Daz Studio Pro BETA - version 4.11.0.335! (*UPDATED*)
Daz SoftwareDaz Software Posts: 44
edited May 2019 in Daz Studio Discussion
Daz 3D is pleased to announce Daz Studio Pro BETA - version 4.11.0.335!
Highlights:
4.11.0.335 (April 17, 2019) - IN PROGRESS
  • NVIDIA Iray
    • Integrated Iray 2018.1.3 (312200.3564); see post for more detail
    • REQUIRES NVIDIA Driver 418.81 (or newer); see NVIDIA Driver Downloads
    • Windows 8/8.1 Users:
      • Until a new driver that addresses the issue is released by NVIDIA (potentially early May), rendering with a GPU based on the Kepler microarchitecture is likely to fail and fall back to CPU: (cards with a code name that starts with GK#)
  • Scripting API
    • Made many additions in various areas; see the Change Log for more detail
  • Fixed bugs and/or made improvements in various areas; see the Change Log for details
4.11.0.236 (October 9, 2018)
  • Bug fixes
    • Fixed an issue with operating system version logging on macOS 10.11 and later
    • Fixed an issue that was causing detection of macOS 10.14 (Mojave) to fail and the application to crash
  • Batch Convert pane
    • Now supports drag-n-drop from asset views (e.g., Content Library pane, Smart Content pane, etc.)
    • Now supports drag-n-drop from the OS file browser (e.g., Explorer, Finder)
    • Now uses the version and type of the script file read when saving the converted file
  • Scripting API
4.11.0.231 (October 1, 2018)
  • dForce
    • Fxed an issue that prevented polylines from being used in Dynamic Surface Add-Ons
    • Fixed kernel build issues on some AMD devices
  • Geometry Editor tool
    • Added an option to control the Point Size when Vertex Selection is the active Geometry Selection Type
    • Added an option to control Highlight Color of selected Group list items; regardless of Geometry Selection Type
    • Added an option to control the Point Size for vertices that participate in selected Detail indices items
    • Added an option to control Highlight Color for vertices that participate in selected Detail indices items
    • Geometry Selection Type is now saved/restored between sessions of the application
  • Node Weight Map Brush tool
    • Selection Analysis now draws highlight vertice(s) regardless of Geometry Selection Type; previously limited to Vertex Selection
    • Added an option to control the Point Size for Selection Analysis
    • Added an option to control the Highlight Color for Selection Analysis
    • Added an option to control the Weight Point Size when Weight Display > Draw Weighted Vertices is active
    • Brush Mode is now saved/restored between sessions
    • Changed the label of the "Edit Gradient Colors…" action to "Edit Weight Display…"
  • Content Library pane
    • The Add Asset ("+") button is now explicitly enabled for all (non-virtual) folders within the native formats container
    • Fixed issues relating to whether or not the "Delete…" or "Remove Reference…" action in the context menu for assets is shown
    • The "Remove Orphaned Reference(s)…" action in the context menu for assets is now consistent with the "Remove Reference(s)…" and "Delete…" actions in that it now displays a confirmation message
    • The "Remove Reference(s)…" and "Delete…" actions in the context menu for assets will now also list the relative path for orphaned references
    • The "Browse to Folder Location…" action in the context menu for folders/assets is now only displayed if the path of the folder actually exists on disk
    • The "Browse to File Location…" action in the context menu for assets is now only displayed if there is a single asset selected and the path of the asset actually exists on disk
    • The "Open in Script IDE..." action is now displayed when multiple (non-encrypted) script based assets are selected
    • The "Cut" and "Copy" actions in the context menu for assets are now omitted unless the number of selected non-orphaned references exceeds the number of orphaned references; cut/copied orphans cannot be pasted
    • The "Refresh" action in the context menu for assets has been moved to the bottom of the menu
    • Copying an asset and pasting that asset to a product now includes the metadata for that asset
  • Database Driven Asset Views (e.g., Smart Content > Files, Smart Content > Products asset view, Posing > Presets, Shaping > Presets, Surfaces > Presets, etc.)
