New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1171820222374
  • 3DIO3DIO Posts: 558
    garrett_3d said:
    Yep, it definitely worked. I got several items for $0.07! laugh
    I don't know how you do it.  I thought there was a cap on the minimum a product can sell for.  I finally caved and bought Minerva 9.  Yet Despite being a Daz+ member.  Despite there being 30% off on top of the 30% off Daz+.  Despite the discount using the offer I chose to use (and met).  Despite there being an extra 30% off the entire cart on top of all that.  And finally, despite Minerva 9 being a Daz original and therefore deserving a further 45% off from using my 8 Daz Tokens on the total ...
    Despite all of that, Minerva 9 still mangaged to cost me over $16 dollars!
    On the plus side, I did finally get Holden for the sort of money Phoenix1966 demonstrated, and Cate 9 was had for a good price as was the rest of the cart.
  • garrett_3dgarrett_3d Posts: 782
    There's a few of the dirt cheap ones. I've bought some more since, not quite as cheap but still mostly under $2.
    800 x 254 - 34K
    edited April 25
    @garrett_3d
    Ah right.  I don't buy stand-alone textures too often, and it seems I'm far too dab hand at being drawn to textures that come with characters!
    Post edited by 3DIO on
    I can't get anywhere near the super-low prices, with only 2 tokens, and just staying with WL products. Oh well, I don't really need anything more ATM.
  • KinichKinich Posts: 940
    The extra 20% discount of 'Ultimate' releases doesn't seem to work.
    Put 2 items in my cart still only 30% off.
    800 x 821 - 290K
  • TogireTogire Posts: 457
    1/ "Mad Door Prizes Return" does not work. With a new 'ultimate' release, the price is unchanged. (see image)
    2/ FLASH-BACK coupon does not work. I already used it yesterday, but it does not seem to be limited to a single use according to the fine print.
    875 x 526 - 98K
  • Cris PalominoCris Palomino Posts: 12,933
    I only see MAD-FLASH. It's working, but it's first time for me. Are you trying it a second time tonight?
    The Shooting Stars and Mad Door cats should be working now.
    My bad. Yes MAD-FLASH works. Definitely, I need a vacation...
  • DeepeyedDeepeyed Posts: 30
    just reiterating this in case it was missed.
  • frank0314frank0314 Posts: 15,068
    edited April 26
    I get the same, so reported it
    Post edited by frank0314 on
    edited April 26
    Seems to be working for me. I've just picked up 2 Ultimates, used MAD-FLASH for the fourth time and added a load from my wishlist. 17 items for $42.
    Post edited by garrett_3d on
    Thats a seperate offer than this one. This is the
    edited April 26
    To be fair, I've been eating into my graphics card fund lately.  No point me doing otherwise since I ain't paying the current astronomical prices for a card.
    I spent way more than I would normally spend, in order to build the discount like that.  On the one hand I look at the total and think, damn, I really shouldn't have spent all that.  But on the other, I'd have needed to spend over time at much greater expense if I hadn't, so that's my only excuse and method of self-consolation!
    edited April 26
    It is now fixed. Deepeyed Kinich
    yep, but unfortunately I don't think the 'Extra 30% off* with any “Ultimate” New Release' on still new in that cat is working on anything older than yesterday?
    It's working for me.. It will only work on;
    30% off “Ultimate” New Releases
    Buy any 2 or more "Ultimate" New Releases to get an extra 20% off* them
    and:
    40% off Still New Releases
    edited April 26
    I tested the "Silk and Sabers Bundle for Genesis 9 Feminine" with "MSO Coco HD for Genesis 9 Feminine" in a cart and it stayed at 40%. What am I missing?
    1080 x 1864 - 401K
    Post edited by Deepeyed on
    edited April 26
    This is what I get using 8 tokens and the discount code. I'm a Premier member, not that I think that makes any difference to the base price anyway.
    1384 x 697 - 162K
    that's what I got, but I removed the discounts to make it clear to see that the still new isn't getting the extra 30%. The still new's discount should be higher than the new. Or am I crazy?
    How I read it, the basic price is discounted 30%. Adding two of them brings the discount to 44%, which seems correct to me. This is how I worked it out:
    Take $100 as the base price for example. 30% off makes it $70. Two items gives an extra 20%, so 20% of that 70% is 14%. Add the 30% and 14% to get 44%, which would give you a final price of $56.
    Does that make sense?
    edited April 26
    Right, but it's not the new release I'm talking about, but the still new, in this case the Silk and Sabers Bundle. It's 40% off, but should get an extra 30% with the new release. Right?
    Seems an issue with Silk & Sabers. I just tried with various others from the list and they are getting discounted further.
    edited April 26
    okay, from my testing, I'm only getting the extra discount on MM still new if I put a still new from the last few days in my cart. It doesn't work with todays "ultimate" new releases.
    Hmmm. I tried it with Coco from Ultimate list and added about ten other items from still new, the only one that didn't discount was Silk & Sabers.
    edited April 26
    But was any of the still new you had in your cart newer than "LI The Magic Rug - Glass Walls 01"? Because that's the cut off product for the discount for me. Any still new newer (and including) that product in the cart and the discount works. Without a still new newer than that, then the discount doesn't work.
    Can a mod please look into this?
  • MonkeMonke Posts: 69
    edited April 26
    Given that when you put something that was released yesterday into your cart it applies the discount,
    I imagine the code behind the discount being applied is checking for items from the start of the [weekend] event, rather than the start of the day.
    Post edited by Monke on
    edited April 26
    yes, exactly. But it doesn't work with just todays new releases, the extra 30% only kicks in with a recent still new in the cart. I just want the discount to work as avertised. I'm just trying to get that reported, but I feel like a crazy person yelling into the dark.
    edited April 26
    OK, this is weird, it all works for me. I've just bought Sepheraas along with 3 still new and a load of other items. I got all the discounts stacking.
    1399 x 896 - 209K
    edited April 26
    If my theory is right, then the EG Dress will have triggered the discount (as a more recent new release) if you had Sepheraas in the cart or not.
    Annoying as I bought the recent still new stuff I wanted yesterday.
