• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Show us your Blender Renders
«1…10111213141516…26»
  • Singular3DSingular3D Posts: 645
    October 2020
    j cade said:
    algovincian said:
    Leonides02 said:
    Krampus said:
    Taking advantage of Blender's Filmic and wide dynamic range, I was able to increase the outside light source while preserving color information without blowing out the highlights.  Very cool for interior renders.  Only 1 light used in this scene, no light tricks.
    This looks great, Krampus. Does Cycles have a wider dynamic range than Iray?
    Iray will render out in 32-bit canvases:
    Render Settings -> Advanced Tab -> Canvases Tab
    Check Canvases and then click the "+" sign to add a beauty canvas.
    HTH.
    - Greg
    Both do the full dynamic range under the hood, blender's tonemapping for the transformation to what we see and eventually output as a non-32bit image is a bit better the whole "filmic" thing uhh does stuff that more closely emulates how cameras work, you can make things a bit better in Iray by turning burn highlights clamp shadows almost all the way off (which I do) or export out the exr and then tonemap that in Blender (or something else with better tonemapping than Iray) which I also do.
    seriously though I wish DS had better defaults for burn highlights/crush blacks
    its not the clearest example but compare
    Straight out of Iray
    Tonemapped in blender (note how the bright and oddly super saturated yellow highlights on the forehead have gone away, I dont even think I adjusted the white value or anything either)
    The reference, which also doesn't have bright yellow saturated forehead highlights
    obviously you can take the iray output and manually adjust it to look nicer, but I find blenders tonemapping makes a nicer base that I don't have to work as hard to make nice
    generally speaking Blender's tonemapping -easier to use stonger lights without blowing out bits of your image in a really ugly way
    That's just amazing. Really have to dig in deeper to get such great results in Blender.
  • CinusCinus Posts: 118
    October 2020 edited October 2020
    Reese's skin and Haydina hair converted to particle hair with my own hair converter. Render time with a 2070 was 13 minutes 12 seconds. No post processing.
    1440 x 1440 - 273K
    Post edited by Cinus on October 2020
  • Krys KryngleKrys Kryngle Posts: 315
    October 2020
    Cinus said:
    Reese's skin and Haydina hair converted with my own hair converter. Render time with a 2070 was 13 minutes 12 seconds. No post processing.
    Hair and skin look good.  I think particles definitely have an advantage over transparancy maps.
    Thanks! Yes, the particle system in Blender is amazing. Just starting to scratch the surface. Took me a while to get the hair to look good.  At some point in time I will try to animate it :)
  • Leonides02Leonides02 Posts: 1,379
    Wow! Cinus, your hair conversion looks amazing. Any chance you will share or sell to the rest of us?
    Post edited by Leonides02 on October 2020
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,321
    October 2020
    It is utterly amazing. 19.4 million particles in total, vram usage was 3.5 gigs for everything.
    1920 x 1080 - 3M
    October 2020
    That is fantastic-looking grass!
    Great grass! The particle system looks very promising!
    Post edited by Singular3D on October 2020
    October 2020
    @Leonides02 Thanks! The converter is very much experimental at this stage. It's also part of a larger plugin i'm working on that has lots of other experimental stuff that is not ready to be shared (and may never be :).
    If I find some time I will extract the hair converter from the plugin and share it as a stand alone plugin.
    October 2020
    @TheMysteryIsThePoint  That is incredible! Very realistic looking grass!
    Like everything I do in Blender that comes out well, I can't take any credit for it :) But I suppose that's what a good addon is supposed to do:
    True-Terrain 3.0 · True Terrain Pro
    Scatter - The Scattering Tool Of Blender
    Physical Starlight And Atmosphere
    Post edited by TheMysteryIsThePoint on October 2020
    October 2020
    Experimental stuff? No I'm really intrigued, LOL.
  • j cadej cade Posts: 2,310
    October 2020
    Wow! that is an excellent conversion
    one thing I will say though not technically physically accurate I find the easiest way to make the scalp transition look smooth is to use the hair info intercept + a color ramp and add just a bit of transparency at the very  very root at it helps smooth the transition right up (The actual reason we have a smooth trsnsition is that our hair gets much finer at the edge of the scalp, but neither blender nor DS have a way to adjust strand thickness within a particle system, and it makes me sad)
    Disirregardless, that still does just look amazing!
