Daz Studio 4.23[.0.x], General Release!
Daz SoftwareDaz Software Posts: 48
edited February 2025 in Daz Studio Discussion
Daz 3D is pleased to announce Daz Studio 4.23 General Release!
  • Version: 4.23.0.1
  • Date: October 7, 2024
Highlights:
Known Issues:
  • Windows
    • NVIDIA's 50 series graphics cards require a newer version of the NVIDIA Iray render engine (2024.1)
      • Due to minimum language version changes to recent Iray/MDL SDKs, 50 series graphics cards cannot be supported
    • Windows < 10 (e.g., 8.1., 8, 7, etc)
      • Drivers required for the version of the NVIDIA Iray render engine included in this version of the application may not be available
  • macOS
    • All Versions
      • Certain 3rd party plugins may crash
        • A prospective fix is currently available (4.23.0.2+) and undergoing verification via the Public Build release channel
    • Sonoma (14), Sequoia (15)
      • Main Manu Bar resides within the Main Window, not the macOS system menu bar
    • Big Sur (11), Montery (12), Ventura (13), Sonoma (14), Sequoia (15)
      • Styling issues on (horizontal) tabbars, (horizontal) tabs, buttons, frames
      • Interactive Lessons draw opaque over the UI, obstructing view of the UI
      • Color selection uses Qt (4) standard color picker, not the macOS native color picker
    • Installation via Install Manager is recommended
      • Installation via standalone application/plugin installers may require an addition to Gatekeeper's exceptions and approved application launch list (via the Command Line)
Frequently Asked Questions:
Public Beta Threads:
  • 4.23.0.4 (October 10, 2024)
    • 4.23.0.3 (October 9, 2024)
    • 4.23.0.1 (October 7, 2024)
    • 4.22.1.228 (October 4, 2024)
    • 4.22.1.224 (September 27, 2024)
    • 4.22.1.221 (September 23, 2024)
    • 4.22.1.202 (September 6, 2024)
    • 4.22.1.161 (June 26, 2024)
    • 4.22.1.154 (June 17, 2024)
    • 4.22.1.150 (June 4, 2024)
    • 4.22.1.136 (May 3, 2024)
    • 4.22.1.123 (April 12, 2024)
    • 4.22.1.110 (March 26, 2024)
    • 4.22.1.99 (March 6, 2024)
    • 4.22.1.88 (February 21, 2024)
    • 4.22.1.74 (February 2, 2024)
    • 4.22.1.58 (January 16, 2024)
    • 4.22.1.54 (January 10, 2024)
    • 4.22.1.41 (December 22, 2023)
Previous General Releases:
  • 4.22.0.19 (September 16, 2024)
    • 4.22.0.16 (February 27, 2024)
    • 4.22.0.15 (December 20, 2023)
    • 4.22.0.1 (November 1, 2023)
  • 4.21.0.5 (October 12, 2022)
  • 4.20.0.17 (April 29, 2022)
    • 4.20.0.2 (February 18, 2022)
  • 4.16.0.3 (November 22, 2021)
    • 4.15.0.30 (September 2, 2021)
    • 4.15.0.2 (January 7, 2021)
  • 4.14.0.10 (December 2, 2020)
    • 4.14.0.8 (November 10, 2020)
  • 4.12.1.118 (June 29, 2020)
    • 4.12.0.86 (September 24, 2019)
  • 4.11.0.383 (June 12, 2019)
  • 4.10.0.123 (December 8, 2017)
Post edited by rbtwhiz on
«134
  • BarubaryBarubary Posts: 1,233
    I do feel really stupid even having to ask this but...how do we even download the current release? I can only find the companion files (default ressources, scene builder etc.)  in my content library but no the installer itself? I don't use Install Manager so I am really wondering if I'm having some sort of brain fart...
    It should be available in your Product Library now.
  • ElorElor Posts: 4,285
    edited October 2024
    When I installed Daz Studio 4.23.0.1 manually, downloading the installer from my library on this website, at the end of the process, the installer will open two web pages and one is an 'Oops' one: https://www.daz3d.com/products/ds4_thankyou
    The pages are opened after I clicked on Finish:
    652 x 382 - 42K
    Post edited by Elor on
    I was working on a Windows computer.
    I'm not totaly sure it's related to Genesis 9 Base Anime Feminine or not (no crash happened when I tried to create the same morph using Genesis 9 Base, though), but each time I tried to export it with clothes to create a morph in Hexagon, Daz 4.23.0.1 crashed once everything was loaded in Hexagon, even when the figure and the clothes were the only items in the scene.
    Could you please provide a simple example with steps to replicate, so that I can try to reproduce the issue.
    Thank you.
    Here is what I did:
    Daz Studio 4.23.0.1 crashed each time once Hexagon finished loading the data Daz sent:
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\dzcore.dll" at 0033:00000000840048C0, DzFacetMesh::getNumTopologySets()
    (I saved one of the crash report)
    I also tested with other clothes (dForce CHB Pleated Pants Outfit for Genesis 9 and 8 Female) with the same outcome (Daz crashed) and yesterday, I used the Witch outfit with Genesis 9 and no crash happened.
    This morning, I used 'G9 Anime Base Feminine Dev Load' in place of 'Genesis 9 Base Anime Feminine' and no crash happened.
  • DoctorJellybeanDoctorJellybean Posts: 10,278
    edited October 2024
    Elor said:
    Here is what I did:
    Thank you.
