Show Us Your Bryce Renders!
Adding to Cart…
There are not many moments when on an 8-way system only part of the cores show activity. There are a lot of services running in the background and you never actually know which is from Bryce. The process monitor which can monitor one single application would be of greater help.
And according to the colour distribution, it appears as if TA would see the HDRI from the outside. Got to experiment with this some more.
I swapped my origami birds for Vicky, just to see how she would respond to the lighting environment.
Edit. As you can see, something went a bit wonky with her outfit. I think it might be due to specular response. I will have to investigate.
Also her toenails and fingernails don't match :)
It also appears that she has an inflammation on her right knee.
Perhaps she fell off her bike, like David likes doing :coolsmirk:
I think "like" is a bit of a strong word to use. Yes, I don't know what's up with her knee... must be the camera angle?
Do they normally?
I don't know, somehow I don't see vicky riding along and then suddenly looking down and saying, "Gee what a fascinating texture all these loose stones strewn across the ground would maaaakkkkeee" *sound of bike and person crashing to the gound*
Do they normally?
I'm not sure about vicky but when my wife paints her's, her's do. :)
So that's what happened? I thought it was the beer... well, that is a relief.
Shhh, I'm trying to paint you as dedicated to your work, not the town lush :)
I rather thought she took the glasses for a bicycle and promptly fell off it. Now she's trying to get on her feet again.
Right... don't know what I can do with her knee. Nor do I know how to change the colour of her fingernails to match her toenails. The specular issue with her clothes I can fix - and in the process might have discovered the source of some of the odd problems I've been having previously lighting this model. For example, curious material setting, specular halo luminance 255!
I also moved her head so we could see her face.
9_mix into 9_blend - I have to go out of that Cornell box, and find more appealing environment for my objects.
6_mix into 6_blend - Test of the human skin - sorry for floating teapot. Can you spot the difference between the top and bottom row? Yup, that teapot has a 'skull' made out of sphere to stop the glossy transmission rays to go through the whole object. Another option would be to paint some sss map controlling the transparency strength.
@David Brinnen
Maybe Vicky's knee could benefit from some glossy transparency?
Now we can see her face - it DOES look a bit unhappy.
About the knee: I know quite a many V4 textures that have those knees. Seems to be the texture ressource many texture artists are using. Short from photoshopping the texture itself I don't know what could be done about it.
With some guidance from David I had another go at My Canyon, I got rid of the mist cloud I couldn't get it to look like what I had envisioned.
Still more tweaking to do..
The result is not that bad. What is mostly amiss is the low sky. As if the clouds would almost touch the ground above the canyon. In the Cloud tab of the Skylab, you can move the clouds higher up. This will also change the distribution of Haze.
Redone with less "glowy" skin. Took out one of the TA radial ambient optimised gel lights and dropped in a bit of direct from the sun.
Second image... another light test. Reflections provided by Horo's HDRI and gels for TA optimised radial lights, spherical mapped versions of the same HDRI.
Edit. I can see the Valley is coming alone nicely. I agree with Horo the sky/clouds is looking a bit low.
The texture on the canyon walls looks much better now. Can you describe what you're trying to accomplish with the mist? If we knew more of what you were wanting to achieve maybe someone could tell you how to do it?
If for example you're wanting a mist coming up like a spray from a waterfall then there is a texture in the sfx folder of pro materials called "Integrated volumetric snow", that applied to a stone shape might give you that effect if viewed from a distance.
@Horo
I never noticed that. :)
I am still learning the programme and bought in a sky from the Sky & Fog palette but don't know how to get rid of it so I can bring in a cloud plain.
@Lord,
Can you describe what you’re trying to accomplish with the mist?
I am trying to create something like a low cloud that doesn't touch the canyon floor or is above the top of the walls and is basically a mist.
David - I really like the second image, especially the "pillow" cubes. How were they done?
Thanks Dan. The cubes were made in Wings3D. If I get chance at the weekend I'll make a little tutorial to show how this is done, it is an easy process that can give rise to any number of such shapes, but easier to show than it is to describe in words.
Image, here I got adventurous and included 2 x Vicky. And Bryce didn't crash!
try six vicky - I did 5
I'm building up to that - with Horo's help and LAA.
never used LAA - whats that
Making Bryce Large Adress Aware means making it able to use more than 2GB memory.
http://www.techpowerup.com/forums/showthread.php?t=112556
never use it - thanks for the info
waiting for 64bit ;-)
Well, I used it since I now have a 64bit system with 32GB RAM ... and it works nicely!
With a 32bit system you would have to make the 3GB switch for Windows first and I never dared to set foot in the Windows registry for that one.
Waiting for a 64bit Bryce ... could be a looooong wait, as Daz didn't even use the s..n word.
There is also a tool on the same site to download for free: Process Monitor. It permits to watch the CPU and memory use for one selected program, e.g. Bryce. LAA makes Bryce a bit less memory restricted while we wait for 64 bit. By the way, you can enable and disable the LAA flag any time. This is nothing permanent.