    • Added the "Create Custom Action..." action to context menu for assets
    • Added the "Open in Script IDE..." action to context menu for assets
  • Create Custom Action
    • The label of the action now includes an ellipsis ("...") to indicate that additional interaction by the user is required
      • An option for choosing a (predefined) Root Menu has been added; Scripts or Favorites
      • An option for providing (selecting) a Submenu has been added; the popup is dynamically displayed/populated based on the submenu hierarchy within the chosen "Root Menu"
    • The action now supports multiple selection; the action text reflects selection count
    • The action now finds pre-existing custom actions based on matching descriptions or scripts/paths
    • The action now provides improved feedback to inform you what was and/or was not done, and why
    • The action now correctly handles assets installed via Daz Connect
    • The action now produces updated embedded code
    • The action now updates an existing (partial) match if the Control keyboard modifier (Ctrl/Cmd) is pressed when the dialog is accepted
  • Content DB Editor... Action
    • Fixed an errant message that indicated the Content Library pane could not be found in a case that it had been found
    • Fixed an issue where triggering the action without first having a container selected in the Content Library pane would result in a crash
    • Now allows editing of product asset containers and any asset containers that contain assets
  • aniMate 2 trial
    • Fixed a regression that prevented the trial period from working before reverting to aniMate Lite
  • Script IDE pane
    • Added a "Close All Except Current" action to the File menu; in the pane menu bar and in the script document context menu
    • The "Go to Line" dialog now handles pressing of the [Return] key while the "Line:" spinbox has focus the same as clicking the "Accept" button
  • Scripting API
4.11.0.196 (August 21, 2018)
  • NVIDIA Iray
    • Fixed a packaging issue that caused unnecessary (and potentially conflicting) files to be included
  • dForce
    • Fixed a crash caused by hiding all of the geometry for an object from simulation using the "Visible in Simulation" property on the surface(s) instead of using the "Visible in Simulation" property on the node
  • Content Loading
    • Reverted changes to limit unlocking on DSON file load
      • This was causing products that depend on compound property limits and ERC driven values to behave other than intended - e.g., collapsing thighs
  • Content Saving
    • Fixed an issue in Figure/Prop Asset Save Options with not being able to save both Compatibility Base and Compatible With
    • Made database speed improvements to the creation of metadata for new files
  • Content Categorization
    • Added a "Create Category Path..." action to the Content Library pane context menu for category containers
    • Fixed labeling issues in the Content Library pane "Create Sub-Folder…" and "Create New Sub-Category…" dialogs
  • Primitive Creation
    • The Create > New Primitive… action now causes surfaces of the created nodes to automatically use the default material type for the active renderer; e.g., Iray Uber material is applied if the active renderer is NVIDIA Iray
    • The label of nodes created using the Create > New Primitive… action now have a leading uppercase character
  • Node Grouping
    • Fixed an issue with (re)parenting taking a significant amount of time on figures with many properties
  • User Interface
    • Fixed an issue on the Tool Bars page of the Window > Workspace > Customize… dialog that caused actions, custom actions, and custom widgets to only exist in one toolbar instead of only once in a given toolbar
  • Scripting API
4.11.0.171 (July 16, 2018)
  • Application Permissions
    • Running the primary application executable with elevated permissions on Windows (e.g., "Run as administrator") is now prevented; running with elevated permissions can cause conflicts with accessing folder/files/registry keys; the application itself does not (and should not) require elevated permissions to run
      • A helper application requests elevation as required and is limited to necessary operations
  • NVIDIA Iray
    • Integrated Iray 2018.0.1 (302800.3495); see below for more details
      • Increases hardware requirement to Kepler class or newer generation GPUs; recent driver recommended
    • Added support for Deep Learning Denoiser (see "Post Denoiser" below)
    • Render Settings pane
      • Added "Post Denoiser Available", "Post Denoiser Enable" and "Post Denoiser Start Iteration" properties to the "Filtering/Post Denoiser" property group
        • "Post Denoiser Available" must be enabled prior to starting a render in order to cause the other "Post Denoiser" properties to be revealed and have meaning
      • Removed "Noise Filter Enable" property
        • Redundant with "Noise Degrain Filtering" being 0 (off) or >0 (on)
      • Added tips to the Advanced page of the Render Settings pane when NVIDIA Iray is the active renderer
    • Iray Uber Shader
      • Fixed an issue with inverted normals on thick translucent surfaces (e.g., Skin)
      • Added a "Invert Transmission Normal" property
        • Flips the direction of the normal vector (e.g., bump/normal maps) for transmission
      • Added a "Round Corners Roundness" property
        • Determines how round the edge will look
        • Valid range is [0.0, 1.0]; 0.0 chamfers the edge, 1.0 gives a rounded edge
  • dForce
    • Added support for polylines to Dynamic Surface Add-On
  • OBJ Import
    • Added a "Read Faces" option
    • Added a "Read Polylines" option
  • OBJ Export
    • Added a "Write Faces" option
    • Added a "Write Polylines" option
  • Hexagon Bridge
    • Fixed an issue with transparency when using Iray Uber shader
  • Node Properties
    • Added a "Visible in Viewport" property to nodes
      • When enabled (default), the geometry/avatar for a given node is drawn in the viewport
      • When disabled, the geometry/avatar for a given node is not drawn
      • When disabled and the node is selected, the bounding box for the node is drawn (draw style settings permitting)
    • Reordered node properties to better suggest that the "Visible" property is a superset of "Visible in *" properties
    • Changing the state of the "Visible" property on a node now causes dependent properties to be dynamically hidden/shown
    • Changing the state of the "Show Bones" property on a skeleton now causes dependent properties to be dynamically hidden/shown
  • Mouse/Cursor handling
    • Rewrote a significant portion of the mouse event pipeline for viewports, view tools and sliders in order to address timing issues brought on by OS and/or driver updates that manifested in a percievable "jump" for a growing number of users
    • Changes made have an impact in the following areas:
      • Viewport (i.e., shortcut navigation)
      • Viewport Tools (e.g., Camera Cube, Pose Tool, Universal Tool, Rotation Tool, Translation Tool, Scale Tool, etc.)
      • Viewport Controls (e.g., non-docked viewport controls)
      • Mouse Buttons (e.g., docked viewport controls, View pane)
      • Sliders (e.g., Parameters pane, Posing pane, Shaping pane, etc.)
