Adding to Cart…
It looks like the file RSClothingConversionFunctions.dse is missing from the zip. I will need to make an update. If you have any of the other clothing converters, the file is in those zips. If not, PM me and I will give you a link to the file.
With very tight items, like some underwear and bodysuits, autofit does and has generally worked better. When we designed the CC, we had to choose between underwear fitting right and literally anything else fitting right, so we went with trying to make the process work best with the things that autofit is worst at.
When I try to convert “dForce Kimono Outfit for Genesis 8 Female(s)” to Genesis 9, DazStudio shuts down.
How can I do a successful conversion?
Ok, I just tried this for all the parts of the dForce Kimono in Daz Studio 4.23.0.1, and it worked for me without crashing. Which version of Daz Studio are you using? What is the log? (After the crash and BEFORE starting DS again, Go to "%USERPROFILE%\AppData\Roaming\Daz 3D\Studio4\log.txt" and only post the end of the log where you are trying to convert something)
Thank you very much.
Log file.
どうもありがとう. The only thing that stands out is that the output directory is strange: D:/KIMONO_DATA/Kimono/KO G8F Kimono.duf. The output directory should be "My Library" (not My Daz 3D Library) that includes Genesis 9/Clothing in the path. For example, this is my output directory: D:/Documents/DAZ 3D/Studio/My Library/People/Genesis 9/Clothing. It should be People/Genesis 9/Clothing added to the first directory listed in the Daz Studio Formats section of the Content Directory Manager (which is usually My Library)
The directory should exist too. After doing that, try selecting the KO G8F Kimono.duf again and clicking the "Force Convert Item(s)" button.
I tried it but it did not work.
Likewise, it does not convert and DazStudio shuts down.
I tried “dForce Kimono Outfit for Genesis 8 Female(s)” and it didn't work at all, but “Kawaii Kimono Outfit for Genesis 8 Female(s)” did convert, although it shut down.
I have DazStudio installed on my C drive.
And I have “My DAZ 3D Library” on the D drive.
I work on multiple computers.
I can be creating a scene on one PC while simultaneously working on rendering on another PC.
Therefore, I need to unify the DazStudio environment on multiple PCs.
I keep all the necessary materials for a scene in one folder, so that I can open that folder and work on the same scene on any PC.
Then, by synchronizing the folder with Cloud, the PCs are synchronized with each other.
Therefore, I tend to put newly converted materials in a project folder and sync it with other PCs rather than in “My DAZ 3D Library” or “My Library”.
I am struggling to figure out why it keeps crashing for you. What are the directories listed, and their exact order, in the Daz Studio Formats section of the Content Directory Manager?
C:\Users\%USERPROFILE%\Documents\DAZ 3D\Studio\My Library
D:\My DAZ 3D Library
I am trying these two, switching them up and down.
The C drive has no products installed.
Since the total volume of the product exceeds 3.5TB, it cannot be placed in the boot drive, and is installed in the D drive dedicated to My DAZ 3D Library.
Those should be fine (and that order, My Lib on top, is DEFINITELY what you want). Obvious questions: is Genesis 9 Essentials installed? Enough space on C drive? Any difference using the Genesis 9 Dev Load character vs Genesis 9?
It seems like the crash always happens AFTER the script returns from converting (or not) an item. If you try and convert 2 items (select two checked items and click force convert), does it go onto the second item and convert it before crashing? Or does it crash before getting to the second item?
Vo Yonina HD for Genesis 9
MB Anezka HD for Genesis 9 Feminine
RY Alison for Victoria 8
After uninstalling these three, DazStudio no longer crashes.
It seems that multiple corrective of the same name is being used, which may be affecting the crashes.
The “dForce Kimono for Genesis 8 Female(s)” (Kimono Base.duf) in the same product folder can be converted.
However, “dForce Kimono Outfit for Genesis 8 Female(s)” (KO G8F Kimono.duf) still cannot be converted.
I need a traditional G9 kimono that follows proper Japanese etiquette.
Therefore, I cannot use products with wide open collars, short lengths, excessively long sleeves, and sexy arrangements that open the front of the hem with dForce when walked on video.
I want a kimono for G9 that is close to the official design and dimensional proportions, and the kimono that seems closest at the moment is the “dForce Kimono Outfit for Genesis 8 Female(s)”, which I would like to convert, hoping that the dForce behavior in the video will work.
Awesome! I am so glad you figured it out.
I am definitely able to convert KO G8F Kimono.duf. However, I have to select it and use the "Force Convert Item(s)" button.
