UltraSceneryXT - large terrain/landscape generator
1171820222342
  • ArtiniArtini Posts: 10,392
    edited April 2022
    This time only UltraSceneryXT + clouds.
    1920 x 1200 - 964K
    Post edited by Artini on
  • Perfect. It gets rid of the DS 'small world' myopia in one hit.
    Regards,
    Richard
    Thanks. I am really excited to discover, what one can do with UltraSceneryXT.
  • HowieFarkesHowieFarkes Posts: 624
    edited April 2022
    Some renders using some new skies and materials that will be in store soon.
    1000 x 1300 - 1M
    1000 x 1300 - 861K
    Post edited by HowieFarkes on
  • Ultrascenery is getting stuck for me on instances.  Been trying to resolve this issue for days!
    Trouble shooting I have already tried: uninstalled and reinstalled, set optimization to memory, uninstalled octane render, uninstalled add-ons
    If you can think of any solutions please help!
    Richard Heger, Chicago IL
    1920 x 1080 - 723K
    You should post this in this thread, you are more likely to get help
    https://www.daz3d.com/forums/discussion/380431/ultrascenery-commercial/p1
    Looks great.
  • davesodaveso Posts: 7,883
    these materieals include ecologies as well or mainly rock/ ground type. Skies have clouds?
    The pack will contain new and improved terrain materials (Biomes not included) and SunSky presets that contain different times of the day and different volumetric haze densities (no clouds)
  • GranvilleGranville Posts: 697
    edited April 2022
    Will you include a more tropical biome? Or maybe a separate tropical pack?
    Post edited by Granville on
    edited April 2022
    Another render of UltraSceneryXT.
    1920 x 1200 - 1M
  • AnEye4ArtAnEye4Art Posts: 860
     well done.
    Thanks a lot, @AnEye4Art
    edited April 2022
    Below is yet another render of UltraSceneryXT.
    1920 x 1200 - 905K
  • alexhcowleyalexhcowley Posts: 2,403
    Howie's first add on set for Ultrascenery XT has just been released.
    https://www.daz3d.com/ultrasceneryxt--materials-and-skies
    Cheers,
    Alex.
  • Ghosty12Ghosty12 Posts: 2,080
    And it went into my cart so fast, that I spent a good time trying to catch my wallet.. laugh
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,733
    edited April 2022
    Hey, everybody ... I know that this has been discussed briefly elsewhere, but I wanted to bring it up here in case anyone runs into this via the path I have.
    It appears that  Daz 4.20 can play havoc with some material files, notoriously OOT hairs, but also UltrasceneryXT mat files. This attached render is an out-of-the-box render with the Vernon biome, and you can see here that while it handles the snow and the trees, the underlying mat file is coming out flat black. (The same thing happens with OOT hairs.) This worked fine in 4.16 - I just did a render with this biome a few days ago.
    I had been on Daz 4.16, holding off on updating to 4.20, but this new add-on specifically states that it makes use of the new 4.20 volumetric enhancements, so I gave it a shot and upgraded Daz this morning. It's introduced these huge issues. I know others have reported the same problems - I've seen a couple of threads on the forum that mention them.
    I already have the new XT add-on in my cart, but now I can't effectively use it until I figure out what got broken and either fix it or work around it. Yes, I've updated Nvidia drivers to no avail.
    If anyone has been here and fought their way through this, suggestions are welcome. From my reading, the OOT hair problem was supposed to be due to something to do with Top Coat and/or Thin Film changes, but I couldn't find anything specific to check or change.
    1500 x 1200 - 1M
    Post edited by paulawp (marahzen) on
  • GoggerGogger Posts: 2,502
    edited April 2022
    I, for one, am UltraThankful to Howie for bringing us Ultrascenery and allowing me to do things in DAZ Studio that I was only able to do in VUE in the past. VUE got too expensive for me to keep using so I have DAZ and the whole UltraScenery line of products and I am very pleased with it all. I think the UltraScenery products are worth it at twice the price.  It is a pleasure to work with and the results are quite often just astounding. I look forward to each and every enhancement and add-on!
    THANKS HOWIE!
    Post edited by Gogger on
    This looks like an occurrence of the Nvidia vMateriaks issue - whereby some of the shader “bricks” in Daz Studio’s Shadermixer are rendered inoperable due to mismatches in the version of Studio and the vMaterials. Quoted from another thread:
    The issue with vmaterials depended on the version of Daz Studio, prior to 4.16 the problem was with the version of the Nvidia Materials Exchange that came with vMaterials v2.0.. And you had to go back to the Materials Exchange that came with vmaterials 1.70 to stop the weird rendering issue.. However after Studio 4.16 and up the reverse happened, and you had to reinstall the Materials Exchange that came with vMaterials v2.0 to stop the rendering weirdness with certain products..
    So I think now that you’ve upgraded to Studio 4.20 you will need to upgrade your Nvidia vMaterials to 2.0
    edited April 2022
    Yay! That fixed it. Thanks, you da man! I'll definitely be picking up the new add-on today to try out.
    So for anyone else who finds or is following this thread in the future, the problem was that after upgrading from Daz 4.16 to 4.20, I found that some material files - I specifically ran into problems with OOT hair and the mat files here in UltrasceneryXT - would show as black in the Nvidia Viewport and when rendering. (Other random items rendered as expected, including OOT hair with other vendor's shaders.) I had done the stock stuff - upgrade drivers, reboot, check for updates, etc - with no luck. Ultimately, the issue was that in the past, I had installed Nvidia vMaterials 1.7, which would seem to be incompatible with 4.20. I uninstalled that and installed Nvidia vMaterials 2.0. The problem is now resolved for me, having confirmed by successfully testing both an OOT hair and UltrasceneryXT render.
    what are these Nvidia materials? This is the first time I've heard of such a thing.
    Same thing here.  Where do we find this update?
    Cheers,
    Alex.
    Cheers,
    Alex.
    I believe it is optional. More info here
    https://www.daz3d.com/forums/discussion/528256/nvidia-vmaterials-2-0-0-shader-presets/p1
    DoctorJellybean said:
    Cheers,
    Alex.
    Thanks for the link.
    Cheers,
    Alex.
  • Just a quick query with the new XT release, is it able to work on a version pre 4.20? I realise the ground fog won't, but will the rest work? I can go up to DS 4.15 with my Win7 machine.
    edited April 2022
    The terrain materials will definitely work on earlier versions of Studio - but I really didn’t try the Skies on anything before 4.20 as the volumetric fog/haze is pretty integral to the look of each one.
    I can't vouch for 4.15 but I was using 4.16 prior to yesterday, so every render I've posted in this thread was made in 4.16.
  • Thanks. I will give it a try. Regards, Richard.
  • MartialMartial Posts: 431
    edited April 2022
    MY test of Ultrascenery XT
    618 x 800 - 607K
    618 x 800 - 387K
    Post edited by Martial on