    Confirmed. Just sending  Genesis 9 Base Anime Feminine/Masculine is enough.
    Please submit a bug report.
    Post edited by DoctorJellybean on
  • Richard HaseltineRichard Haseltine Posts: 112,183
    edited October 2024
    Moved some 4.23.0.1 posts over from: Daz Studio 4.22[.0.x] Pro, General Release!.
    My ticket is written, but I have a question before submitting it: the bug tracking system does not currently have Daz 4.23 as a possible application.
    Do I wait for an update of the bug tracker or do I submit my request now, with Daz 4.22 as the application and the correct application number in the next field ?
  • Just note in the text, and ideally in the topic/title, which version it was.
  • functionfunction Posts: 285
    edited October 2024
    Hello, I have a question, through the DIM, it seems like I had installed DAZ 4.23 at April, but when opened DAZ, it just shows 4.22, no where to see that I have the 4.23, and there is a yellow mark on the 4.23 in DIM, are these all right?
    2048 x 1088 - 444K
    Post edited by function on
  • While you are working online, as you are here (Ready To Download tab is not disabled) the label displayed will be the current one, the 1 item in Ready To Download is likely to be the new version itself.
    Actually that 1 item ready for download is GoZ, which shows as update. Let the main DAZ software Online is no use, still 4.22, have opened and closed DAZ many times, no difference.
    Should I uninstall that 'DAZ Studio 4.23 - 2024/4/5' in the DIM and reinstall it? But I'm afraid my Scripts and Favorites gone in the menu after uninstall, that will be a huge lost...
    2560 x 1355 - 530K
  • How are you launching DS? Are you sure it isn't pointing to an old installation of 4.22.x.x?
    I went directly to the DAZStudio.exe link as shown in the 1st picture, I only have this one version installed in my Win10 PC.
    The problem is, in the DIM - Ready to Download didn't show 4.23 so that I can not install it again. I remember that I have installed 4.22 earlier this year and never installed 4.23, but the DIM shows I had installed 4.23 so that it doesn't give me chance to download the 4.23 now.
  • frank0314frank0314 Posts: 15,120
    Uncheck your hidden files and see if it is there. You may have inadvertently hidden it.
    Unchecked, but same.
  • I needed to know if it is possible to have the My Daz libery and Daz3DIM files on an external hard drive. I have to free up space on my computer's hard drive because Daz product files take up a lot of disk space.
    You were answered in both of your previous therads, which have now been merged https://www.daz3d.com/forums/discussion/705246/daz-studio-and-daz-3dim-folders
  • uncle_0c7bfe3ccduncle_0c7bfe3ccd Posts: 3
    edited October 2024
    Is there a way for me to roll back to 4.22?
    On 4.22 I managed to rendered Image Series with 100 Images and more without any problems, in 4.23 it crashes after 10 to 20 frames or so. I tested this with various different scenes that made no problems before.
    Post edited by uncle_0c7bfe3ccd on
  • LeanaLeana Posts: 13,739
    If you don't have a backup copy of 4.22 install files, you can try contacting Daz support to see if they can provide you with one (there's no guarantee they will though).
    edited October 2024
    Thx, I will try. I was stupid to not create a backup.
    I became somewhat naive, because all earlier updates went without any problems for me.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,893
    my 4.23 is also giving me grief rendering animations
    it builds up VRAM as it goes and between 200 and 300 frames will max out my card so I have to break my image series down into 200 frame chunks
    edited October 2024
    this is ridiclous
    200-300 frames of animation is pathetic, most of mine 900-1800 at a time
    its starts off mid 6GB VRAM and hits over 11GB before stopping and then holds onto over 8GB doing nothing in bounding box view
    txt
    txt
    log.txt
    4M
    402 x 546 - 19K
    402 x 546 - 20K
  • If Iray fails it dos usually hold on to memory until the application restarts, so that part is not surprising given the preceeding events.
    edited October 2024
    it doesn't appear to be scene related either
    this was 3 furred housecats but it also did it with just a 3 walled room and a cat tree (midground scene) and also the outside background of a couple of trees, a billboard and a HDRi, both those scenes around 3GB initially
    the full scene with cats, human, setee even fits on the card and lasted 115 frames, I broke it down into 4 layers to try and save memory to no avail
    I am wondering if it's D|S or the newest Nvidia studio driver 565.90
    rolling back my driver is something I am considering as trying D|S 4.11 on a simpler scene did it too
    showing scene breakdown, deleted camera movement section components so cannot show the far background but you see it in the BG image for frame 300
    the man scene has an advanced iray matt cube for the setee with the man, the background is the first image
    1920 x 1080 - 2M
    1920 x 1080 - 166K
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
  • I can confirm, if you have the "an illegal memory access was encountered" error with Iray, revert back to the previous studio driver... the newest one, which funnily released right when I did the DAZ Update, was the culprit, not DAZ itself.
    yes it's the driver, rolled back to 561.09 and it all rendered in 2 hours and 45 minutes to completion 657 frames
  • karlkarl Posts: 72
    I wish Daz would either release a Linux version, or just make the code open source so others could do it. When I first used Daz I still used Windows as my main OS, but that changed three years ago. Now I only boot into Windows for Daz (everything else works in Linux), which means I hardly ever use it (and never buy anything from the store any more). If Daz code was released others would make it work on Linux for you!
    What about the closed-source modules - 3Delight, Iray, OptiTex, Decimator, and various plug-ins at least.
