RRRR - Weird Holiday Traditions Render Contest *CLOSED*
Totte
Welcome to yet another round of RRRR. This time we're having a theme, and the theme is Weird Holiday Traditions. It can be weird fictiona traditions for an existing or a fully fictional holiday, Do you celebrate Serenity day by dressing as a space cowboy shouting gorram at all people you meet? Do you, as Jack in the entries only thread drink tea scented with fermented herring for Easter? You options are endless, just limited by your imagination and the gods of random.
RRRR stands for Random Runtime Roulette Renders, and it's a contest that has been running for over twelve years now, on and off. We invite anyone to enter, specially all those new users who have shown up the past years. This is not the usual make a very nice render contest but more like tell a really great story, often fun, with your render!
How does it work?
Make your pull of 4 items, and if your any Lucky Bastards, you pull one extra item per LB.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list and items that wil not work with the software you work with.
For example if you have items for Poser, Bryce or Carrara, and want to use DAZ Studio, remove those other items from your list. If you have loads of older figures, M3, M4, a ton of non Iray stuff and you only want to use Studio with Iray, remove all the junk from you list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store. Now build a scene with those 4 items plus any other items you want to add to make a fun scene. For newcomers I heartly recommend looking at the previous contests below to get ideas how you can do this.
Working randomizer:: https://www.random.org/integers
There are some situations where you allowed to redraw, these are:
- You pulled something that doesn’t work, broken thing, only works in a version / software not used etc etc, or you forgot to remove that item from you list even though you knew it wont work, or figure that out later.
- You pulled a software or add-on to a software or anything you should have filtered out from the list.
- You pulled only huge environment props and will not be able to render a scene without crashing.
- You pulled an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
I say this again: If you have Lucky Bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won. No lucky bastards are in play now, but will be for the next run.
| Player | Current LBs |
| Luci45 | 3 |
| acb | 3 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread (Don't miss that, entries without pulls and posts in this thread will be disqualified!!).
Then the entry should also be posted in the Entries only thread
Bundles
If you pull a bundle, use two or three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from Victoria 8 Pro Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for Genesis 8 Female, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Saturday October 19, 2024, and will go on until Sunday January 12, 2025 at 23:59:59 local DAZ time. Yes, a long run, but I thought what is better to do in the holidays than render what you do not do in the holidays?
This months sponsors so far:
Totte (Code 66) is sponsoring with two items from his store
Elliandra is sponsoring with two items from her store
3Diva is sponsoring with two items from thier store
(Sponsored items does not include any Daz Originals, as it has never done)
We want more sponsors!
Do you want to sponsor the RRRR?
Please chip in a gift card sponsorship, sponsors can play, they should play, they are even extra encouraged to play, as sponsors always plays for keeps.
Maximum number of entries?
For this round it will be a maximum of 12 entries per player.
