Fiddling with Iray skin settings...
1568101191
  • Oso3DOso3D Posts: 15,115
    edited April 2015
    The problem, I finally realized, is that the surface is too smooth. Water on skin is often bumpy with droplets or whatnot.
    (I'm having reasonable results using base thin film, not top coat, and making sure the skin has decent bump values)
    Post edited by Oso3D on
  • 8eos88eos8 Posts: 170
    That's interesting....I've been wondering if we should be using thin film for something. :)
    8eos8 said:
    Some more experimentation....I finally got a more noticeable SSS effect by increasing translucency, but the skin tone became a bit darker as a side-effect. Need to play with the translucency and transmission colors more. What I did this time:
    - Removed all specular maps
    - Translucency Weight: 0.8; Color: HSV 48/72/240
    - Glossy Layered Weight: 0.5; Color: white; Roughness: 0.8
    - Refraction Index: 1.44 (not sure this has any effect though, as Refraction Weight is 0)
    - Top Coat Weight: 0.02 (or 0.05 for face); Roughness: 0.1 (0.2 for less shiny skin); Layering Mode: Fresnel; IOR: 1.34; and add bump maps with weight 2
    - Transmitted Measurement Distance: 2; Color: HSV 300/48/240; Scattering Distance: 0.5
    - SSS Amount: 0.8; Direction: -0.5
    Thank you for sharing your settings! I have to try this mapless spec idea. *Off to re-render Sebastian again*
    edited April 2015
    Glad I could help :) I've also been finding that inverting the specular maps and plugging them into the roughness channels (Glossy and Top Coat) helps to break up the specular highlights and not make the skin look so smooth. (I tried inverted bump maps too, but that didn't work as well, I guess because they're too much in midrange grays.)
    Post edited by 8eos8 on
    edited April 2015
    This is a before and after! I'm going to experiment with some of my no-spec M4 textures next. It's not a perfect comparison because I also changed my HDR to a more skin-friendly one.
    1619 x 1000 - 1M
    2000 x 1235 - 2M
    Post edited by SickleYield on
    edited April 2015
    Well, that's weird.
    Doing some tests, I'm finding that with, say, Victoria 6HD, top coat (.8 weight, flat white, fresnel 1.3 IOR) looks fine for 'wet skin' and thin film barely registers.
    (scratches his head)
    Here's a 'dry skin' vs. 'wet skin' with top coat test, which looks pretty cool.
    SO CONFUSING
    (You know, looking at the 'top coat' render, I wonder if it would look better with diffuse put back in as top coat color...)
    667 x 1080 - 981K
    667 x 1080 - 1017K
    Well, that's weird.
    SO CONFUSING
    That looks good!
    I changed the Trans/SSS colors on mine for Sebastian's very pale, not-at-all-olive skin compared to Olympia's, I forgot to say.
    edited April 2015
    Hrm. I THINK putting Diffuse in the top coat color might be a good idea?
    hrrrrm
    First image: Top coat white (.8 weight, 1.3 IOR fresnel)
    Second image: Top coat = diffuse map
    But the second image just ends up looking more... metallic than wet.
    667 x 1080 - 984K
    667 x 1080 - 981K
    Okay, this is behind deviantart's maturity filter, so I think it's okay to post the link. It has male nudity, but the skin shaders are MUCH better than I've been doing to this point!
    Lighting really matters. I had to just throw out the .exr I made in Blender, it was muddying up my skins.
    http://sickleyield.deviantart.com/art/Taric-in-Iray-Male-Nudity-525814922
    And here is Fawne by Silver with 8eos8's suggested settings! I'm getting closer on the eye settings, finally. Here's a preset for her if anyone else wants to try. Adjusting the degree of bump for render distance is recommended.
    https://www.dropbox.com/s/zuzoc98tblu8h1p/FawneMatIray.zip?dl=0
    500 x 650 - 153K
    Have people seen much point to using SSS for skin rather than just translucence?
    The effects are small, have people really noticed a difference?
    SSS shows up most in dim or indirect lighting. So how much it shows up depends entirely on the scene.
  • RarethRareth Posts: 1,462
    I don't know I tried adjusting the skin settings based on what I've gotten from this thread but.. the glossy is just too uniform, doesn't look right.
    521 x 844 - 302K
    What's your lighting?
    oh! :cheese: As soon as I get threw the past two days of missed messages, messing with that SubDragonLE mats, lol. I still have some Benches to run as well. Thanks!
  • TJohnTJohn Posts: 11,381
    Raise the Glossy Roughness until you're happy with it, maybe. :)
    sun positioning, and I am pretty sure I remembered to turn the headlamp off.. tried again with some minor tweaks but still not sure.
    (same sun position, again no headlamp.)