      • Remote operation
        • All clients tested have been significantly improved
        • Responsiveness depends heavily on the frequency of mouse events
          • RDP has performed the best in internal testing
  • User Interface
    • Updated default menus; recommend clicking Window > Workspace > Update and Merge Menus
    • Customize dialog
  • Content Directory Manager
    • Added support for "CMS Cluster Directory"
      • Allows a Content Set to specify a different database
    • Updated context menu and buttons item entries/states for Cloud Data items
    • "Fast" stop mode is now used instead of "Immediate" stop mode when switching CMS Cluster Directory; safer
  • Script IDE pane
    • Added the ability to edit version and file type information for non-encrypted scripts
    • Saving an encrypted script now checks for an existing file and prompts accordingly
    • Reloading an encrypted script no longer causes that script to fail on subsequent executions
    • Action enabled/disabled states for a given script tab's context menu now update properly
    • A portion of the Edit menu is now dynamically populated (immediately prior to first display, or when refreshed) from the folder/file structure of specified directories on disk
      • "<application_home>/resources/Script IDE/…" and "<mapped_native_dir>/data/resources/Script IDE/<vendor_name>/<product_name>/…" and "<daz_connect_product>/data/resources/script ide/<vendor_name>/<product_name>/…"
      • Where an adjacent PNG exists, it will be used for the script action's icon
    • Added several new script based actions to the Edit menu
    • Added support for file IO event scripts
      • Scripts that are executed if they exist when specific operations are performed (i.e., _new.dsa, _open.dsa, _save.dsa)
  • Scripting API
Important Notes:
!! IF YOU HAVE NOT UPGRADED TO THE 4.9 GENERAL RELEASE, IT IS HIGHLY RECOMMENDED THAT YOU BACKUP YOUR CONTENT DATABASE IN DAZ STUDIO 4.x BEFORE LAUNCHING THIS VERSION !!
How do I backup my User Data in Daz Studio?
!! IF YOU HAVE NOT ALREADY MIGRATED FROM THE VALENTINA DB BASED CMS, IT IS HIGHLY RECOMMENDED THAT YOU MIGRATE TO THE POSTGRESQL BASED CMS BEFORE LAUNCHING THIS VERSION !!
Has the Content Management Service (CMS) changed?
For anyone using a pre-4.9.x build of Daz Studio:
  • The first time you launch Daz Studio 4.9+, any data that exists in the content database is migrated so that it can be used in Daz Studio 4.9+.
  • The amount of time the database migration operation takes is proportional to the amount of data to be migrated.
  • The database migration operation does not delete the data that it migrates from the previous location so that it remains accessible by earlier versions and other applications, such as Carrara.
  • Daz Studio 4.9+ uses the same PostgreSQL database as Daz Studio 4.6 and later, and/or other applications, such as Carrara.
  • A portion of the data contained within the database is shared amongst versions but not entirely. For example:
    • Creating a category in either Daz Studio 4.9+ or 4.8 will cause that category to exist in the other version
    • Assigning a file to that category in Daz Studio 4.9+ will NOT cause that file to be assigned to that category in Daz Studio 4.8
    • Assigning a file to that category in Daz Studio 4.8 WILL cause the file to be assigned to the category in Daz Studio 4.9+
  • Reseting the database in any version of Daz Studio that uses PostgreSQL (e.g., 4.6 or later) will purge all of data in the database, including any data that may be used by earlier versions or other applications, such as Carrara.
  • After the initial migration operation, edited metadata in Daz Studio 4.8 will not be migrated to Daz Studio 4.9+.
    • A workaround is to export User Data from Daz Studio 4.8 and reimport User Data in Daz Studio 4.9+.
Frequently Asked Questions:
General Release Threads:
Post edited by rbtwhiz on
«13456732
  • rbtwhizrbtwhiz Posts: 2,485
    Has the NVIDIA Iray renderer been updated?
    Yes, it has.
    *Note: The entries below come directly from the NVIDIA Iray 2018.0.1 release notes. Some entries, such as any mention of Linux, etc, currently have no bearing on Daz Studio itself but are included for completeness.
    Iray 2018.0.1, build 302800.3495
    Added and Changed Features
    • AxF Importer
      • The AxF SDK 1.5.1 has been integrated. This adds support for GGX fitting targets (AxF SVBRDF profile version 3).
      • Carpaint with less than 3 specular lobes are now handled correctly.
      • The compatibility of carpaint flakes has been improved.
      • The sub-clearcoat component baking has been fixed for the case that all lobes have zero roughness.
      • An importer option axf_module_prefix can now be used to modify the module name under which imported MDL is stored. Defaults to axf (which is the previous behavior).
      • The changes require that the updated nvidia/axf_importer/axf_importer.mdl is used.
    • Iray Interactive
      • Extended the handling of shadow rays for section plane capping in IRT Now the case of shadow rays through semi-transparent materials is handled correctly and it matches the Iray Photoreal result. Handling of camera rays through semi-transparent materials added. The result does not match Iray Photoreal.
    • Material Definition Language (MDL)
      • Compilation time for very simple material expressions has been improved.
    Fixed Bugs
    • Iray Photoreal & Iray Interactive
      • If bump map parameters of MDL layering functions (e.g. df::weighted_layer) were not explicitly provided, they did not correctly default to state::normal() but to the inherited normal of the current BSDF (e.g. a parent layer’s bump). This has been fixed.
    • Iray Photoreal
      • For the caustic sampler, dispersion with spectral rendering enabled was handling wavelengths incorrectly. This bug led to rainbow-colored caustics, even if the emission spectrum was narrow and has now been fixed.
    • Iray Interactive
      • Fixed missing emission from emissive objects with decals in IRT Objects with emissive materials would not actually appear emissive in IRT if they had decals assigned.
      • Fixed brightness differences between IRT and Iray Photoreal for irradiance probes.
      • Fixed wrong appearance of section plane colors for IRT when one of their component is negative. Result now matches Iray Photoreal.
      • Fixed an issue with brightness levels in IRT when using clipping planes. The problem was due to VPLs not being placed in a scene that was completely enclosed but also having a clipping plane that would cut it open - it would suddenly turn bright when the camera moved inside it.