So, good luck and start your render engines!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) https://www.daz3d.com/forums/discussion/29000/closed-rrrr-chain-render-contest/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1 ;
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread ;
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced ;
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest (February 20 -2017 to Sunday April 2 2017): https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
RRRR A long time ago or Far far away Contest (June 22 2017 to Sunday August 20 2017): https://www.daz3d.com/forums/discussion/178416/closed-rrrr-a-long-time-ago-or-far-far-away-contest ;
Entries: https://www.daz3d.com/forums/discussion/178406/rrrr-a-long-time-ago-or-far-far-away-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/197491/rrrr-a-long-time-ago-or-far-far-away-content-winners
RRRR They're ba..ack ( September 16 2017 to Sunday October 29 2017) https://www.daz3d.com/forums/discussion/198056/rrrr-the-re-ba-ack-render-contest
Entries: https://www.daz3d.com/forums/discussion/198051/rrrr-they-re-baa-ack-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/214026/rrrr-they-re-ba-ack-winners-announced
RRRR - What can go wrong? (Monday November 27 2017 to Sunday January 14 2018) https://www.daz3d.com/forums/discussion/214591/rrrr-what-can-go-wrong-render-contest
Entries: https://www.daz3d.com/forums/discussion/214586/rrrr-what-can-go-wrong-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/232941/rrrr-what-can-go-wrong-winners-announced
RRRR Judged by the cover ( Saturday February 17 2018 to Sunday April 1st 2018) https://www.daz3d.com/forums/discussion/233496/closed-rrrr-judged-by-the-cover-render-contest
Entries: https://www.daz3d.com/forums/discussion/233491/rrrr-judged-by-the-cover-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/249461/rrrr-judged-by-the-cover-winners
RRRR - Error 404 Not Found! (Sunday May 6 2018 to Sunday July 22 2018) https://www.daz3d.com/forums/discussion/251026/rrrr-error-404-not-found-render-contest
Entries: https://www.daz3d.com/forums/discussion/251021/rrrr-error-404-not-found-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/277091/rrrr-404-not-found-winners
RRRR RRRR Muddled Maxims ( Sunday September 16, 2018 to Sunday November 18 ) https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest/
Entries: https://www.daz3d.com/forums/discussion/278006/closed-rrrr-muddled-maxims-render-contest
Winners: https://www.daz3d.com/forums/discussion/302491/rrrr-muddled-maxims-winners-announced
RRRR Build it and they will come ( Sunday October 20 2019 to Sunday December 15 2019 ) https://www.daz3d.com/forums/discussion/360136/rrrr-built-it-and-they-will-come-render-contest/
Entries: Entries only thread
RRRR - But you promised entries thread (this one was the last and we never got enough votes, thats why no winners were selected) (Wednesday December 25 2019 to Sunday February 16 2020 ) https://www.daz3d.com/forums/discussion/374106/rrrr-but-you-promised-render-contest-closed
RRRRR - Coming Late Excuses (another one where we tried a new voting system, that worked, but then wanted a shitload of money to actually get the vote results (as it was past the 10 day free trial time) (May 3 2021 to Sunday June 13 2021 : https://www.daz3d.com/forums/discussion/497476/rrrrr-coming-late-excuses-voting-thread-closed
RRRR - Back From the dead: (Monday April 3 2023 to Sunday May 28 2023) https://www.daz3d.com/forums/discussion/627661/closed-rrrr-back-from-the-dead-render-contest
Entries thread: https://www.daz3d.com/forums/discussion/627656/rrrr-back-from-the-dead-entries-only-thread/
Winners: https://www.daz3d.com/forums/discussion/642826/winners-rrrr-back-from-the-dead-contest
RRRR "Behind the scenes": (WednesDay September 14 2023 to Sunday October 29 2023) https://www.daz3d.com/forums/discussion/650126/rrrr-behind-the-scenes-render-contest-closed
Entries thread: https://www.daz3d.com/forums/discussion/650121/rrrr-behind-the-scenes-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/660276/rrrr-behind-the-scenes-winners-announced#latest
RRRR "That went well" (Thursday November 23 2023, to Sunday January 28 2024 ) https://www.daz3d.com/forums/discussion/660851/closed-rrrr-that-went-well-render-contest/p1
Entries only: https://www.daz3d.com/forums/discussion/660846/rrrr-that-went-well-entries-only-thread
RRRR "As the story goes" (Saturday February 3, 2024, to Sunday March 31 2024 )
https://www.daz3d.com/forums/discussion/672471/rrrr-as-the-story-goes-render-contest-closed/
Entries thread:https://www.daz3d.com/forums/discussion/672466/rrrr-as-the-story-goes-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/683131/winners-announced-rrrr-as-the-story-goes-render-contest
RRRR "Picture or it didnt happen" (Friday April 19, 2024, to Sunday June 23, 2024)
https://www.daz3d.com/forums/discussion/683536/rrrr-picture-or-it-didn-t-happen-render-contest/
Entries thread: https://www.daz3d.com/forums/discussion/683531/rrrr-picture-or-it-didn-t-happen-entries-only-thread
Winners:https://www.daz3d.com/forums/discussion/695536/rrrr-picture-or-it-didn-t-happen-winners-announced
RRRR "Render Contest Summer 2024"
https://www.daz3d.com/forums/discussion/696321/closed-rrrr-render-contest-summer-2024/p
Entries thread: https://www.daz3d.com/forums/discussion/696316/rrrr-summer-2024-entries-only-thread
Winners: https://www.daz3d.com/forums/discussion/705816/rrrr-summer-contest-2024-winners-anncounced
Pull #1
#5056 FR-Simonee (Rendo)
#1492 AH_Vestibule Iray AddOn (#33451)
#4649 German E Boat (for Poser) (Render) (Hmm, will see if it loads)
#5160 LoREZ Rat 2 (#91291)
This was a weird pull!
