Daz Studio 4.24[.0.x], General Release!
123457»
  • Andrew_CAndrew_C Posts: 130
    edited March 20
    So obviously the latest update, DS 4.24.0.4, was mostly about removing 3Delight, but I noticed today that there are update to the default resources & tutorials. What is that update for? couldnt find any info on it.
    Post edited by Andrew_C on
  • DoctorJellybeanDoctorJellybean Posts: 10,123
    Most likely bug fixes and improvements.
  • OmnifluxOmniflux Posts: 442
    Metadata update for Scene Builder scripts for the resources and templates; I don't have the lessons installed so not sure if is the same.
  • alofaroalofaro Posts: 43
    Hi,
       A very specific question. Will 4.24 work with a Quadro 6000 Pro ?
       Yes, I have seen the reference to not working with series 50 cards, and the 50 are Blackwell-based, but the 6000 Pro is a different family/category, even if Blackwell, so, not sure if it will apply automatically to those as well.
      Thank,
    alofaro said:
    Hi,
      Thank,
    If it is Blackwell, then probably not. A quick look seems to indicate that the latest driver is R570 U6 (573.42), 2025 June 17.
    DoctorJellybean said:
    alofaro said:
    Hi,
      Thank,
    Thanks ! Actually, I found a post and thread here with insturuction to be make Blackwell work with Daz Studio, but since that user is using Daz 2025 beta, I do not know if it will work with Daz 4.24 or even 4.25.
  • Richard HaseltineRichard Haseltine Posts: 111,491
    alofaro said:
    Hi,
      Thank,
    No.
  • memcneil70memcneil70 Posts: 6,121
    edited April 9
    I have been having crashes when I try to download User Data. I get to Vol 4 of 8 when Daz Studion crashes. This is on both my Windows 11 and my MacMini M4 and I try checking the help log and until today haven't been able to find any trace. I am pasting something where I think it might (?) be pertinent or not. But I only made it to vol 4. When I reopened Daz Studio 4.24.0.4 and tried to get into that log on my MacMini, Daz crashed again just by clicking the log. I selected 'reopen' and this time it stayed stable.
    2026-04-09 10:12:45.154 [INFO] :: Viewport redraw unlocked.
    2026-04-09 10:12:45.212 [INFO] :: Json Parser (1,1): Syntax error - expected '{' or '['
    2026-04-09 10:18:59.603 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_1.dsx (This is actually where I have 4 volumes built.)
    2026-04-09 10:27:51.483 +++++++++++++++ Daz Studio 4.24.0.4 starting +++++++++++++++++
    2026-04-09 10:27:51.483 [INFO] :: Performing cleanup...
    2026-04-09 10:27:51.533 [INFO] :: Release Cycle: Public Build
    2026-04-09 10:27:51.533 [INFO] :: Platform bits: 64
    2026-04-09 10:27:51.533 [INFO] :: Qt Version: 4.8.7
    2026-04-09 10:27:51.533 [INFO] :: OpenSubdiv Version: 3.0.0
    2026-04-09 10:27:51.572 [INFO] :: Running on macOS Tahoe 26.4
    2026-04-09 10:27:51.586 [INFO] :: CPU Information:
    2026-04-09 10:27:51.586 [INFO] :: CPU Brand String = Apple M4 Pro
    I have been having to check to see if Runtime>Support has the expected number or more of files created, and if not run the Content DB Maintenance>Export User Data until it does.
    Also, not sure what is up with Windows 11, but running this since the a recent update is causing my screens to go blank and freeze up. I have at times had to do a hard reboot on my system to get it back. And Daz Studio opens up on its own. I actually have been worried that another MS update was running in the background, but I had checked before opening DIM or DS that no updates from Microsoft or Nvidia were waiting to run.
    Mary
    Edit to add: I was able to get a successful backup on my MacMini, which only has 7 files:
    2026-04-09 10:31:56.092 [INFO] :: Viewport redraw unlocked.
