[SOLVED] Weird texture bug
Krys Kryngle said:
Happens every time I re-import from MD to Blender.
After import into Blender, go into edit mode and select all. Then Mesh -> Normals -> Reset Vectors.
I can't remember who shared that with me, but if you're reading this, thank you.
Well, I guess now I have you to thank. Thanks a ton! That worked perfectly :D
[SOLVED] Weird texture bugHappens every time I re-import from MD to Blender.
Installing, activating, and accessing Daz Studio Premier featuresI am frustrated beyond belief.
About every second or third time I try to launch DAZ Studio, it fails to recognize that I have a Premier membership. Sometimes if I load a scene and save it, close DAZ and relaunch, it'll come back. Sometimes.
But today, I can't get it to load Premier features no matter what I do. I checked my account on line -- it says I'm in Premier. I tried turning off auto-login and logging in manually, but it still doesn't recognize it. This sucks up time every time it happens, and today, it's taken the better part of an hour and I'm no closer to getting my Premier features back. And it doesn't give me any sort of error message. It just quietly refuses to load Premier features which I don't discover until I actually need them.
I've searched the forums a few times over the past year when it happens, but nobody else seems to be having this issue? Or, if they do, they get helpful suggestions like "reinstall the app."
I've reset the database, and reloaded metadata. I've uninstalled and reinstalled PostgreSQL. The log file says that it's failing web authorization. Other than that (and one metadata item not able to update, for some reason) I don't see anything in the log suggesting any other issues.
This isn't a hobby -- it's my livelihood, which is why I haven't tried to just file a bug, because I know how long it'll take somebody to get back to me, and I need to get work done. HELP!!
Export/import settings for creating morhpsAll - can I get a quick summary of settings for exporting .obj files to blender, then exporting .obj back to daz for morphs?
I hae a simple prop I'm trying to modify. Everytime I try to import back to daz using morph loader pro, it says "geometry did not match". I tried various combinations of settings from blender.
Daz 4.24, Blender 5.1
Unable to open some Iray material files...Unable to open some Iray material files, such as "Chic Bob Hair/Materials/Iray/..." DAZStudio 4.24.0.3 MacOS Tahoe. Version 4.24.0.4 for Mac has a lot of other bugs, so I reverted to version 4.24.0.3.
Error message: An error occurred while reading the file. See the log more details.
LOG FILE:
2026-04-17 12:34:38.367 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
2026-04-17 12:34:38.367 [INFO] :: Locking viewport redraw...
2026-04-17 12:34:38.367 [INFO] :: Viewport redraw locked.
2026-04-17 12:34:38.659 [VERBOSE] :: Native format content directories: 2
2026-04-17 12:34:38.659 [VERBOSE] :: Poser format content directories: 1
2026-04-17 12:34:38.660 [VERBOSE] :: Other import format content directories: 0
2026-04-17 12:34:38.660 [INFO] :: Begin asset load (merge): /People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
2026-04-17 12:34:38.669 [INFO] :: Determining missing assets...
2026-04-17 12:34:38.699 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2026-04-17 12:34:38.699 [WARNING] :: Error loading asset: /Volumes/Data 1/DAZ 3D/My DAZ 3D Library/People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
Operation failed
2026-04-17 12:34:39.003 [INFO] :: Unlocking viewport redraw...
2026-04-17 12:34:39.003 [INFO] :: Viewport redraw unlocked.Diffeomorphic Add-ons Version 5.2.0 ReleasedBe sure to use the figure presets in easy import, there's G8 G81 and G9. Works fine here.
p.s. For example G9 doesn't support face units, as well G8 is not meant for FACS if you want to load G8 poses. So the presets help you get the standard features for the figure.
New Marvelous Designer update broke morph imports (geometry does not match)?Hello everyone,
As a part of my workflow, I've always been using Marvelous Designer to create morphs on clothing. I find that the clothing simulation has always been much more fluent and worked great. However, as of updating to the most recent version of MD, version 2026.0.189, something seems to have broken in my pipeline.
