No encrypted for me.
1…1718202223…41
  • gregbogregbo Posts: 39
    Daikatana said:
    Daikatana said:
    Havos said:
    I do not think the content encryption has much to do with making the pirates' lives harder. It probably does make a pirate life harder, but i think it just does not matter (at least for DAZ). Nowadays vendors had 10 years time or so to become accustomed to piracy and probably have adjusted their prices and expected sales with the existance of piracy taken into account anyway. So why start fighting piracy now? Do they suddenly feel the urge to make all their products cheaper? Sounds unlikely to me.
    To prevent piracy, all the DS application would need to do is to check if the content is legit, i.e. if it was previously bought be the user (provided that the Dson content is mainly used in DazStudio). If one wants to throw cryptography at that challenge, one would use a so called signature algorithm. Most signature algorithms do not require the data to be unreadable. Think of Https (e.g. like in the personal account area of this site): Https authenticates the daz account area to the user, so the user can be sure that the page really comes from daz. It does not make it unreadable. So a pirate could copy the webpage, but it cannot be used as a replacement for the daz-page, because of the 's' in 'Https'. The same mechanism could be used to authenticate content. But DazConnect does not use signatures; it uses encryption. So the question naturally is: what is this encryption trying to accomplish besides restricting illegal usage of content? At least if this encryption scheme was engineered intentionally.
    One possibility it might be used for is a way to implement vendor-lock-in. Or to be more exact, it will happen, but if it will be a blessing or a curse can not be foreseen today. But the effect is not so much to lock out non-users (ie pirates) of using the products, but to lock in existing users with the software (and the content), so that they continue use the products (that can be a good or a bad thing, but its usually good for the vendor, i.e. Daz in this case). Like DAZ_* wrote more than once, they have no plans for the near future to do this and that. Above all they probably have no plans for the more far future. For example if DS will be free of charge forever. Might not be the question today, but maybe in a year or two? It might also be out of DAZ's control. Perhaps one day the NVIDIA's revenue stream originating from DS users buying high end graphics cards might trickle, and NVIDIA might say: "Sorry Daz, the free iray doesn't cut it any more, from now on you have to pay $100 for every iray license". I could imagine a lot of users would not pay that and look for alternatives. Who knows, by the time that happens some competitors (like Poser or 3dsmax)  might have implemented the Dson format, and might actually be cheaper and/or better in every aspect. But even if 3dsmax would cost only $10 and had a perfect Dson format reader: if a user had built a considerable $1000-library of encrypted content which only DS can read, the user would likely swallow the pill and pay the price for the newest DS version, just to keep that content.
    An example where that worked out rather well in the 3d-world is 3dmax. Once i have a considerable library of .max files, i will buy (or rent) the 3dsmax software. It does not really matter to me if 3dsmax contains bugs, provides no innovations or is worth its money. I will buy it anyway because no other non-autodesk application can read those .max files. It could also be called customer-loyalty instead of vendor-lock-in. Does not sound so negative.
    Piracy has been getting worse.
    You are begging questions there - not least, "does nVidia give Daz free licenses for Iray in DS?" (I am not privy to the terms of the deal, but it's certainly not soemthing that should be blithely assumed).
    Could you please point out any references you have for why you say: "Piracy has been getting worse". It may indeed be true, but I have heard contrary evidence. A friend of mine who is a part owner of a software company, whose own products have been widely pirated in the past, has told me the opposite. He said, that whilst his products are still undoubtable pirated, it is much less of an issue now than it was before.
    I meant specifically Poser/DS content piracy, rather than gernally, and even then it's based on perception rather than measure - including the "worse" of the growing number of sites that take payments (subscriptions, donations or whatever) up front for access to the content.
    "Perception rather than measure" is not hard data, is completely subjective, and is not an accurate assessment of what may or may not be happening.  Just because something LOOKS worse does not mean it IS worse.  Give us some hard data that we can fact check for ourselves and should your perception prove out, more of us might be on board with you.  Also if you "perceive" that its the illegitimate subscription sites causing the issue, go after them rather than inconvenience the legitimate paying customers.
