Hex Gallery
1568101139
  • m_m_italym_m_italy Posts: 386
    Buon modello.
    Applica texture.
    Ciao
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    Nicely done sircamillo, looking forward to see what you do with it next :)
  • useroperatoruseroperator Posts: 247
    edited December 2013
    I found a new way of creating round leg shapes in just a couple of minutes.
    Step 1. create a cylinder with an appropriate round smoothness. leave the number of sections at default.
    Step 2: select all of the horizontal section lines except the lines on both ends (preferably with the loop command) and then go to edge tools and extract along or around the lines, creating a kind of ribbed pattern of lines.
    Step 3. select all the new sections (again, preferably with loop command) by their faces. you basically want every other section selected.
    Step 4. do a radial extrude/sweep on those faces so that they are recessed a little compared to the rest of the object.
    Step 5. use the twister deformer to twist it around a couple of times along the default axis
    Step 6. Set a smoothing level of 1 or 2.
    that's basically the gist of it. you can create more variety by twisting more or less, or changing the spacing of the sections early on, or by making some of the sections bigger than the others, or adding more sections, or all of the above.
    944 x 626 - 220K
    Post edited by useroperator on
    Bye bye
    800 x 600 - 103K
    800 x 600 - 111K
    1148 x 841 - 79K
    Post edited by m_m_italy on
    Oh, that is very nice M_M, I really like the texture you've given the glass - great piece of modeling :)
    Grazie "WDJ".
    Ciao.
  • grinch2901grinch2901 Posts: 1,247
    Took my daughter to see "Frozen" yesterday, decided to recreate one of the characters.
    819 x 490 - 178K
  • Tramp GraphicsTramp Graphics Posts: 2,423
    Not bad for a tart, but it still needs more work before it's perfect. The mouth, in particular, is off. It should be pulled forward more, as seen in the pictures on this page.
    created in hexagon
    690 x 388 - 2M
  • RedSquareRedSquare Posts: 0
    Is that a urinal for both sexes ~ portable for the use of ?
    Or, just a thinnnnnnnnnnnng ?
    Happy New Year. :-P
    I'd like to know what it is.
    Nice turn table effect :)
    It's a marijuana/crack pipe.
    Oh ! right, just shows what an innocent I am; must be me age. :cheese:
    :blank:
    800 x 600 - 44K
    1148 x 841 - 120K
  • jodprakjodprak Posts: 5
    Hi everyone, my name is Jodie and I'm new in this forum but I would like to share my 3D model made with my Hexagon. Before I knew Hexagon in 2012, I have been using Maya since 2002. And now I prefer Hexagon much better than Maya for modelling. Seriously! The project was meant to be 3D printed and it worked. I didn't put any texture nor color for it. I just exported the files into STL and OBJ formats and then printed using Up 3D printer. All the part were carefully sculpted to make sure the articulation works well. So here are the pictures, I hope you like it. Cheers!
    811 x 1000 - 118K
    1410 x 518 - 124K
    920 x 558 - 107K
    Sweet work there. You should rig it in DAz Studio and use it in renders and animations too.
  • bighbigh Posts: 8,147
    I agree .
    I agree .
    Thanks, guys. Yes, maybe I should render it on Carrara or Daz, but because my passion is to create a toy product at this moment so I'm a bit distracted by the temptation of 3D printing. This is another mecha project which hopefully follows the first project, wish me luck on the 3D printing process, because it's quite costly.
    671 x 682 - 60K
    657 x 685 - 73K
  • GhostmanGhostman Posts: 215
    That's a frickin cool robot. Really nice work. :)
  • RoygeeRoygee Posts: 2,247
    That is seriously good work there - congratulations !
    Great to see the positive comments about Hex:)
    Thanks, guys. I really appreciate it. :)
    boredum. I was going for a futuristic pillar look, could use some paneling....and a scene to build around it.
    1920 x 1330 - 996K
    Interesting shape. What did you render this in, I like the metal shader - nice :)
    edited January 2014
    so I finally figured out how to wrap objects around a shape.
    and I came up with a new clock type.
    1920 x 1330 - 1M
    1920 x 1330 - 1M
    edited February 2014
    Fenicotter lavabo.....
    Ciao
    1000 x 600 - 237K
    800 x 600 - 214K
    800 x 600 - 94K
    1148 x 799 - 221K
    Nice one M_M. I like your renders to :)
    here's a dump of some stuff.
    640 x 360 - 4M
    1330 x 806 - 1M
    643 x 695 - 492K
    1010 x 810 - 238K
    766 x 794 - 362K
    Very nice UserOperator, I really like the bowl and fish, very imaginative.
    Thank you very much.
    Always very kind.
    Bye bye.
    1000 x 600 - 482K
  • DzFireDzFire Posts: 1,473
    edited March 2014
    Needed to build something bad a$$
    1000 x 1300 - 531K
    1850 x 1000 - 243K
    Post edited by DzFire on
