* Closed* RRRR Good Intentions / Mixed up Mythology Render Contest
Totte
Welcome to yet another round of RRRR. This time we're having a theme, and the theme is Good Intentions / Mixed up Mythology. This time we have two parallell themes, I just like to change things and the Mixed up Mythology was something thrown out in a chat by a fellow PA and friend and stuck like glue.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastards Standings
| Name | LBs |
luci45 |
1 |
acb |
2 |
| Totte | 2 |
aprilshowers2065 |
1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Monday April 21 - 2025, and will go on until Sunday June 22, 2025 at 23:59:59 local DAZ time. Yes, a long run, but I thought what is better to do in the holidays than render what you do not do in the holidays?
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
Luci45 is sponsoring with $25 in Daz GCs
Dartanbeck is sponsoring with items from his store
(Sponsored items does not include any Daz Originals, as it has never done)
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
RRRR "Weird Holiday Traditions"
https://www.daz3d.com/forums/discussion/706621/rrrr-weird-holiday-traditions-render-contest-closed/
Entries Thread: https://www.daz3d.com/forums/discussion/706616/rrrr-weird-holiday-traditions-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/719746/winners-rrrr-weird-holiday-traditions-render-contes
Well, this (new RRRR) made my day!
Pull #1:
4298 Savona Roma
3881 Pure Hair Fantasy
2006 Hanging Baskets
2273 iRadiance - HDRI Variety Pack One
2073 Hibiscus Garden
tag:luci45#1
It Never Hurts to Help*
"Its true that I am not from here, but these little gentlemen are and they have been here a very long time. They just needed a little encouragement to re-build their ancient ancestral community center. And...they generously installed a hoop because they know how the big folks love games."
World traveler Xlorea liked to help out when she could.
*It Never Hurts to Help -Eek! The Cat
Pull:
4298 Savona Roma
Also used
Kalea 7
Kimo 7
Various morphs
Ajax Hair
Heart Throb Hair for Genesis 3 Males
Gladiator skirt
Mec4D Genesis Beard
Hoop it Up
LM Lowpi Lowpoly Figure
Slacker shirt and Shoes
Beach Vibes shorts
Nice Luci! Forum notifications are not working for me (and probably a lot of others).
Yay, a new round - a RRRRR so to say
And a nice start! @luci45
Let's see what I get...
Pull #1
Pull #1
#4971 Morphing Cast Net (Rendo)
#4554 Assault Weapons_4 (Rendo)
#1375 Spaceship Corridor (#31677)
#220 From Cowardice to Heroism for Genesis 2 Female(s) (#21514)
LB1 #1062 Sophisticate Outfit for Genesis 3 Male(s) (#23713)
LB2 #2297 Wise Wizard Beard for Genesis 8 Male(s) (#52575)
What can you say? Random!
Thanks, Totte and acb. I see you both have really nice pulls.
My notifications aren't working either.
Pull#2:
1379 Elegant Fantasy Poses for Victoria 7
703 Carnival Picnic Tables
5786 Wasteground Vignette
4154 Ron'S Grungiest
4206 Rosemoor Manor II - Furniture
Also Used:
Markus Zombie for Genesis 3 Male + Luciano + Iconic Fedora
Mael for Genesis 8 Male + Wise Wizard
Lilith 6 HD Iray + Vault Rustler + Rockstar Hair
Dansel for Genesis 8 Males + Orelius Gladiator +
The knight's Castle
LowPi Crowd Generation Bundle
LowPoly Crowd Creator Expansion: Undead
LowPoly Crowd Creator Expansion: Winter Wonderland
Parkside Loading Bay (Pallet and Pallet Truck)
Light Battle Tank
Scripts, Shaders and Lights used:
RSSY 3Delight to Iray
UHT2 Ultra Saloon
Legacy Set Converter
Advanced Material Converter
C66 Toolbox Vol 2
LowPi Crowd Generator Plus Extension
LowPi PathTool Extension
Skies of Economy
The battle of Gradokhan Castle
In the big battle against the dark one, the bald wizard Mordakk von Friesburger used an untested spell to perform time teleportation to get future equipment and warriors to add resources to the battle. But as usual, field tests usually will not work as expected.