    2026-04-09 10:31:56.143 [INFO] :: Json Parser (1,1): Syntax error - expected '{' or '['
    2026-04-09 10:53:51.765 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_1.dsx
    2026-04-09 10:56:39.634 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_2.dsx
    2026-04-09 10:59:09.288 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_3.dsx
    2026-04-09 11:01:31.608 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_4.dsx
    2026-04-09 11:04:06.926 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_5.dsx
    2026-04-09 11:06:37.177 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_6.dsx
    2026-04-09 11:08:24.703 [INFO] :: Writing User Data file: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/Runtime/Support/UserData_PublicBuild_7.dsx
    Post edited by memcneil70 on
  • CriosCrios Posts: 3,127
    I would buy a new pc,with a nvidia 5050, i can use DAZ 4.24 on it?
    edited April 12
    Yes, but to render in Iray you will need to use DS6.
    Post edited by DoctorJellybean on
  • HamEinarHamEinar Posts: 138
    Please, stop saying this. You can clearly read that English is not the first language of the poster - so he or she will most likely read and understand your "Yes" - but not the but... Stop being so litteral; you CAN'T use Daz Studio 4.24 on any 50-series card IF said usage include plans to render in Iray (which, in my humble opinion is implied in the initial question).
    You can;'t render with the GPU, you can with CPU.
  • FrankTheTankFrankTheTank Posts: 1,624
    A 50 series GPU will supposedly work with DS 4.24 if rendering in Filament and greatly increase render speed according to AI (I haven't been able to verify as I only have an RTX  2060). Has anyone tried this and seen an improvement in render speed? I realize Filament is already very fast, but as an animator that is great news if true. Depending on complexity of the scene my current 4K animations rendered with an RTX 2060 take anywhere from 2 to 5 seconds per frame. According to AI, a 50series card could drop that time down to 1 second or less per frame. Thats a big deal when doing thousands of frames. I hope somone will test and respond. That would mean I can use 4.24 indefintely.
  • edited May 27
    where can I find the "simulation settings" utilities?
    Daz Software said:
    Daz 3D is pleased to announce Daz Studio 4.24 General Release!
    • Version: 4.24.0.4
    • Date: December 29, 2025
    Highlights:
    Known Issues:
    • Windows
      • NVIDIA Iray
        • 50 series GPUs require a newer version of the engine (2024.1) than is included in any Daz Studio 4.x build
          • Recent Iray/MDL SDKs provide support for 50 series GPUs, but are not compatible with the architecture of Daz Studio 4.x
        • Windows < 10 (e.g., 8.1., 8, 7, etc)
          • Drivers required for the version of the engine included in this version of the application may not be available
    • macOS
      • Sonoma (14), Sequoia (15), Tahoe (26)
        • Main Manu Bar resides within the Main Window, not the macOS system menu bar
      • Big Sur (11), Monterey (12), Ventura (13), Sonoma (14), Sequoia (15), Tahoe (26)
        • Styling issues on (horizontal) tabbars, (horizontal) tabs, buttons, frames
        • Interactive Lessons draw opaque over the UI, obstructing view of the UI
        • Color selection uses Qt (4) standard color picker, not the macOS native color picker
      • Installation via Install Manager is recommended
        • Installation via standalone application/plugin installers may require an addition to Gatekeeper's exceptions and approved application launch list (via the Command Line)
    Frequently Asked Questions:
    Public Beta Thread:
    • 4.24.0.4 (December 29, 2025)
      • 4.24.0.3 (April 28, 2025)
      • 4.23.1.47 (April 15, 2025)
      • 4.23.1.44 (March 31, 2025)
      • 4.23.1.40 (February 25, 2025)