    Since I asn't a decison-maker with respect to encryption 9and would have decided agaisnt if I had been) my perceptions are not entirely relevant, and I shouldn't have mentioned them in the quoted post. However, the way people perceive the market does affect their willingness tot ake part as vendors - which obviosuly affects us when it comes to the content available - so I don't think perception in general is irrelevant if it was a factor in the decision to implement the encryption component of Connect, of which I have no knowledge.
    Thank you for clarifying.  Your candor is appreciated.  :)
    Agreed! Thank you from me as well, Richard!
  • ghastlycomicghastlycomic Posts: 2,531
    I've just found a Rendo email, the first words "DRM-FREE!"
    I have a feeling that rival companies are going to have a field day over this DRM/encryption stuff.
    Yeah noticed the Rederosity e-mail today that contained the phrase "Don't let DRM Products limit your creativity..." in big bold letters.
    Looks like Daz has given their competition a great big ol' birthday present.
  • DaikatanaDaikatana Posts: 830
    gregbo said:
    It's like we're back in the 80's and none of the lessons of DRM being evil have been learned.
    Totally... I'm afraid DAZ is about to find out the hard way what happens when one "puts Baby in a corner".
    (Being a child of the 80's I had to go there) ;)
    I am afraid you may be correct. The people that made the decision to force unwanted encryption on us may soon get some hard data in the form of lost revenue regarding how well their decision is accepted.
  • I've just found a Rendo email, the first words "DRM-FREE!"
    This is hilarious considering what happened at Rendo last year.  For those that don't frequent that store, the people in charge made massive changes to the store and to their Prime membership (a subscription similar to DAZ's PC+ club).  These change recieved an enormous amount of negative user feedback (similar to what's happening here) and Rendo staff and their published artists kept talking up the changes saying how great they were for the customer and how fun they were.  Consumer's didn't buy it and several months later you saw posts from their artists talking about how much sales were down following the changes and they began to backtrack on some of the changes.
    When there was the huge backlash against DAZ for the Rev Up sale last year and they responded by changing the sale I thought what a stark constrast between the two companies but now...
  • SnowSultanSnowSultan Posts: 3,845
    What that shows is how quick they are to take advantage of people's hysteria and lack of understanding about this entire situation to try and sell their products.
    I updated and used Connect.  I can still use my content offline, nothing exploded, nothing stopped working, and I'm pretty sure DAZ isn't getting any more information from me than when I downloaded my products through DIM. I am impressed with how calm Richard and the other DAZ staff have been in dealing with this lunacy.
  • IvyIvy Posts: 7,165
    I got that email too. I'm post a capture of it but it would just get removed
  • lx_2807502lx_2807502 Posts: 2,996
    Yeah when I first looked at Rendo I was all set to join their Prime thing but then I looked at what you actually got for the money and it was just unbelievably bad. And the site is still a nightmare to navigate and generally just spams you to death with products you don't care about. PC+ is such great value and I'm always happy being a member of it.
    But now things are going the other way with Daz's encryption iniative... oh well it's not like anyone told them this would happen.
    Today is a day where I am very glad that I back up the downloads folder in DIM.  I made sure it was updated with everything today and then backed that folder up on another hard drive.   Way too much content to burn to media.  On that backup are the install folders for Studio 4.8.  I have the feeling that this is going to be a bumpy ride for what is in my opinion the best content provider in the business and while I plan to ride it out until I am absolutely FORCED to use DRM encrypted content, I am also preparing for the worst.
  • HavosHavos Posts: 5,705
    I was also highly amused by the rendo email, very well timed given the opinions raised in this thread. The problem with rendo coupons, is that virtually the only things with a decent discount (ie not 10 or 20%) are prime items, which you can never use the coupons on. At least this time clearence items are included, but these are by definition "unloved" products.
    But has Daz ever, and I mean EVER, listened to it's customers? Lunatic or otherwise?
    What have we asked for since... well forever?
    • Better integration of Daz Studio assets in Carrera/Poser/etc.
