Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)
1…4546485051…54
  • StezzaStezza Posts: 9,289
    edited September 2024
    .. yes
    800 x 600 - 300K
    Post edited by Stezza on
  • therixxtherixx Posts: 264
    Stezza said:
    looks good... looking at the fur on the image you may need to untick wrapUV apply the smoothing and maybe apply the fur transmap manually yes
    Thank you @Stezza. Yes, you are right. I noticed the fur issue, but the model was working so, after wondering about this, I was very happy and wanted to confirm it. Your tips will be really valuable when I try to fix it, thank you again.
    You know, I must say that I quite like it like this as well. A friend of mine, who is an artist (painter) also said that's very cool. Maybe the not transparent fur reminds us of some frazettish illustration... :-)
    Anyway, I'll surely try to fix it following your tips!
    Barnabus from Predatron loaded in Carrara fine after weight transfers were done however the hair seems to be a problem loading up .. maybe just a bit too dense to use though I also have trouble with the eyebrows ect... so I used a substitute hair from Gosha ( a Poser figure ).
    anyways I got him into some Mr Bobble stuff easy enough in Carrara wink
    800 x 600 - 755K
  • Bunyip02Bunyip02 Posts: 9,345
    Cool, was thinking about buying him, bought Mr Bobble and some landcapes instead.
    Void Prime: Dakari - https://www.daz3d.com/void-prime-dakari
    Is missing base textures for both the skin and some clothing items, lodged a get it fixed with the help desk.
    Also the open mouth morph is not working. Opened the figure in DAZ Studio, opened the mouth and saved as an obj then imported that into Carrara.
    Added shaders to the skin and bodysuit in Carrara
    1600 x 1200 - 1M
    Post edited by Bunyip02 on
    Sledge - https://www.daz3d.com/sledge
    Mouth morph worked on this one !
    Added shaders to the skin and armour in Carrara
    1600 x 1200 - 2M
    Hunter-Fiend - https://www.daz3d.com/hunter-fiend
    Is missing base textures for both the skin and clothing items, lodged a get it fixed with the help desk.
    Also the abdomen morphs for the belly flaps and small arms are not working. Edit - In DAZ Studio 4.22 the poses work showing the belly flaps open, will be able to do an obj export.
    Added shaders to the skin and clothing in Carrara
    1600 x 1200 - 2M
    1913 x 1036 - 358K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,797
    good luck with that Bunyip02, I am still waiting for missing textures from a V4 set I bought
    I hope they can update the sets. I bought 15 Sixus1M items, so far everyone I have opened has been missing the base/skin textures .....
    EDIT - Yay - one that worked !!!
    Arrrggghhh - another one .....
    S1M: Reptilez - https://www.daz3d.com/s1m-reptilez
    Is missing base textures for the skin except for the eyes, lodged a get it fixed with the help desk.
    Also extreme poses are causing distortion in the limbs, poser rigging.
    Added shaders to the skin in Carrara
    1600 x 1200 - 3M
    And another one ....
    S1M Mythos: Gug - https://www.daz3d.com/s1m-mythos-gug
    Is missing base textures for the skin and hair, lodged a get it fixed with the help desk.
    Morphs for the mouth and tongue don't work in Carrara.
    1600 x 1200 - 2M
    And this one tops the cake .....
    Nosferocious - https://www.daz3d.com/nosferocious
    Is missing the original figure with only the clothing items included in the obj/cr2 files.
    1737 x 1034 - 236K
  • We will report these.
    Thanks Richard !
    I have asked for them to be updated via the Help Center.
    Thanks Richard !
    can you add https://www.daz3d.com/wildwood too which is missing it's textures and I reported to the help desk a couple months ago? cheeky
    I paid little enough and it was in a mixed order with things triggering other things so did not bother bugging the PA about it though considered it
    Thanks Richard !
    Please check for updates now, they have been reuploaded.
    Thanks Richard !
    Thanks again Richard !
    Only two in the list, and they are both working now, trust that the others will get fixed as well !
    798 x 1015 - 117K
    2708 x 1038 - 647K
    Thanks Richard !
    Hope they get Wildwood fixed too Wendy !
    I had the Nele
    https://www.daz3d.com/nele
    download broken.
    In a couple of tickets I asked to fix it, and in the end they managed to do it (I do not know how long it took because I did not get a warning when they did it). So, keep the faith, @Wendy ;-)
    Post edited by therixx on
  • Sorry, I hadn't noticed the previous reports - I think I read them as renders. I will add them in now, but it will probably be enxt week now before they are fixed.
  • We beleive all of these have now been corrected.
    Thanks once more Richard. Downloaded and working well !!!
    2654 x 1038 - 519K
    2672 x 1036 - 681K
    That leaves one to go, reported over a month ago.
    A7D/E Corsair II (for Poser) - https://www.daz3d.com/a7d-e-corsair-ii-for-poser
    When the files were downloaded they were for the A62M Seishin-Kaze ....
    798 x 1009 - 151K
    Thanks, not sure if that was reported or not so I have sent it in as new.
    Thanks Richard !
    EDIT - Just checked my DIM and it was waiting to be downloaded. Checked it after downloading and it's the right aircraft this time !!!
  • YES!!!
    ThankYou Richard Haseltine
    will try and get a Carrara render done later today yes
    775 x 963 - 105K
    WendyLuvsCatz said:
    YES!!!
    smileyyes
  • Glad they are working, and sorry it took a while to get them flagged up.
    bit late but a short video, I accidently hid the skirt leaves
    is Autofitted to Stephanie 5 curvy, yes pokethrough too blush