Nice pull, Totte! Always fun to get an interior to slow a render down.
Pull #1:
4828 Screech owl
4785 Sci-fi Hanger A
5485 The Abandoned City
2740 Jetbike
2626 iRadiance Pro Series 16k HDRIs - Rain City Chicago (LB)
5998 Urban Sprawl 3 (LB)
6304 White King Poses for Gorilla for Genesis 8 Male (LB)
Two big environments Luci, hmm - I see King Kong here.....
And here they go again...
Pull#1:
70% clothes. I can work with that.
If you don't have your purchase in a database, can you use your Product Library? For instance, if you have 250 pages in your product library, and each page has 40 products listed, could you roll for 4 numbers between 1 and 250 to get 4 product pages, then roll a second time, this time between 1-40 to get the number of the product on each of the previous 4 pages chosen?
So my first roll was 176, 113, 103, 236.
My second roll was 12, 25, 9, 7.
So product one would be the 12th product listed on page 176. Product 2 would be the 25th product listed on page 113. And so on. Would that work?
Also, I'm a PA, so I don't think I will be allowed to play (at least not for prizes, but maybe just play for fun and not actually be eligible to win?).
*EDIT: If I'm allowed to play this is what I rolled:
Page 176, product 12: Throne Defender Armor https://www.daz3d.com/throne-defender-armor-for-genesis-8-female-s
Page 113, product 25: Edwardian Accessories https://www.daz3d.com/edwardian-accessories-for-genesis-2-females
Page 103, product 9: Alawa 8 https://www.daz3d.com/alawa-8
Page 236, product 7: Faery Wings Deluxe https://www.daz3d.com/faery-wings-deluxe
I just plan on playing for fun, not to win anything but if I'm not allowed please let me know. I won't be offended or anything if I'm not allowed, I'd be happy to just sit back and watch the fun renders coming through. :)
*Edit 2: Oh I just realized I could sponsor! I sponsor two non-Daz original products from my library (not allowed to give any of the Daz Orignals away since Daz owns them).
Hi 3Diva and welcome!
Anyone is allowed to play! We had FirstBastion here the round before last, and many others over the years. It's a great way to get your creative juices flowing.
Yes, you got a good solution to the random issue, another is to export your catalogue from DIN by rightclick and select export as .csv. (Rendo now have export as .csv as well after Amaranth (I think) wanted to to plat RRRR and told them to add that feature).
And thanks for sponsoring! I'll add you and your store link.
And once again - welcome to the madness and fun of RRRR!
Tag: Totte #01
Also Used:
Fletcher Class Destroyer (glass box)
ECLO PT Boat
Victoria 4 + Val AngieLee + Yolande Hair
Dinner at the Orient Express (tables)
AH_Vestibule
Monty for Genesis 8 Males + Naval Officer Outfit + Mr Banks Hair
Nautical Whimsey Vol 1
Script, Lights and Shaders used:
Legacy Set Converter
Advanced Material Converter
JM Human Shaders
3DL To Iray
UHT2 Ultra Saloon
Invisi Lights
iRadianceLightProbes
The Navy Day Rat Fight
Every morning on the annual Navy Day, the retired fleet commander Sir Monty Winterbottom III and his stepdaughter Angie Winterbottom has a traditional rat fight. A rat fight much like the sailors did during the age of pirates, but today, they are using fake movie prop rats.