    521 x 844 - 303K
  • evilded777evilded777 Posts: 2,543
    edited April 2015
    Why are male skins so much easier to make convincingly realistic? Is it that they are more photographic and less painted?
    My guys, even older textures like M4, can look pretty convincing with some attention to settings... the women, however, even with the newest V6 et al, soooo much harder. Best i've come up with so far is Olympia's base texture... and I'm still not at all happy with it.
    Post edited by evilded777 on
    Are you using top coat? How's it set? and have you put the bump maps in top coat?
    Not quite 'skin,' but what refraction do folks suggest for 'Eye Reflection'?
    No I don't have bumps in the top coat.. should probably work on that
    top coat weight 0.5
    top coat color white
    top coat color effect scatter & transmit
    top coat roughness 0.4
    top coat laying mode fresnel
    top coat IOR 1.5
    anisotropy 0
    roations 0
    thin film 0
    ior 1.4
    top coat weight 0.5
    top coat IOR 1.5
    anisotropy 0
    roations 0
    thin film 0
    ior 1.4
    Definetly put in the bumps, the wgt is kinda high for me and the roughness kinda low (preference). Try changing the color to 230,230,230 (.8.8.8) for base and top coat.
    edited April 2015
    tjohn said:
    Raise the Glossy Roughness until you're happy with it, maybe. :)or try using a map in the strength control. I haven't mentioned it before, as I'm still not sure what map and where it would go in the Iray shader. Just the Where the gloss is, and Where the Velvet is, makes or breaks the look of skin and scales, even in 3delight.
    To quote myself sort of referring to that SubDragonLE experimentation. Peach-fuzz on the cheeks and back of the hands is good, not so much on the lips, palms of the hands, and knuckles. Translucency on the ears is good with super-bright lights, not so much elsewhere there is bone in the way.
    It may also require altering some maps as I had done with the SubDragonLE for 3DL.
    http://www.daz3d.com/forums/viewreply/799887/
    "O" and Rogerbee was absolutely correct for the 'Amount' of reflection on eyes, 29%. It's just a matter of figuring out what layer to apply the settings to, on people. and translating this to the equivalent Iray shader settings.
    http://www.daz3d.com/forums/viewreply/799951/
  • MusicplayerMusicplayer Posts: 515
    edited April 2015
    With the thin coat shader set at around a refraction of 1.33 I could never seem to get any eye reflections. Once I put the eye reflection settings refraction to 1.86 I got reflections 'All the time".
    In certain instances I have lowered this rate, but fiddling with all the cornea, and tear surface settings turned out for me to be a waste of time, because once the eye reflections refraction rate was increased from the default Iray shader setting, I got reflections with no problems.
    Hope this helps and works for you. :-)
    Post edited by Musicplayer on
    edited April 2015
    uh, perhaps I was a little optimistic at first. The only 'Fawne' that showed up in a search is an old V4 figure. :smirk: Nope, a V4 outfit, lol.
    https://www.daz3d.com/fawne-v4
    Well, in any case, folder folder folder, hmmm? Time to look and see if tinkering is even possible, or if Dragon Storms V4-to-G2F script will even function on Iray shaders.
    I honestly just don't feel like fussing with V4's backwards joint controls, and Iray at the same time, lol. I'll find another way to have fun with this.
    872 x 403 - 37K
    Fawne is a Silver character in the Marketplace for the Site beginning with "R". :)
    edited April 2015
    lol. As I think I discovered, I'll spare you the Error log, lol.
    I can think of two sites that start with 'R', and they specialize in Poser only stuff.
    Do not have Poser, Do not want Poser-only content, Do not like how it dose not function half the time in Studio, Sam I am. lol.
    Still, If it can be Ctrl-clicked onto another figure, it's a start. An example of sorts.
    (EDIT)
    Especially if it only takes switching the UV mapping back to whomever.
    (EDIT2)
    Now I do have Sapphira, IF it is the 'R' site I'm thinking of. Or is Silver at RuntimeDNA?
    1451 x 695 - 227K
    1451 x 695 - 223K
    Not Poser-only although some products are. Fawne for example comes with a V4 and Genesis version, and textures for both Poser and DS.
    Just like a lot of products here at DAZ.
    edited April 2015
    We doubled when I edited my post, lol. I think there is something worth trying here. I'm sure some maps are in the wrong slots, tho this is much better already.
    (EDIT)
    Well, not so good in Iray, tho not horrid either. And there is a bad setting somewhere still, tho It is at least tolerable for experimenting with Iray now. Spot-renders don't take over an hour to get anywhere, lol.
    (EDIT2)
    Sapphira needs hair, and Taigafaeri posted some settings for that I want to try.
    http://www.daz3d.com/forums/viewreply/800407/
    1741 x 1098 - 499K
    1562 x 524 - 37K
    1556 x 917 - 436K
    still playing around with settings
    618 x 800 - 211K
