Daz Studio 6.25[.0.x], General Release!
1131416181921
  • IceCrMnIceCrMn Posts: 2,333
    edited June 20
    I don't have a 5xxx GPU the test with, but with my 12GB 3060 I found that if I fiddle with "Response Threshold(msec)" I can get the viewport to respond a bit better.
    The screenshot is the settings I found best for me.
    Oddly, higher response time made it smoother.
    Can someone else try it out and see if it does anything?
    Also, I'm not sure what "Draw Node Avatars" does but turning it off didn't seem to do much of anything that I could see right away in my simple scene.
    edit: Ok "Draw Node Avatars" draws nodes like cameras and spotlights. After adding a few to my scene to keep testing I noticed I wasn't seeing them and visability toggled off and on when I toggled it. :)
    804 x 1164 - 85K
    Post edited by IceCrMn on
  • donniekeidicdonniekeidic Posts: 72
    Sadly, I see on the Daz Blog that both Mimic and Mimic Live! have been officially retired. So no more DS 32-bit Mimic. That pretty much keeps me firmly with DS4 forever.
  • butterflyfishbutterflyfish Posts: 1,750
    I'm just getting random crashes after working with it for a while. I'm not doing anything in particular when it happens. Just now I was rotating a prop on the Z-axis.
    Windows 11, i9-10850K, RTX-3050, 32 GB RAM
  • SaintSaint Posts: 87
    edited June 21
    Tried that one myself, a couple of weeks ago, it didn't do {anything}
    (Edited by mod)
    Post edited by frank0314 on
  • hejjj12hejjj12 Posts: 70
    edited June 25
    Same crashes very often for no reason. Just randomly when changing parameters.
    Edit: After some more testing it seems like maybe it was the scene that just broke on Daz3d 6 and not the old one. Set up a new and now it works, and after testing the old again, I noticed how much better the new one is, everything is fast, the view port actually has settings that work. A welcome upgrade.
    Post edited by hejjj12 on
  • I have installed DAZ Studio 6.25, but I don't see my Poser 11 content directory. How do I tell DAZ Studio 6.25 the path to my Poser content?
  • DoctorJellybeanDoctorJellybean Posts: 10,045
    You need to add it manually:
    F2 - Content tab - Content Directory Manager - select Poser Formats - click the Add button and browse to where it is installed.
    F2 - Content tab - Content Directory Manager - select Poser Formats - click the Add button and browse to where it is installed.I
    Thanks for the advice. I did it by right-clicking in the leftmost column with Poser Formats selected, and selecting "Add a Runtime Directory…" from the contextual menu.
  • Jack of SpadesJack of Spades Posts: 104
    edited June 25
    I'm having the same problem, only with dual RTX-5000 Ada cards. Support tells me it's because I'm using third party content. WHAT THE HELL?!
    All of it, including the supposedly unsupportable 5xxx series cards, works just fine in 4.24.
    Post edited by Jack of Spades on
  • Richard HaseltineRichard Haseltine Posts: 111,137
    In Iray, using the GPU (CPU rendering works in 4.24, of course)?
    • Which driver version on those Ada cards?
    • Are both cards selected as Photoreal devices, or only one?
    • Are the crashes happening during Iray renders specifically, or also during general use?
    • What DS log entries appear around the time of the crash?
    • Are the cards in x16 PCIe slots, or shared bandwidth slots?
  • DamselDamsel Posts: 406
    I lost my whole Daz content and program in a computer reinstall. Installed Daz 6. I now have to redownload everything. But the new C: drive is way too small for my library, so I need to put smart content on my G drive. I watched a ton of tutorials yesterday trying to find out how to do that. I found out how to fix DIM, but not how to chang the path on Smart Content. Can anyone tell me either how to do that or where to find a tutorial? This is so frustrating and I'm on deadline on a project that is due this weekend.
  • LeanaLeana Posts: 13,473
    Go to edit > Preferences > Content tab,  there's a "content directory manager" button at the bottom of the tab.
    Once in the content directory manager you can then edit the current directories to change the path to CMS content cluster, Connect directory, and Poser and DS directories
    Thanks!
    596.59. As far as I can tell that's the most current Studio driver.
    Both. I have a third card that actually drives my display; all these do is render and dForce.
    When rendering, simulating, loading unrigged assets, changing viewport angle, posing... once when loading a plane primitive into the scene.
    The last log entry is frequently more than 30 seconds old, and is what you'd expect for normal operation doing that task. No warnings, no errors.
    This I don't know. How can I tell? The machine was a custom built high-end workstation, so I assume it was done right, but I lack the hardware skills to say myself.
  • jbowlerjbowler Posts: 867
    Padone said:
    Apart that, if those problems only arise with DS6 and not with any other program, then one may wonder why DS6 triggers the security software while others don't. As for disc problems again they would affect all the programs including the OS.
    The OP (@almahiedra) has a custom CMS directory (if I read the post correctly).  On Windows (10 and 11 IRC) there is a security feature called, "Controlled Folder Access".  Those of us who have it turned on have to either disable it for both Studio and DIM or allow both to access all our CMS directories (like the OP and others I have multiple CMS directories on different drives).  It's not just CMS, the Postgre database has to be writable too if you moved it.
    The settings apply to a single path name; so Windows regards DS4 General, Public and I assume all the others as well as the same group for DS6 as different guys.  That's an answer to your question.
