* Closed * RRRR Render Contest - Turn the tide
Totte
It's time for a new RRRR Render Contest!
The theme for this round is Turn the tide - The challenge of making the best of a bad situation. Something went south, but how was it turned into something better, like the classic when life gives you lemons, make lemonade.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Player | LBs |
| Totte | 3 |
| acb | 2 |
| Fae3D | 1 |
| katywhite | 1 |
| emanuela1 | 1 |
| luci45 | 1 |
| aprilshowers2065 | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread.
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Friday August 7 - 2026, and will go on until Sunday September 27 2026 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Dartanbeck is sponsoring with items from his store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/ ;
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
RRRR Good Intentions / Mixed up Mythology
https://www.daz3d.com/forums/discussion/727991/closed-rrrr-good-intentions-mixed-up-mythology-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/727986/rrrr-good-intentions-mixed-up-mythology-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/736086/rrrr-good-intentions-mixed-up-mythology-winners
RRRR - Unusual Laws / Refused Sports
https://www.daz3d.com/forums/discussion/737821/closed-rrrr-unusual-laws-refused-sports-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/737816/rrrr-unusual-laws-refused-sports-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/745691/rrrr-unusual-laws-refused-sports-winners-announced
RRRR - The Lyrics
https://www.daz3d.com/forums/discussion/745966/rrrr-the-lyrics-render-contest-closed/
Entries Only: https://www.daz3d.com/forums/discussion/745961/rrrr-the-lyrics-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/753416/winners-rrrr-the-lyrics-render-contest
RRRR It was a great idea but...
https://www.daz3d.com/forums/discussion/753491/rrrr-it-was-a-great-idea-but-render-contest
Entries Only: Entries only thread
Winners:https://www.daz3d.com/forums/discussion/758766/rrrr-it-was-a-great-idea-but-winners-announced
RRRR Remale or Sequel
https://www.daz3d.com/forums/discussion/758931/rrrr-remake-or-sequel-render-contest-closed/
Entries Only:https://www.daz3d.com/forums/discussion/758926/rrrr-remake-or-sequel-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/766341/rrrr-remake-or-sequel-winners-announced
Good to see a new RRRR up! (Even though it's too hot to render, so might have to use Filament. Ugh)
Pull #1:
808 Charlotte 8
4130 REAL Hairy G2M
1341 dForce Koralyn FrizzPonytail Set for Genesis 9
1417 East Asia for Genesis 2 Females
5608 Vignettes for Poolside (LB)
I need to clean out my Runtime again.
Lets see if I can get something done this time!
339 - CGI Essential Piercings for Genesis 9
50 - Aradior Point DS
262 - Member Festival Resin Trinket Tray Hex
153 - Cowgirl for Genesis 2 Female(s)
O.o
tag:luci45 #1
A New Kind of Beauty
Jax was proud of his muscular physique, but the body hair, not so much. When hard times hit and waxing and shaving became too expensive, he decided some colorful dyes could be attractive instead. Who knows, he might even start a fad?
pull:
808 Charlotte 8
4130 REAL Hairy G2M
Also Used:
Uerica Hair
All Seasons Dress
All Seasons Shoes
Olympia Skin
Young Pants and Shirt
Mary Janes Shoes G2F
Chace Hair
David 5
PHCool Hair
Mellow texture for Effortless Cool outfit
Koo Yaelle
Grow Freely Outfit G9
Cut for Gianni 6
Kyle Hair
SY Swimwear for Genesis 2 Male(s)
FG City Blocks Parts
IGD Laughing Poses for Genesis 8
Feeling Fruity OmniHair Shaders
@Luci45 #1: That's a brilliant solution to a tough problem!
Thanks, Totte.
Pull #2:
6015 Z My Smartphone Mega Set For Genesis 8 And 8.1
4928 Summerwear For Genesis
2316 i13 Lost and Found
4182 Reparation
3658 OOT HDR 360° Environments Space for DAZ Studio Iray
I finally got some time to sort out my list, and make a pull.
