RRRR - Remake or Sequel Render Contest *CLOSED *
Totte
A new round of RRRR. no Aprils fool version this time.
The theme for this round is Remake or Sequel
Think movies or TV-series, a remake or a new sequel that never made it, but would in the world of RRRR.
Check the entries only thread, first post, for an example on how to post an entry.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Player | LBs |
| Totte | 3 |
| acb | 2 |
| Fae3D | 1 |
| katywhite | 1 |
| emanuela1 | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread.
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Thursay April 2 - 2026, and will go on until Sunday June 7 2026 at 23:59:59 local DAZ time.
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
Dartanbeck is sponsoring with items from his store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/ ;
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
RRRR Good Intentions / Mixed up Mythology
https://www.daz3d.com/forums/discussion/727991/closed-rrrr-good-intentions-mixed-up-mythology-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/727986/rrrr-good-intentions-mixed-up-mythology-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/736086/rrrr-good-intentions-mixed-up-mythology-winners
RRRR - Unusual Laws / Refused Sports
https://www.daz3d.com/forums/discussion/737821/closed-rrrr-unusual-laws-refused-sports-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/737816/rrrr-unusual-laws-refused-sports-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/745691/rrrr-unusual-laws-refused-sports-winners-announced
RRRR - The Lyrics
https://www.daz3d.com/forums/discussion/745966/rrrr-the-lyrics-render-contest-closed/
Entries Only: https://www.daz3d.com/forums/discussion/745961/rrrr-the-lyrics-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/753416/winners-rrrr-the-lyrics-render-contest
RRRR It was a great idea but...
https://www.daz3d.com/forums/discussion/753491/rrrr-it-was-a-great-idea-but-render-contest
Entries Only: Entries only thread
Winners:
https://www.daz3d.com/forums/discussion/758766/rrrr-it-was-a-great-idea-but-winners-announced
Pull #1
#3577 Fantasy Axes Collection Vol1 for Genesis 8 (#81022)
#1876 Sci-fi corridor B DS (#46515)
#4106 Environment Set Splitter (#87033)
#1686 VIPER-420 Energy Rifle Set (#37481)
LB1: #3055 Cute Little Robot (#67465)
LB2: #4182 Summer Bikini for Genesis 9 (#87566)
LB3: #4041 Historical Weapons Pack for Genesis 8 and 8.1 Females (#86508)
Looks like some kind of Sci-Fantasy
Pull#1
That's almost boring with so few items to pull.
Pull #1
5056 The Living Room Collection 2
743 Cat World for Genesis 8 Male(s)
1289 dForce Fair Maiden Outfit for Genesis 9
5134 The Waltzers
I agree that it is boring with so few items. But, here we are...
I guess we could just pull more.
As a complete novice (or old like dinosaur as my daughter says) - where do I find my itemised history? On my Daz account or in the software?
There're two main ways to get the list of your items:
OK thanks. Just logged in to DIM and found I have 156 items to download (the joys of working on 2 PCs). I'll take a look after it's finished if I have time - I'm due at the airport just after lunch.
Tag: Totte #01
Also Used:
Cyborg Generation 8 + Solo
Walter 9 + Mathis Hair Set + Runic Tattoos + Adventure's Toybox 3
Rune 7 + Rough Rider
Nenana HD for G8F + Barbarian Armor
Lake Village ( for Environment Set Splitter )
UltraScenery2 + SnakeBridge
SY Real facial smoke for Genesis 9
OS VDB Magus Effects
SGM Explorer
Scripts, Shaders and Lights used:
Skies of Economy
Skies of Gaia Volume 2
RSSY 3DLToIray
C66 Drop Collide
OmniGraffle
Rebel Moon Part III
After part I and II was released on NetFlix, we do need a part III.
Awesome render and story, Totte! I love the anti drone tattoos and re-purposing the drones to harvest truffles! LOL.
Thanks Luci, it's a result of the bikini. I needed a reason to put it on him, then the rest fell in place.
I'm a little bit behind putting things on my pull list, but not much.
149 https://www.daz3d.com/darius-6
221 esha's dForce Utilities ...reroll?
356 https://www.daz3d.com/galene-hair-for-genesis-3-female-s
311 https://www.daz3d.com/sword-of-time-outfit-for-genesis-3-male-s
Is dForce utilities a reroll? if so:
56 https://www.daz3d.com/medieval-prince-outfit-for-genesis-3-male-s
That was surprisingly cohesive.
You should use the dForce utils one way or another. Scripts can be such a pain to pull ( like I pulled Environment Set Splitter )
Will do, I need to get some practice in with dForce, anyway...had *interesting* results last time.
I've learned a lot over rthe years doing RRRR renders pulling strange things I didnt even rememeber buying, a good built in learning in the contest!
tag: luci45#1
Beauty and the Beast 2026
Belle and the prince lived happily-ever-after until the government took their castle for back taxes due. After moving to a cheap apartment they looked for budget furnishings at Waltzers AutoMart Furniture. Belle looked for the enchanted talking variety. The prince, who had been feeling really sorry for himself, lost his temper and turned back into The Beast.
