mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
14244464748
  • RAMWolffRAMWolff Posts: 9,298
    With the huge update to Blender I think I may need your script finally.  Can one export their character with skins over to Blender?  Like my Gino to make small corrections to the skin base and save out those corrections directly from Blender?  I was thinking of your script as a tool to content creation work flow.
    Also I just downloaded your version 3 script for safe keeping.  Do I need the BlendBot zip and if so where do those files go?
    Thanks so much
    Richard
  • Will there be Octane support when importing into a Blender?
  • mCasualmCasual Posts: 4,160
    edited August 4
    if it's what you are talking about, the mcjTeleBlender4 pre-release is meant mostly for people familiar with mcjTeleBlender 3 that installed Blender 2.8
    eventually mcjTeleBlender4 will have its own instructions, but for now you can follow mcjTeleBlender3's instructions ( part of which are on the mcjTeleBlender2 page )
    if you mean mcjTeleBlender 3 which wont work with Blender 2.8 but did work since 2012 with versions 2.6 to 2.79 then
    it's here https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    Blender 2.8 Eevee render of Aiko3
    400 x 800 - 22K
    Post edited by mCasual on
  • Silver DolphinSilver Dolphin Posts: 1,120
    wow 43 pages now, where do I extract zip file to?
    Where to install
    mcjTeleBlender is a script for Daz Studio 3 and greater, we suggest you install it in your daz content folder example: C:\Program Files (x86)\DAZ\Studio\content once installed it will be in the content/scripts/mCasual folder
    mcjBlendBot is a set of Blender-Python scripts used to import the scenes exported by mcjTeleBlender the mcjBlendBot package (zip) must be unpacked the current Blender version's "modules" folder typically :  C:\Program Files\Blender Foundation\Blender\2.71\scripts\modules
    This is strait from Mcasual download site
    OK, I'll wait for version 4 to be released.  Thank you!
    i will see, if octane uses the same materials node-trees as eever/cycles then it may be easy
    edited August 4
    Thanks so much
    Richard
    teleblender3 and mcjBlendBot will remain on the net for people that will still use blender 2.60 to 2.79 teleblender4 will have its own set of blender-python scripts ( that's what mchBlendBot contains ) and will only work with blender 2.8 and up .... the 2020"s are nigh!! i'm not familiar with what the vendors use to make theirfigures and props but blender may be able to import/export figures without changing the vertex order.
    edited August 6
    this afternoon ( it's about noon here ) i'll post another teleblender4 beta
    that's an iray render of the shaders i have in daz studio's bundle, i'll make sure they look vaguely the same in Blender 2.8
    1000 x 1000 - 547K
    Post edited by Chohole on
    edited August 7
    mcjTeleblender 4 new BETA !!
    it's before midnight so it counts as "in the evening"
    https://sites.google.com/site/mcasualsdazscripts9/mcjteleblender4temprelease
    718 x 718 - 80K
    Nice thank you.
    edited August 7
    TeleBlender 4 Beta for Blender 2.8 UPDATE
    August 7th 2019 10:34 AM
    TeleBlender 4 Beta for Blender 2.8 UPDATE August 7th 2019 10:34 PM
    the new version of teleblender is still mcjTeleBlender4Beta08062019.dsa
    ( black emissive iRay materials were wrongly emissive )
    960 x 637 - 81K
  • Hi everyone i'vre got a problem with the script import
    somebody has the same issue?
    1919 x 1079 - 320K
    edited August 7
    i dont see an error message
    that's the script which is supposed to load the scene file ( .obj/.mtl )
    note that teleblender 4 is for Blender 2.8
    for earlier versions of blender get teleblender 3 ( url at the top of this forum thread )
    in the same folder as the python script ( c:\blender ? in your case ) there's a .bat file
    you could try starting  blender and the scene.py script using this .bat file
    Oops actually, judging by the script you show
    you are attempting to use mcjTeleBlender 3 with Blender 2.8, this wont work and it's the reason i'm developping TeleBlender 4
  • ok thank's for the reply i will try this later
    edited August 10
    mcjTeleBlender 4 For Blender 2.8 - * * * Beta * * * - August 8th 2019 4:37AM
    improved Glass Water etc
    improved Bump maps ( apparently new Daz Studio versions now don't export them for iRay materials )
    BETA = This is meant for people familiar with TeleBlender3
    BETA = new versions issued often
    1300 x 2178 - 266K
    edited August 10
    so teleblender 4 will simply set the Principled shader to metallic, 0.33 rough, Clearcoat 100% Clearcoat Roughness 0.0 no metallic flakes. Since TeleBlender has a way to re-use materials or borrow them from another blender file, the users will be able to use their bought or custom car paint shaders
    1000 x 800 - 273K
    Oooh, nice thank you
  • Thanks for update version to Blender 2.80 . Working Perfect in my side .But I`m still wonder about eye reflection just like we`ve got in DAZ Studio Render .