Is this thread still being monitored?
I have a situation where something broke where the product will not function at all. It starts, I can import files but not folders, and when I select convert or force convert, it runs through the list of files as if it is working and then ends up with 0 converts after x minutes. The log file just says "skipping." I have tried to uncheck all of the recommened check boxes but that didn't help. I then tried to uninstall and reinstall and still nothing. It seems to have a cache issue but I have no idea what that file(s) would be or where to find it/them if exists
It sounds like the metadata broke in your Daz Studio. Try selecting one of the checked items and clicking Force Convert. If that works, multi-select the items and try Force Convert
As I mentioned in my post, I already tried Force Convert. Please re-read.
Sorry about that. Ok, then I need the Daz log when the script is executing to see what is happening. Thanks.
hi, Riversoft...
i ran into an issue trying to convert some swimwear from G3F > G8F > G9. i selected the 'ignore previously converted files' option, added the files through the 'add files' dialog, and used 'force convert items'.
the G3F conversion worked just fine, but the G8F > G9 conversion bogged down. the script doesn't attempt to convert the items; it converts 0 items in 0 second, and returns the inexplicable error "Input filename does not have clothing in its path". this despite its path being: E:/oh3D/DAZ 3/Library 3/People/Genesis 8 Female/Clothing - Converted from G3F/School Sports Outfits Clothing/Clothing SSO Swimsuit B.duf. (you'll note that i've added "clothing" to the names of the files and their containing folder, on round two of my attempts to convert the items.)
i'm using the current stable release of studio 4.24.
any idea what's happening, or how to successfully force convert the files? help!
yt,
j
The script is looking for a folder name that is "Clothing", nothing else, not one that contains the word clothing.
thanks! that solved the problem.
yt,
j
You're welcome!
Hi Riversoft and all,
I hope it's okay to ask a question that might sound very dumb.
I want to convert a dress with long sleeves. When I tried, neither Daz nor this converter was able to assign them to the arm bones where they belong. The lower part of the sleeves were always assigned to the nearer Pelvis and Spine1 bone. So when I pose the arms of the character, the sleeves stretch from the arms to the Pelvis and it looks so ugly.
From the promo pics it seems to me like this converter should be able to change the bones of the cloth. Also Space Jingoroh asked about the Kimono which has long sleeves as well and since they stopped posting here, their problem seems to be solved, which makes me believe the bones of the sleeves can be changed from Pelvis and Spine1 to the arms and I'm simply making a mistake although I tried all the conformers aside from Heels.
If anyone knows how to assign long sleeves to the arm bones with this product, I'd greatly appreciate if you could tell me how. Please also tell me if it's impossible, so I can finally have peace of mind. ^^
The converter uses conformers that basically pull the dress and attach it to the nearest bones on the new rig. The different conformers pull different areas around the figure differently, but they cannot account for every clothing item. For things that hang too close to the body, as it sounds like with these long sleeves, the clothing item mesh is pulled to the wrong bones. I will ask Sickleyield to chime in but it sounds like you are not going to be able to convert this specific item.
From Sickleyield: There is no automated way to correctly rig long sleeves as far as I know. If anything looks otherwise in a promo, it is because the original mesh had the sleeve standing far away from the body for dForce purposes, or dForce was used to correct the rigging, or something like that
Ah, that's a bummer. This converter is usually pretty good, but I understand it has it's limits.
Anyway, I'm glad you took the time and effort to answer my question. Thank you very much.
You're welcome! Happy Holidays!
I have recently started to use this converter to convert some of my favourite G8 Male outfits to fit G9
As you can see from the below image of the High necked sweatshirt the cuffs partially cover the hands. The only way I can get round this problem is to hide the cuffs. Is there another solution that you know of?
What conformer did you pick for this item? Perhaps the loose body conformer will give better results.
Hi Thomas — just bought the full bundle. None of the scripts launch on DAZ Studio 6.25.2026.14722 (macOS).
Error:Script Error: ...RSSY Clothing Converter G8F to G9.dse line 15962
TypeError: Cannot call method 'connect' of undefined
Log warnings before the crash:WARNING: Use of Function::connect() can lead to object lifetime issues.
Use the Global::connect() function (recommended), or Function::scriptConnect(), instead.
(repeats many times, then crash)
Same crash on Clothing (G8F + G8M), Hair, and Character converters. G9 base is loaded and selected in scene. Files all present. Log attached if needed.
Looks like 6.25 removed
Function::connect()— scripts need recompiling withGlobal::connect().Post it and let me know when it's up.