To also explain my (basic) way of doing these emulations, I always have worked as follows:
- Complete posing etc in daz, including clothing
- set back the resolution level of clothing to base
- Disable smoothing
- set back chest related parameters on the outfit to 0%
- export with attached settings (OBJ)
- export model at normal resolution level (OBJ)
- Import model in MD with attached settings
- Import outfit part (import OBJ as garment) with attached settings
- tack outfit where needed, Simulate outfit
- Export with attached settings
- Import back into Daz with attached settings (Morph loader pro)
I've included my export settings and import settings for reference, and to clarify, I do always set my clothing back to base resolution level. My question is if anyone else has experienced this, or if some kind of setting has been broken on my end. I'd like to ask for some advice, to see if I can get it fixed. If you spot anything wrong, or if there's some kind of extra step I'll have to (start) making, please let me know!
Thanks in advance
Trying to save a poser figure in DS. but morphs no longer workWere they loaded on to the figure when you saved the .duf file? I am not sure it is ideal to take this approach, I would be inclined to keep the Poser format content and import it when needed (but saved scenes should work, regardless of approach).
Sigrid 9 - Discussion Threadmemcneil70 said:
The current support line for her has "/Runtime/Support/DAZ_3D_114287_Sigrid_9_Athlete_HD_Shape_Add-On.dsx" in my DAZ Studio metadata.
Search DIM SKU::114287 to see if you can find her that way.
There's no problem getting it to show up in DIM. It just won't download. The file is missing on the DAZ server, or the link in their system (both via DIM and website) to the file is incorrect.
EZFinder - Advanced Content Manager for Daz Studio [Commercial]Deepeyed said:
EZ3DTV said:
Deepeyed said:
In EZOrganizer what does the export do?
Great question! EZOrganizer gives you three export options — Export Folder, Export Panel, and Export All — and they all do
the same thing at different scales: they convert your EZFinder organization into a format Daz Studio can natively read.Why does this exist? EZFinder stores your folders in its own optimized format for speed. Daz Studio can't read that
directly. Export bridges the gap — it translates your virtual folders into standard Daz-compatible metadata.Export All is the big one. It takes every tab, panel, and folder you've built and writes them out to a single location.
Point Daz Studio at that folder as a base directory, and suddenly all your carefully organized content shows up in Smart
Content and the Content Library — no EZFinder needed.So if you prefer working inside Daz Studio rather than switching to EZFinder, you get the best of both worlds: organize in
EZFinder where it's fast and flexible, then export so everything is available right inside Daz.One thing to keep in mind: if you reorganize anything in EZFinder, you'll need to re-export for Daz to see the changes.
Thank you, that's what I was hoping it would do. So I had a play with this, and I found the exported folder in the content library(under daz studio formats), but where would it show up in smart content? Right clicking to show there gave an error about a missing category. I might be fundamentally misunderstanding something. Thanks for your help!
Within the next few days I'll be making a YouTube video showing how to export your Virtual Folder content to Daz Studio's
Content Library and Smart Content. Once it's ready, I'll drop a link in this thread.
If you'd like to catch it live, head over to @EZ3DTV on YouTube — subscribe and click the bell for all notifications, and
I'll give a heads-up before going live. I'm not sure yet what time I'll be available, so stay tuned!
Thanks so much for the interest.
One important caution: do not export your EZFinder library into your Daz library
(If it is there now move it out or re-export it to a locaiton outside your library.).
Always export to a folder outside of your Daz Studio library, then add that exported folder as a base directory in Daz Studio.
That way, the next time EZFinder scans your Daz Studio library, it won't end up scanning the same content twice.
In my opinion, it's best to keep your Daz library reserved for native Daz Studio content installed through Daz Install
Manager — nothing else.