      • Irradiance probes had shown strong sampling artifacts. With this extension the sampling patterns disappear entirely in some scenes, in some others they change into other patterns but they are a lot less annoying than before.
      • Fixed the handling of MDL archive conflicts in the same search root: it is an error if a qualified MDL name, or its prefix, can be resolved in more than one archive or package.
      • The MDL core compiler now explicitly generates an error message if a variant of a function returning a deferred size array type is created, which is forbidden by the MDL specification. Before, this case was forbidden, but the error message was "undefined symbol" for the deferred array size symbol.
      • The archive API now creates MDL archives in strict mode, i.e. forbids MDL modules that do not strictly follow the MDL spec.
      • The usage of the ternary operator at the root of a compiled material is now avoided by the MDL compiler. Instead, the operator is moved down to ensure that the root is always a material construction.
      • Rare random crashes during JIT compilation for CPU have been fixed.
      • Inconsistent sampling between the CPU and GPU version of the mi::neuraylib::IBaker has been fixed and sampling now takes place at the center of the pixel when only one sample per pixel is requested for baking.
    • Deep Learning based Denoiser
      • Denoiser had a problem to denoise green noise. Fixed with new training run for HDR and LDR images.
      • Fixed denoising alpha channel when memory tiling has become effective.
      • Fixed the issue that when Denoiser runs on multiple GPUs that the image sometimes was garbled.
      • Resolutions was clipped at 3000, now replaced by accurate calculation.
    Iray 2018.0.1, build 302800.1716
    • AxF Importer
      • The conversion of the car paint sub clear coat material has been improved:
        • The directional color curve is now fully represented which yields correct rendering of color shifting paints.
        • Car paints with refractive clear coat are now supported.
        • These improvements are realized via measured BRDFs in MDL. This behavior can optionally be disabled by a material parameter: if disabled, the material will not use the measured BRDF and potentially render incorrectly though.
      • Car paint flakes are now supported by a dedicated procedural:
        • Flake statistics are derived from the measured flake BTF data in the AxF.
        • Flakes are enabled by default if present in the AxF file. They can be disabled by a material parameter.
        • The material exposes artistic controls to modify flake size, intensity, and reflection roughness.
      • Section plane capping has been implemented.
        • This adds two new options: "section_caps_enabled" (default off) that enables section caps. If the feature is enabled, parts of the objects that are cut open by a section plane will be closed with a virtual surface along the section plane. The surface has a diffuse material with a color that can be controlled via the "section_caps_color" option.
        • Note that the detection of which parts to cover depends on normal orientation and that surface and geometry normals must be oriented consistently.
    • Iray Phtoreal
      • Ray tracing performance on Volta has been improved.
    • Iray Interactive
      • GPU ray tracing performance has been improved along with memory usage being decreased.
      • MDL 1.4 support has been added:
        • All newly defined MDL 1.4 distribution functions have been implemented.
        • UDIM-style texturing is now supported.
        • The new standard annotations ui_order(), enable_if(), thumbnail(), and usage() have been added.
        • The quality of the MDL distiller results has been improved.
      • A note about the expected HDR range: the RGB values in the color buffers must not be too low (dark). The HDR version of the denoiser expects the RGB values in the range from zero to 10000. If they are too low, like close to zero, the denoiser might create wrong colors and artifacts in the denoised image. This will be simplified in the next version of Iray. An automatic exposure control will be provided in a future version of the denoiser.
    Fixed Bugs
    • General
      • Enabling "TITAN Xp Star Wars Edition" GPUs has been fixed. These cards are now properly recognized.
    • AxF Importer
      • The sample_size_u and sample_size_v material parameters are now correctly set for carpaint materials.
      • The implementation of df::thin_film previously converted the ior parameter to a scalar. It is now correctly used as a color.
      • The incorrect implementation of the curve of df::directional_factor has been fixed.
    • Iray Photoreal
      • A regression in backplate quality has been fixed.
      • Random crashes in the MDL compiler during displacement of special materials have been fixed.
      • Variants of materials with default values containing relative resource URLs have been fixed.
      • Using a material parameter for the gamma mode of texture material parameters has been fixed.
      • Functions returning size-deferred arrays with the same size as a parameter but a different element type have been fixed.
      • MDL compiler auto-import of enum values has been fixed.
    Iray 2017.1.4, build 296300.6298
    • General
      • Support for Tensor Core on Volta GPUs has been added to the denoiser. The Tensor Core accelerates inference in the denoiser up to three times on GV100 GPUs.
      • Denoiser training sets have been updated. Features are preserved better.
      • Automatic tiling in the denoiser has been improved to reduce memory consumption.
      • Support for PCX in the FreeImage image plugin has been disabled due to security issues.
      • Ambiguous overload error messages in the MDL compiler have been improved.
      • MDL compiler error messages have been improved regarding semantic version numbers.
    Fixed Bugs
    • General
      • A bug in the Iray Bridge networking code has been fixed that could cause slowdowns and even connection timeouts for scenes with a huge number of elements.
      • An incorrect conversion of the anisotropy rotation in the axf importer plugin has been fixed.
      • An incorrect weighting of the sub-clearcoat BRDF for carpaint has been fixed that generally resulted in a too dark appearance.
      • Numerical issues with self-intersection with instancing enabled have been addressed. Bug #18605 and #17748.
      • Using a bloom postprocess no longer sets the alpha channel to zero for RGBA images.
