UltraScenery - new territory [Commercial]
Adding to Cart…
That is amazing and you are right we need parks for US, I ran into this lack with a render I will post shortly
I can't remember which ecology I used for this now and I ended up modifying it quite a bit anyway, by hand as I don't have toolbox 2 yet.
The bridge and lamp posts are ones I have made just for this render. It is best viewed at full size. (once I can actually upload something that is
That is impressive! And I aggree, ecologies for parks would be nice. Short well maintained grass, garden flowers along paths, decorative shrubbery, etc. :)
I did a Sheakspeare in the park background once. I used the Toolbox to mix up the trees and removed the long grass and grass tufts.
And finally here you go, please click for full view
Hi there ... yep, notifications not working again. :( I've done various experiments with Materia MeshMaker but so far all on the ground or on ground props with geometry (and/or planes), for which I am pleased with the results. (I've also tried Materia, highly modified, for sand, though less usefully.) Brief, intial forays into putting snow on US trees was not successful due to the instances/geometry situation. I ned to circle back to that. If I get some time today, I'll try again.
I was afraid of that. I was able to get the snow on the ground without issue. But nothing I did would get it on the trees no matter how many trees I have in the scene or what I did. Might have to generate it without the trees then place some add the snow then use Scatter to add more in.
Thanks for the reply!
Some quick retesting here, given a few spare minutes ...
First, Instances to Objects will turn US trees to real instances, though there's a whole separate other thing about that, which I won't belabor here.
Once I had trees with geometry I tried some testing. For those who don't have Materia Meshmaker on hand, there's two ways of using it: it comes with a nice shader, which you can use alone to good effect for a lot of purposes (the ground, especially). There's also the Materia Meshmaker pane, which has presets intended for creating Meshmaker snow around people, animal-shaped things, and plane or cube primitives. Neither of these was particularly successful out of the box with a de-instanced US tree. Applying the shader to the individual surfaces (branches, needles, etc) produced too much coverage: the branches would have an unrealistic coating of snow on all surfaces including underneath, and putting the shader on the needles produced entirely freaky looking stuff. (And no, my beloved planes are of no use here.) I have not exhaustively retested the Meshmaker from the pane, but initial results produced giant tree-sized piles of snow - not nice snow scattered on branches. I have to review my notes on what the numerous pane settings do before I give up, but I think it was designed for use as a mounding snow on things like bodies, and the ground, vs fine, scattered things like branches.
I'm trying some testing with MARSA elements also.
I'm betting someone with higher end knowledge of surfaces might have some ideas of how to tweak the out-of-the-box effects.
Hmm might have to try that I know that it can be added to a tree becuase one of the examples the PA does is with a fell tree. I haven't had time to really test anything, will hopefully be able to this afternoon. I completely forgot about Instances to Objects, Im pretty sure I own it too.
Thanks for doing the testing! Will post any results if I figure it out.
You're welcome! I'll keep trying and update if I figure anything new out.
Well, that was weird. I had managed to link to an image after a fair amount of testing, but the whole post disappeared. Not sure what's up with that. Anyway, here's a retry at sharing the modest image in question.
If this one disappears, I'll just give up on it.
Very nice paulawp!
So the best result ive gotten so far is to use the geoshell then used the shader from MateriaMaker. I used a US Tree 8 prop, at this point I am just trying techniques until I figure out whats best then I will go back with US and see if I can get it to apply. I have had no luck getting a geometry generated on the US trees that looks good. For this tree I did have to remove the leaf geometry completely from the prop. Even if you hide the geometry in Geometry Editor the snow still applies to the leafs (with or without a geoshell).
I used the geoshell from DA let it snow because I already had it applied. The Materia shader looks better to me because it creates an uneven surface but Let it Snow doesn't look bad. Both have to much coverage. Im going to play with the shader some to see if I can get it to be not as thick. The picture attached is the default it looks to me like a snow came through but was blowing from one side, this tree has been rotated also.
2nd tree with the displacement minium set at -10 and raised the Y translate on the geoshell to 0.6.
Both look pretty good to me! I haven't done anything with geoshells yet.
This a an US scene, ecology Oaks 4. For this I only let it generate the trees since thats what I am testing on. I zoomed in on the tree that has the geometry (and just FYI for those of us (me) who forgot, the geometry trees are under the US terrain not actually on the terrain. I did the same steps as above, this is just one of the trees and I think with the others done it will be less noticable about the duplicates, you can see the rotation of the trees in this example.
(The force is with me tonight, three successful attachments!)
Still no luck on attachments. I just finally figured out how to link straight to the gallery, so at least I have a backup option for those days when I can't get attachments to work.
I used Let it Snow to get snow in Ultrascenery.
https://www.daz3d.com/forums/discussion/comment/7820021/#Comment_7820021
@DoctorJellybean! That is an amazing composition and rendering feat. KUDOS!.
Very nice Paula. Very serene,
That looks very nice. I have played with DA Let it Snow, but could not get good results
on the leaves of the trees, so I have to give up on that.
Need to find the other shader, that works properly with the cutout transparency on the leaves.
If trees have snow they wont have leaves unless they are evergreens like Firs.
I woke up to snow in Canada on 31 August, about 4" deep. While camping in a tent and my only vehicle was a motorcycle (yeah, it was cold). I was in the Yukon, but the deciduous trees all still had their leaves on.
Regards,
Richard
I have seen it too even here in Scotland but I don't look on that as 'Normal', whatever that means these days :)
An experiment with UltraScenery and https://www.daz3d.com/da-let-it-snow
@Artini I have one too, with leaves :)
2023-01-17 21:13:57.423 Total Rendering Time: 36 minutes 11.60 seconds
Click on image for full size.
Nice, @Fishtales
Below is my another trial, after further adjustments.
If anyone is stocking up on UltraScenery products they are included in today's sale for 65% off if you buy one of the new items.
Corrected. No buy-in needed. See @Fishtales note below. Thanks.
I had quit trying to get this to work since no real solution was given, but maybe I'm the only one not able to see Arboretum Volume 2 when I go to--->Utilities---->Ultratrees - realistic tree system--->utilities--->ultra tree creator. I run the script but all I have shown is oak Genus: Quercus but no ultra tree birch. I installed via DIM, uninstalled and reinstalled but it does not show up, not even the bark shows up.
You don't need a new item. I have them in my cart and they are 65%.
Oh good, I need more coffee in the first hour of the morning.
Can you link to the product? I tried searching the store but couldn't find an item 'Ultra Tree Creator'. I thought I owned every UltraScenery item.
