GenX2 and Genesis 2 AddOn released! [Commercial]
1111214161742
  • OridionOridion Posts: 0
    edited March 2014
    What does it mean to transfer between different versions of Genesis? Isn't Genesis a single figure?
    Post edited by Oridion on
  • RogerbeeRogerbee Posts: 4,460
    Hallelujah, it's out!
    Now folk have got over that, they now have to get it to work, LOL!
    CHEERS!
  • JOdelJOdel Posts: 6,322
    IT'S IN THE STORE!!!!
    Now. The question is: how do we get gen3 morphs over to G2? I have a number of them. Do the gen 3 add-ons for Gen X work with Gen X2? It hasn't sounded like it from the discussion so far. And I see that none of the promos show gen 3 character bases moved over to G2.
    I am assuming that the character morphs that we've already moved to Genesis can be ported from Genesis to G2. But those never worked without the gen 3 base clones to dial in first. IIRC, the gen 3 iconic shapes are a separate product from DAZ, not a part of Gen X itself. There hasn't been a set of iconic gen3 shapes released for G2.
    So what is the new procedure? First port over any gen 3 characters *before* deinstalling gen X and replacing it and then port those Genesis morphs over to G2? Or is it now a 2-step procedure of first port them to Genesis -- using Gen X2, and then port *those* ports to G2 *without* needing to separately dial in the iconic gen3 shape?
    Greetings,
    OMG! Dimension3D that's awesome! I had not expected it to be that inexpensive as an upgrade. I can't wait to set it up and try it when I wake up!
    Thank you!
    -- Morgan
  • scorpioscorpio Posts: 8,533
    Yes its in the store - well the full product is, the upgrade is throwing a 404 error.
    Cypherfox said:
    Greetings,
    Thank you!
    -- Morgan
    I just get a n error if I click for the upgrade from the full version blurb link, do you have a direct link please
  • Dimension3DDimension3D Posts: 464
    YES, GENX2 HAS ARRIVED !!!
    Genesis Generation X2 and the GenX2 AddOn for Genesis 2 have been released.
    For details, see the new announcement forum thread for GenX2.
    For upgrades from the previous version, there is no upgrade version (as the store page notes), you will get a 66% off coupon on checkout.
  • jerhamjerham Posts: 155
    edited March 2014
    It seems the upgrade version is missing?
    Getting a 404 not found, when using the link that is in the full version.
    Edit: Never mind..just saw the post above.
    Post edited by jerham on
    edited March 2014
    Oridion: "Different versions of Genesis" means Genesis 1, Genesis 2 Female, and Genesis 2 Male.
    JOdel: If you have both, a Gen3 add-on and the Genesis 2 add-on, you will be able to transfer morphs from generation 3 to Genesis 2. For the Gen3 add-ons, there are free updates that you have to download and install. GenX2 will create working morphs from the clone morphs for gen3 characters, and you may transfer the gen3 shapes from Genesis 1 to Genesis 2 as a base for the GenX morphs.
    Also, GenX2 includes all features and supported figures of GenX1, no need to do anything in GenX1 before installing GenX2.
    Post edited by Dimension3D on
  • linvanchenelinvanchene Posts: 1,386
    Thank you a lot for all your hard work creating this new and improved version!
  • acanthisacanthis Posts: 604
    edited March 2014
    Sorry to be dense. When you say there are free updates to addons that you have to download for Gen3 characters, where does one download them from? I have GenX plus all the Gen3 addons and am about to take the plunge on GenX2 so it would be nice to know the process.
    Thanks.
    Post edited by acanthis on
  • caravellecaravelle Posts: 2,691
    edited March 2014
    From the announcement forum I can't see which 'different versions of Genesis' you mean, so I want to repeat Oridion's question. Do you mean V5, M5, S5, etc.?