      • The camera attribute tm enable tonemapper is now correctly handled when using Iray Bridge.
      • An issue has been fixed where GPUs were not properly detected on Grid. Nvbug #200336679.
    • Iray Photoreal
      • The normal buffer now outputs a weighted average of all BSDF bump maps, not only the main material bump.
      • The normal buffer now always creates normalized output, even if the camera transformation contains scaling.
      • The firefly filter heuristics have been improved.
      • Fix rare appearances of NaN of Infinity floating point values in the output buffers.
      • User mode instancing has been partially fixed. Geometry is now flattened into the lowest ancestor in the scene graph with the instancing attribute set to false. If none such ancestor exists the object is flattened into the root node. Bug #18683.
    • Iray Interactive
      • The computation of the ray depth through cutouts has been fixed. Bug #18652. Previously, there could be crashes on CPU or hangs on GPU. This also addresses a potential hang in the render call to Iray Interactive. Bug #18621.
      • Various crashes and artifacts in network mode have been fixed.
      • Missing or wrong MDL compiler warnings regarding dependency annotations have been fixed. Bug #18417.
      • MDL compiler auto-import has been fixed. Bug #18656.
      • A missing major version dependency check for imported MDL modules in the MDL compiler has been added. Bug #18416.
      • Missing index functions for arrays of imported types haven been added.
      • A wrong limit for the over?ow check on decimal literals has been fixed.
      • A crash on CPUs with AVX512 capabilities has been fixed.
      • A useless/wrong error message containing <ERROR> as a type name has been fixed.
    Iray 2017.1.3, build 296300.4444
    *Note: No Iray SDK 2017.1.3 has been released. Only a MDL SDK 2017.1.3 has been made available.
    Iray 2017.1.2, build 296300.3713
    • Iray Photoreal
      • The performance when rendering a scene with camera transform motion, but without geometry transform motion, has been improved.
      • The "tm_enable_tonemapper" attribute has been added to be able to specify a tonemapper that will only be used to steer the firefly filter, but will not actually tonemap the image.
    Fixed Bugs
    • General
      • Html5 video support for newer versions of Chrome (>= 62) has been fixed.
    • Iray Photoreal
      • A crash with object motion has been fixed. The crash was triggered when using OptiX Prime and rendering on CPU and GPU at the same time.
      • Rendering with the caustic sampler enabled and MDL materials requiring JIT compilation could fail with high probability on the GPU and fall back to CPU rendering, which has now been fixed.
      • A regression of convergence performance (e.g. more noise) has been fixed that was visible mostly in simple materials/lighting setups like a diffuse object lit from a mostly uniform environment.
      • The handling of 3d textures in the CUDA baker has been fixed.
      • The gamma correction of used textures when baking MDL expressions on the GPU has been fixed.
      • A GPU memory leak in the baker if CUDA baking is used, has been fixed.
    Iray 2017.1.1, build 296300.2915
    • General
      • A dependency to vcomp110.dll in FreeImage 3.17.0 introduced in Iray 2017.1 beta has been removed.
    Fixed Bugs
    • General
      • If a device crashed, the CPU rendering fallback wasn’t triggered. This has been fixed.
      • Iray 2017.1 introduced a performance regression. "Light-weight" changes like changing the camera between rendering calls caused an unnecessary copy of the internal scene representation, which for larger scenes led to a considerable slowdown. This has been fixed.
      • A crash has been fixed that could occur when distilling MDL materials that used a mix of bsdf components that were only default initialized or empty.
      • A regression in the look of some backplates, including backplates using the color offset or color scale features has been fixed.
      • Adaptive network bandwidth control was throttling down network bandwidth more than intended in a rare case. This has been addressed.
    • Iray Photoreal
      • Unnecessary render restarts if rendering with more than one render context are now avoided.
    • Iray Interactive
      • Artifacts with stereo images and SSIBL (screen space image based lighting) have been fixed.
        • When rendering two stereo images at once.
        • When rendering a stereo image for one eye with spherical camera.
        • When rendering in batch mode.
      • Wrong colors when using scalar input/mono mode textures have been fixed.
    Iray 2017.1, build 296300.2288
    • General
      • The render mode Iray Realtime has been removed from this release.
      • Only certain scene elements can appear as children of instances and groups. It is no longer possible to attach other scene elements.
    • .mi importer/exporter
      • Support for reading and writing builtin attributes of type mi::Float64 has been added to the mi importer and exporter by mapping them from and to "scalar".
    • Resources (textures, light profiles and BSDF measurements)
      • The default interpolation of IES light profiles in case the input grid is not equidistant has been improved.
    • Iray Photoreal
      • A new scene option "matte area lights visible" has been added to make matte area lights optionally visible.
      • The degrain filters have been re-enabled.
      • The scene option "animation_time" is now passed to /tt mdl_state::animation_time when rendering with Iray Photoreal or Iray Interactive.
      • The default baker resource in IMdl_distiller_api::create_baker() has been changed to BAKE_ON_CPU.
      • Distilling now supports compiled materials created with class compilation (flag Compilation_options::CLASS_COMPILATION in function call IMaterial_instance::create_compiled_material).
      • The function ICompiled_material::depends_on_global_distribution() has been added.
      • Generated PTX code is now cached in order to improve performance when baking the same expression more than once.
      • Support for the bidirectional scattering distribution function (BSDF) in nvidia::df has been added to the MDL distiller targets.
      • The denoiser now attempts to automatically adapts the GPU memory usage to the memory available on the GPUs. This allows to denoise larger images even on GPUs with relatively small memory sizes.
