Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1232426282952
  • Mystarra said:
    Mystarra said:
    there was something about a submarine a bunch of pages ago.
    underground sub?
    If you're referring to my post last year about a texture issue it was about https://www.daz3d.com/secret-underground-base-and-submarine.
    thanks.  nice sale price,
    just needs a splash of yellow paint.
    Oh dear, seeing what you mean.
    not seeing any geograft to cause artifacts
    mebbe something that can test normals all pointing the correct way ...
    I exported it from Studio as an obj and then retextured it. It was a lot more trouble than it was worth, but I needed for a print add.
    2500 x 1773 - 708K
    i want to understand why this is happening.  doh
    are these double sided polys?
    pretty sure carrara has a way to show the normals direction.  dunno where it went.
    1118 x 574 - 172K
    1055 x 574 - 160K
    500 x 277 - 75K
    wasnt there a way to load a texture map on the uv grid for reference?
    know i've done it before. cant remember where to load it. something global
    only 4 selected.  guess if was double sided would show 8 selected?
    512 x 458 - 70K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,142
    edited September 2019
    Is it unticked on U and V?
    normal spikes options are in the interactive render down the bottom
    your default shader is the one which has a map show if one assigned
  • I definately unticked U and V when I was trying to get it to work. That wasn't the issue.
    whiskey tango
    a series of unfortunate events led to this?  lol
    and carrara doesn't have troubles with ngons.  looks like this poly has 6 verts on it  ?
    820 x 371 - 76K
    1008 x 486 - 122K
    starting over
    thinking we may have overlapping polyies
    one ping only
    Post edited by Mistara on
  • StezzaStezza Posts: 8,758
    I remember the issue... I think at the time I saved it out as an OBJ file... can't quite remember now..
    anyways I did get around the problem by modeling my own Carrara sub... I'll post it in the Wacky Modeling thread if you can do anything with it..
    640 x 480 - 121K
    640 x 480 - 99K
    Post edited by Stezza on
    Thanks Stezza  much nicer than the other one smiley
    i guess we alls made an effort to make dforce clothes hangy bits into carrara soft body?
    https://www.daz3d.com/layla-for-genesis-3-8-female
    bought Layla.
    the morph slider didnt show in Carrara until i moved her morphs folder/file .dsf  under \data\DAZ 3D\Genesis 8\Female\Morphs\DAZ 3D\
    by default it installed directly under Morphs.
    trying to make a 'Carrara' folder show under 'Root'
    playing with the presentation settings in the morph properties
    bought Layla.
    so how did you get that G8 character in Carrara?
    i am dying to know  lol..it would save me lots of time...would really love if i could get G3 to work
  • Bunyip02Bunyip02 Posts: 9,248
    edited November 2019
    Needs Misty's presets:-
    For G3F/G3M do a search at the Renderosity marketplace for Janette and Johnathon
    For G8F https://www.renderosity.com/mod/freestuff/carrara-compatible-character-preset-for-genesis-8-female/77504&ca
    For G8M https://www.renderosity.com/mod/freestuff/carrara-compatible-character-preset-for-genesis-8-male/77745
    Note: You will need to convert any clothing/hair for G3/G8 to Blended Weight in DAZ Studio
    Post edited by Bunyip02 on
    14MU Transport Scamp - https://www.daz3d.com/14mu-transport-scamp
    Needs to be saved as a CR2 file in DAZ Studio to get it to work in Carrara
    The Artifact - https://www.daz3d.com/the-artifact
    Was coming up with an error message and freezing Carrara when loaded. Saved as a DUF file in DAZ Studio then worked okay.
  • DiomedeDiomede Posts: 15,391
    Oh, thank you, Bunyip.  This vehicle has been in my computer garae gathering dust.  Can take out for a spin now.
    As part of the conversion process, an obj file will be generated and saved to your temp folder, copy that obj file to a location where you can find it again. If you get keen you can also change the directory called for in the CR2 file of the obj in notepad. Is a fun vehicle, used it in several renders already.
    The Colosseum looks awesome
    it uses instances in DS which doesn't work in Carrara
    will be interested to see if any Carrara users purchase it and get it together using replicators and how hard it is to do it.
    That would be a good subject for a plug-in - finding the instances in a scene and converting them to Carrara copies, or replicating them...
  • That would be a good subject for a plug-in - finding the instances in a scene and converting them to Carrara copies, or replicating them...
    https://www.daz3d.com/instances-to-objects
    gonna take a chance on the new kibaretto ship
    I keep getting an I/O error with it in Carrara.
    Got the error when I first opened it in Carrara, then opened it in DAZ Studio to try Blended Weight but as it is a prop it wouldn't let me do it. Saved as a scene subset but still got the I/O error.
    2964 x 1039 - 467K
    I haven't got it but try exporting from DS as an OBJ and import it into Carrara... see what happens... enlightened
    On the to-do list !!!
    Imported obj
    2267 x 1035 - 342K
    a long way around now is to save out the unit from DS with the landing gears and/or whatever else as seperate OBJs and then import as morphs into the Carrara model
    seeemples yes
    it;sthe erc formulaes  poor carrara,
    making a preset without them
    there no weight mapping to worry about.
    each part of the craft is an individual figure.
    just makin sure there no geometry in the preset.  cant be too careful  doh
    can open the ramp manually with rotation wire
    There is no geometry or morphs in this preset.  Requires Astro master by Kibaretto
    dunno why, my brain keeps going to ass master  as in donkey master, or donkey jockey
    zip
    zip
    Astro Master Carrara Preset.duf.zip
    157K
    1920 x 522 - 618K
    1920 x 522 - 628K
    1920 x 522 - 487K
    Can you convert it to a prop under rigging?
    Thanks for the Preset Misty !!!
    2593 x 1039 - 479K