EZFinder - Advanced Content Manager for Daz Studio [Commercial]EZ3DTV said:Deepeyed said:
Diffeomorphic Add-ons Version 5.2.0 ReleasedHi, im using the new diffeomorphic & blender 4.5.5. When I import my character, all the JCMS work aside from smile? Snarl, surprised, etc. all works fine, except she will NOT smile at all. How can I fix this please? Thanks in advance!
Sigrid 9 - Discussion ThreadThe current support line for her has "/Runtime/Support/DAZ_3D_114287_Sigrid_9_Athlete_HD_Shape_Add-On.dsx" in my DAZ Studio metadata.
Partial rendering a scene / "Spot rendering" to Filestitlown said:
2. [I got ChatGPT to write me a python-script-turned-into-windows-.exe] Process the frame sequence to turn black transparent. This was a little tricky as part of the re-rendered area were fire flames that were part transparent themselves and too-simple a black-to-transparent conversion left them with blackened edges quite unlike the proper render. This was solved by pushing the black-to-transparency a suitable distance into grey and the potential for some feathering of the boundary.
3.[I got ChatGPT to write me another ...-to-.exe] Merge the rerendered .png sequence onto the original .jpg sequence.
A much easier option would be to use Photoshop (in my case I use paint.net). Select the rendered section using the rectangular select tool, copy it, create new layer and paste it onto that. Then delete the original layer with the black. You are left with a perfectly positioned spot render that you can layer over your "faulty" image. You can either save it and use it later or import your faulty image straight in and layer it underneath. Job done in around a minute.
Anyone having issues with the oxygen tank in the full diving suit?I have only a couple of morphs that do this, AM Body Weight being one, and it dos seem semii-reasonable - that moves the back out (so the nearer part of the mesh gets squished as it is closer to the surface and so more strongly affected) while also spreading sideways (so when the model follows that it gets stretched wider). This seems to be due to the (sliightly odd) Rigidity Groups - removing those (with the Geoemtry Editor) and then Edit>Figure>Shape>Clear Generated Morphs to get rid of the existing, flattening morph did stop the odd behaviour but it would also mean that a lot of morphs with a less uniform effect would distort the model. I suspect the issue is that the reference group seems to eb the same as the Rigidity Group, which is a bit odd, but I don't know what the tradeoffs found in creating the model were. Converting to another figure will remove the Rigidity maps and projected morphs, which is why you don't see the same thing there.
What you might try is removing the Rigidity Groups, clearing the generated morphs, and then apply each problem morph (as long as it is a single morph) to an otherwise zeroed base figure. If the default morph projection looks OK you could then export the tank as OBJ, using the same name as the morph on the base figure (the name isn't the labvel, you can get it from Parameter Settings - the gear icon on the slider for the morph). The reload the origiinal tank, with its Rigidity maps, and use Morph loader pro to import the exported OBJ files as new morphs - when you set the morph on the base figure it will use the imported shape, not the problematic projected morph, though you may need to adjust the rigging to accomodate the new shape, but you should still have protection from distortion due to other morphs.
DAZ Director Plugin (WIP)Just in case anyone is following, I've added substantial updates to the Script Server and the MCP Server.
See https://github.com/bluemoonfoundry/daz-script-server and https://github.com/bluemoonfoundry/daz-mcp-server
Main updates are tighter integration between the two to work together, async requests to support long-running scripts like batch renders, and probably most important 70 tools/skills/resources exposed through the MCP server that can be leveraged by LLMs. The next big update will expose the DAZ content library to natural language search, which will also be exposed as a tool.