      • The log output when using the deep learning based denoiser has been improved.
    Fixed Bugs
    • General
      • A crash bug in Iray Bridge when decoding using the NVIDIA hardware h264 decoder because of an incompatibility with CUDA 9.0 has been fixed.
      • A crash bug when editing a material on a mesh with multiple materials has been fixed.
      • The .mi export of MDL material attributes has been fixed.
      • Attributes of MDL material instances were not correctly exported to the .mi format, causing syntax errors on following imports. This has been corrected.
    • Iray Photoreal
      • Negative "nominal_luminance" values are now clamped to zero.
      • Rendering errors which happened in some cases when using the deep learning based denoiser with Iray Photoreal and multiple hosts have been fixed.
    • Iray Interactive
      • A bug causing too bright lighting with translucent materials and irt_indirect_light_mode==2 has been fixed.
      • A bug causing triplanar projections to be ignored has been fixed.
      • Spotlight material was always facing the +Z axis when applied to emissive geometry. This has been fixed.
      • A bug has been fixed that caused erroneous behavior when setting the aperture blade count to 1 or 2.
      • A bug causing erroneous ground shadows in the left eye image when rendering stereo images has been fixed.
      • A crash which appeared in some cases when using the same texture in multiple texture slots of an MDL material has been fixed.
      • A crash which appeared in some cased when using Iray Interactive with the deep learning based denoiser has been fixed.
      • A crash bug in the MDL distiller that could occur when diffuse BSDFs were combined for the diffuse_glossy target has been fixed.
      • A crash bug when distilling a simple_glossy_bsdf in an MDL module of MDL version 1.2 or lower has been fixed.
      • A bug in the distiller when encountering a 0-initialized normal has been fixed.
      • A bug in the distiller causing materials with mixed EDFs to fail has been fixed.
      • A a crash in the MDL compiler which occured when compiling a material expression containing a call to float3(float,float,float).y(float3) created using IExpression_factory has been fixed. Bug #18530.
      • NULL is now returned if IValue_factory::create_invalid_df() is called with an argument of a resource type instead of a distribution function type, which fixes a crash bug.
      • Crashes happening in some cases in the MDL compiler when used in multi-threaded environments have been fixed.
    Iray 2017.1 beta, build 296300.616
    Known Issues and Restrictions
    • General
      • The FreeImage plugin now uses FreeImage 3.17.0. On Windows, this adds a dependency to vcomp110.dll. The dependency will be removed in a later release.
    • General
      • Iray is now CUDA 9 based to allow for compute version 7.x (Volta generation) support.
      • Support for compute version 2.x (Fermi generation) has been removed due to CUDA 9.
      • Color conversions have been optimized.
      • The color space of AxF import is now configurable.
      • On Linux, plugins are no longer loaded with the RTLD DEEPBIND flag since it causes problems with Address Sanitizer (see https://github.com/google/sanitizers/issues/611). The original reasons for that flag are gone, and its absence did not reveal any problems so far.
      • The performance of both decals and projectors handling when adding or removing decals or projectors, respectively, has been improved.
      • NaN value handling in .mi import and export has been generalized. Whenever the .mi exporter detects NaN values in geometric data, it dumps them in the appropriate format. This enables the .mi importer to detect these values and replacing them by the value '1.' allowing the continuation of the import. Both exporter and importer warn about such occurrences.
      • If the methods reset_file() or reset_reader() fail, they no longer change the resource in any way.
      • The loading of light profiles with non-equidistant angles has been improved. If no explicit resolution is specified in the API call, we attempt to choose a resolution that maintains the angles given in the .ies file as close as possible.
    • Iray Bridge
      • Support for a camera sub-window has been implemented for streaming mode (scheduler mode set to interactive or synchronous). This was only supported with scheduler mode set to batch before.
      • Nvenc (NVIDIA h264 hardware encoder) can now handle the Rgb pixel type natively in addition to Rgba.
      • Nvcuvid (NVIDIA h264 hardware video decoder) can now handle the Rgb pixel type natively in addition to Rgba.
      • Hardware h264 video decoding has been disabled for Fermi GPUs since they are no longer supported by Bridge.
      • The cloud render context options "video_formats_interactive" and "video_formats_batch" of type String[] have been added that control the video format per canvas for interactive/synchronous and batch scheduler mode, respectively. The old video_format option remains and is equivalent of setting/getting video_formats_interactive[0].
      • The min/max_bitrate cloud render context option is used as the total bitrate and will now be evenly divided amongst all the layers of all canvases of the render target. Previously, each layer would get the specified bitrate rather than share it since multi-canvas/layer was not taken into account.
      • Support has been added for the special Bridge video format "disabled" which is handled just like any other video format except that no data is sent with the frame and the video sink will receive a canvas with resolution 0x0. This feature is supported by Bridge Video, so it can also be used by Dice Bridge applications.
      • A new image denoiser pass has been added. This deep learning-based pass replaces the previous degraining mechanism in Iray Photoreal. Consequently, the following options have been removed: "progressive_rendering_filtering", "iray_black_pixel_filtering_max_frame", "iray_degrain_filtering", "iray_degrain_filtering_radius", and "iray_degrain_filtering_blur_difference". They are replaced by "post_denoiser_available", "post_denoiser_enabled", and "post_denoiser_start_iteration". See the manual for details.
      • All postprocessing operations can now run on either CPU or GPU so interactive performance is further improved if a CUDA capable device is enabled.