Pull #2
#13 Voodoo Queen Outfit for Genesis 2 Female(s) (#21036)
#5145 Long Hair and Bangs for Genesis 9 (#91395)
#1376 Eternal Desert Warrior Outfit for Genesis 3 Male(s) (#31681)
#409 An Abandoned Mine (#22046)
HAHA This is very funny! I was worried for the rats -so glad they use movie prop fake rats! :D
Thank you for the tips! I'll try to remember the export thing for the future. :) And thank you for adding me to the sponsor list. I look forward to seeing everyone's creations!
Thanks @3Diva
It was a rainy weekend... lol...
Tag: Totte#02
Also Used:
Skies Of Economy
Edgar for Genesis 3 Males + Kieron Hair + Whiskers + Shortblades + Modern Weapons
Tamara for Genesis 2 Female
Victoria 9 HD + 1930s Party Frock And Hat (no hat)
KOO Nils + Adventure Style Outfit + Old George Hair + Diana And Jones (whip)
Everyday Drinks
Pest Control (sausage)
Background picture of Stekenjokk (my own)
Shaders, Lights and Scripts Used:
JM Human Shader
Geometry Sculptor
Indy Midsummer Morning
At Midsummer at an abandoned mine in Pajala, north of the arctic circle in Sweden, a group of Indiana Jones fans reenact scenes from the movies while drinking the famous drink Pajala Sunrise*, as the sun never sets in Pajala in the summer.
*Pajala Sunrise: A glass of moonshine with a thick slice of sausage on the glass edge.
tag:luci45#1
Happy Founders Day
Multi-Trillionaire Elron Sputz bought Chicago in order get rid of crime and make its citizens happy, as well as to have a nice lab and resources for his cyborg experiments. Every year he and his citizens joyously celebrate Founders Day. Because they always try to kill him at the end of his speech, Elron comes and leaves quickly on his classic turbo motorbike.
Pull#1
4828 Screech owl
2740 Jetbike
Also Used
LowPoly Crowd Creator Expansion: Undead
Crowd Generation For LM Lowpi Lowpoly Figure
VDB Steam and Smoke Mega Pack
H&C Weekend Casual Suit for Genesis 8 Male
Dominator Robot
Demonstration Poses and Props
@luci45: #1 : That's a wonderful render and story, Elron Sputz seems to be a both loved and hated person.
Thanks, Totte. (The skeletons are bored and the zombies hungry, so not much love or hate but he gets their attention.)
Totte #1 - Great use of a really awful pull. LOL.
Totte #2 -Sausage w/moonshine? Sounds good! Especially with the sun never setting. Do you ever sleep in the summer?
Pull #2:
3587 Movie Sets, City Block Eight
1800 Fg Luxury Passenger Train
3373 MHE: Vegetables
5217 Step Van Extension
3823 Old Joey Hair for Genesis 9
4333 Ranch Environment Prop Set
3297 Medieval Kitchenware
Thanks @Luci45
Up north to sleep you need really dark curtains, like blackout ones.
An interesting pull indeed !
tag:luci45#2
International Vegetable Day
Wally and Becky Masterson always celebrated International Vegetable Day with nothing but fresh raw vegetables and Celery/Carrot nectar. When the holiday coincided with a lovely train trip with their niece and nephew, the children were unhappy with the menu - Georgie wailed about the importance of the food groups, while Livia announced that some people were eating tacos and chili, which also contained vegetables.
pull:
Also Used
Subsurface Workshop - SSS Shaders for Iray
Dirty Dishes 2
Missy Dress
Lucinda Hair
Daytime Noir Dress
Teen Ryan G3M
Slacker Shirt
Adam Hair
Growing Up G3M and G3F
Presidential Shirt
Alexandra 8 and Mabel 8
Walter And Gilbert G9
Heath Hair
LoRez Police
@Luci45: That was a great usage of that pull, and a very good story and render!