Pull #1
#3713 Castle Creator For Daz Studio (#82618)
#4569 Space Jump Gate (Rendo)
#373 Heat Up Outfit Textures for Genesis 3 Female(s) (#21971(
#5224 Particle Accelerator DS (#66217)
LB1: #3436 Mars the planet DS (#78736)
LB2: #1058 Chimera 2 (#23691)
LB3: #6199 Muelsfell Modular Buildings: Watchtower (#110941)
OK, 5 Environments, a Fantasy monster and Clothing set texture pack, who said it would be easy?
edit: saw it failed to attach the pull.
You have to turn the tide!
That's my cunning plan ... :P
First time player. Here's Pull #1
6636 - Modern Loft Furniture Set 001
9237 - Floor Cleaner
14905 - Drago Rider Royal Add-on
4294 - Wang 9 Elder Shape
Welcome, jecswp!
Welcome to the RRRR jecswp, enjoy the ride!
Thank you, @luci45! and @Totte! Excited to play. Here's my entry
Mystical Mitt of Muck
General Wang uses her broom baton to marshall her forces to turn the tide against the Mystical Mitt of Muck
Also used:
9224 Mystical Mitt
15070 Dragon Rider Outfit
3520 PT Modern Apartment
4970 Cityscapes Backdrops Vol. 3
Tag: Totte#01
Also Used:
Eva 7 + Heat Up Outfit for Genesis 3 Female(s) and Genesis 2 female(s) + Dragonfly Hair + Goth Boots + Accordion
M5 + On The Farm
Rama Drums + IG Gianni 6 + Drum Solo + Air Defender for Genesis 2 Male(s)
JP Darrow HD for Genesis 9 + Bristol Ridge Outfit + Horse Stable Props ( pitchfork )
Freja 9 + Rock On Misfits! Outfit for Genesis 9 + Elgrid Hair + Classic Rock Poses for Genesis 9, 8 and 3
Mobile Stage Trailer
Medieval War Camp ( Ground )
Harpsburg (sign )
RW Letters and More
Pyromantix
SY Real Fog Iray
LowPi Crowd Generation
LI Kinetic Arcana
Moonshine Drivein ( Fence )
Plugins, scripts, lights and shaders used:
Skies of Gaia Vol 2
MJFAT4 Atmouspheres Vol 4 Dawn To Dusk
PBS Shaders Vol. 3
RSSY 3DL To Iray
LP Reposition Crowd
Farmageddon
At the annual farm festival and fair in Gibsons Creek, the main music attraction cancelled due to sickness. Five farmers, who had auditioned for the gig, but was rejected, quickly made a set of heavy metal songs using AI, and entered the already set stage and ran a show playback. People filmed it with their phones, it went viral, and the heavy metal cult band Farmageddon was born.
@jesswp: You need to post your enrty in the Entries Only Thread , which is were voting is done.
Oops! I forgot. Thanks for the heads up.
Totte#1, Farmers, AI and Heavy Metal - that had to go viral! Great band name but they need bigger pyrotechnics.
Tag:aprilshowers2065#1
Live Streaming
68 XI Dwarven Dwelling
299 Swidhelm's Tyrannosaur
404 Hot Air Balloon
992 DAZ Horse 2
994 Hellborn Dragon
When Jane first inherited the depleted mine from her late uncle, she thought it would be nothing but a financial drain, especially given the aggressive inhabitants that haunted the tunnels. But livestreaming the monster fights from her hot air balloon, turned out to be a pretty lucrative business.
luci45#1 Even if he doesn't, he'll definitely draw attention wherever he goes XD
jecswp#1 A useful weapon against this enemy ;)
Totte#1 Well, that's one way to start a band XD
@jecswp#1: That's not a very "helping hand", good riddance!
