Unable to open some Iray material files...
Unable to open some Iray material files, such as "Chic Bob Hair/Materials/Iray/..." DAZStudio 4.24.0.3 MacOS Tahoe. Version 4.24.0.4 for Mac has a lot of other bugs, so I reverted to version 4.24.0.3.
Error message: An error occurred while reading the file. See the log more details.
LOG FILE:
2026-04-17 12:34:38.367 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
2026-04-17 12:34:38.367 [INFO] :: Locking viewport redraw...
2026-04-17 12:34:38.367 [INFO] :: Viewport redraw locked.
2026-04-17 12:34:38.659 [VERBOSE] :: Native format content directories: 2
2026-04-17 12:34:38.659 [VERBOSE] :: Poser format content directories: 1
2026-04-17 12:34:38.660 [VERBOSE] :: Other import format content directories: 0
2026-04-17 12:34:38.660 [INFO] :: Begin asset load (merge): /People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
2026-04-17 12:34:38.669 [INFO] :: Determining missing assets...
2026-04-17 12:34:38.699 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2026-04-17 12:34:38.699 [WARNING] :: Error loading asset: /Volumes/Data 1/DAZ 3D/My DAZ 3D Library/People/Genesis 9/Hair/Female/Bob/Chic Bob Hair/Materials/Iray/M3D Chic Bob Hair Color Blonde.duf
    Operation failed
2026-04-17 12:34:39.003 [INFO] :: Unlocking viewport redraw...
2026-04-17 12:34:39.003 [INFO] :: Viewport redraw unlocked.
  • felisfelis Posts: 6,501
    This usually means you are using the hair on a different character as it was intended for, e.g. using a G9 hair on G8.
  • LeanaLeana Posts: 13,499
    Well that technically means you're using a hierarchical preset with the wrong thing selected. The most common case would be that you selected the hair while the preset expects you to select the parent figure, but indeed using it on a different figure than it was made for would also cause that.
