dialed up Aurore head and body morph- just those - and there you have it. HD morph caused issues, so I let it off as well.
    This did not work for me at all. I keep getting the popup to either zero or restore the figure 0's.  Did you?  What did you choose?
  • Lovely product. I'm glad I came here to the forums else I would have NEVER figured out how to solve all the morph distortion that was happening when converting characters. The material suits are excellent as well! I am wondering however... has anyone else run into an issue where they are unable to apply any G8 materials or shaders to the G8 Eyelash Suit?  I've been tinkering with it for about half an hour now on a few converted characters and haven't really been able to make much progress.
    It's truthfully not THAT big of a deal as I can just hide the Eyelash suit and apply a G9 eyebrow product to the character but I was wondering if anyone had found a viable solution for this.
    Another version arrived in DIM today, and that fixed the mac file issue. Thanks a lot @RiversSoftArt
    edited June 2023
    Here is the Aurore G8 conversion
    To correct the corrupt conversion a number of dials are in play
    HD body Body causes Distortion
    HD head Body causes Distortion
    Kayleyss Square Nails causes figure to look like it's unfed for weeks, not sure why this dial is at 100% ?
    FHM Aurore Assymetry changes face completely not just the assymetry
    In the renders below no particular order the original has the RSSY eyelashes in the wrong place, render with RSSY eyelashes removed and render with eyes replaces with g9 ones
    You can't change the eye colour with these RSSY 8 eye's, but you can if you replace them with the g9 eyes or reloading the RSSY eys 8 or 8.1 eyes
    Unable to use the make up options
    Breast up and down controls set to 80% reset to 100 to correct
    Good attempt, keep up the good work
    1920 x 1187 - 618K
    1920 x 1187 - 618K
    1920 x 1187 - 615K
  • JeremionJeremion Posts: 54
    edited June 2023
    RiverSoftArt said:
    Jeremion said:
    I only tried to convert Michael 8.1, and so far I don't get it fine as G9. Issues on the eyes (not well placed, nor good size and when trying to move them with powerpose, they just go out of the head xD) and the morph around the eyes is not OK. So, I don't know really what to do to get better result. I will try again.
    Michael should not be a problem at all.  You do not need the eye dialog.  It sounds like a morph was created on the eyes that are moving them.  Check in \data\DAZ 3D\Genesis 9\Genesis 9 Eyes\Morphs to see if there is an eye morph that could be engaging that messes things up (a quick way is just to rename this directory so none of the eye morphs engage.  Look for this folder under the first directory listed in the Daz Studio Formats section of the Content Directory Manager (which is usually My Library
    Hello,
    Yeah I found that weird too... look. I renamed the "morphs" directory. And retested. Enclosed the screen and below the logs.
    One strange thing : If I load Michael 8.1, everything is fine.
    I see in the log that the converter script copy "BaboonG8M-IrisSize" for any reason? (it is one of the character I tried to convert as well, but I don't have it anymore, I deleted it). Is there a place the script keep its previous work? For sure, BaboonG8M is not used on the original Michael 8.1 lol.
    10:03:35 GMT+0200 (Paris, Madrid (heure d’été)): Executing Script
    10:03:35 GMT+0200 (Paris, Madrid (heure d’été)): Selecting Preset: D:/Daz3D/People/Genesis 8 Male/Characters/Michael 8.1.duf
    10:03:35 GMT+0200 (Paris, Madrid (heure d’été)): Converting character from D:/Daz3D/People/Genesis 8 Male/Characters/Michael 8.1.duf to D:/Daz3D/People/Genesis 9/Characters/Converted/Michael 8.1.duf
    10:03:35 GMT+0200 (Paris, Madrid (heure d’été)): Enabling morphs for asset, D:/Daz3D/People/Genesis 8 Male/Characters/Michael 8.1.duf
    10:03:36 GMT+0200 (Paris, Madrid (heure d’été)): Turbo Loader: 8 morphs were searched for
    0 Enabled (0 failed to enable)
    0 Disabled (0 failed to disable)
    8 unchanged
    0 skipped
    in 221 msecs
    Note: Multiple files may exist for a morph if you use Daz Connect
    10:04:25 GMT+0200 (Paris, Madrid (heure d’été)): Michael 8.1 is of type Actor/Character
    10:04:43 GMT+0200 (Paris, Madrid (heure d’été)): Converting Morphs: BaboonG8M-IrisSize,FHMMichael8_1,FBMMichael8_1,CTRLMichael8_1,PHMMichael8_1HDIris
    10:15:41 GMT+0200 (Paris, Madrid (heure d’été)): Copy Icons from D:/Daz3D/People/Genesis 8 Male/Characters/Michael 8.1.duf to D:/Daz3D/People/Genesis 9/Characters/Converted/Michael 8.1 Genesis 9.duf
    10:15:41 GMT+0200 (Paris, Madrid (heure d’été)): Copy Categories from D:/Daz3D/People/Genesis 8 Male/Characters/Michael 8.1.duf to D:/Daz3D/People/Genesis 9/Characters/Converted/Michael 8.1 Genesis 9.duf
    10:15:41 GMT+0200 (Paris, Madrid (heure d’été)): Execution Complete.