A pitiful bunch of warriors. Better luck next time, Mordakk (if there is a next time.) The skeletons seem happy with your new LowPi PathTool Extension product. LOL.
Thanks for your comment @luci45, and yes, I held the post until the release today ( I know, but it worked so well with that weird pull )... and speaking of a weird pull.. those lucky bastards weren't that lucky at all :P
Pull#2
#602 Chinatown (#22502)
#6080 Low Res Wild Dendrobium Orchid (#107345)
#106 SCI FI Beds (#21274)
#2939 dForce Doomed Dust (#65049)
LB1:#2446 Solaris Station 2 DS (#54891)
LB2:#1676 1stBastions Highland Lakeside Cabin and Dock (#37211)
2 props, 3 environments and a cloth set...
tag:luci45#2
Helping the Less Fortunate
Good Fairy Alieta tried to help her less-fortunate relatives, but the most of the lovely gifts she gave them ended up in the trash, including the gorgeous Rosemoor furniture collection, except for one chair which cousin Margo seemed to enjoy.
pull:
Also used
Fairy Wings for Giselle 6
Natural Fae Wings for Genesis 8
Gamebirds (Rendo)
Popcorn from Bar Interior 2018
Dandelion Hair
Aftermath Parched for Genesis 3 Female(s)
Rhys for Genesis 3 Male
LoREZ Pig 2 Piglet
Alieta Spryte Hair for Genesis 2 & Genesis 3 Female(s)
Asher Hair for Genesis 3 Male(s)
Moto Racer Outfit for Genesis 3 Male(s) Muscele Shirt
Slacker Outfit for Genesis 3 Male(s) Pants
Breena for Genesis 3 Female(s)
Dewdrop textures for Breena
Pull#3
5420 Tropical Plants - Edible Exotics
5207 The Pool House
4233 Ruby Hair for Genesis 3 Female(s)
1913 Gordon HD for Jonathan 8
3489 Ollie 8
Well, there have been easier pulls...
acb#1
Kevin's Tale
Also used:
At some point you may want to add this delightful story comic to the one pager thread.
https://www.daz3d.com/forums/discussion/725456/comic-one-pagers#latest
@Luci45 #2: Yes, hard to help those who dont apriciate to be helped, nice one
@acb: A very clever use of the pull and a great and fun story!
Tag: Totte#02
Also used:
LowPi Low Poly Figure Bundle
Diego 8 + Doomed for Genesis 8 Male(s) + Simply Standing Poses
Victorian Garden
Scripts, shaders and lights used:
3DL to Iray
Skies of Economy
LowPi Path Tool
Pollen season
Charlie Walker decided to surprise his best mate Ian for his birthay. He bought them tickets to go to China and see the landing of the Chinese space station Yǔzhòu Lóng (Space Dragon). The problem was, this was the peak of the pollen season, and Ian is very allergic, so he had to be kept in a pollen free encapsulated bed the whole time to survive.
Pull#3
#4518 G2M His Black Boots (Rendo)
#1006 Peasant Outfit for Genesis 3 Male(s) (#23585)
#1979 Sci-fi Police Outfit Textures (#47897)
#4147 X Fashion Club Harness Outfit Set 02 Bra and Harness for Genesis 8 and 8.1 Females (#87165)
LB1: #3182 Old Manor (#69547)
LB2: #1518 SS Marcoor Medbay DS (#33891)
And again the LBs comes like slap in the face!
Thanks, Totte.
acb#1: Sometimes the worst pulls make the best renders. Great job and really funny.
totte #2: Wow, three environments! Well, looks great and what a story! And LowPis on a path are back.
Thank you Totte, luci45 and FirstBastion
Pull#2
Thank you All!!!
