Headshop 11 Questions
andolaurinaandolaurina Posts: 676
edited November 2018 in The Commons
Hi all!
Does Headshop 11export an OBJ that is Genesis 8 Female/Male base geometry? Or is it using a geograft?
What I'm getting at is... Once I've created a morph, can I save & redistribute it as a morph asset for Genesis 8?
Also is the resulting head texture compatible with the Genesis 8 Female/Male UVs respectively?
Thanks so much!
Post edited by andolaurina on
«13456
  • LeanaLeana Posts: 13,536
    Headshop creates morphs, not a new head. I have no idea if you're allowed to distribute morphs created with it though.
  • Hi all!
    Thanks so much!
    Yes, If you click on the Export button HeadShop 11 does export full head as an OBJ file, complete with textures.
  • Hi all!
    Thanks so much!
    @info_b3470fa520
    Thanks for the response. I just want to be clear. The exported geometry matches Genesis 8 Female or Male's geometry at base resolution, right? And the textures are for the actual Genesis 8 Male/Female head, matching the UVs that come with Genesis 8 Female and Male? I just want to make sure this is doing what I want before I buy it. Thanks for the help!
  • Hi all!
    Thanks so much!
    @info_b3470fa520
    Yes
  • HavosHavos Posts: 5,704
    Abalone, Could you please clear up the confusion over the upgrade prices. In particular, if you own Headshop One Click, are you entitled to the upgrade price?
  • HeadShop and OneClick are different products, so, the answer is no; you are supposed to have the previous version of HeadShop (HS10) installed to be able to upgrade.
  • DecoyboyDecoyboy Posts: 516
    I am also interested in this product but on the fence. Some reviews are positive while others are not. Just not sure. Does the head take on the person's skin, and leave you with a skin body of gen8?
    Yes, only the head gets changed.
  • mindsongmindsong Posts: 1,788
    Question:
    Per the Product page:
    "HeadShop 11 works with the following figures:
    • Genesis 2 Male and Female
    • Genesis 3 Male and Female
    • Genesis 8 Male and Female"
    Also, Per the *same* product page:
    "HeadShop 11 works with all Genesis figures (Genesis, Genesis 2, Genesis 3 and Genesis 8)"
    So... (?)
    The previous version (10) *did* support "Genesis", so it could go either way, and the main product start-up image text also reflects Genesis1 support.
    My initial experiments indicate the first version is correct: no Genesis1 support, unless I'm missing something obvious.
    Am I off to get a refund? or ... ?
    --ms
  • ArtiniArtini Posts: 10,911
    How can one move autodots in Headshop 11?
    Could you describe it here, without pointing out to the video tutorial.
    In Front tab, I have just tried to click on the dot, but it does not select the dot
    and only move around the reference picture itself.
    It will be useful for the reference pictures, when the backgroud and one side of the face is bright.
  • Pls. try different screen resolution on your PC. Very high screen resolution may shrink the dots and make it difficult to see/grab
  • Peter WadePeter Wade Posts: 1,699
    I've bought and installed the full verion of Headshop 11 but I think I may have a conflict with an older version. I did buy OneClick, I'm not sure if it is installed on this computer but I can't find any way to de-install it. I've tried following the quickstart tutorial but the window I get when starting Headshop is nothing like the one shown in the tutorial. It says Headshop 6, is this OneClick or even older? When I go past this point the next part does look like the tutorial. Here is a screenshot of what I get on launching Headshop
    902 x 765 - 97K
    Post edited by Peter Wade on
  • info_b3470fa520info_b3470fa520 Posts: 901
    This looks normal HeadShop 11. (Disregard the HeadShop 6 in the header - it is an error). In regard to the tutorial: find it under Help menu in HeadShop. It is linked to this pdf file: https://printahead.net/wp-content/uploads/2018/09/HeadShop11manual.pdf
    Post edited by info_b3470fa520 on
    Sorry, now I look at it more closely I understand. I didn't see why I had a much smaller window without so many options. Now I see that in the tutorial you ticked the View/Change Figure Settings box. That came up as unselected when I did it. When I tick that box it does look like the tutorial.
    Thanks for the explanation. My screen resolution is 1920 x 1200. Is it too high?
    Below is one of my tests on Genesis 2 Female.
    It will be even more fun, if I figure out, what is causing the distorsion around the ears.
    This one is with the material from https://www.daz3d.com/beautiful-skin-iray-genesis-2-female-s
    1280 x 1080 - 244K
    1280 x 1080 - 234K
    1280 x 1080 - 274K
    Post edited by Artini on
  • What was the original picture you used?
    My jaw joint around the ears has distortions although not as bad as some of the pictures I've seen here. It depends a lot on how the jaw is flexed.
    It was the one from https://movieplayer.it/foto/vivien-leigh-disperata-in-una-scena-del-film-via-col-vento-1939_216059/
    but cropped to the head only.
    By the way, has anybody tried using black and white pictures as a reference in Headshop?
    I have not tried yet, but it will be probably easy to fix in Character Creator 3
    or maybe even in Hexagon.
  • I bought Headshop 11 directly from the vendor when it was first mentioned on here, and I can confirm that Laslo does try to resolve bugs where found, and releases updates.
    If your source photograph is a three quarter view, or the person is smiling, ( which the vast majority of available portrait photos are ) then it's the only game in town really.
    I find the results, while not 'perfect' are a big improvement over previous versions.
    That was exactly, why I have bought it. During the years, I have bought all of its previous versions, as well,
    because I want to support the development of such an interesting program.
    Thanks!! It means a lot to us to appreciate the two year's worth of development we put into HeadShop 11.smiley
    I really like, how well HeadShop 11 capture the smile.
    This feature alone is worth a lot for me - great work.
    Below is an example render of HeadShop 11 produced character, based on Genesis 3 Female.
    1280 x 1080 - 236K
    Be nice to see the same character but with the smile expression remove with the morph slider. Is that possible?
    Maybe. You get better results if you do the smile removing DAZ Studio/Parameters/Posing :-)
    Another example of Genesis 3 Female based character.
    1280 x 1080 - 369K
    ... and one more  on G3F
    1280 x 1080 - 217K
    This is pretty awesome!
