Star Trek Builders Unite 7: The Continuing Mission
12930323435101
  • fixmypcmikefixmypcmike Posts: 19,714
    edited September 2015
    Scavenger said:
    Scavenger said:
    Ikyoto said:
    I know I missed it- where is the "e" please? the more detail, the happier. anything I can pull into DAZ Studio 4.8+
    Enterprise 1701-E
    Good news ... Foundation3D seems to be working great atm so have verified and added some more links back onto the list :-)
    I know you can (with various degrees of difficulty) import most formats into DS, but pretty much the things labeled CR2 there are "native"?
    CR2 is an import format - handled by the DzPZ3Import plug-in, which handles all Poser formats (and OBJ, apparently).
    But like rigging would come over?
    Yes, as long as it's parametric (legacy) rigging, not P9+ weight-mapped.
    Post edited by fixmypcmike on
  • grinch2901grinch2901 Posts: 1,247
    TimG once did a fantastic render of Ptrope's awesom TOS bridge set up for Iray.  His was faithful to the original set.  I wanted to see how it would look with some surfaces changed to a more modern sensibility (stainless steel, painted metal, etc). I also changed some of the lighting.  With a few tweaks I think it looks pretty good even by todays standards.
    1188 x 950 - 700K
    Post edited by grinch2901 on
    Scavenger said:
    Scavenger said:
    Enterprise 1701-E
    Mattymanx rigged most of the .cr2 files in this section over at Foundation3D. Work in D/S3+. As with all files created before the latest editions of D/S, mat files may need to be updated so the program can read them.
    Maybe I missed something but I have yet to import a .cr2 file. I simply click on the icon and they load just fine in D/S. It is "export" to CREATE them.
    .cr2 files must be in the runtime > libraries > character > desired subfolder ... and are found in the "Content Library".
    I made a transporter this morning. Have no idea atm how I'm going to texture it.
    2000 x 2000 - 727K
  • IkyotoIkyoto Posts: 1,159
    Redfern said:
    SGreco was kind enough to send me a copy since Foundation has yet to create a page for the model.
    In these two renders we see both his new model and his earlier version. I tweaked the material settings to a personal preference, applying them to both.
    While SGreco's older model is quite the valiant effort, we can see how he made it even more screen accurate by applying the subtle curve to the casing in his current model. Franz Joseph could not determine this detail from the limited resource materials when he composed the famed "StarFleet Technical Manual". That (understandable) oversight as well as others resulted in years of less than screen accurate props. Thankfully, sites like "HeroComm" have revealed gobs of information many never knew. For instance, the main "housing" of the flip lid communicator prop was based upon a ubiquitous plastic pencil case readily available at the time. Wah Chang cut apart one of these cases, removing a fair amount of its length and a bit of its width, and used the reassembled "corners" as a template for the final housing shape. When I I saw a picture of the pencil case he used, I recognized it as something I used during the second grade! Why I never saw the resemblance, I'll never know.
    Anyway, if you're a TOS fan, I HIGHLY recommend this model!
    Sincerely,
    Bill
    Love the retro style
  • EveniosEvenios Posts: 119
    a lot of those links apparently no longer work..........
  • mdbruffymdbruffy Posts: 2,345
    You mean in the freebie list? Are you trying the right one?
    Try this one:
    http://www.daz3d.com/forums/discussion/58973/star-trek-builders-unite-7-cm-re-booted-link-list
  • ashe5k said:
    Well it's been a busy week but I haven't been building a whole lot, however I did do up a few more renders that were enough o assemble a few pages. This is from scene 9 in the first issue of the comic I'm working on. I'm pretty sure I really need to work on text sizing and word bubbles, but I figured I'd share what I've got and get some constructive criticism.
    The set up for this is that my Captain has been having nightmares of a past event that never actually happened to her. Q shows up and taunts her with it, threatening her with actually sending her back to this alternate past to change events. Arcelyn wants answers and after conferring with her crew opts to try for some answers using the holodeck.
    These look great, the only suggestion I would like to offer is on page three that you posted on the top panel the last word bubble change it to Beam weapon fore to aft hit. It would flow better and sounds more complete. Sorry if offering suggestions upsets you in advance, being Paul's proof reader for his books I tend to catch things like that.
    Absolutely won't get mad. This is my first attempt making a comic after having written fanfiction for years, so I'm open to any and all ideas. :)
    PDSmith said:
    Going to weigh in the pages that were just posted.
    I like where you are going with this, it's flowing well but Page 3 frame 1 needs work.  Not to sound like the 'Word Bubble Stickler' but your word bubbles should never cover your characters like that.  I can only suggest, is open this up to a second page, have her walk around the room looking on with disdain at sections of the room while talking to the computer and then have the explostions on the following page, as a shocker effect.  Remember you're not being charged for printing pages.
    -Paul
    Yeah I actually have dialogue I wrote that I cut down to fit even that. I realized while I was assembling it that it was crammed pack and trimmed here and there. Definitely going to have to render up a few more panels for this section of the comic. I like your idea of dropping that explosion on the next page as well. I'll have to give that a shot.
