RRRR - The Lyrics - Render Contest *CLOSED*
Totte
Welcome to yet another round of RRRR. This time we're having a theme, and the theme is The Lyrics. The idea is to render an image that pictures a piece of lyrics from a song, You can always, as usual in the RRRR, make your own lyrics and your own made up band and song, otherwise you post band/artist : song name with the post. Check the entries only thread, first post, for an example on how to post an entry.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Name | LBs |
| acb | 3 |
| Totte | 3 |
| katywhite | 1 |
| Rafael | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Wednesday October 15 - 2025, and will go on until Sunday December 28, 2025 at 23:59:59 local DAZ time.
This months sponsors so far:
acb is sponsoring with $50 in Daz GC
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
Dartanbeck is sponsoring with items from his store
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/ ;
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/ ;
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
RRRR Good Intentions / Mixed up Mythology
https://www.daz3d.com/forums/discussion/727991/closed-rrrr-good-intentions-mixed-up-mythology-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/727986/rrrr-good-intentions-mixed-up-mythology-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/736086/rrrr-good-intentions-mixed-up-mythology-winners
RRRR - Unusual Laws / Refused Sports
https://www.daz3d.com/forums/discussion/737821/closed-rrrr-unusual-laws-refused-sports-render-contest/
Entries Only: https://www.daz3d.com/forums/discussion/737816/rrrr-unusual-laws-refused-sports-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/745691/rrrr-unusual-laws-refused-sports-winners-announced
Well, that was fast.
Pull #1:
582 Bone and Fantasy Scale Iray Shaders
1995 GIS Skyway
3925 Planet Glise
2232 Hobby Clothes for Genesis 3 Female(s)
Pull #1
#3522 Cookies And Cocoa Outfit for Genesis 8 Females (#80291)
#5085 The Dirt Road (#89778)
#3122 More Cowbell! for Genesis 8 Male (#68555)
#1262 Lapis morte (#27430)
LB1: #3929 VDB Cloud Collection for Iray (#84695)
LB2: #1942 HDRI Clean Skies (#47613)
LB3: #5469 W Troll Faces Expressions for Gren the Troll 9 (#92677)
Pull#1
I just claimed in the last round I didn't have a police car besides the toon one, and now RRRR has discovered my new buys... a little nosey, I must say.
Must be the AI connected neural interface :-)
Tag: Totte#01
Also Used:
LY Kieran HD 8.1 + Duola Hair + Glasses Set 1
KOO Malcolm + Caballero Outfit + Long Mane Hair + CC Beard Boss
KOO Alfonso + Gren The Troll Head Morph + Golden Stillness + Daniel Ponytail Hair
Vintage Royal Car
Scripts, Lights and Shaders used:
UHT2 Ultra Salon
RSSY 3DLToIray
Talking Heads: Road To Nowhere
We're on a road to nowhere, come on inside
Takin' that ride to nowhere, we'll take that ride
I'm feeling okay this morning, and you know
We're on the road to paradise, here we go, here we go
Pull #2
#2544 Vintage Sleds Vol 2 DS (#57093)
#3581 Pig Cart (#80910)
#1531 Fantasy Chamber Interior(#34289)
#3273 Abasi HD for Ashan 8 (#70831)
LB1 #4342 Oso Elder HD for Genesis 9 (#88730)
LB2 #5840 Elco Patrol Torpedo Boat (#104791)
LB3 #3281 Moonshine Cinema Projection Building DS (#70953)
This pull was really difficult - yikes!!!!
(I guess because the first was too easy)
Nice one, Totte! Wow, I was going to use that song but changed my mind. It is better for yours with all the LBs.
tag:luci45#1
Bridge Over Troubled Water - Simon and Garfunkle (Altered)
The Space Corps Builders on Planet Glise couldn't finish their bridge due to budget cuts they begged for help from a giant lizard. (The local game warden may not like the idea of these tiny aliens taking advantage of the good-natured creature.)
When we're weary, feeling small,
When tears are in our eyes, you will dry them all,
Cotylorhynchus. When times got rough
And parts just can't be bought,
Like a bridge over troubled water,
Cotylorhynchus.
You will help us cross.
Used
1995 GIS Skyway
3925 Planet Glise
Also used:
CotylorhynchusDR
SE Animal Lityn
Traffic Patterns Script and Prop Collection
LowPoly Crowd Creator Expansion: Outer Rim
@luci45: That's a beautiful render and a very nice altered song, love it!
Thanks, Totte. Your low poly vehicles and people worked great at that distance.
Pull #2
3492 Nature Plants 04
6251 XI Thailand TukTuk
5305 Textures for Reptilian 6 HD
5763 Ultraviolet Shaders, Lights, and Props
I should be able to find a trippy song from the 70s for this one...
@Luci45, I just made them end up in places, the actual arists behind them are Lyrra, and a mysterious secret modeler who did the trucks and cars who is very talented.
Tag: acb#1
Roll roll roll your goat
... gently down the street
Aiko with her new car, on the other hand, wasn't too keen on girls with beards rolling their goats down the street.
Also used:
pulll #1
237 - Hot Jumpsuit Outfit for Genesis 3 Female(s)
183 - Monique 6 HD - I was all set to replace this, since I don't have Monique6, but apparantly it'll apply to genesis 2, and so will another add-on I have for Monique, so I guess I'm using this.
