The terrain is from High Resolution Terrains 1 with a material from High Resolution Terrains 2. The water is the ground plane with my material. Sky and ambient light by the ErmClouds12_SD HDRI from Grand Mountains and the key light by the sun. A small lake in a rough valley with steep mountains.
I played with abstracts again. Used 'Odd world nr. 5' in the center. Made it semitransparent and added a red spherical light inside. Surrounded it by a number of fully reflective spheres. In the first one, there is a plane above and below, each tilted so that they for a wedge with the sharp end behind the scene. The second one is the same, but without the planes.
Here’s the TreeGrass exercise. I found it tricky to get good grass, but fun to do nonetheless. The material for the mountains is from Hi-Res 3, lit by an Hdri from Hi-Res 4. I scattered some daisies by Esha and added two trees from the Vegetation pack.
mermaid - that looks like a very beautiful place. The daisies in the grass enhances the scene, also the the trees at te sides. Very nicely done scene.
NGartplay - thank you.
The object was made with Incendia NEXT and given a simple material with some reflection. It stands on the ground plane with some reflection and transparency. Everything is with the camera within a translucent sphere with some reflection. Light and colour by the WpH08 HDRI from Hyper Textures Base and a tiny bit of light by the sun. Many differently sized shells within each other.
A self-made terrain, starting from a picture of vegetation, two times stacked, though in this light that is not very well visible. The sea is the same terrain, modified very much. I added some of the free birds from a set I used before. I added a Jepe space effect (which is a partly transparent picture on a 2D face) behind the mountains.
The terrain is from High Resolution Terrains 3 (X-Island) with a material from Landscapes under Fantastic Skies. The water is the ground plane with my water material. Sky and ambient light by the Marmorera_SD HDRI from High Resolution Terrains 4 and the key light by the sun. An uninhabited island with a needlepointed mountain.
The setup is by Alymac (ShareCG), I modified the scene a bit, changed some materials, I used an Hdri from Landscapes under Fantastic Skies for lighting.
The terrain was made from a Moon DEM (Digital Elevation Map) and given a material from High Resolution Terrains 3. The city in the hemisphere are buildings from the Dystopia City Blocks (not anymore available at Daz 3D). The moon, the star cluster and the stars are from the Space Construction Kit, sky and ambient light by the DS-Sky04 HDRI from Deep Space HDRI 2 and the key light by the sun. A city in a hemisphere on a moon.
The terrain was self made and given a material from High Resolution Terrains 3. The clouds are from Object Clouds 2D & 3D. Sky and ambient light by the Gasclouds_B01 HDRI (unpublished) and the key light by the sun. A hillscape in the evening light.
Another very realistic scene Horo, beautiful lighting.
Random spheres and tori (both with different reflective materials) within a bigger sphere, with a material from the Stylised Rendering. Lighting from an Hdri from Deep Space 2.
Horo, you have made some wonderful landscapes again. I like all, but the moon terrain is my favourite.
The landscape modified from Alymac is shown very well, a lovely view, mermaid010. I also like your abstracts.
You'll have to be patient for my next render, because I have been tinkering with a scene for a long time. I started making renders a couple of times, but each time decided more changes were needed. Now it is rendering again (for at least 5 hours) and I hope I will be sufficiently happy with the result this time.
Hansmar -great scene, nice lighting. Thanks for the info about 'Smoke and Mirrors'
NGartplay-thanks
Hansmar - thank you. Very nice landscape scene with the balloons.
Another magnificent realistic landscape Horo.
Thanks, NGArtplay, Horo and mermaid010.
Fantastic landscape render again, Horo!
Both your abstracts are magnificent, Hansmar, the planes made an amazing difference between both renders.
Thank you mermaid.
Hansmar - thank you. Interesting setup for an abstract and two very nice results.
Hansmar, that abstract looks deadly and beautiful at the same time.
Wonderful atmosphere, Horo.
Mermaid, beautiful spot for a picnic.
Thanks NGartplay and Horo.
Beautiful still Horo, I like the contrast between the dark and light areas, cool object.
Thank you mermaid.
mermaid010, Horo, NGartplay, thank you.
Very nice beautiful grass field, mermaid010.
That is a nice object render, Horo.
Very nice unusual scene Hansmar, more like a painting. Thanks
Thank you Hansmar. Very nicely done special landscape scene.
Magnificent, realistic scene, Horo beautifully done; love the clouds.
Thank you mermaid.
Very nicely done scene mermaid.
Thanks Horo
Wonderful space scene Horo, put together beautifully.
Thank you mermaid.
mermaid - thank you. Great looking spheres and tori in this mesh. Good idea.
Thanks Horo.
Same abstract as the previous one but this time viewed thru the GWLens.
mermaid - also great looking as seen through the GWL.