    • Better animation tools in Daz Studio.
    • A proper functioning, updated version of Hexagon.
    • Dynamic cloth and hair in Studio (not Optitex which only 1 person in the world has the rights to create clothing for in Daz Studio)
    • Physics in Studio.
    What have we ever gotten from them? Yet another Genesis figure nobody asked for and DRM that nobody asked for. What will we get from them in the future? Probably another Genesis figure nobody asked for.
    We're assuming anybody who matters at Daz even knows or cares that people are confused and pissed off about DRM restrictions on their software.
    I think we can all agree there has been lunacy, but exactly who were the lunatics has yet to be determined
  • IppotamusIppotamus Posts: 1,580
    Getting your credit card hacked repeatedly over at Rendo is probably the only thing worse than encryption.  :P
    Pretty much you are spot on.  I actually just use a reloadable visa for shopping at that site.  Its safer that way.
    Oh I'm pretty sure they KNOW as many of them were conceivably in on the decision making.  If they actually CARE about our reaction to it is another question all together and at this point, I am not sure that the decision makers involved actually DO care about customer opinion.
  • nicsttnicstt Posts: 11,715
    Paypal is far more secure, using a credit card for extra protection of course.
    Its not the actual mechanism of DazConnect that is what has us all upset , SnowSultan.  Its the encryption that is being used as DRM that has us concerned. The two things are very different.
  • But has Daz ever, and I mean EVER, listened to it's customers? Lunatic or otherwise?
    I've only been here about a year but just off the top of my head I've seen them take feedback and action on, Rev Up sale (rev ups no longer expired and no calculus to figure out the sales), winter punch sale (punchs stopped expiring), if you look at the 4.9 beta thread they did incorporate a lot of user feedback into how connect works (what is in release is much different from the original incarnation that was going to have all connect content be DRM'd among other usability improvements), some of the banners now have a date and time listed for when the sale expires.
    You are probably correct and I may take that route at some point in the future given how things are going.  For now, this works pretty well for me
    I can't speak for DAZ, but a lot of those points have answers:
    * Carrara, Bryce, and Hexagon appear to have pretty much become DAZ's backburner projects that they'll never really get around to concentrating on again. Most software companies do this though, so it's not unprecedented.
    * Adding KeyMate and GraphMate to Studio along with aniMate will give it very good animation tools.
    * I don't have a good reason why we don't have better dynamics in Studio yet, but I doubt it's just "DAZ doesn't want to do what we want".
    * Technical advancements made it too difficult to keep compatibility with Poser when developing new figures and content.
    DAZ has listened to customers many times, they've given rebates and changed the rules of sales because people couldn't understand them. They continue to release content for Genesis 2 (for which many of us are thankful) even though they're pushing Genesis 3. The arguments against DRM sound like the arguments I hear regarding gun safety laws. "Well criminals don't follow the law!"...so let's do nothing to help curb piracy because some people may find a way around it anyway?
    I think in both those cases the "feedback" they got was likely lower sales than expected. They saw people bought more when they had 5 punches, so thought, why remove the punches. As has been said many times before, it is this sales feedback that will determine the success or failure of drm products
    I wholeheartedly agree... Plus I can only imagine the additional costs (and time) of regaining lost customers coupled with the loss of time/money/resources it took to develop, implement, advertise, handle the customer relations nightmare this has caused. I cringe at what the final total losses may be.
    I feel sorry for the poor soul in DAZ's marketing department who is going to be saddled with the impossible task of presenting DRM Encryption as a positive selling point or "feature" (lol) to potential new customers. The only new truthful campaign I can think of is "DAZ Studio 4.9 - Now with DRM Encryption!! We Done Goofed!!"
    edited January 2016
    Alright, then please explain why, in simple terms and with as little Chicken Little-esque "they're punishing paying customers!!1" claims as possible, how encryption and DRM will hurt us. We can still access the OBJs and textures, we can still export to other software, we have to download the products at least once to get them to begin with, and there is a method (perhaps a bit of work, but it's there) to get content working on a computer than has no internet access. I'm not mocking you, I'd honestly like to hear a real reason that doesn't sound like a conspiracy theory coming from the same group of people who complain about everything DAZ does anyway.