5134 The Waltzers
also used:
Le Roi Outfit and texture add-on
Nutcracker Props
Victoria 9
Soft Curls Long Hair for Genesis 9
B-Bot
A Curious Tea: Drink Me
Candle Collection
Rural Chateau III
Night and Day City for Daz Studio
Reflections Vanity Set
Retro Apartment Props
@Luci45: Poor Prince, taxes can be such a source for anger, great one!
Pull #2
#362 Grantham Hall Suit (#21934)
#2606 Have A Seat (#58245)
#1193 Iconic Outfit for Genesis 3 Male(s) (#24187)
#6078 Easy Environments: Winter II (#57215)
LB1: #3945 Iray Ghost Light Kit One (#85078)
LB2: #3556 Spring Flowers - Scilla Siberica - Squills (#80841)
LB3: #942 Old Warehouse Room (#23395)
Thanks, Totte.
Pull #2
922 College Classroom
3843 Predatron Common Nettles
3175 Miranda Hair for Genesis 3 & 8 Female(s)
3158 Millawa 8
Tag: Totte#02
Also Used:
IG Iray Gianni 6 HD + Boris Hair
Merrick For Michael 7
A Curious Tea chairs ( For Have A Seat )
Old Garden (n pots )
Julius 9 HD + Black Jack
Valentio 8 + Bootstrapper Outfit + Vintage Male Hair
Alex Capital 8.1 + Slueth Detective outfit
Everett 9 + Eldritch Seeker
Underbelly Bundle
Victorian Bedroom ( Carpet ) + The Safe ( Gold bar )
MJF Scatter Romantic Roses
Scripts, Shaders and lights used:
UHT2 Ultra Salon
Stack'Em Up
The Gangster Chronicles
A non violence remake of the TV series from 1981 about the rise of Lucky Luciano. Instead of bloody fights and shootouts, the gangsters divided the gold from the casinos by a flower growing contest. The winner was Bugsy Malone.
That's awesome, Totte! Some sore losers - it fits.
Great use of your pull!
Pull #3
#4604 Phx Jack Character for M4 (Rendo)
#4217 MMX Sporty Sunglasses for Genesis 3 8 and 9 (#87810)
#3096 Q Suit for Genesis 8 Male(s) (#68493)
#4387 Cliff for Thimor 9 HD (#89278)
LB1: #5419 NG Ankle Socks for Genesis 9 (#92404)
LB2: #5553 dForce Angie Cuffed Jeans Outfit for Genesis 9 (#88389)
LB3: 31 Fantasy Cloth Wrap for Genesis 2 Female(s) (#21072)
tag:luci45#2
The Second Happening
After discovering how easy it is to chemically manipulate human beings, the plants decided to try reeducating and making humans clean up the environmental mess they made.
3158 Millawa 8
Also used
Tree Giant
Tropical Tradescantia Plant
Jungle Construction Kit
Hawthorne Trees
Plant Pots Vol 2 - Square and Unusual
Hair - PH Punk, Micah, Chase, Margot
Clothes - HnC Basic Jacket Outfit w/DD PBR Hawaiian Print Fabric Shaders Vol 2
MMX VDB Smoke FX 01
@luci45: A wonderful render, very clever idea!
Thanks, Totte.
pull #3
4430 Shanty Bus House
88 A Simple Shave Props
2695 LI Wolfsbane Fur - Pelts
3475 Nydo Hair for Genesis 3 Female(s)
Tag: Totte#03
Also used:
Michael 4 + Hardcore
Gene Hair
Jinx Jones B + Sci-Fi Rebel Outfit for Genesis 8 Females + Miranda Hair
Bethany 7 + Adventure Gir + dForce Fantastic Twirls Hair
Milo for Genesis 8 Males + Dax Hair for Genes 3 Males ( Autofit )
IG Iray Lilith 6 HD + Ruffle Teddy + Julius Hair + Edwardian Assessories (Shoes)
JS Cleona HD + BW Fsryn ( footwear ) + BW Zoran Crimson Armor Outfit + M3Du54a Hair + Dianne Hair
Zack 9 HD + Rogue Marshall Outfit + Aiden Hair + Bath Towels ( duck )
Walter 9 Heavy + Priest Outfit fir Genesis 9 + M3D Balding Hair Styles
ART Collab; Cargohold
Scripts, Lights and Shaders used:
RSSY 3DLToIray
JG Simple Fabric
Legacy Set Converter
Advanced Material Converter
PBS Shaders Vol 2
TEMU Plime: Firefly
To become the next Amazon, TEMU decided to start their own streaming service, TEMU Plime, and their first series was a reboot of the iconic Sci-Fi series Firefly.
Wow, that looks like what TEMU would produce! LOL. That was a strange pull - all clothes and characters! What is the set? It looks familiar.
It fell off my used list, there now, ART Collab CargoHold.
I think that one is the loading dock, or part of it. I forgot about those, from 2012! I remember when they came out, only 14 years ago. Anyway, they were favorites of mine then.
They were my favouritrs too. Ann and Frank did a good job with then.
what does this make me feel? Older but not wiser :P
I feel like I get dumber every year, but am consoled by wise Socrates saying that he knows that he knows nothing.