    Should those reflection driven by Blender light or I should use another shader setup ?
    BTW there are free Eevee Comic shader from this link https://gumroad.com/l/JWdjJ
    .Would you publish tutorial how to make changes so we can use other shader setup especially toon shader like in link above?
    Thanks again
     i didnt test if it still works (maybe not ) ... but the final release will support using and re-using materials from other .blend files
    the mat-lib and lib-map options
    for eye refloections there's different methods, some used "fake" reflections
    for real reflections you'd probably need to tweak the shader in Blender, which is quite easy in Blender 2.8
    the "manual" for teleblender 2012 explains the lib-mat and mat-lib process
    https://sites.google.com/site/mcasualsdazscripts/mcjteleblender-for-ds1-2-3-4
    Thanks again
    edited August 11
    Special treatment for wax, jade, Car Paint, Velvet and Silk will be included in the TeleBlender 4 Beta release, later tonight
    Waxing Poetic
    the Wax and Jade materials from the iRay Uber materials
    subsurface scattering
    what was that song by ... Scatter Brain ? ... i almost remember ... she sang the Gollum song ... and Wednesday's child ...
    https://www.youtube.com/watch?v=LcEtkxu2aNk
    Wednesday's Child
    Emilíana Torrini
    Scatter-brain
    You've been crying in the rain
    You've been drowning in your pain
    Ain't gonna die
    800 x 1000 - 165K
    edited August 12
    The Latest mcjTeleBlender 4 Beta for Blender 2.8
    Monday August 12th 2019 00h48 Release
    The latest BlenderBot for Blender 2.8 : MCJBLENDBOTFORBLENDER28BETA124508122019.ZIP
    The Latest mcjTeleBlender 4 Beta for Blender 2.8 MCJTELEBLENDER4BETA124708122019.DSA
    new : Better Car Paints, Wax, Jade, Colored Wax, Velvet and Silk
    600 x 1080 - 105K
    Looking really good!
    Yeah, very cool. Thank you
  • JoepingletonJoepingleton Posts: 731
    edited August 13
    Thank you for all your hard work and for sharing this with us.
    Here is a quick experiment with the latest "mcjTeleBlender 4 Beta for Blender 2.8" script to export Sugatak's "Ninja Village" model from DAZ Studio 4.11 to Blender 2.8. I used the default settings, added a little camera movement and rendered everything using Eevee @ 1920x1080 (300 frames/3 min total render time).  This example is played at normal speed and then at half speed in reverse.
    It works great so far.  I noticed a few things that didn't transfer correctly by default, but I suspect that they can be easily fixed in Blender. :)
    Post edited by Joepingleton on
  • DigiDotzDigiDotz Posts: 431
    edited August 13
    yes Comes in with the bump a tad high for melaugh .  I can't remember how to fix the hair at the moment
    blender 2.80 eevee
    755 x 716 - 201K
    Post edited by DigiDotz on
  • Robert FreiseRobert Freise Posts: 2,489
    Looks like a severe case of dry skin
    edited August 13
    haha! Yes, blender 2.80 now knows when a model is not wearing enough sun protectionlaugh
    edit - "clip threshhold" for the hair I think
    edited August 13
    Good News TeleBlender4 + Blender 2.8 works without the "collect maps" option . That's a blender-cycles render - The Messenger - https://www.youtube.com/watch?v=cPjyq55poHo
    https://www.daz3d.com/forums/uploads/FileUpload/c0/8bf3b11f83341a2c18e1b619eb1931.jpg
    1920 x 1080 - 423K
     next version will have bump map strength that matches what it looks like with iRay
    blender 2.80 eevee
    edited August 13
    EEVEE BUMP MAP ISSUES
    TeleBlender 4 for Blender 2.8 and Up Still Very Beta -- Update
    Tuesday August 13th 2019 16:00 Release
    The latest BlenderBot for Blender 2.8 : MCJBLENDBOTFORBLENDER28BETA0357PM08132019.ZIP
    The Latest mcjTeleBlender 4 Beta for Blender 2.8 MCJTELEBLENDER4BETA160008132019.DSA
    new : reduced Bump strength looks less scary in Eevee
    BUT NOTE : The Water shader used on the eyes of genesis 8 look ok in Cycles but No-Good in Eevee, so you should replace them with uber Base and make use opacity/cutout
    ALSO NOTE: the bump map strength is now lower ( this change in teleblender ) but in EEvee render i still had to reduce it to 1/3 of it's value, i did it "manually" in Blender, but i could have done it "manually" in Daz Studio
    1920 x 1000 - 355K
