Star Trek Builders Unite 7: The Continuing Mission
12728303233101
  • mylochkamylochka Posts: 168
    edited August 2015
    If someone's looking for a project, I'd like something like the terrium-like things in these Matt Jefferies drawings -- particularly the tall one.  No plants necessary.  I may want to put something else in them at another time.
    360 x 446 - 32K
    346 x 428 - 20K
    360 x 446 - 32K
    Post edited by mylochka on
  • mdbruffy said:
    You're welcome. Hope the textures work for everyone.I'm not used to doing a set of clothing textures this detailed. Change a basic color or add an item or two, but I think the Chancellor's Outfit was the last time I had to go to this extreme for an outfit. You Daz Studio users let me know if they work, ok?
    Thanks for the uniforms
    Well they work, but I think the transparancey might need a little tweaking as I'm seeing some artifacts on the render around the bottom of the jacket, and I need to toy with the bump maps a bit, but other than that this is pretty much a straight render of the V4 and M4 outfits using iray. They look great.
    2116 x 2116 - 242K
    If I wasn't in the middle of assembling the shuttlebay for the galaxy class and planning out a briefing room for the Connie refit I would totally work on these.
  • mdbruffymdbruffy Posts: 2,345
    edited August 2015
    Well, they look great. In Poser 9, I had the transparency set to 2.0 and both edge and falloff set to 0.0. see if that helps.
    Post edited by mdbruffy on
    I can wait. Got a ton of other projects going myself.  Take your time!
  • blutobluto Posts: 913
    mylochka , i might have some time to dedicate to this . i like the idea not only for botanicals but also for small lifeform habatats.
    edited August 2015
    Tam comes across this in her time- travels. Couldn't find one, so I made this one. But I have 2 things I need a second set of eyes for.
    1. Are the globs too big?
    2. Right now there's only one spotlight positioned in the base. Does it need more than that?
    632 x 787 - 49K
    The ones I've seen in the shops over the years vary a lot; sometimes lots of little blobs, sometimes big ones. Usually (I think) the only light is in the base. That looks OK, I'd say.
  • Robert FreiseRobert Freise Posts: 4,606
    Looks OK my mom had one and the at first it had several large blobs then it went to a bunch of little blobs and then it became one big blob
    the only light it had was in the bottom shining up through the green liquid it had
    Robert, Spotted Kitty, thanks. I'll go with it like it is then.
    edited August 2015
    Yeah, I was thinking it would be good for that sort of thing too.  I'm trying to equip a Star Fleet research lab for some illustrations.
    Anyone know where I can find a folded flag? A properly folded flag. Textures don't matter, I'll make my own.
    Haven't been able to find one not even at TurboSquid
    edited August 2015
    I checked all the sites I usually deal with and  couldn't find any folded ones.
    I have the makings of one in a display case, but I need one outside the case- to be presented.
  • shadowhawk1shadowhawk1 Posts: 2,206
    It might be easier to go with a triangle prop or flatten a pyramid and texture one that way if it is going to be in a display box. I have wanted to do several images with a folded flag and I gave up because I couldn't find one.
  • jaguarry3jaguarry3 Posts: 230
    edited August 2015
     Assuming you would,t need it for a close up you can have this one. It is a .obj file I made  which you should be able to import
    jpg
    jpg
    136K
    1483 x 942 - 136K
    Post edited by jaguarry3 on
     Assuming you would,t need it for a close up you can have this one. It is a .obj file I made  which you should be able to import   This new forums a  fight PIA to  use.
    Jaguarry3, that would work. I'll PM you with my e-mail.
    THere are no models of a folded flag on the internet. I have a model for one in a case, but I need one without a case.
    edited August 2015
    This was originally created for Nova Trek Book 8: Special Report. But I had to resurrect the jacket for this last story, You'll need M3 and M3's tunic to use these. There are only the jacket textures in this zip.
    http://mdbruffy.deviantart.com/art/Textures-for-the-Presidential-Jacket-557210411
    517 x 821 - 57K
    No Problem  sent this morning  Hope its useful
    Got it and I'm working with right now. Thanks!
    Link posted. Thank you.
    M3's tunic is a PC item if anybody is interested.
    You're welcome.
  • TimbalesTimbales Posts: 2,423
    Heads up for my fellow fans, Netflix will has switched over their TNG to HD remasters: http://www.darkhorizons.com/news/38639/netflix-adds-star-trek-tng-remasters
    1392 x 1840 - 308K
  • Thank You
    You're welcome.
    Thank You
  • mdbruffy said:
    That's a neat design. Thanks for sharing!
    edited September 2015
    You're welcome. It's inspired by an early Next Gen episode.
    ashe5k said:
    659 x 690 - 363K