@Totte, clever use of the sets!
tag: luci45 #2
Making the Most Of A Boring Vacation Spot
While vacationing in the Cynax System, the Higbys, Lewises, and Boyntons flew to the second moon of Ardoon to visit the 'haunted' grave of Laura Lewis' great Uncle Buckley. To their surprise, it was a desolate spot with a four-hour wait for the shuttle to return. Fortunately Fred Boynton had anticipated the situation and arranged for a satellite to provide cell phone coverage. The Higby boys claimed to have seen some 'spooky' things.
Pull:
6015 Z Mega Set For Genesis 8 And 8.1 G8 Poses Props
2316 i13 Lost and Found g3 poses
4182 Reparation envr arch
3658 OOT HDR 360° Environments Space for DAZ Studio Iray (LB)
Also used
dForce Collection 01 - Casual Pants & Blouse for Genesis 8 Female(s)
Toon Generations 4 Hair for Genesis 8 Female(s)
VYK Ghostly Plane for Iray
XI Sci-Fi Satellites
Just Josh and Texture Pack for Genesis 3 Male(s)
Upscale Shopper Outfit for Genesis 3 Female(s)
Antique Lanterns
Lil Devil Tails for Genesis 3 Female(s)
Jonathan 8
Alexandra 8
Blooming Outfit for G8F
dForce On Vacation Outfit for Genesis 8 Male(s) + Textures
Secret Service Hair for Genesis 8 and Genesis 3 Male(s)
Capri Hair for G8F
Ethereal VDB Fx
Atmosphere for Filament
Tyler Hair for Genesis 2 & 3 Male(s)
@aprilshowers2065 #1: Don't we all dream about inheriting something useful, good work Jane!
@luci45 #2: Beautiful and a lovelty story, very good one.
Thanks, aprilshowers2065 and Totte.
jecswp - Good one! You have a definite aptitude for RRRR.
aprilshowers2065 - LOL, a brilliantly creative use of your pull!
tag: luci45 #3:
2696 KOO Janek HD for G8.1 Male
4530 Scifi Ship Building Blocks
5110 Teen Josie 7
5122 Tengu Mokushiroku: Eternal
5089 Tattoo Machine (LB) (Rendo)
katywhite:#1
Title: Once in a Lifetime Advertising Opportunity
Caption: When two warriors decided to duke it out on amongst her fountain inventory, Gia started filming it live on her phone - if her inventory was going to get destroyed anyways, might as well turn it into an advertising gimmick. At the very least, it would make her ad about fountains unique.
Items I pulled:
MD Candle Lamp
BWC The Man
Caped Heroine For Genesis 2 Female(s)
Gia 7
Fountain Collection for Iray
tag: emanuela1 #1
Girl and the Fall of the Mouse King
As soon as the legendary Girl entered the hotel lobby, the paparazzi went wild trying to photograph her, knocking everything over and dropping many objects, creating a massive mess; the chaos was total, some of the falling items landed on Mouse King, halting his hasty escape.
Last-minute render; I hope I'm in time.
Extracted numbers
2326 480 848 2719 1141
Pulled
n Item (sku)
2326 Art Deco Hotel Lobby Pt2 DS (52697)
480 Victoria 5 Tank Dress (14188)
848 Girl 6 Diva Poses (16667)
2719 Mouse King for Genesis 8.1 Males (83422)
1141 99 DAZ Studio Props (18453)
Other DAZ items used in the render
Beach wave hair g2f
chace g8m
the chairman g8m
mouse king accessories
cow girl outfit g2f (boots)
The girl 6
and two freebies from other sites
camera from Renderosity
magazine from Renderhub
tag: luci45 #3
The Tide That Turned Badly for Tengu
Tengu Mokushiroku resented his low position of tattoo artist when 'artificials' were banned from more interesting professions. He occasionally avenged his kind with rude tattoos.
Pull
4530 Scifi Ship Building Blocks Vehicles
5110 Teen Josie 7
OK Closed - voiting wioll start soon.
@luci45: Post your last one in the entries thread.
Voting is up: https://www.daz3d.com/forums/discussion/772146/voting-rrrr-turn-the-tide
Winners announced: https://www.daz3d.com/forums/discussion/772916/rrrr-turn-the-tide-winners-announced