  • TheKDTheKD Posts: 2,711
    October 2020
    Can you show that setup?
    @j cade
    But Blender has several settings for the root/end diameter of the strands, as well as the cap and scaling, doesn't it? And permission to steal "Disirregardless" :)
    Edit: Oh, you meant along a strand, didn't you?
    @Cinus I agree, that conversion looks amazing. I'll be interested if/when you make it available through whatever conduit.
    October 2020
    Thanks j cade!.  I never thanked you for the tip regarding the eye shader. I am using that and the eyes look a lot better, so thanks for that too :)
    Not exactly sure what you mean with the hair info intercept + color ramp, but I will experiment with it and see if I can make it work.
    @j cade
    Maybe per strand is a better description? AFAIK you can't have individual strands within a particle system with different thicknesses. Generally speaking, the strands along the edge of the scalp are thinner than the rest of the scalp (other than the 2 random super thick strands I get popping up a centemeter down from my hairline)
    And feel free to steal "disirregardless" - I stole it myself and find it delightful. It means both "regardless" and "yes I do actually know the correct term, but also I like chaos"
    Not the greatest hair styling ever and the lack of eyebrows is frankly disturbing, but a pretty illustrative example
    Without Root transparency
    With root transparency
    Node setup to add root transparency
    787 x 442 - 62K
    787 x 442 - 59K
    1920 x 1080 - 214K
    Post edited by j cade on October 2020
    Thanks a lot! Can't wait till I can get a few minutes to try it out! Hopefully this weekend. I been itching to try particle hair. It does look a lot nicer to my eyes as well.
    Post edited by TheKD on October 2020
    @j_cade - Thanks for sharing your node setup.  Definately putting that in my stash.  I almost understand it too!  I'll have to play around with it to see what the Map Range does...
    Another method is to adjust the root diameter.  Same effect, different method, all depends on one's preferences.
    Strand shape seems to be a ratio between Diameter Root and Tip.  Closer to 1, more tip diameter and less root diameter along the hair strand.  Closer to 0, more root diameter and less tip diameter along the strand.  You can't see it in this example but Diameter Scale is set to 0.001.  It might vary depending on the scale of your character and scene.  I think the diameter scale value is just a multiplier for the root adn tip values.
    First example shows a thicker root just as an example (how far along the strand the root diameter travels with strand shape set at 0.990)
    Second example changes the root diameter to a much smaller value than the tip diameter.  In this example the root diamteter is 0.001.
    'Hair Shape' is found under the particle properties tab on the right.
    1489 x 704 - 281K
    590 x 208 - 20K
    1487 x 707 - 275K
    588 x 209 - 20K
    Post edited by Krys Kryngle on October 2020
    October 2020
    Thanks @Krampus I had the notion of the root/tip swapped and was making the root smallerf than the tip. My scalps looks 100% better.
  • ScarecrowScarecrow Posts: 191
    November 2020
    Cycles render with Angel Armor for Genesis 3 females and feathered wings for all. Diffeomorphic importer.
    1920 x 1080 - 3M
    November 2020
    So this is a cycles render with dz fire's Forsaken Keep https://www.daz3d.com/forsaken-keep-and-construction-set
    The trees and grass are from various Daz sets painted in with Blender's Scatter addon.
    1920 x 1080 - 4M
    November 2020
    This looks great!
    November 2020 edited November 2020
    Thanks!
    Post edited by Scarecrow on November 2020
    November 2020
    That does look good.  Possibly the start of a great scene...
    November 2020
    Krampus said:
    Well let's hope so, Thanks!
  • GordigGordig Posts: 10,703
    November 2020
    My Cabbages!
    Rendered in Cycles.
  • jeff_someonejeff_someone Posts: 254
    November 2020
    Here's a render...
    https://i.ibb.co/Pxtvf7d/203.jpg
    November 2020
    You guys are really blowing me away.
    November 2020
    Guitar Gods...
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