MCP Server Tools Documentation Tools ┌─────────────────┬────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├─────────────────┼────────────────────────────────────────────────────────────────────┤ │ daz_script_help │ Get DazScript documentation, examples, and best practices by topic │ └─────────────────┴────────────────────────────────────────────────────────────────────┘ Low-Level Tools ┌──────────────────┬───────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────┼───────────────────────────────────────────────────────────┤ │ daz_status │ Check DAZ Studio connectivity and DazScriptServer version │ ├──────────────────┼───────────────────────────────────────────────────────────┤ │ daz_execute │ Execute inline DazScript code with optional args │ ├──────────────────┼───────────────────────────────────────────────────────────┤ │ daz_execute_file │ Execute a .dsa/.ds script file from disk │ └──────────────────┴───────────────────────────────────────────────────────────┘ High-Level Tools ┌──────────────────┬────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────┼────────────────────────────────────────────────────────────┤ │ daz_scene_info │ Get scene snapshot (figures, cameras, lights, selection) │ ├──────────────────┼────────────────────────────────────────────────────────────┤ │ daz_get_node │ Read all numeric properties of a node by label/name │ ├──────────────────┼────────────────────────────────────────────────────────────┤ │ daz_set_property │ Set a numeric property (transform, morph, etc.) on a node │ ├──────────────────┼────────────────────────────────────────────────────────────┤ │ daz_render │ Trigger render with current settings, optional output path │ ├──────────────────┼────────────────────────────────────────────────────────────┤ │ daz_load_file │ Load a content file into the scene │ └──────────────────┴────────────────────────────────────────────────────────────┘ Morph Discovery Tools ┌───────────────────┬──────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├───────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_list_morphs │ List all morphs on a node with current values; filter to active only │ ├───────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_search_morphs │ Search morphs by name pattern (case-insensitive substring match) │ └───────────────────┴──────────────────────────────────────────────────────────────────────┘ Scene Hierarchy Tools ┌────────────────────────┬──────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├────────────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_get_node_hierarchy │ Get complete hierarchy tree for a node with all descendants │ ├────────────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_list_children │ List direct children of a node │ ├────────────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_get_parent │ Get parent node of a node │ ├────────────────────────┼──────────────────────────────────────────────────────────────────────┤ │ daz_set_parent │ Set parent of a node with optional world-space transform maintenance │ └────────────────────────┴──────────────────────────────────────────────────────────────────────┘ Multi-Character Interaction Tools ┌───────────────────────┬─────────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├───────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_look_at_point │ Make character look at world-space point with configurable body involvement │ ├───────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_look_at_character │ Make one character look at another character's face │ ├───────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_reach_toward │ Position arm to reach toward world-space point using pseudo-IK │ ├───────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_interactive_pose │ Coordinate two characters for interaction (hug, handshake, etc.) │ └───────────────────────┴─────────────────────────────────────────────────────────────────────────────┘ Batch Operations Tools ┌──────────────────────────┬─────────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_batch_set_properties │ Set multiple properties on one or more nodes with individual error handling │ ├──────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_batch_transform │ Apply same transform properties to multiple nodes │ ├──────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_batch_visibility │ Show or hide multiple nodes │ ├──────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_batch_select │ Select multiple nodes (replace or add to current selection) │ └──────────────────────────┴─────────────────────────────────────────────────────────────────────────────┘ Viewport and Camera Control Tools ┌──────────────────────────┬──────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────────────┼──────────────────────────────────────────────────────────────────────────┤ │ daz_set_active_camera │ Set which camera is active in the DAZ Studio viewport │ ├──────────────────────────┼──────────────────────────────────────────────────────────────────────────┤ │ daz_orbit_camera_around │ Position camera orbiting around target at specified angle/distance │ ├──────────────────────────┼──────────────────────────────────────────────────────────────────────────┤ │ daz_frame_camera_to_node │ Frame camera to show a node (auto-calculates distance from bounding box) │ ├──────────────────────────┼──────────────────────────────────────────────────────────────────────────┤ │ daz_save_camera_preset │ Save camera position/rotation as JSON-serializable preset data │ ├──────────────────────────┼──────────────────────────────────────────────────────────────────────────┤ │ daz_load_camera_preset │ Restore camera from saved preset data │ └──────────────────────────┴──────────────────────────────────────────────────────────────────────────┘ Animation System Tools ┌────────────────────────┬─────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_set_keyframe │ Set a keyframe on a property at specified frame │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_get_keyframes │ Get all keyframes for a property │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_remove_keyframe │ Remove a keyframe at specified frame │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_clear_animation │ Remove all keyframes from a property │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_set_frame │ Set current animation frame │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_set_frame_range │ Set animation frame range (start and end) │ ├────────────────────────┼─────────────────────────────────────────────────────────┤ │ daz_get_animation_info │ Get animation timeline info (current frame, range, fps) │ └────────────────────────┴─────────────────────────────────────────────────────────┘ Advanced Rendering Control Tools ┌──────────────────────────┬───────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────────────┼───────────────────────────────────────────────────────┤ │ daz_render_with_camera │ Render from specific camera without changing viewport │ ├──────────────────────────┼───────────────────────────────────────────────────────┤ │ daz_get_render_settings │ Get current render settings and configuration │ ├──────────────────────────┼───────────────────────────────────────────────────────┤ │ daz_batch_render_cameras │ Render from multiple cameras in sequence │ ├──────────────────────────┼───────────────────────────────────────────────────────┤ │ daz_render_animation │ Render animation frame range as image sequence │ └──────────────────────────┴───────────────────────────────────────────────────────┘ Spatial Query Tools ┌──────────────────────────────┬─────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────────────────┼─────────────────────────────────────────────────────────────────────────┤ │ daz_get_world_position │ Get world-space position, local position, rotation, and scale of a node │ ├──────────────────────────────┼─────────────────────────────────────────────────────────────────────────┤ │ daz_get_bounding_box │ Get bounding box (min/max corners, center, dimensions) of a node │ ├──────────────────────────────┼─────────────────────────────────────────────────────────────────────────┤ │ daz_calculate_distance │ Calculate distance and direction vector between two nodes (cm) │ ├──────────────────────────────┼─────────────────────────────────────────────────────────────────────────┤ │ daz_get_spatial_relationship │ Natural language spatial relationship between two nodes │ ├──────────────────────────────┼─────────────────────────────────────────────────────────────────────────┤ │ daz_check_overlap │ Check if two nodes have overlapping bounding boxes │ └──────────────────────────────┴─────────────────────────────────────────────────────────────────────────┘ Property Introspection Tools ┌───────────────────────────┬──────────────────────────────────────────────────────┐ │ Tool │ Description │ ├───────────────────────────┼──────────────────────────────────────────────────────┤ │ daz_inspect_properties │ List all properties on a node; filter by type │ ├───────────────────────────┼──────────────────────────────────────────────────────┤ │ daz_get_property_metadata │ Get detailed metadata for a single named property │ ├───────────────────────────┼──────────────────────────────────────────────────────┤ │ daz_validate_script │ Static analysis of DazScript for known anti-patterns │ └───────────────────────────┴──────────────────────────────────────────────────────┘ Lighting Preset Tools ┌───────────────────────────┬──────────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├───────────────────────────┼──────────────────────────────────────────────────────────────────────────────┤ │ daz_apply_lighting_preset │ Create a professional lighting setup in one command │ ├───────────────────────────┼──────────────────────────────────────────────────────────────────────────────┤ │ daz_validate_scene │ Validate scene for collisions, lighting, cameras, and figures; returns score │ └───────────────────────────┴──────────────────────────────────────────────────────────────────────────────┘ Emotional Direction Tools ┌─────────────────┬───────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├─────────────────┼───────────────────────────────────────────────────────────────────────┤ │ daz_set_emotion │ Apply an emotional expression to a character (morphs + body language) │ └─────────────────┴───────────────────────────────────────────────────────────────────────┘ Content Library Navigation Tools ┌──────────────────────┬────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├──────────────────────┼────────────────────────────────────────────────────────────┤ │ daz_list_categories │ List subdirectories in content library under a parent path │ ├──────────────────────┼────────────────────────────────────────────────────────────┤ │ daz_browse_category │ List .duf files in a content library category path │ ├──────────────────────┼────────────────────────────────────────────────────────────┤ │ daz_get_content_info │ Read metadata from a .duf file without loading it │ └──────────────────────┴────────────────────────────────────────────────────────────┘ Scene Composition / Cinematography Tools ┌────────────────────────────┬──────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├────────────────────────────┼──────────────────────────────────────────────────────────────┤ │ daz_apply_composition_rule │ Position camera using a photography composition rule │ ├────────────────────────────┼──────────────────────────────────────────────────────────────┤ │ daz_frame_shot │ Frame camera to subject using a standard cinematic shot type │ ├────────────────────────────┼──────────────────────────────────────────────────────────────┤ │ daz_apply_camera_angle │ Apply a standard camera angle preset relative to a subject │ └────────────────────────────┴──────────────────────────────────────────────────────────────┘ Scene Checkpoint Tools ┌─────────────────────────┬─────────────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├─────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_save_scene_state │ Save current transforms, morphs, and light properties as a named checkpoint │ ├─────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_restore_scene_state │ Restore scene state from a named checkpoint │ ├─────────────────────────┼─────────────────────────────────────────────────────────────────────────────┤ │ daz_list_checkpoints │ List all saved checkpoints in the current session │ └─────────────────────────┴─────────────────────────────────────────────────────────────────────────────┘ Scene Layout & Proximity Tools ┌───────────────────────┬───────────────────────────────────────────────────────────────────────┐ │ Tool │ Description │ ├───────────────────────┼───────────────────────────────────────────────────────────────────────┤ │ daz_get_scene_layout │ Full spatial map of all scene nodes with positions and bounding boxes │ ├───────────────────────┼───────────────────────────────────────────────────────────────────────┤ │ daz_find_nearby_nodes │ Find all nodes within a radius of a target node │ └───────────────────────┴───────────────────────────────────────────────────────────────────────┘ Total: 70 tools across 17 categories
An Attempt of a "Limited Time Freebie" Message Only Email Alert Thread Part 2New bi-weekly batch of “Limited-Time Free” from Fab (until April 21 at 9:59 AM ET).
- FANTASTIC - Dungeon Pack. Dungeon building components, numerous props, scenery. On the lower-poly side, but probably still very useful for fantasy style renders. Unreal, Unity, Blender, fbx, formats.
- Forest Of Spikes. Creepy trees and rocks. Unreal format.
- Not useful for Daz: NexxNote | Sketch & Note for Blueprints. (Unreal scripting/blueprints tool.) Unreal format.
Special comment: The dungeon pack will be of particular interest—not just because there are fbx and Blender files—for folks doing fantasy/dungeon renders. There are a lot of usable props and environment pieces.
With Fab freebies, you can choose a Personal or Professional license. I always switch to the Professional license (since it’s free and gives you more).
Note that these are usually in Unreal or sometimes Unity, Godot, Blender, or generic 3D formats, so will require some work to convert for use in Daz.
I’m not aware of any tool for straight conversion from Unreal to Daz. so it takes a couple steps. First, convert from Unreal Engine to Blender format, then export/import between Blender and Daz. This article covers some ways of doing the conversion from Unreal to Blender: “Exporting from Unreal Engine to Godot, Unity or Blender”. Then from Blender to Daz, you can use one of the various tools, such as Diffeomorphic.
Please take replies and discussion to the discussion thread.
What is this?Early versions of DS4 used ValentinaDB to store metadata for Smart Content and Daz switched to PostgreSQL in 4.9. So they provided an utility to migrate your metadata into the new format at the time.
I don't think it has had any use after that, but it's still provided with DS.
The new "blender to Daz plugin"takanuinuva_40f6ab6ae5 said:
I don't use Blender but would like to port Blender models.
So do I need to Download Blender to use this porter or can I just import the files with this installed?You need Blender itself.
The new "blender to Daz plugin"I don't use Blender but would like to port Blender models.
