Hex Gallery
1303133353638
  • NovaNova Posts: 348
    edited August 2024
    Current project_ 008-00_ Rooms_ 002-00_ Room 00_ 000-00
    Own models
    I'm currently building furniture, I still have to make the door smaller.
    Twinmotion 2023.2.3
    Modeler: Hexagon
    No AI & no PS
    2216 x 900 - 643K
    3200 x 1300 - 567K
    1391 x 909 - 130K
    2500 x 1080 - 449K
    1468 x 982 - 118K
    1391 x 960 - 154K
    1871 x 1035 - 221K
    2500 x 1200 - 433K
    Post edited by Nova on
    edited August 2024
    Walled landing pond, once with and once without AI
    _
    1500 x 563 - 746K
    1500 x 563 - 718K
  • TugpsxTugpsx Posts: 882
    Very impressive work.Thanks for sharing.
  • Roman_K2Roman_K2 Posts: 1,276
    I'm not clear as to what the A.I. is bringing to the picture? A touch up of the small lily pads, an adjustment to some reflections?
    edited August 2024
    Even if they are only minimal improvements, you can now overlap both and edit them with PS.
    I myself only like to use AI to make people look more realistic.
    654 x 811 - 86K
    Thank you, I keep hoping that Hexagon will be developed further.
    edited August 2024
    Once again, had some time to work on the VR gallery. Pictures and objects are still being placed. An outdoor area is planned for later. There is still a lot to do and the time flies by.
    Own models
    3200 x 1300 - 783K
    3200 x 1300 - 825K
    3200 x 1300 - 745K
    1278 x 868 - 104K
    1509 x 960 - 127K
    edited August 2024
    We are currently in the process of expanding the moon base.
    However, there are still some discrepancies at the moment.
    1559 x 871 - 164K
    edited September 2024
    Concept Entwurf_ Gebäude 033-02 / 360° VR
    2000 x 1125 - 1M
    4x Tanks
    1920 x 1080 - 297K
    edited October 2024
    New flower pots for the home
    Hexagon 2.5.2.137 (32-bit) Public Build +BETA+
    1920 x 1080 - 2M
    1920 x 1080 - 4M
    1920 x 1080 - 4M
    1731 x 1004 - 229K
    Very nice design and render. Thanks for sharing.
    edited October 2024
    Thanks Tugpsx
    ________________________________________________________________________________________ Please help
    Mirroring is an important tool, but unfortunately it doesn't work.
    Reflections are displayed in black. Texturing not possible! We cannot texture the mirrored models
    A name change was unsuccessful.... Anyone have a solution?
    1200 x 612 - 76K
    1531 x 845 - 130K
  • Nova said:
    Thanks Tugpsx
    Did you try flipping normals on the mirrord pieces?
    edited October 2024
    Hi Richard, I have tried the normals in hexagon, either I am doing something wrong, but it does not lead to success
    You can reproduce the problem yourself by opening the mirrored object (.obj) from Hexagon in Blender, see for yourself.
    With the older Hexagon version you had to rename the mirroring, then the problem was solved, with the current beta this is no longer possible.
    See last picture, here was mirrored, after renaming everything is fine. (Old Hexagon version)
    Hexagon after Blender_ Control= Mirrored object is dark, texturing not possible
    1006 x 770 - 96K
    1324 x 597 - 94K
    1233 x 821 - 50K
    1008 x 656 - 64K
    edited October 2024
    Richard Haseltine said:
    Nova said:
    Thanks Tugpsx
    Yes it's the normal ones that get completely mixed up, someone on another forum discovered it after I provided him with the obj file. It took 3 steps in Blender to fix this problem. It is a software bug. The mirroring in Hexagon is therefore unusable for me.
    INFO_ https://www.3d-board.de/thread/38823-suche-leute-die-mit-hexagon-arbeiten-vortgeschritten/
    _____ Addendum_ Someone in another forum has found a 1 click solution in Blender to resten the normals.
    edited October 2024
    Architektur_ Öffentlich_ 005-00_ Museum 004-00_ JPG 000-00
    Test_ Muster
    The model is checked for errors and extensions are considered.
