Show Us Your Bryce Renders Part 14
1…4547495051
  • mermaid010mermaid010 Posts: 6,307
    edited August 31
    Hansmar -great scene, nice lighting. Thanks for the info about 'Smoke and Mirrors'
    NGartplay-thanks
    Post edited by mermaid010 on
  • HoroHoro Posts: 11,750
    Hansmar - thank you. Very nice landscape scene with the balloons.
    NGartplay - thank you.
    edited August 31
    The terrain is from High Resolution Terrains 1 with a material from High Resolution Terrains 2. The water is the ground plane with my material. Sky and ambient light by the ErmClouds12_SD HDRI from Grand Mountains and the key light by the sun. A small lake in a rough valley with steep mountains.
    Lake in Rough Vale
    1200 x 800 - 266K
    Post edited by Horo on
    Another magnificent realistic  landscape Horo.
  • HansmarHansmar Posts: 3,239
    edited September 1
    Thanks, NGArtplay, Horo and mermaid010.
    Fantastic landscape render again, Horo!
    I played with abstracts again. Used 'Odd world nr. 5' in the center. Made it semitransparent and added a red spherical light inside. Surrounded it by a number of fully reflective spheres. In the first one, there is a plane above and below, each tilted so that they for a wedge with the sharp end behind the scene. The second one is the same, but without the planes.
    1370 x 651 - 1M
    1370 x 651 - 605K
    Post edited by Hansmar on
    Both your abstracts are magnificent, Hansmar, the planes made an amazing difference between both renders.
    Thank you mermaid.
    Hansmar - thank you. Interesting setup for an abstract and two very nice results.
    edited September 2
    Here’s the TreeGrass exercise. I found it tricky to get good grass, but fun to do nonetheless. The material for the mountains is from Hi-Res 3, lit by an Hdri from Hi-Res 4. I scattered some daisies by Esha and added two trees from the Vegetation pack.
    900 x 600 - 557K
  • NGartplayNGartplay Posts: 3,420
    Hansmar, that abstract looks deadly and beautiful at the same time.
    Wonderful atmosphere, Horo.
    Mermaid, beautiful spot for a picnic.
    edited September 2
    mermaid - that looks like a very beautiful place. The daisies in the grass enhances the scene, also the the trees at te sides. Very nicely done scene.
    The object was made with Incendia NEXT and given a simple material with some reflection. It stands on the ground plane with some reflection and transparency. Everything is with the camera within a translucent sphere with some reflection. Light and colour by the WpH08 HDRI from Hyper Textures Base and a tiny bit of light by the sun. Many differently sized shells within each other.
    Shells
    1200 x 800 - 162K
    Thanks NGartplay and Horo.
    Beautiful still Horo, I  like the contrast between the dark and light areas, cool object.
    Thank you mermaid.
    edited September 4
    mermaid010, Horo, NGartplay, thank you.
    Very nice beautiful grass field, mermaid010.
    That is a nice object render, Horo.
    A self-made terrain, starting from a picture of vegetation, two times stacked, though in this light that is not very well visible. The sea is the same terrain, modified very much. I added some of the free birds from a set I used before. I added a Jepe space effect (which is a partly transparent picture on a 2D face) behind the mountains.
    1370 x 651 - 1M
    edited September 5
    Very nice unusual scene Hansmar, more like a painting. Thanks
    Thank you Hansmar. Very nicely done special landscape scene.
    edited September 5
    The terrain is from High Resolution Terrains 3 (X-Island) with a material from Landscapes under Fantastic Skies. The water is the ground plane with my water material. Sky and ambient light by the Marmorera_SD HDRI from High Resolution Terrains 4 and the key light by the sun. An uninhabited island with a needlepointed mountain.
    Needle on Island
    1200 x 800 - 209K
    Magnificent, realistic scene,  Horo beautifully done; love the clouds.
    Thank you mermaid.
    edited September 6
    The setup is by Alymac (ShareCG), I modified the scene a bit, changed some materials, I used an Hdri from Landscapes under Fantastic Skies for lighting.
    950 x 475 - 527K
    Very nicely done scene mermaid.
    Thanks Horo
    edited September 7
    The terrain was made from a Moon DEM (Digital Elevation Map) and given a material from High Resolution Terrains 3. The city in the hemisphere are buildings from the Dystopia City Blocks (not anymore available at Daz 3D). The moon, the star cluster and the stars are from the Space Construction Kit, sky and ambient light by the DS-Sky04 HDRI from Deep Space HDRI 2 and the key light by the sun. A city in a hemisphere on a moon.
    City on a Far Moon
    1200 x 800 - 244K
    Wonderful space scene Horo, put together beautifully.
    Thank you mermaid.
    edited September 9
    The terrain was self made and given a material from High Resolution Terrains 3. The clouds are from Object Clouds 2D & 3D. Sky and ambient light by the Gasclouds_B01 HDRI (unpublished) and the key light by the sun. A hillscape in the evening light.
    Hills in Evening
    1200 x 800 - 215K
    edited September 10
    Another very realistic scene Horo, beautiful lighting.
    Random spheres and tori (both with different reflective materials) within a bigger sphere, with a material from the Stylised Rendering. Lighting from an Hdri from Deep Space 2.
    700 x 700 - 598K
    mermaid - thank you. Great looking spheres and tori in this mesh. Good idea.
    edited September 11
    Thanks Horo.
    Same abstract as the previous one but this time viewed thru the GWLens.
    700 x 700 - 482K
    mermaid - also great looking as seen through the GWL.
    Horo, you have made some wonderful landscapes again. I like all, but the moon terrain is my favourite.
    The landscape modified from Alymac is shown very well, a lovely view, mermaid010. I also like your abstracts.
    You'll have to be patient for my next render, because I have been tinkering with a scene for a long time. I started making renders a couple of times, but each time decided more changes were needed. Now it is rendering again (for at least 5 hours) and I hope I will be sufficiently happy with the result this time.