    Post edited by caravelle on
  • greysgreys Posts: 335
    Hey, not sure why but I'm not getting asked for a serial number on this? It's listed in my plug in list as green/good to go but there's a serial number in my account and I haven't entered it anywhere. Is DIM autofilling serial numbers now?
    edited March 2014
    acanthis: I'm sorry, it looks the updates are not available yet. They should have been together with the release of GenX2, but they aren't. Wait until you see a version 2.0 file in DIM or Product Library.
    polka dot: "Genesis" refers to the base figure. There are three Genesis base figures: Genesis (also called Genesis 1 to prevent confusion with other versions), Genesis 2 Female, and Genesis 2 Male. Victoria 5 or 6, Michael 5 or 6 etc. are not separate figures, they are morphs (or better morphs systems because they consist of several morphs including hidden correction morphs) for one of the Genesis base figures. GenX2 only deals with the base figures Genesis. Because V5, M5 etc. are morphs, GenX2 can transfer these morphs from one Genesis base figure to a different Genesis base figure.
    temporal.ranger: GenX2 works with the old serial number of GenX. If you upgraded from GenX, you will get a new serial number, but you don't have to use it, if GenX was installed before.
    Edited to note that the Gen3 add-ons are now available for download.
    edited March 2014
    Thank you, Dimension3D. I understand that eg. V4/M4 and Genesis 1 morphs can be transferred to G2F or G2M. The Add-on is for the interchange of G2F to G2M and vice versa, right?
    The GenX2 plugin includes support for generation 4 figures (V4, M4, K4) and for Genesis 1. Any other figure will require an add-on. The Genesis 2 add-on is required to transfer morphs to, from, or between G2F and G2M. Together with Gen3 add-ons, it will also enable transfer from generation 3 figures to Genesis 2.
    edited March 2014
    Thanks again, this seems to be a must-have. Bought! :-)
  • Coon RaCoon Ra Posts: 200
    Oridion: “Different versions of Genesis” means Genesis 1, Genesis 2 Female, and Genesis 2 Male.
    but then you tell
    and it renders the http://www.daz3d.com/new-releases/genesis-generation-x2 's description misleading as the latter quote means that initial GenX2 plug-in doesn't support G2F and G2M figures without GenX2 AddOn for Genesis 2, am I correct?
    but then you tell
    The plugin is able to transfer morphs between different versions of Genesis, but you need the add-on to actually use this feature.
    The product description of GenX2 mentions clearly and several times that for Genesis 2, a separate add-on is required.
  • CMKook-24601CMKook-24601 Posts: 200
    edited March 2014
    okay so... I own Generation X, and in the ad thing it says an extra 66% off for owners of Generation X.. yet that savings is not reflecting in my shopping cart
    EDIT: Never mind it finally went through
    Post edited by CMKook-24601 on
  • TaozTaoz Posts: 10,288
    edited March 2014
    I can see that GenX1 is no longer available for download in my Product Library, isn't that an error?
    Post edited by Taoz on
  • KeryaKerya Posts: 10,943
    Did you search for GenX? You will find it under Genesis Generation X:
    http://www.daz3d.com/downloader/customer/files/#prod_13516
    edited March 2014
    I can find it in my order history but this is what I get when I click the download link. I doesn't show up when I search on "generation".
    991 x 661 - 132K
    okay so I bought Gen X2 and GenX2 AddOn for Genesis 2 but I can't seem to get the Genesis people on to the Gensis 2 people such as freak 5 and Aiko 5
    I can find it in my order history but this is what I get when I click the link. I doesn't show up when I search on "generation".
    Ouch - you have the Upgrade from Gen4 ... I think you will have to contact Daz to make them repair that one!
    The updates for the Gen3 add-ons to work with GenX2 are now available for download at DAZ via DIM or Product Library.
    Xen0phage24601: I transferred Aiko 5 and other characters successfully from Genesis to Genesis 2 (see promo images). At which step does it fail for you?
    Taozen: Kerya's right, you have to address DAZ about this.
    BTW, anyone else getting "Error Message: Unable to receive your submission at this time" when trying to post in this thread?
    yeah my bad it works I was being stupid and trying to drag and drop instead of click the source button
  • whispers65whispers65 Posts: 1,034
    Where is the manual located? I'm having trouble finding it. I have been so looking forward to this release. I want to try it out at lunch today but I don't have a connection so trying to set everything up before I leave in a few minutes. Thanks.
    Yes. It's still there in my local database from feb. 26 so I guess something's gone wrong when they updated things for the GenX2 release.
    The GenX2 manual should be installed under docs/plugins/genesis generation x2 in the DS application folder.
    Manuals for GenX2 and the Genesis 2 add-on can be downloaded from my web-site here:
    * Genesis Generation X2
    * GenX2 AddOn for Genesis 2
    Product readme's seem to be missing at the moment, but they should include the manuals as well.