    I'm also going to shrink my text size and word bubbles a bit. Maybe make them more circular instead of oval. They're awfully crammed in there. I was thinking about going for a specifc set number of pages, but I think that might get tossed in favor of just telling the story I want and not go with a page count. I'm not going to end up printing this.
    Don't limit yourself to a set number of pages- That's the absolute worse thing you can do. because you end up cutting stuff out that you need and you end up with a collection of pages without a story. You're right. This won't be published. You take as many pages as you need to tell the story right- even if you have to break it down into 2 or more books. I had to do that. Nova Trek books 5,6 and 7 are all one story, but it was so big, I figured the best way for folks to handle it was to break it up.
    Starts with this one. If you want to take a glance, you'll see what I mean:
    http://mdbruffy.deviantart.com/art/NT5-A-Tale-of-Two-Captains-Part-1-365953763
    -Paul
    Post edited by mdbruffy on
  • PDSmithPDSmith Posts: 715
    One last note for all Graphic novels, comic stips or even a one shot image.
    ALWAYS and I mean ALWAYS use the same speech font size but for three execeptions.
    1) Distance shots  2)  Whispering  3)Emphasis (such as yelling or screaming)
    the same font style and size need to be consistant through the whole strip. I'm gonna plug a reletively cheap program, I use Comic Life 3. The demo has everything available, it's not cripple ware.  Try it, don't like it, dump it.
    To me, it's one of the simplest programs for balloons, it moves and restructures the text in the balloon so you don't have to worry about fitting. Also if you set the standard font size at the beginning, like in my case I use a font that came with it  Lint McCree Intl BB at Font size 8. Your whole process of balloons is a breeze!  And remember...
    -Tails point at mouths.
    -Balloons should flow from top left to bottom right, there shouldn't be any zig zagging up to the next balloon...one downward fluid flow of text balloon to the next.
    -Don't ever use use geek speek or foriegn/criptic languages unless you want to loose your audience.  ie.  AFAIK, TY, 'Kiirusta laps"** People don't like to look online or  down to see a translation for wording to continue reading a story or information.  Use <>  with a note in the bottom and be clear.
    So that about does my soap box, I hope it helps.
    ** "Hurry up child"  in Estonian   (The language I chose to use for Orion Trade in all my Graphic Novels.)
    Post edited by PDSmith on
    Checking out Comic Life 3 now. Looks awesome. Much easier than manually doing all this in Photoshop
  • Here are some stripes to use in Stitch Witch
    130 x 9 - 4K
    237 x 56 - 25K
    110 x 18 - 7K
    110 x 18 - 5K
  • mylochkamylochka Posts: 168
    And a few buttons..
    135 x 138 - 32K
    135 x 138 - 24K
    135 x 138 - 30K
    135 x 138 - 28K
    Post edited by mylochka on
  • ...And a little Vulcan trim.
    599 x 391 - 374K
    599 x 391 - 405K
    599 x 391 - 371K
  • TimG once did a fantastic render of Ptrope's awesom TOS bridge set up for Iray.  His was faithful to the original set.  I wanted to see how it would look with some surfaces changed to a more modern sensibility (stainless steel, painted metal, etc). I also changed some of the lighting.  With a few tweaks I think it looks pretty good even by todays standards.
    This looks gorgeous!
    Thank you for all the trim, M!
    Wow. Really love that look. Like that you threw in the TMP-VH bridge chairs as well. My favorite bridge chairs. :)
    Thank you :-)
  • DOWNLOAD HERE:  http://www.sharecg.com/v/82095/view/11/Poser/TOS-Utility-Jumpsuit-for-M4-Valiant
    Here is a TOS Utility Jumpsuit texture for M4 Valiant.
    I went with Valiant instead of the M4 bodysuit because Valiant has morphs that allow you to widen the sleeves and puff the tunic out over the beltline in a way that I thought looked good for this outfit.
    636 x 636 - 337K
    Thank you for this Mylochka, your work is outstanding!
  • Hope you get some good use out of it!
    Thank you. Link is posted. :-)
  • Thank You
  • Thanks very much, Mylochka.  :-)
  • Thanks, Mylochka! :)
  • TimbalesTimbales Posts: 2,439
    I have been in a creative rut lately when it comes to renders, so I've been trying to model things. I've created a version of one of the chairs from TNG. I based it off actual props auctioned from the series, though it's not a 100% match. I will share it with anyone who wants it. I have it as a Daz Studio file and save it as an .obj.
    The purple version is an IRAY example. The gray is a 3Delight example.
    png
    png
    378K
    464 x 600 - 378K
    464 x 600 - 372K
    464 x 600 - 284K
    464 x 600 - 276K
    jpg
    jpg
    36K
  • galattgalatt Posts: 229
    A question if I may;
    I'm trying to create a uniform texture based off the MFD so I can use it for V4 through V7 (when her version of it comes out).
    Is there an equvilant outfit that I can use for males?
    Thanks
    Thanks
    No not exactly.
    Genesis can be either gender though, and then from said creation there one can jump it over to G2, then from there to G3, I will say 'maybe'. Haven't actually done this myself but technically AFAIK it might work.
    Sure, chairs are always a welcome addition. :-)
