Star Trek Builders Unite 7: The Continuing Mission
11213151718101
  • mdbruffymdbruffy Posts: 2,345
    Does that just delete a comment or an entire thread?
    At your end, the entire "conversation" ... on the other end it strikes out your name notifying the other party that you are "removed from the conversation" unless they decide to contact you again. If they also delete the conversation, then it would be gone from both accounts but AFAIK but given the number of previously deleted messages that showed up in my inbox I'd say that the system keeps everything somewhere forever.
    So that still doesn't help if you start to post a comment and then change your mind after clicking on the comment box. There's still no way to back out or close the window?
    edited July 2015
    Oh no, this is a different deletion problem we were all having with the PM/Messages/hundreds of them ... in our mailboxes.
    This silly edit box follows one around the forum, even clearing the cache, signing out, clearing the cache, signing in ... nothing, it haunts.
    However when one wants to post somewhere, one can then delete the information and type whatever they want to.
    I have never been a fan of these types of coding boxes.
    edit: Option to delete conversations is now in visible ink :-)
    Post edited by patience55 on
    Update for tonight. Didn't get as much done as I wanted. Had some very strong thunderstorms roll through. When that happens, I shut things down till it's over. But I did get the last of the bulkheads in place.
    1824 x 1952 - 397K
    Okay, in and around all the hard storms, I managed to get the doors and viewports done.
    1733 x 911 - 187K
    1733 x 911 - 162K
    1733 x 911 - 242K
  • wsterdanwsterdan Posts: 3,475
    edited July 2015
    Ptrope said:
    Well, since this is the Javelin, ya might want to hold off on that ...
    Interestingly enough, Boeing may have a patent on the precursor  to the Javelin:
    "Boeing Patents Laser Nuclear Fusion Jet Engine"
    http://spectrum.ieee.org/tech-talk/energy/nuclear/boeing-patents-laser-nuclear-fusion-jet-engine
    -- Walt Sterdan
    Post edited by wsterdan on
    edited July 2015
    Any one know how to move an object's origin from the middle to the side? I knew at one time, but I can't remember. I'm building a cabnet for this crew quarters set and I want the doors on it to swing correctly once they're parented.
    Post edited by mdbruffy on
  • MattymanxMattymanx Posts: 7,000
    edited July 2015
    With the Joint Editor Tool selected, go to the Tool Setting Tab and you can adjust the End & Center points of all the bones
    Post edited by Mattymanx on
    edited July 2015
    In Poser 9 I have a Joint editor window. But I don't have a Tool setting tab. At least I'm not seeing it. I'm probably looking right past it.
    And no fair changing your avatar- I didn't recognise you at first. :-)
  • fixmypcmikefixmypcmike Posts: 19,718
    That would be DAZ Studio rather than Poser
  • Robert FreiseRobert Freise Posts: 4,678
    In Poser turn on show origins that should give you a set of dials and show you the center and end points select the center and drag it to where you want it then save as usual
    I tried that.I had to click on both "Display Origins" and "Animate Origins" before the dials would show and the origins would move. I saved it, reloaded it into the scene and the origin is right back in the middle again.
    I got it figured out.  With the joint editor screen up, I have to click on and move the green and red crosses where I want them and then I can save it to my runtime. But If I export that obj, the origin goes right back to the middle again. I guess, when I release this crew quarters set, I'll have to include some notes on this.
    Here's my shelf unit- with working doors. Thanks to everyone for trying to help.
    620 x 787 - 93K
     Looks very nice! yes
    edited July 2015
    Thank you, Patience.  Here's tonight's update with the shelf unit in place. The food replicator, dining set and view screen are from my runtime. Now, I need to sit down and design the living area and the sleeping area.
    1820 x 1956 - 477K
    Looks good
    Must have been a change in Poser since last time I made something with doors Didn't have to click "Animate Origins"  been a while
    I think you missed a post, Robert:
    "I got it figured out.  With the joint editor screen up, I have to click on and move the green and red crosses where I want them and then I can save it to my runtime. But If I export that obj, the origin goes right back to the middle again. I guess, when I release this crew quarters set, I'll have to include some notes on this."
    Animate Origins isn't needed. That was one of my mistakes.
    Looks good
    Probably missed one the forum has been flakey on notifications sometimes it'll skip a couple before notifying me
    edited July 2015
    Tonight's update: The only thing in these pics that are not mine is the egg chair in the corner and the desk top monitor beside it. This will probably be the first Captain's Cabin in the history of 'Trek that doesn't have a specific work desk. I figure she can use the monitor where it's at, or she can put it on the coffee table or the dinning table. And if she REALLY wants to work, she's got the Ready Room and the Observation Lounge.
    1808 x 1944 - 701K
    Not a problem. we'll get caught up eventually. :-)
    edited July 2015
    The dresser unit for my Crew quarters set. The 4 doors all work- within Poser 9. Anyone want to take a crack at setting them up for other programs?
    869 x 787 - 170K
    1852 x 1876 - 370K
  • scathascatha Posts: 756
    Looks good Mads, wish I could help, but I am a beginner at best at that stuff.
    This is the most complicated piece I've done. I don't know how much will get shown in my story, but I wanted to give it a try.
    I'm still dabbling away though to see if I can get the hang of it.
    smiley
    Hey, it keeps me occupied and sane now that I have been declared disabled after 4 years of fighting the system...
    You'll get there. 5 years ago, when I started Nova Trek- I would never have attenpted somthing like that dresser. Now, my first thought it,"How do I break it down so I can do it?"
    So far it's been three freebies... and the most popular was the first one I released on ShareCG, complete with easy install zip file. Go figure.