Here's my pull:
2094 - Barkley HD for Genesis 3 Male
987 - Sunday Casuals: Cozies
488 - Genesis Head Morph Resource Kit 3
1209 - P3D Mia HD for Genesis 9
Welcome to the madness @Dartanbeck!
Pull #1
Hi guys. Here are my numbers. They are not the same as my table because I did not clean my list for items I have not installed, so I just went up to the nearest (up) usable item:
Timestamp: 2025-05-18 16:39:43 UTC
Welcome @Rafael!
Indeed (pull culling is OK), I do that when I have Poser and DS versions "still in some cases" in the list, or when you pull something that yout hough you had deleted, ike a Carrara or Bryce item.
Tag: aprilshowers2065#1
87 Flinks Spiderwebs
166 Valoria for Arabella 7
191 Cute Christmas Reindeer
251 Tourist Props
297 Solaris Corridor
Unappreciated
Valoria decided to be a good Samaritan and report what she thought was a long missed cleaning hazard. Too bad someone else didn't appreciate her good intentions.
luci45#1: Tradition meets modern, nice ;)
#2: Poor Alieta, her gifts aren't appreciated... :(
Totte#1: Hmm, might need to adjust the parameters on that spell next time...
#2: Yikes! The trouble with allergies...
acb#1: Well, at least there's a plus side! :)
@aprilshowers2065 #1: That's a monster with a lot own free will and you never know its intentions, to the right you see a spider! Great one!
Also Used:
IG Iray Lee 6 HD + Kung Fu Hair + Steampunk Working Class + Commoner Co-Star Lee Poses + Horse Stables broom)
Ragnar for Genesis 3 Male(s) + Bubba Hair + Barnabus props (staff)
Nenana HD for Genesis 8 Female(s) + SY dForce rags for Genesis 8 female(s)
Edie 8 HD + Sci-fi Police Outfit + Aeridian Future firearms
KOO Tyson + Gentleman Style Outfit +
ART Garbage
Oso VDB Magus Effects
Magical Potions and Bottles
Shattered
Sci-Fi patrol Bot
RSSY 3DL to Iray
Refracted Iray Glass
Platinum HDRI Pack 1
Alien Investigations
Multi billionaire and philanthropist Lotsa Pezos had captured an alien life boat while performing one of his trips to space. He decided to make his own scientific examination of his find, all in good faith. He did not anticipate that the alien's enemy's recon bot should arrive, and even less that the alien could use his powers to freeze dangerous objects in motion. To make it worse, bottles of strange liquids from the alien's ship shattered, but Lee the helper was quick to mop it up.
Then, old Edie, the security guard showed up, asking a lot of questions, specially about this strange fellow appearing out of nowhere, holding back the recon bot with his hand.
Pull #4
#3229 Lightning Bolts Vol. 1 (#70131)
#671 Nature - Forest Flowers 2 DS (#22681)
#3186 Volta Hair and Beard for Genesis 8 (#69599)
#196 Hard Target DS (#21501)
LB1: #843 Klaus Shapes for Genesis 2 Male(s) (#23108)
LB2: #2666 Blair Hair for Genesis 8 Male(s) and Female(s) (#58691)
Thanks, aprilshowers2065.
aprilshowers2065#1 Haha, great drama there! A bit more caution would have helped.
Totte#3 - An appropriately chaotic scene for that very messy pull. Great job. (LBs are so much fun.)
tag:luci45#3
The Auspicious Baby
Maureen Ploutz, a scholar of religious mythology and mythological religion, was thrilled to find an infant in a basket in their reed-filled swimming pool. "An auspicious event", she told husband Gordon (an aquatic botanist.) "We must adopt and raise him for surely he will be a great leader." Gordon was skeptical, but not wanting the odd-looking little fellow subjected to the traumas of state foster care, agreed to raise him as their own.
5207 The Pool House
3489 Ollie 8
Also used:
Dolb + Tobyn
Ninive
Morley Hair for G8M
Alphakini for G3F