Using 3Diva's method, I got the following rascals:
https://www.daz3d.com/praetorian-autoturret
https://www.daz3d.com/fwsa-tamara-for-monique-6
https://www.daz3d.com/toon-generations-4-hair-for-genesis-8-males
https://www.daz3d.com/dforce-dorothy-outfit-for-genesis-8-females
I guess Tamara will be celebrating Lazer Hair Styling Day.
Welcome, WinterMoon and 3Diva! And thanks for being a sponsor, 3Diva.
Thank you, Totte. Seven items makes the holiday pretty strange.
Pull #3:
3800 Odin Hair & Beard for Genesis 8 Male(s)
5140 Spring Canyon Texture For Winter Canyon
160 Aircraft Colo
1077 Colors For Pony Knots
3852 Ollie 8 HD Add-On
1482 East Park (wasn't in my product library list, nor was West Park, but were in Install Manager. Strange.)
442 B25 Steam Punk Aviator V4
Welcome to the madness of fun @WinterMoon!
That's another mouthful @Luci45.
Pull #3
#5179 Drusilla Weapons Collection (#90737)
#2147 Sci-Fi Gun and Poses for Genesis 3 and 8 (#50309)
#1635 Green Hills Skydome and HDRI DS (#36153)
#1883 RW Wooden Boxes and Palettes (#45945)
Another weird pull
Tag:acb#01
Halloween
Zombie Bert had been wondering for a few years why the humans always dressed like normal people at the end of October and went from house to house. And in return they were given something to eat at every door they rang.
He wanted that too!
This year Bert got his friends together to also go from house to house in normal clothes (apparently everyone has a different idea of what normal clothes are).
And the whole thing was a great success. But the best part was at the Fletchers. There they got 80s tech instead of food.
Bert and his friends do this every year from now on.
@acb: Perfect timing with that one ;-) Nice work!
Thank you @Totte
But I was apparently in such a hurry to get the timing right that I uploaded the wrong version.
I swapped it.
Pull#2
Tag:Totte#03
Also used:
Eva 7 + Private May
IST Aegenwulf for G9 + Combat Ready Uniform + Monster Hunting Poses
Jinx Jones 8.1 + Tactical Assault + Atlas Berett
Chablis for Genesis + War Dog for Genesis
KOO Alphonso + Combat Uniform +
Script, shaders and tools used:
Iray Converter for Genesis
3Delight to Iray
Flat Earth Day
On flat earth day, April 22nd, members of the 11th flat earth rangers battalion have a competition, much like king of the hill. They build a tower from pallets and crates and tries to be the one who can see the edge of the world. As soon as you have placed your item on top, someone will try to toss you down. Try to take out the other team on the way down, as the last team standing on the top, wins.
Pull#4
#4035 Mael for Genesis 8.1 Male (#85851)
#1480 Stairs and the Rocks DS (#33323)
#3123 dForce MoonAge Outfit for Genesis 8 Male(s) (#68375)
#5873 Textures for Aether Outfit (#20989)
Tag:Totte#04
Also used:
Beradius Hair
IG Iray Stephanie 6 + Aether Outfit + Nikki hair
Julius Elder HD + Calvin Candle Outfit + M3D Facial Hair
Grandmother HD for Edie 8 + Chiffon Crop Dress + Volta dForce Hair
Freshwater Game Fish
Lights, tools, scripts and shaders used:
3Delight to Iray
UHT2 Ultra Salon
Revolution
Skies of Economy
Fishing Day
August 31 marks fishing day in the Irish calendar. All families dress up in their finest clothes and then bring a fish, preferable self caught, and meet for the fish slapping festival. Old Ian's mate Jimmy forgot to let his salmon defrost properly before he used it.
acb#01 Very cool. I love the characters. It's nice to be appreciated once a year.
totte#3 LOL, one of my favorites ever! Great idea and render. I love the face in the front.
totte#4 Oh, so silly! Ouch. (but not as smelly.)