    For those who experience something like this check out, "Controlled Folder Access".  It's in "Windows Security" under "Ransomware Protection"; Microsoft have it well hidden these days but if, like me, you turned it on as soon as it was available it's still on.
    Don't change the path to the "CMS content cluster" unless you know exactly what you are doing or you are doing a completely fresh install.  The DAZ ecosystem only has one cluster (one Postgre SQL database to be more techy) so changing it in one place changes it everywhere.  The cluster can be copied, backed up (by a copy or, perhaps, using Postgre) and moved but I have yet to find a workable way of having more than one.  I have certainly tried; I know how to do it but it isn't "workable".
  • crosswindcrosswind Posts: 10,144
    That's not entirely true~~  One can setup multiple cms cluster folders for specific purpose (e.g. content creators can set up unique configuration of Daz Libary / cms cluster purely for the purpose of making products, etc....) and change the cms target by switching Content Sets in CDM as each Content Set can have different cms target folder. The problem is that only one JSON configuration file related to cms connecton / port can be saved / read by DS... However, it can be technically resolved by some ways like using BAT / scripts to update JSON config. file as well as restart postgreSQL service before (or after) loading DS.
    If running multiple DS instances even + multiple builds of DS, cms ports have to be also changed as one port cannot be used for multiple cms targets... Setup will be cumbersome but it's still workable.
  • jmucchiellojmucchiello Posts: 1,928
    Studio Driver 610.62 came out in mid-June.
  • TaphneMTaphneM Posts: 6
    edited June 29
    @zev0
    Hello, unfortunately, this script  Brow Remover for Daz Studio | Daz 3D doesn’t work for me in the latest Daz Studio 6. The utility box (grey panel with options) appears, and the Genesis model selection slider works. However, the “Show Mask” option does not. Also, when I try to run the script without the mask showing, the viewport flickers on the selected model’s face and the process cancels itself (the eyebrow removal "plucking" doesn’t complete.)  I have tested it on Gen 1 through 8 on both M and F models, but the mask (reddish mask) does not show over the eyebrow area. I have tested the height dial also, nothing.
    Post edited by TaphneM on
  • JimbotiniJimbotini Posts: 46
    There seems to be something going on with almost all draw styles (for me at least).  There is this ghost/shadow around hair (perhaps transparency) and all other draw styles except iray just don't draw anything.  Did I miss a post about this or a checkbox to actually draw things in the viewport?  Studio 6 has the problem, but same scene in 4 doesn't show any of those problems.
    windows 11
    AMD Radeon RX 5600 XT for displays
    Nvidia 3060 for rendering only
    654 x 846 - 625K
    679 x 1010 - 40K
    windows 11
    How about if  you use the nVidia GPU for the display?
  • pwyskowskipwyskowski Posts: 13
    Is just me or does DAZ Install Manager automatically install DAZ Studio 6 without being told to?
    Install Manager doesn't automatically install any downloaded packages incl. DS 6... unless you check the option Install After Download in Ready to Download tab.
    Richard Haseltine said:
    windows 11
    It seems to behave if I plug my monitor running DAZ into the nVidia card.  So seems to not support the radeon card even for drawing the window/viewport on the screen.  This is a change from V4.  It would be nice to not require that so I don't have to use video memory running monitors.  I knew Radeon cards are wholly worthless for literally everything, didn't think it was now worthless for even running monitors.
    edited June 29
    It must have been under the list of "New" downloads instead of the "Updates" and I didn't notice it there. I wanted to avoid updating/upgrading DAZ Studio so I wouldn't lose access to the 3Delight renderer and all of the products related to that I purchased over the years. It caught me by surprise when a popup appeared asking for my preferences for DAZ Studio 6 and I hadn't seen it in the list of downloads selected. I'm glad that I didn't lose the version of DAZ Studio 4 that I had installed but I did notice in the "Installed products" tab of DAZ Install Manager that DAZ Studio 4 disappeared and DAZ Studio 6 is there only.
    edited June 29
    Correct, DS6 shouldn't be under "Update" unless you've installed it before. But DS 6 is installed separately into the dedicated folder of its own and has a different SKU# rather than DS4's, so you should be able to find both of DS4 and DS6 under Installed Products. Check the screenshot down below.
    Besides, better always back up the old DS packages / installers, just in case...
    1193 x 869 - 121K
    DS6 is a completely separate version so installing it won't affect your DS4 install.
    Did you maybe hide DS4 in DIM so you wouldn't risk installing the update?
    edited June 29
    No. I did not hide anything so I find it odd that it's not listed under the installed tab.
  • pivasmanyapivasmanya Posts: 4
    Their comments on the main DAZ6 build
    Many scripts don't work - is this intended? Right-clicking often doesn't bring up a pop-up menu.
    The camera in FPS mode still frequently breaks and becomes discontinuous, jumping along a trajectory it only knows (this most often happens when you hold down the right mouse button to view : orbit).
    Most complex operations (scene optimizer, character skin modification, etc.) must first be done in 4.24 and then render the saved scene in DAZ6. The user experience is excellent (considering that 4.24 still hasn't fixed the proper multi-monitor support, although it works as expected in DAZ6).
    P.S.
    Why are the pins working so poorly in DAZ? I'm making a scene on a horse. I pinned the hands to the horse's reins. In any other program, I would simply twitch the hip or pelvis up and down and there you have it, simulating a trembling motion, but in DAZ, for some reason, sometimes, but not always, the hands twitch. Sometimes, it works as expected, but in In most cases it's bad... Which in principle can be said about the entire DAZ6.