    • Iray Photoreal
      • Convergence speed on long running renderings has been improved.
      • Interactive performance in general has been optimized.
      • A new refract_backplate option has been added: instead of only thin walled materials, perfectly specular/refractive materials are now also allowed to connect to the backplate image.
      • The performance on compute version 6.0 cards (Pascal generation) has been optimized.
      • Texture sharing on NVLINK capable systems: A new render context option "iray_nvlink_peer_group_size" has been added. Enabled CUDA devices are divided into peer groups of the specified size. The group size needs to be a factor of the total number of enabled CUDA devices. Textures are subsequently shared between CUDA devices in a peer group and each texture is only uploaded to one of the devices in the peer group.
      • Vertex motion blur support has been added.
      • The performance for many non-overlapping decals on a single object with tight decal bounds has been improved.
      • Noise for volumes with a colored scattering coefficient has been reduced.
      • The firefly filter is now less agressive, most notably, glossy highlights are usually more correct now.
      • The (already deprecated) architectural sampler has been removed.
    • Iray Interactive
      • Support for cpu fallback in the render configuration has been added.
      • The interface IModule has been extended to allow enumeration of constants as well as struct and enum types declared in an MDL module.
      • The methods set_name() and get_name() have been added to IValue enum. They allow setting and getting the value of an enum by its string representation.
      • The deprecated interface IValue_invalid_ref and enum value VK_INVALID_REF have been removed. Use IValue_invalid_df / VK_INVALID_DF for references to distribution functions, or the regular resource value interface with NULL as name for resources.
      • PTX code generation has been improved, leading to faster rendering performance if JIT compilation is triggered for a MDL material.
      • PTX code generation for newer GPU generations has been improved in addition.
      • The MDL core compiler now suggests the correction of possible misspelled entity names inside error messages.
      • Texture lookups in JIT generated code have been slightly speeded up.
      • The error handling in the MDL core compiler when a syntax error inside an enum value occurs has been improved.
    Fixed Bugs
    • General
      • Rare crashes that could happen while textures were processed have been fixed.
      • When the "enabled decals" attribute is given but is empty, all decals are now ignored altogether. Bug #18317.
      • When too many interactions happened between two transaction commits, there was a chance that some changes would get lost. This is now avoided and handled more conservatively. Bug #17528.
      • Projectors don’t have a bounding box. This was handled incorrectly before. Bug #18457.
      • Logging of license handling has been improved. In certain cases erroneous messages were issued. Bug #18450.
      • MDL array constructor function calls in .mi export are now ignored. This avoids issuing superfluous error reports from the .mi export. Bug #17336.
      • .mi export of indices for multiple texture spaces has been fixed. Indices for multiple texture spaces were pointing to the same vectors. Now each texture space is handled correctly. Bug #18349 and NvBug #1912271.
      • The parsing of incorrect $include lines has now better error reporting. Bug #18436.
    • Iray Bridge
      • A synchronization bug has been fixed where changes were not detected correctly when executing a sequence of Bridge jobs using the same transaction where changes were made between job executions.
      • Canceling a Bridge job could cause the transaction to be aborted in some cases. This has been fixed.
      • A bug has been fixed where no synchronous frame was requested when switching the video format. This is needed especially when switching from a lossy/disabled format to a lossless format to make sure that the returned frame contains all the data asked for.
      • Swirl on poles in stereo renderings has been fixed.
    • Iray Photoreal
      • Occasional stripes in the alpha channel have been fixed. Bug #294009.
      • Decal priorities were not correctly handled. This has been fixed. Bug #18280.
      • Light Path Expression results for some cutout opacity cases have been fixed.
      • Rendering artifacts when rendering only on the CPU and with the caustic sampler scene option enabled have been fixed.
      • Flake noise and mono bitmap recoloring have been fixed. Bug #18456.
      • When rendering light path expressions (LPEs) along with an alpha channel, the alpha channel is no longer constant 1.0, but now contains the correct alpha value for this LPE instead.
      • When using a solid color as the backplate, along with inverse-tonemapping of the backplate enabled, and enabled backplate contributions for reflections and/or refractions, the contribution of the backplate now has correct intensity (used to be too dark, depending on tonemapper settings).
      • Wrong cutout opacity handling (resulting in overall too dark renderings) in some rare cases has been fixed.
    • Iray Interactive
      • Slow startup times with measured materials have been fixed. Bug #18373.
      • A memory leak when destroying scopes has been fixed. Bug #18365.
      • The missing import of type names that are only used inside the default parameters when a material is created from a material Instance using the create material API has been fixed. Bug #18461.
      • A crash inside the MDL core compiler has been fixed that occured on rare conditions if a wrong function declaration was processed.
      • The start position of postfix expressions in the MDL core compiler that led to wrong positions inside error messages has been fixed.
  • nothingmorenothingmore Posts: 25
    edited July 2018
    Is anyone else experiencing significantly longer scene load and save times compared to 4.10? In other news resolving the mouse handling issue is a godsend.
    Post edited by nothingmore on
  • IceCrMnIceCrMn Posts: 2,331
    I'm having a problem getting a new dforce kerenel module compiled.
    I get the prompt telling me I need a new, I click "ok" it compiles for about 3 seconds then I get the error message popup saying "Error initializing OpenCL"
    attached is the log
    txt
    txt
    log.txt
    5K
  • barbultbarbult Posts: 26,590
    The kernels compiled OK for me, and I haven't noticed a slowdown in file loading or saving. My GPU seems to run a few degrees cooler while rendering. It may be too early to tell whether that is an illusion.
