Daz Studio 6 Beta - version 6.26.2026.30901! (Updated November 05, 2026)
1…8182838587
  • emaneman Posts: 145
    The OpenGL view doesn't work with Radeon cards; I still have all the bugs I had with the alpha version.
  • crosswindcrosswind Posts: 10,363
    Sigh.... nearly 3 months since last update of PB,  0 critical issue has been fixed in the latest build ~~
  • At this point we have better chance asking claude to make a daz clone
  • MasterstrokeMasterstroke Posts: 2,538
    DAZ Studio 6 is a wasted chance.
    Imagine, what could have been done, since DAZ studio 5 has been anounced,
    but is is all about a "hey an AI assistent has been added".
    No Dforce 2.0
    No RTX renderer
    Nothing done about the Timeline, to make animations easier.
    The list goes on...
  • ImagoImago Posts: 5,828
    No Dforce 2.0
    No RTX renderer
    The list goes on...
    And many basic functions locked behind a paywall.
    Actually our first priority is to get solid usability, stability as well as longstanding bugs fixed....rather than brand-new features in DS6 ~
    But now, when pressing shortcuts, nothing happens as you have to click in Viewport to get it focused first of all.... when accidentally Zoom In/Out even if the cursor doesn't fall in Viewport, it still Zoom In/Out.... when rendering some Scenes, DS crashes, so on and so forth.
    Disappointed ~~~
  • bilyatboringbilyatboring Posts: 41
    edited October 1
    Are the devs even present here on the forum, I never hear anything from daz other than mods. At blender you could interact with developer and have a section for reported bugs you could track.
    And if they are having such trouble with developing daz then atleast make a better blender bridge.
    My thoery is daz probably bought into the ai hype and kicked out the actual devs.
    Post edited by bilyatboring on
  • DoctorJellybeanDoctorJellybean Posts: 10,281
    The devs are still here, even though they don't interact on the forums. Bugs are being fixed all the time, you only have to look at the change log.
  • Okay Dr Evil I totally believe you.
     Which OS and version do you have?
    edited October 1
    Radeon card owners seem to be having the same issue; in previous versions, the geometry was invisible, now it is completely black.
    https://www.daz3d.com/forums/discussion/769246/daz-studio-6-viewport-display-issue-texture-smooth-shaded-mode
    Post edited by eman on
  • Richard HaseltineRichard Haseltine Posts: 112,232
    No Dforce 2.0
    No RTX renderer
    The list goes on...
    Nothing that was part of the application in DS 4 is behind a paywall in DS 6.
  • golem841golem841 Posts: 233
    From my point of view, progress are made in DS6, too slowly for us end users, but I suppose there are big changes under the hood with QT6 and so on.
    An open source dev would be great for a free program. It's not Daz perspective.
    For Carrara, instead of letting it rotting, opensourcing would be an extremely good idea...
  • barbultbarbult Posts: 27,676
    I like those boxes that can be colored next to objects in the Scene pane. It makes it easier to scroll through a large scene and get back to a particular object.
  • ProPoseProPose Posts: 551
    golem841 said:
    ...For Carrara, instead of letting it rotting, opensourcing would be an extremely good idea...
     I beg to differ.  No ROT on my Carrara, it gets used every day.  I know what I've got, and I know it's limitations.  Anything can be overcome with a bit of imagination..  The last thing I would want is for someone messing ouround under the hood, as well intentioned as it may be. Just my thoughts.
  • RiverMissyRiverMissy Posts: 326
    What kinds of things are you doing in Carrara? Just curious how you might be putting it to such good use. Thanks.
    Mostly portraits and such, simple stuff, occasional outdoor scenes, which Carrara excells at.  I model my own studio type sets, but I can import just about anything
  • Turning off diffuse makes the whole model into a nightmare, please any way to solve this as I usaully work at night ?
    I'm using latest daz6 beta
    3042 x 1317 - 364K
    edited October 17
    Latest PB version fixed no critical bugs but brings a new critical issue: PA's / 3rd-party plugins all fail to load ~
    Those vendors have to recompile the plugins ? or you guys fix it ?
    743 x 1027 - 88K
    Post edited by crosswind on
    The vendors have to recompile. However, QA is aware and will release updates as soon as possible.
    Thank you for the warning! I won't install it now.
  • umblefuglyumblefugly Posts: 261
    It was a fairly straight forward recompile for the newest DS 2026. Early warning would have been nice though.
  • jmucchiellojmucchiello Posts: 2,888
    Does this mean all the existing plugins need to be updated and approved again?
  • V3DigitimesV3Digitimes Posts: 3,510
    edited October 18
    About PA plugins, yes they all have to be updated as mentionned here or elsewhere..
    I ran some compatibility tests yesterday with plugins compiled against the old and new DS6 SDKs, and the results were:
    • Recompiled with the new SDK: works perfectly with the latest DS6 Public Build, but fails to load in older DS6 builds ("Made for a newer version of Daz Studio").
    • Not recompiled (old SDK): works perfectly with older DS6 builds, but fails to load in the latest DS6 Public Build. (exactly as expected reading the changelog)
    What puzzles me most is the backward incompatibility. Since the SDK version check was introduced in the latest DS6 build, when I started my tests, I naivley expected (with fingers crossed) plugins recompiled with the new SDK to still load in older DS6 versions, which presumably don't have this new check step.
    However, my tests show that they don't.
    Is this the expected behavior? Is there a way to ensure compatibility for both users who will update to the latest DS6 build and those who, for reasons that are probably perfectly valid, choose to stay on older DS6 versions?
    Post edited by V3Digitimes on
  • PadonePadone Posts: 4,400
    In general, the SDK is not supposed to change inside a release major version, in any other software this is a symptom of instability or beta stage. Please make your CEO and developers aware of that, it may improve their ability to process things.
    With the SDK still in beta, I admire your courage and generosity for the updated plugins !
    I wasn't aware they released a new major version with a beta SDK, I'm not sure this does even make sense. If the SDK is a beta then this makes the release a beta itself.
    It is a new Beta release of DS6. The title of this thread is Daz Studio 6 Beta.
  • TotteTotte Posts: 15,368
    Just PASSed updates to 4 released plugins
    Support for NVIDIA 50xx cards made the ds6 release necessary.
    And the SDK has no bearing on the release status. You can release software with NO SDK. Just because the SDK isn't fully vetted doesn't mean the actual software can't be generally available. The internal Daz programmers do not use the SDK. Only third party developers use the SDK.