8 - Eternal Desert Warrior Outfit for Genesis 3 Female(s)
1 - should be the headers on my spreadsheet, I'lll have to fix it later
56 - Swim Cap Hair for Genesis
13 - First Star on the Right Earrings for Genesis 9 didn't need (but willl probably stilll use)
...and I actualy have an idea
Pull#2
tag:luci45#2
Uptown Funk (with Lizards)
Well, it's Saturday night and we in the spot
Don't believe me, just watch, come on
Also used
Cargo Shorts and Tee for Genesis 2 Male(s)
Capsces Poses Reptilian 6
Cyberpunk Kitset
Creature Creator for Genesis 2 Female(s)
Amazing Hat
Death Cap HD
Urban Survivors HD for G2F and G2M
Ron's Bokeh 2
@Luci45: What a funky render, love the colours!
LOL, acb, with all those LBs you added a cartoon goat!? So very RRRR!
Thanks, Totte. I didn't know what to do with that pull.
Pull #3
963 Colors for Sunday Casuals: Basics G3F
2506 Japanese Maples
2511 Jarek for Michael 6 HD
2621 Kameron Hair for Genesis 3 Male(s)
lol, but that is pull 3 I think!
Oh, it is 3. I will fix it. Thanks.
Yeah, well, I don't get it myself. Even with this many items, there wasn't a single goat.
I have eagerly viewed these contests for a long time, and I always wanted to participate but wasn't sure how. I FINALLY learned how to get all my DIM stuff in a file and properly culled, and found I'm still left with over 4,000 items XD So that should be a good amount to work with.
I fed the numbers into the generator, and got this:
Pull #1
Which gives me these items to work with:
1360 - Look At Me II Pose Control (I guess this is ok to use, I mean I can be sure to show someone obviously looking at someone/something)
917 - dForce Hi-Low Dress for Genesis 8 Female(s)
3671 - Pteranodon
4133 - Dystopian Weapon Cache 1 (This is no longer in the store, but it's exactly what it sounds like, dystopian styled artillery)
Well, the algorithm certainly didn't give me an easy first go! So I just need a song about dinosaurs and fancy girls with guns who are looking at something. I'm going to give this a shot, please let me know if I did something wrong (or if I need to re-pull on the Look At Me II Pose Control)!
Welcome Fae3D!
Tag:Totte#02
Also Used:
Moonshine Drive-in Theatre
Drutherson 8 + Renaissance Attire
Corsican Raider Outfit for Genesis 8 Male(s) + Yoan Hair + Medial Weapons
Uniform Styles + Backstab Alley ( Rope)
Dreamland Models LowPoly Block Six
Dreamland Models LowPoly Block Seven
1950 family car
1950 Luxury car
Military GP
Lowpoly Crowd Creator Bundle
P3DA Tom for Genesis + 50s casual for genesis male
LY Emily for Genesis + %0s everyday clothes + Lucy + Trixy Hair
Scripts, Shaders and Lights used:
RSSY 3DL to Iray
Instancify
Skies of Economy
Invisi Lights
Ultra Scenery Xt
Atmospheres 4 : Dawn to Dusk
PBS Shaders Vol 2
David Bowie: Drive-In Saturday
Chorus:
His name was always Buddy
And he'd shrug and ask to stay
She'd sigh like Twig the Wonder Kid
And turn her face away
She's uncertain if she likes him
But she knows she really loves him
It's a crash course for the ravers
It's a drive-in Saturday
Pull #3
#2265 Winterblack Hall Throne Room Props (#58809)
#4591 Science Deck for Space Station Construction Kit (Rendo)
#3214 Alpha Airdrome DS (#70115)
#4502 G2M His Black Boots (Rendo)
LB1 #5988 Troll Outfit for Genesis 9 (#105966)
LB2 #466 Chace Hair for Genesis 2 Female(s) (#22181)
LB3 #3941 Matteo HD for Genesis 8 and 8.1 Male (#84831)
tag:luci45 #3
The Police - Every Little Thing She Does Is Magic
Every little thing she does is magic
Everything she do just turns me on
Also Used
Young Jarek Shapes for Genesis 2 Male(s) and Brodie 6 HD
Wind Chill for Genesis 2 Male(s)
Gone Girl Outfit for Genesis 3 Female(s) skirt,
Missy Outfit for Genesis 3 Female(s) shoes,
Midnight Special Hair for Genesis 3 Female(s)
Nomad for Genesis 3 Male(s) and Female(s) jacket
Skies of Sylva
PTF Magic! Shaders and Wearables for Genesis 3 and 8
Ron's Particles
Jack Pumpkin
Gobbles
That's cute! and he just looks so happy.
Tag: acb#2
"Wandabe" (Spice Girls)
♪ Yo, I'll tell you what I Wand,
what I really, really Wand ♫
... a Toothbrush!
Not really, really my music. Got a little bit stuck with this pull. It's best not to question it.
Pull:
Also used:
@luci45: Thanks for your comment
@acb: #1: Roll your got, soon to be a list hit in Fantasystan, love it!
@acb: #3: A magic toothbrush - very cool idea!
Thanks, cosmosm. He seems to be happy; I hope he stays happy.
Thanks, Totte. I would like to take credit for the magic toothbrush render, but probably shouldn't. LOL.
Totte#02 That's the way to get all those LBs in!
acb#2 I love this one - what wonderfully crazy things those LBs can make us do!
Pull #4
1758 Forest
3118 Mec4D Unshaven 2 for Genesis 2 Male(s)
3064 Marina Conference Room
4172 Raoul for Ivan 7 HD