  • OstadanOstadan Posts: 1,130
    Crashes every time when dForce simulation applied (using the 'sheet' scene, for example).  Mac OS 10.12.6
  • nonesuch00nonesuch00 Posts: 18,830
    I thought that the event loop code for the viewports were going to be refactored but I saw no mention of that in the release notes. frown
    I am downloading but I guess if it's still way to slow with the Universal or Translate gizmos selected or with the viewport icons I will select Geometry Editor mode to escape from the viewport event loop using the Unversal/Translate/some other gizmos and pose via Puppeteer /Power Poser/Parameters tab
  • SpyroRueSpyroRue Posts: 5,020
    edited July 2018
    TY for the update!
    I just wanted to drop in and request the developers for an icon change for at least the beta to be visually distinguishable. For a while you guys used to change the colour per major iteration, but since 4.9 its been that same yellow. I really liked how it went blue then green then yellow, made it easy to click the right version lol - Yeah yeah I know, I can read... but its cut off on desktop icons DAZ Studio 4.11 (64-b... Plus if you like me and place it on the taskbar there is no words.. I had fingers crossed it would change when 11 arrived laugh
    Post edited by SpyroRue on
    edited July 2018
    I am still testing the viewport for event loop improvements but in my initial tests with the Universal Tool gizmo selected: the icon gizmos on the right f the viewport only need me hover over them a couple of seconds before mouse over event selects the correct gizmo & after clicking the requested action is pretty quick.
    So I have to try more complex scenes but the scene I testing with was moderately complex (recent products : Collective3D's Neighborhood, G8M with fibre hair & eyebrows & geoshell to be wet, & the Public Pool) so my great is A- on the event loop improvements!
    Thanks! laugh
    Second scene - not nearly as responsive but still doable with 5 - 10 seconds mouse over time. It uses the recent Tree Swing scene with swing hidden, G8M wearing G3M Highlander outfit, & same G8M character as previous scene. Still a B- though.
    Post edited by nonesuch00 on
  • DoctorJellybeanDoctorJellybean Posts: 9,792
    attached is the log
    What are your system specs, especially graphics?
  • ErrilhlErrilhl Posts: 20
    Huh... Installing the Beta (via DIM), goes fine, no issues - starting the Beta, no issues - checking the library: LOTS of issues. Basically, nothing is showing - I get "file not found" on every single asset. The assets are listed, but not working.
    Anyone got any ideas? I would prefer not having to reimport the database, but if that's what I need to do... :(
  • nickalamannickalaman Posts: 196
    Any clue how to render a stereo image, I''ve looked everywhere and I see no trace of it. But if you look and the changelog it's mentioned a few times.
    Iray Interactive
    Do you have the content paths mapped? If it is the first time that you have installed a Beta, you would need to map the paths in Content Directory Manager.
  • evilded777evilded777 Posts: 2,487
    /So.... where's the "see denoiser post below" Because I don't see it.  Unless its buried in ones of those Iray update posts.
    The main post(s) are still being edited, but in the meantime see the various Deep Learning Denoiser sections.
  • RAMWolffRAMWolff Posts: 10,373
    Weird.  I decided THIS TIME I'm going to use the beta but the only thing that's showing in my DIM are the plugins but no DAZ Studio 4.11 Public Bulid.  Did you guys pull it to fix some stuff?  I have all the appropriate boxes ticked off to get the Public Build's in my prefs so not sure what's going on!
    Looking into it.
    edited July 2018
    Having a strange problem with some poses, when the shin bends right or left it distorts the thigh. Once this happens the figure becomes corrupt and has to be reloaded. I've tested these poses in 4.10 and they work as expected. So not sure what's going on. This happens to the genesis 8 male amd female. Also not all poses that have a bend on the shin cause this problem. I have a bunch of poses i created and most of them have the same problem, not sure if anyone can test, i've also included the pose.
    Nick
    800 x 856 - 49K
    duf
    duf
    099v.duf
    233K
    Post edited by nickalaman on
  • Dolce SaitoDolce Saito Posts: 196
    edited July 2018
    Same here, double checking each step, exact same 4.11 stuff but no actual daz studio 4.11. Also funny that the same impression happened here as: "oh, they might have just found a serious production issue and pulled build back".
    Post edited by Dolce Saito on
    Just checked again, nada....
    Try leaving the limits on.
    The limits are on for rotation.
  • SnowSultanSnowSultan Posts: 3,803
    THANK YOU for fixing the wonky camera, now I can work with far less frustration again!
    I'm not sure if this is an issue or not, but I can't seem to save individual lights normally where they don't replace all others in the scene. Saving them as Scene Subsets works fine, but choosing "Selected lights" doesn't prevent them from clearing all others when loaded into a scene, even when drag/dropping them. Like I said, using Scene Subsets works great but I just don't remember if that's how saving lights has always been.
  • glaseyeglaseye Posts: 1,312
    Hmm. for some reason all but the ds 4.11 program files show up in DIM for me. The 4.11 beta files for decimator, measure metrics etc. show up. but NOT the program file itself. Checked my download filters and to be sure have set them that all available files show. When looking for 4.10 the DS 4.10 files show up.... Does DIM a hardware check before listing available files? (I don't have DIM on my render system, but on an older system, just and only for dl the beta versions, and that worked fine until now with the 4.11 version...... I DO NOT use DIM for installing/managing - I've got my own (preferred and tried, tested and working for a decade now) manual install.