      • 4.23.1.36 (February 14, 2025)
      • 4.23.1.27 (January 30, 2025)
      • 4.23.1.23 (January 23, 2025)
      • 4.23.1.20 (January 16, 2025)
      • 4.23.1.18 (January 13, 2025)
      • 4.23.1.8 (December 10, 2024)
    Previous General Releases:
    • 4.23.0.1 (October 7, 2024)
    • 4.22.0.19 (September 16, 2024)
      • 4.22.0.16 (February 27, 2024)
      • 4.22.0.15 (December 20, 2023)
      • 4.22.0.1 (November 1, 2023)
    • 4.21.0.5 (October 12, 2022)
    • 4.20.0.17 (April 29, 2022)
      • 4.20.0.2 (February 18, 2022)
    • 4.16.0.3 (November 22, 2021)
      • 4.15.0.30 (September 2, 2021)
      • 4.15.0.2 (January 7, 2021)
    • 4.14.0.10 (December 2, 2020)
      • 4.14.0.8 (November 10, 2020)
    • 4.12.1.118 (June 29, 2020)
      • 4.12.0.86 (September 24, 2019)
    • 4.11.0.383 (June 12, 2019)
    • 4.10.0.123 (December 8, 2017)
    What do you mean? It has it's own pane in Window - Panes (Tabs) -  Simulation Settings. The various settings for dForce enabled assets, e.g. clothing, are in the selected asset's Surface channel.
  • greywolfgreywolf Posts: 155
    wizzard2k2 said:
    I tend to use power pose a lot. Never really used it before 4.24, so I don't know if this feature was present before, but being able to go from hands to head is really nice. Why isn't there a shortcut from head to hands?
    This is another place where I feel the UI is somewhat mis-designed; if I select head (basic) from body, I would expect the selection on the right side to go in deeper to head (detailed), not back to body (which is what I'd expect to see on the left).
  • GeorgeNoXGeorgeNoX Posts: 0
    Unsure if this has been reported before, but the latest NVIDIA studio drivers (610.62) cause major viewport lag while using filament. With this update, NVIDIA retired the old control panel and in the app not all of the old optimization options are available which I assume is causing these issues. I can barelly move in viewport on this driver. Reverting to previous one clears these issues, but makes the Iray preview slightly slower but it's not a big issue. However in the future, if not fixed this will cause major problems. Might want to coordinate with NVIDIA to put ALL custom settings from the old control panel into the app
  • GeorgehazeGeorgehaze Posts: 200
    If this has already been brought up then feel free to disregard...
    As DS now has a version 6X, is this the last iteration for 4X?
    Most likely, yes. Nothing written in stone though.
  • jmucchiellojmucchiello Posts: 2,188
    Frankly, given the state of plugin updates, sunsetting DS4 should not be happening just yet.
    Makes sense. Still, I see the writing on the wall....
  • m.gunnm.gunn Posts: 4
    Keeping a copy of 4.24.0.4 purely for dse's and those poor PA's that can't update their dse's [R.I.P]
    They work in 4 but not, or most of them, in 6.
    I had an update to my Nvidia platform on my Windows 11 laptop this morning and I noticed a green dot on graphics. Looked at the tabe and under Program Setting a note for DAZStudio.exe - 'Program doesn't support optimization'. Is this in relation to DS4.24 or D|S in general that new Nvidia cards will not support or work efficiently in this program? I have DS 4.24 Beta, DS6.25.2026.14722 and DS 6.25.2026.19821 Beta installed.
    Any clarification would be appreciated.
    edited September 6
    It just means that NVIDIA does not have a preset list of automated graphics tweaks for DAZ Studio. You can ignore that.
    Just out of interest, are you using the Game Ready or Studio driver?
    edited September 6
    Studio, current drive at 616.56 released 26 Aug 2026
    Thanks @Doctorjellybean
  • MasterstrokeMasterstroke Posts: 2,505
    edited September 16
    I am going back to 4.23, because 4.24 fails to safe subsets at their exact position.
    Edit:
    my bad, took me 2 hours to find the glitch.
    Post edited by Masterstroke on