    1358 x 586 - 778K
    Post edited by Jeremion on
    Strange, the fix worked for @w_r_brook_ec9f3e956e.   Can I see the log?  Maybe it is pulling in an old version?  The size of the data/RiverSoft Art/Common/RSG8G9CharacterConversionFunctions.dse is 57,680 bytes (size on disk is different of course)
    You must not buy most of your characters from Daz. smiley  This is a naming convention that has been in place for years.
    Ok, I will make an update to check if the morph name starts with FHM/Head or FBM/Body.
    necroscension said:
    RiverSoftArt said:
    Keiron said:
    Hi RiversoftArt
      'mouthrealism',
      'eyelash',
      'height',
      'navel'
    Or any morph used more than once that causes problems.
    Thoughts;
    The ADJUST_TARGET_BASE constant is the one that sets the 'reverse source shape from target'
    I passed your question onto SickleYield
    Yes, this is intended.  The "&" represents the underscore under the "v" that is used to hotkey to the Favorites window by pressing Alt-v on Windows.
    I would rename your converted morphs directory temporarily so that you are starting from scratch and know that a bad conversion is not affecting anything.  The converted morphs are located in \data\DAZ 3D\Genesis 9\Base\Morphs under the first directory listed in the Daz Studio Formats section of the Content Directory Manager (which is usually My Library)
    Oh good!  I am glad it fixed it.
    edited June 2023
    Select the RSSY Genesis 8 Eyelash Suit.  Go to the Surfaces pane.  Select the RSSY Genesis 8 Eyelash Suit surface.  Double-click on the preset that is for G8 Eyelashes.
    p.s. I am glad you came to the forum and didn't give up.  I am happy you got it working for you.
    Morph Dials are set to the values the G8 version had on conversion.
    Assymetry morphs on the head will not ever work I think.
    To change the eye color, select the RSSY Genesis 8 Eye Suit and load the G8 eyes preset to change.
    To use makeup, select the RSSY Genesis 8 Female Suit and load the G8 makeup preset to change.
    Not sure what you mean here, but morphs that only affect a small portion of the body will also affect the body as a whole
    Jeremion said:
    Hello,
    What do you mean if you LOAD M8.1?  Do you mean just LOAD M8.1 into the same scene or CONVERT M8.1?
    8 unchanged
    0 skipped
    in 221 msecs
    The script works by loading the character and seeing what morphs are being used.  If you load M8.1 into a new scene, look for BaboonG8M-IrisSize, I am sure you will find it (it may be a hidden property though).
    edited June 2023
    Hi I think the G8 is OK, I just looked at all the dials for the nails etc for a standard g8 they are set to 0
    However when you choose the actor the converted character has morph dials at 100%
    Just loaded the original Albany it has Mousso nails at 100%, so the actor is setting the dials differentely, no hd settings in this one
    Hi I had filter by contex on, so it was selecting g9 eyes. In the surface tab, I entered just her name in the search field all is good, otherwise you get everything
    Hi Thank you, I had filter by contex on, so it was selecting g9. In the surface tab, I entered just her name in the search field all is good
    When I loaded both the converted actor and the original, the breasts looked different, so I checked the settings and found that everything looked OK
    From the parameters tab, I looked at the parameters breast up and down and found it was set to min -80% I reset this to -100% then they looked the same