    INFO_  https://www.bruder-aural.com/07_-architektur_-oeffentlich_-005-00_-museum-004-00_-000-00.html
    edited October 2024
    000-00_ 020-00_ Präsentationsfläche_ 016-00_ 000-00
    INFO_ https://www.bruder-aural.com/08_-000-00_-020-00_-praesentationsflaeche_-016-00_-000-00.html
    000-00_ 020-00_ Präsentationsfläche_ 016-00_ 000-00_ JPG 000-00_ CS5 000-00 1500x.jpg
    1500 x 844 - 968K
    1191 x 680 - 155K
    edited October 2024
    Lounge & Bar
    _
    edited November 2024
    Building with Hexagon
    Tank / Update 2.0 (Tanks in the hanger for a general overhaul)
    Small job for someone, but mistakes were found and so some things need to be fixed.
    The next project is to build a drone based on this model. ( Rendering Twinmotion )
    1627 x 864 - 215K
    1900 x 704 - 966K
    1280 x 720 - 507K
    1280 x 720 - 402K
    1280 x 720 - 273K
    1280 x 720 - 450K
    1280 x 720 - 449K
    1280 x 720 - 282K
    1920 x 1080 - 710K
    Drone construction part 1
    One element of the base is finished, now the inner workings including the shock absorber and the pressure stamp are still missing.
    1898 x 875 - 150K
    Drone construction part 2
    1897 x 1014 - 252K
    1214 x 835 - 111K
    1221 x 799 - 62K
    Wow, the concept art and execution is very helpful. You have created very nice models with Hexagon and helping to keep it alive.
    edited December 2024
    Thanks Tugpsx, I do a lot of promotion for Hexagon, it's a great software for beginners and also advanced and an alternative to Blender.
    When I look at some tutorials from Blender, I would say that you work faster with Hexagon if you know it well.
    1547 x 802 - 204K
    1401 x 784 - 234K
    1297 x 566 - 141K
    1200 x 960 - 873K
    1800 x 675 - 912K
    1000 x 800 - 725K
    edited March 2025
    Moderner Chemietank für die Quantenschmiede.
    Modern chemical tank for the quantum forge.
    _ ca. 80  % fertig.
    1885 x 868 - 157K
    1850 x 870 - 163K
    1898 x 880 - 201K
    1901 x 991 - 309K
    1920 x 1080 - 96K
    1920 x 1080 - 176K
    2500 x 1300 - 121K
    1920 x 1080 - 154K
    edited March 2025
    Hologram table for research & development
    Vorbereitung für VR Galerie
    Ich stelle mir einen Hologramm-Tisch so vor:
    Über der Tischfläche schweben 3D-Projektionen – Objekte, Daten, sogar ganze Landschaften. Man kann sie nicht nur sehen, sondern auch (durch Ultraschall) leicht „fühlen“. Die Projektion entsteht durch kleine Laser oder Projektoren im Tisch, und Sensoren erfassen, wie man damit interagiert. Perfekt für Design, Spiele oder Meetings – total futuristisch, aber irgendwie greifbar. Ich liebe die Idee, dass Technik so sinnlich wird – nicht nur anschauen, sondern wirklich erleben.
    This is how I imagine a hologram table:
    3D projections float above the table surface - objects, data, even entire landscapes. You can not only see them, but also “feel” them (through ultrasound). The projection is created by small lasers or projectors in the table, and sensors detect how you interact with it. Perfect for design, games or meetings - totally futuristic, but somehow tangible. I love the idea of making technology so sensual - not just looking at it, but actually experiencing it.
    1920 x 1080 - 93K
    2500 x 1300 - 257K
    1920 x 1080 - 171K
    1920 x 1080 - 203K
    1920 x 1080 - 407K
    edited March 2025
    A spiral staircase was needed, with a radius and wide concrete walls.
    Light strips on the steps with glass elements were needed .... Hexagons and spiral staircases have a life of their own.
    I really thought I knew better ^^ .... Always a little adventure with this software.... But that's what makes it so interesting.
    1659 x 988 - 281K
    edited March 2025
    A modern VR gallery is being created here on 3 levels.
    1741 x 927 - 231K
    1741 x 927 - 255K
    1641 x 869 - 158K
    1735 x 873 - 221K
    edited May 2025
    Captain Future_ Professor Simon Wright
    Overall, the model has been given a contemporary update: some elements have been given a modern interpretation without losing their original character.
    Test_ All diodes can be selected individually, later during the animation they will light up differently as if he were speaking.
    The brain will later pulse in bright blue.
    _________________________ Music
    _________________________ Test_ Unreal Engine
    1652 x 879 - 183K
    1198 x 925 - 160K
    1202 x 921 - 153K
  • Breath-taking!
    You are such an inspiration!