    Post edited by SnowSultan on
  • Its not the actual mechanism of DazConnect that is what has us all upset , SnowSultan.  Its the encryption that is being used as DRM that has us concerned. The two things are very different.
    Carrara and Bryce users can no longer natively use encrypted content.
    DAZ Studio uses a thumbprint of your computer to determine if it's the same computer or a different machine.  I found in the beta that some Windows updates that modify the OS version number changed this thumbprint (I would guess things like modifying hardware would also trigger it but I have not seen anyone mention running into this yet).  You will be unable to use the encrypted content until your computer can connect back to DAZ.  For people who have connectivity issues, physcially move machines to another location to obtain internet (like a cafe), or in the event that DAZ's servers/datacenter are having a meltdown (like this week), you could be locked out of using your legitimately purchased content.
    If DAZ goes bankrupt, is sold, gets out of the content business, you have currently no legal recourse to get keys to decrypt content.  A DAZ emplyoee mentioned they promise to have a poison pill to remove the encryption but that is just a promise on a forum and I do not belive has been added to the EULA.  In theory you could pursue them in court under the legal theory of promissory estoppel but you would obviously need to pony up the lawyer fees.
    edited January 2016
    We've had encrypted content for what, three days now? Like I said, Carrara and Bryce are not DAZ's priority, but it's likely at least Carrara will get a fix for that.
    I go through this with Steam every time I do the slightest thing to my computer. It's a pain, but it's tolerable and if it reduced piracy at all and helped the company continue to release products, I'll deal with it. You may not, and that's your right not to.
    Another hypothetical situation where you're willing to take the word of people who have absolutely no insider knowledge of DAZ's failsafes over those who might.
    If you go back and read through this thread your question has been answered many times, but each time it is, it is dismissed by those that asked with "Nobody does that", or "No one uses that software anymore", or "There are workarounds for that issue"
    Kindly link to one of those answers then if it differs from what RobotHeadArt just told me. And perhaps if someone says there are workarounds for an issue, maybe there are. Why is everyone so quick to assume that DAZ is lying and take the word of people who have NO FACTS to back up anything they're saying about DAZ's plans or future?
    I don't recall saying I think DAZ are lying about anything, as far as I am concerned they have been honest and up front about what they are doing, and why. It is just that some of us don't agree.
  • Oso3DOso3D Posts: 15,125
    The benefits of DRM:
    It will cut down on the most casual of criminals freely stealing stuff.
    The drawbacks of DRM:
    Company goes out of business.
    Scripts and other stuff that require free access to files to do funky cool stuff with products YOU OWN.
    Readable format to see what stuff YOU OWN does, and how it's organized, so you can learn from it or do funky things with it.
    Easier to copy/paste between machines or otherwise store the way you want.
    General bad experience with promised 'DRM will be fine' in the past, and the general truism that the more complications you make, the more chances for things to go wrong.
    So, like people keep saying, DRM mildly inconveniences theft while less mildly inconveniencing customers. Obviously we can see why Daz and some PAs may, naturally, want to somewhat drop misuse of their stuff. Obviously, we can see why many customers aren't thrilled at something that doesn't benefit them (except in the most roundabout ways).
    You can disagree with folks' assessments, and some of the complaints are loonytunes. But brushing away all concerns as stupid or silly is wrong.
    No much of the discussion is about the restrictions of DRM, not to pirates, they hardly notice but to us; then there's the matter of the DRMd products having a potential permenant lockout that we have no control over. There are many examples in threads where folks state they have lost to DRM - I haven't to the best of my knowledge: I avoid DRM products that carry that risk.
    I will continue to do so.
    Also, the point of 'We prefer to call it encryption because DRM is usually worse' sounds a lot like doublespeak.
    Yes, it's DRM. DRM comes in all sorts of formats. But there's a reason the term has such negative connotations.
    (God, anyone here remember Spore's DRM?)
